[U-Boot] [PATCH 00/11] OMAP: Move SATA to use block driver model
This series adds support for SATA using the driver model on omap platforms. It is based on the work of Mugunthan V N mugunthanvnm@ti.com in Feb 2016
The first 2 patches are preparatory work. The 3rd patch adds a new framework to handle PHYs in a generic manner. The idea is to move the phy initialization out of the board-specific code into a proper driver. The link between the phy device and the controller device is done in by device-tree as it's done in linux. The API to control a phy has been copied from linux, excpet that the functions are prefixed by 'generic_phy_' instead of just 'phy_' because phy_reset() is already used to handle the Ethernet phys. The 5th patch adds a phy driver for the pipe3 sata phy found in the omaps/am5x/dra7x SOCs. The 6th patch allows the device under the node ocp2scp@4a090000 to be probed. The 7th patch implements a driver for the SATA controller found in the omaps/am5x/dra7x SOCs. The 8th patch is cosmetic and changes the interface of scsi_detect_dev() The 9th patch moves the call to part_init() out of scsi_detect_dev(). This is a preparatory work path #10. The 10th patches fix a divide-by-0 error that happens in scsi_scan() when DM is used and split scsi_scan() in 2 functions for clarity. The last patch enables the DM sata by default for the dra7 platforms.
changes since v2: * Added unit tests for generic PHY uclass. * Changed the generic phy API to use a 'struct udevice*' to reference the phy device. * Don't modify anymore the root Makefile. * Updated the Kconfig with more details on the PHY framework. * Use a Unique Lincense Identifier (SPDX) * Use omap5-u-boot.dtsi to mark the ocp2scp bus as compatible with "simple-bus" * Split scsi_scan() in 2 for clarity. The function was becoming too long.
changes since v1: * changed the way the 'old' sata code is compiled out when DM_SCSI is enabled. * added a new framework for PHY management. * added a new driver for the PIPE3 phy and use it in the dwc_ahci driver. * changed the interface of scsi_detect_dev() and moved the call part_init() out of it. * modified the fix to scsi_scan() in order to call scsi_detect_dev() only once. * the max_lun and max_id parameters are now taken from the device-tree. * Updated the defconfig changes to include the PHY driver and its dependencies.
Jean-Jacques Hiblot (11): arm: omap: sata: move enable sata clocks to enable_basic_clocks() arm: omap: sata: compile out board-level sata code when CONFIG_DM_SCSI is defined drivers: phy: add generic PHY framework dm: test: Add tests for the generic PHY uclass drivers: phy: add PIPE3 phy driver dra7: dtsi: mark ocp2scp bus compatible with "simple-bus" drivers: block: dwc_ahci: Implement a driver for Synopsys DWC sata device scsi: make the LUN a parameter of scsi_detect_dev() scsi: move the partition initialization out of the scsi detection dm: scsi: fix divide-by-0 error in scsi_scan() defconfig: dra7xx_evm: enable CONFIG_BLK and disk driver model for SCSI
arch/arm/dts/omap5-u-boot.dtsi | 4 + arch/arm/mach-omap2/Makefile | 2 + arch/arm/mach-omap2/omap5/hw_data.c | 12 ++ arch/arm/mach-omap2/sata.c | 23 --- arch/sandbox/dts/test.dts | 9 + common/scsi.c | 98 +++++----- configs/dra7xx_evm_defconfig | 12 +- configs/dra7xx_hs_evm_defconfig | 11 +- configs/sandbox_defconfig | 2 + configs/sandbox_noblk_defconfig | 2 + configs/sandbox_spl_defconfig | 3 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/block/Kconfig | 10 + drivers/block/Makefile | 1 + drivers/block/dwc_ahci.c | 100 ++++++++++ drivers/phy/Kconfig | 59 ++++++ drivers/phy/Makefile | 4 + drivers/phy/phy-uclass.c | 64 +++++++ drivers/phy/sandbox-phy.c | 78 ++++++++ drivers/phy/ti-pipe3-phy.c | 365 ++++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/generic-phy.h | 36 ++++ test/dm/Makefile | 1 + test/dm/generic_phy.c | 89 +++++++++ 25 files changed, 922 insertions(+), 67 deletions(-) create mode 100644 drivers/block/dwc_ahci.c create mode 100644 drivers/phy/Kconfig create mode 100644 drivers/phy/Makefile create mode 100644 drivers/phy/phy-uclass.c create mode 100644 drivers/phy/sandbox-phy.c create mode 100644 drivers/phy/ti-pipe3-phy.c create mode 100644 include/generic-phy.h create mode 100644 test/dm/generic_phy.c
All the clocks which has to be enabled has to be done in enable_basic_clocks(), so moving enable sata clock to common clocks enable function.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/mach-omap2/omap5/hw_data.c | 12 ++++++++++++ arch/arm/mach-omap2/sata.c | 23 ----------------------- 2 files changed, 12 insertions(+), 23 deletions(-)
diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index 5d956b5..a8a6b8a 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -361,6 +361,9 @@ void enable_basic_clocks(void) (*prcm)->cm_l4per_gpio6_clkctrl, (*prcm)->cm_l4per_gpio7_clkctrl, (*prcm)->cm_l4per_gpio8_clkctrl, +#ifdef CONFIG_SCSI_AHCI_PLAT + (*prcm)->cm_l3init_ocp2scp3_clkctrl, +#endif 0 };
@@ -379,6 +382,9 @@ void enable_basic_clocks(void) #ifdef CONFIG_TI_QSPI (*prcm)->cm_l4per_qspi_clkctrl, #endif +#ifdef CONFIG_SCSI_AHCI_PLAT + (*prcm)->cm_l3init_sata_clkctrl, +#endif 0 };
@@ -411,6 +417,12 @@ void enable_basic_clocks(void) setbits_le32((*prcm)->cm_l4per_qspi_clkctrl, (1<<24)); #endif
+#ifdef CONFIG_SCSI_AHCI_PLAT + /* Enable optional functional clock for SATA */ + setbits_le32((*prcm)->cm_l3init_sata_clkctrl, + SATA_CLKCTRL_OPTFCLKEN_MASK); +#endif + /* Enable SCRM OPT clocks for PER and CORE dpll */ setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, OPTFCLKEN_SCRM_PER_MASK); diff --git a/arch/arm/mach-omap2/sata.c b/arch/arm/mach-omap2/sata.c index 2c2d1bc..0c82689 100644 --- a/arch/arm/mach-omap2/sata.c +++ b/arch/arm/mach-omap2/sata.c @@ -37,29 +37,6 @@ int init_sata(int dev) int ret; u32 val;
- u32 const clk_domains_sata[] = { - 0 - }; - - u32 const clk_modules_hw_auto_sata[] = { - (*prcm)->cm_l3init_ocp2scp3_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_sata[] = { - (*prcm)->cm_l3init_sata_clkctrl, - 0 - }; - - do_enable_clocks(clk_domains_sata, - clk_modules_hw_auto_sata, - clk_modules_explicit_en_sata, - 0); - - /* Enable optional functional clock for SATA */ - setbits_le32((*prcm)->cm_l3init_sata_clkctrl, - SATA_CLKCTRL_OPTFCLKEN_MASK); - sata_phy.power_reg = (void __iomem *)(*ctrl)->control_phy_power_sata;
/* Power up the PHY */
When CONFIG_DM_SCSI is defined, the SATA initialization will be implemented in the scsi-uclass driver.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/mach-omap2/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-omap2/Makefile b/arch/arm/mach-omap2/Makefile index e814eb0..aa3986d 100644 --- a/arch/arm/mach-omap2/Makefile +++ b/arch/arm/mach-omap2/Makefile @@ -29,9 +29,11 @@ obj-y += abb.o endif
ifneq ($(CONFIG_OMAP54XX),) +ifeq ($(CONFIG_DM_SCSI),) obj-y += pipe3-phy.o obj-$(CONFIG_SCSI_AHCI_PLAT) += sata.o endif +endif
ifeq ($(CONFIG_SYS_DCACHE_OFF),) obj-y += omap-cache.o
The PHY framework provides a set of APIs to control a PHY. This API is derived from the linux version of the generic PHY framework. Currently the API supports init(), deinit(), power_on, power_off() and reset(). The framework provides a way to get a reference to a phy from the device-tree.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- drivers/Kconfig | 2 ++ drivers/Makefile | 1 + drivers/phy/Kconfig | 32 ++++++++++++++++++++++++ drivers/phy/Makefile | 2 ++ drivers/phy/phy-uclass.c | 64 ++++++++++++++++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/generic-phy.h | 36 +++++++++++++++++++++++++++ 7 files changed, 138 insertions(+) create mode 100644 drivers/phy/Kconfig create mode 100644 drivers/phy/Makefile create mode 100644 drivers/phy/phy-uclass.c create mode 100644 include/generic-phy.h
diff --git a/drivers/Kconfig b/drivers/Kconfig index 0e5d97d..a90ceca 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -88,6 +88,8 @@ source "drivers/video/Kconfig"
source "drivers/watchdog/Kconfig"
+source "drivers/phy/Kconfig" + config PHYS_TO_BUS bool "Custom physical to bus address mapping" help diff --git a/drivers/Makefile b/drivers/Makefile index 5d8baa5..0be0624 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -7,6 +7,7 @@ obj-$(CONFIG_$(SPL_)CLK) += clk/ obj-$(CONFIG_$(SPL_)LED) += led/ obj-$(CONFIG_$(SPL_)PINCTRL) += pinctrl/ obj-$(CONFIG_$(SPL_)RAM) += ram/ +obj-$(CONFIG_$(SPL_)GENERIC_PHY) += phy/
ifdef CONFIG_SPL_BUILD
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig new file mode 100644 index 0000000..d66c9e3 --- /dev/null +++ b/drivers/phy/Kconfig @@ -0,0 +1,32 @@ + +menu "PHY Subsystem" + +config GENERIC_PHY + bool "PHY Core" + depends on DM + help + Generic PHY support. + + This framework is designed to provide a generic interface for PHY + devices. PHYs are commonly used for high speed interfaces such as + SATA or PCIe. + The API provides functions to initialize/deinitialize the + phy, power on/off the phy, and reset the phy. It's meant to be as + compatible as possible with the equivalent framework found in the + linux kernel. + +config SPL_GENERIC_PHY + bool "PHY Core in SPL" + depends on DM + help + Generic PHY support in SPL. + + This framework is designed to provide a generic interface for PHY + devices. PHYs are commonly used for high speed interfaces such as + SATA or PCIe. + The API provides functions to initialize/deinitialize the + phy, power on/off the phy, and reset the phy. It's meant to be as + compatible as possible with the equivalent framework found in the + linux kernel. + +endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile new file mode 100644 index 0000000..b29a8b9 --- /dev/null +++ b/drivers/phy/Makefile @@ -0,0 +1,2 @@ +obj-$(CONFIG_$(SPL_)GENERIC_PHY) += phy-uclass.o + diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c new file mode 100644 index 0000000..e15ed43 --- /dev/null +++ b/drivers/phy/phy-uclass.c @@ -0,0 +1,64 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * Written by Jean-Jacques Hiblot jjhiblot@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <generic-phy.h> + +struct udevice *dm_generic_phy_get(struct udevice *parent, const char *string) +{ + struct udevice *dev; + + int rc = uclass_get_device_by_phandle(UCLASS_PHY, parent, + string, &dev); + if (rc) { + debug("unable to find generic_phy device (err: %d)\n", rc); + return ERR_PTR(rc); + } + + return dev; +} + +int generic_phy_init(struct udevice *dev) +{ + struct generic_phy_ops const *ops = dev->driver->ops; + + return (ops && ops->init) ? ops->init(dev) : 0; +} + +int generic_phy_reset(struct udevice *dev) +{ + struct generic_phy_ops const *ops = dev->driver->ops; + + return (ops && ops->reset) ? ops->reset(dev) : 0; +} + +int generic_phy_exit(struct udevice *dev) +{ + struct generic_phy_ops const *ops = dev->driver->ops; + + return (ops && ops->exit) ? ops->exit(dev) : 0; +} + +int generic_phy_power_on(struct udevice *dev) +{ + struct generic_phy_ops const *ops = dev->driver->ops; + + return (ops && ops->power_on) ? ops->power_on(dev) : 0; +} + +int generic_phy_power_off(struct udevice *dev) +{ + struct generic_phy_ops const *ops = dev->driver->ops; + + return (ops && ops->power_off) ? ops->power_off(dev) : 0; +} + +UCLASS_DRIVER(generic_phy) = { + .id = UCLASS_PHY, + .name = "generic_phy", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 8c92d0b..9d34a32 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -83,6 +83,7 @@ enum uclass_id { UCLASS_VIDEO, /* Video or LCD device */ UCLASS_VIDEO_BRIDGE, /* Video bridge, e.g. DisplayPort to LVDS */ UCLASS_VIDEO_CONSOLE, /* Text console driver for video device */ + UCLASS_PHY, /* generic PHY device */
UCLASS_COUNT, UCLASS_INVALID = -1, diff --git a/include/generic-phy.h b/include/generic-phy.h new file mode 100644 index 0000000..24475f0 --- /dev/null +++ b/include/generic-phy.h @@ -0,0 +1,36 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * Written by Jean-Jacques Hiblot jjhiblot@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __GENERIC_PHY_H +#define __GENERIC_PHY_H + +/* + * struct udevice_ops - set of function pointers for phy operations + * @init: operation to be performed for initializing phy (optionnal) + * @exit: operation to be performed while exiting (optionnal) + * @reset: reset the phy (optionnal). + * @power_on: powering on the phy (optionnal) + * @power_off: powering off the phy (optionnal) + */ +struct generic_phy_ops { + int (*init)(struct udevice *phy); + int (*exit)(struct udevice *phy); + int (*reset)(struct udevice *phy); + int (*power_on)(struct udevice *phy); + int (*power_off)(struct udevice *phy); +}; + + +int generic_phy_init(struct udevice *phy); +int generic_phy_reset(struct udevice *phy); +int generic_phy_exit(struct udevice *phy); +int generic_phy_power_on(struct udevice *phy); +int generic_phy_power_off(struct udevice *phy); + +struct udevice *dm_generic_phy_get(struct udevice *parent, const char *string); + +#endif /*__GENERIC_PHY_H */
Hi Jean-Jacques,
I mostly have minor things at this point. Note that I've applied the patches from your series that I can, so please rebase on master.
Also can you please: - check your version number (I think you might be up to v3 now) - include a change log with each patch (patman might help you) - rebase on u-boot-dm/master
I'm sorry if this comes across as a bit pedantic. But you are creating a new uclass which I think will be quite important in U-Boot. I suspect it will be used by USB, perhaps Ethernet and other systems, so careful design and documentation is pretty important.
Please maintain the ordering here
+config GENERIC_PHY
bool "PHY Core"
depends on DM
help
PHY means?
SATA or PCIe.
Please write out SATA and PCIe in full at least once. This is help so we should not assume much.
Is it PHY or phy?
linux kernel.
depends on DM
help
SATA or PCIe.
linux kernel.
- Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/
- Written by Jean-Jacques Hiblot jjhiblot@ti.com
Can you make this return an error code instead, and the device pointer as a parameter? This is how it is generally down in DM. See uclass_first_device() for example.
Also I think you should drop the dm_ in the name. That prefix is used for core driver model functions, and DM versions of function that have a non-DM analogue.
Also I think 'get' is too short. We normally use that for getting by index. How about generic_phy_get_by_name() or, phy_get_by_name() if you rename it?
string, &dev);
if (rc) {
return ERR_PTR(rc);
return dev;
Please use a header-file macro to access ops. See clk-uclass.c for an example.
You don't need to check ops since it is invalid not to have one. So:
return ops->init ? ops->init(dev) : 0;
.id = UCLASS_PHY,
I would like the uclass name to match the header file and the uclass name. So if you are calling this generic_phy, then the uclass should be named this too. Same with the directory drivers/phy. If you want to rename it all to 'phy' then that is fine too.
Physical layer device? Can you make your comment a bit more useful?
- struct udevice_ops - set of function pointers for phy operations
- @init: operation to be performed for initializing phy (optionnal)
optional
Can you please put these comments in front of each function in struct generic_phy_ops as is done with other uclasses? Your description should explain what the operation does. For example, what happens for init()? Since the phy has already been probed, what should you not do in probe() but do in init()?
- @exit: operation to be performed while exiting (optionnal)
exiting what? Please add some more detail.
- @reset: reset the phy (optionnal).
- @power_on: powering on the phy (optionnal)
- @power_off: powering off the phy (optionnal)
Are these optional because the phy might be powered on during one of the other operations? Otherwise it doesn't seem helpful to have the thing not ever power on.
Here you need to repeat your comments from above - see other uclasses for an example.
This function need a comment. Also instead of string can you think of a descriptive name, e.g. phy_name?
1.9.1
On 15/04/2017 19:10, Simon Glass wrote:
Hi Jean-Jacques,
- config PHYS_TO_BUS bool "Custom physical to bus address mapping" help
+config GENERIC_PHY
bool "PHY Core"
depends on DM
help
PHY means?
SATA or PCIe.
Is it PHY or phy?
linux kernel.
depends on DM
help
SATA or PCIe.
linux kernel.
string, &dev);
if (rc) {
return ERR_PTR(rc);
return dev;
.id = UCLASS_PHY,
IMO 'phy' would be the best option. Unfortunately there are already tons of functions starting with 'phy_' and they're used for the ethernet phy. So I would propose to use 'phy' everywhere except for the API where 'generic_phy_' can be used to prefix the functions. What do you think ?
optional
I'll work on documenting this. Too bad that linux also lacks this documentation. The core idea is that probe() does not do much hardware-wise, it sets up everyting (irqs, mapping, clocks) but the actual initialization of the hardware is done in init().
Jean-Jacques
1.9.1
Hi
.id = UCLASS_PHY,
Sounds good. That would be easy to clean up later once Ethernet Phy is done.
optional
OK sounds good.
Those tests check: - the ability for a phy-user to get a phy device a reference in the device-tree - the ability to perform operations on the phy (init,deinit,on,off) - the behavior of the uclass when optional operations are not implemented
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- arch/sandbox/dts/test.dts | 9 +++++ configs/sandbox_defconfig | 2 + configs/sandbox_noblk_defconfig | 2 + configs/sandbox_spl_defconfig | 3 ++ drivers/phy/Kconfig | 9 +++++ drivers/phy/Makefile | 1 + drivers/phy/sandbox-phy.c | 78 ++++++++++++++++++++++++++++++++++++ test/dm/Makefile | 1 + test/dm/generic_phy.c | 89 +++++++++++++++++++++++++++++++++++++++++ 9 files changed, 194 insertions(+) create mode 100644 drivers/phy/sandbox-phy.c create mode 100644 test/dm/generic_phy.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index fff175d..918c899 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -59,6 +59,15 @@ ping-add = <3>; };
+ gen_phy: gen_phy { + compatible = "sandbox,phy"; + }; + + gen_phy_user: gen_phy_user { + compatible = "simple-bus"; + phy = <&gen_phy>; + }; + some-bus { #address-cells = <1>; #size-cells = <0>; diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 7f3f5ac..42116cf 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -164,6 +164,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_GENERIC_PHY=y +CONFIG_PHY_SANDBOX=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y CONFIG_LZ4=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 3f8e70d..7a5cd4b 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -166,6 +166,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_GENERIC_PHY=y +CONFIG_PHY_SANDBOX=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y CONFIG_LZ4=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index ade6714..9b4cf39 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -170,6 +170,9 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_GENERIC_PHY=y +CONFIG_SPL_GENERIC_PHY=y +CONFIG_PHY_SANDBOX=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y CONFIG_LZ4=y diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index d66c9e3..032b932 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -29,4 +29,13 @@ config SPL_GENERIC_PHY compatible as possible with the equivalent framework found in the linux kernel.
+config PHY_SANDBOX + bool "Sandbox PHY support" + depends on SANDBOX + depends on GENERIC_PHY + help + This select a dummy sandbox PHY driver. It used only to implement + unit tests for the generic phy framework + + endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index b29a8b9..0125844 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -1,2 +1,3 @@ obj-$(CONFIG_$(SPL_)GENERIC_PHY) += phy-uclass.o +obj-$(CONFIG_PHY_SANDBOX) += sandbox-phy.o
diff --git a/drivers/phy/sandbox-phy.c b/drivers/phy/sandbox-phy.c new file mode 100644 index 0000000..1c60308 --- /dev/null +++ b/drivers/phy/sandbox-phy.c @@ -0,0 +1,78 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * Written by Jean-Jacques Hiblot jjhiblot@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <generic-phy.h> + +struct sandbox_phy_priv { + int initialized; + int on; +}; + +static int sandbox_phy_power_on(struct udevice *dev) +{ + struct sandbox_phy_priv *priv = dev_get_priv(dev); + if (!priv->initialized) + return -EIO; + priv->on = 1; + return 0; +} + +static int sandbox_phy_power_off(struct udevice *dev) +{ + struct sandbox_phy_priv *priv = dev_get_priv(dev); + if (!priv->initialized) + return -EIO; + priv->on = 0; + return 0; +} + +static int sandbox_phy_init(struct udevice *dev) +{ + struct sandbox_phy_priv *priv = dev_get_priv(dev); + priv->initialized = 1; + priv->on = 0; + return 0; +} + +static int sandbox_phy_exit(struct udevice *dev) +{ + struct sandbox_phy_priv *priv = dev_get_priv(dev); + priv->initialized = 0; + priv->on = 0; + return 0; +} + +static int sandbox_phy_probe(struct udevice *dev) +{ + struct sandbox_phy_priv *priv = dev_get_priv(dev); + priv->initialized = 0; + priv->on = 0; + return 0; +} + +static struct generic_phy_ops sandbox_phy_ops = { + .power_on = sandbox_phy_power_on, + .power_off = sandbox_phy_power_off, + .init = sandbox_phy_init, + .exit = sandbox_phy_exit, +}; + +static const struct udevice_id sandbox_phy_ids[] = { + { .compatible = "sandbox,phy" }, + { } +}; + +U_BOOT_DRIVER(phy_sandbox) = { + .name = "phy_sandbox", + .id = UCLASS_PHY, + .of_match = sandbox_phy_ids, + .ops = &sandbox_phy_ops, + .probe = sandbox_phy_probe, + .priv_auto_alloc_size = sizeof(struct sandbox_phy_priv), +}; diff --git a/test/dm/Makefile b/test/dm/Makefile index 1885e17..e2b7d43 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -41,4 +41,5 @@ obj-$(CONFIG_TIMER) += timer.o obj-$(CONFIG_DM_VIDEO) += video.o obj-$(CONFIG_ADC) += adc.o obj-$(CONFIG_SPMI) += spmi.o +obj-$(CONFIG_GENERIC_PHY) += generic_phy.o endif diff --git a/test/dm/generic_phy.c b/test/dm/generic_phy.c new file mode 100644 index 0000000..08b862a --- /dev/null +++ b/test/dm/generic_phy.c @@ -0,0 +1,89 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * Written by Jean-Jacques Hiblot jjhiblot@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <test/ut.h> +#include <generic-phy.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Base test of the phy uclass */ +static int dm_test_phy_base(struct unit_test_state *uts) +{ + struct udevice *dev_method1; + struct udevice *dev_method2; + struct udevice *parent; + + + /* Get the device using the phy device*/ + ut_assertok(uclass_get_device_by_name(UCLASS_SIMPLE_BUS, + "gen_phy_user", &parent)); + /* Get the phy device with std uclass function */ + ut_assertok(uclass_get_device_by_name(UCLASS_PHY, "gen_phy", + &dev_method1)); + + /* + * Get the phy device from user device and compare with the one + * obtained with the previous method. + */ + dev_method2 = dm_generic_phy_get(parent, "phy"); + ut_assertnonnull(dev_method2); + ut_assertok_ptr(dev_method2); + ut_asserteq_ptr(dev_method1, dev_method2); + + /* Try to get a non-existing phy */ + ut_asserteq(-ENODEV, uclass_get_device(UCLASS_PHY, 1, &dev_method2)); + dev_method2 = dm_generic_phy_get(parent, "phy_not_existing"); + ut_assert(IS_ERR_OR_NULL(dev_method2)); + + return 0; +} +DM_TEST(dm_test_phy_base, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test of the phy uclass using the sandbox phy driver operations */ +static int dm_test_phy_ops(struct unit_test_state *uts) +{ + struct udevice *dev; + struct udevice *parent; + + ut_assertok(uclass_get_device_by_name(UCLASS_SIMPLE_BUS, + "gen_phy_user", &parent)); + dev = dm_generic_phy_get(parent, "phy"); + ut_assertnonnull(dev); + ut_assertok_ptr(dev); + + /* test normal operations */ + ut_assertok(generic_phy_init(dev)); + ut_assertok(generic_phy_power_on(dev)); + ut_assertok(generic_phy_power_off(dev)); + + /* + * test operations after exit(). + * The sandbox phy driver does not allow it. + */ + ut_assertok(generic_phy_exit(dev)); + ut_assert(generic_phy_power_on(dev) != 0); + ut_assert(generic_phy_power_off(dev) != 0); + + /* + * test normal operations again (after re-init) + */ + ut_assertok(generic_phy_init(dev)); + ut_assertok(generic_phy_power_on(dev)); + ut_assertok(generic_phy_power_off(dev)); + + /* + * test calling unimplemented feature. + * The call is expected to succeed + */ + ut_assertok(generic_phy_reset(dev)); + + return 0; +} +DM_TEST(dm_test_phy_ops, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Hi Jean-Jacques,
Those tests check:
This looks really good, just some nits.
gen_phy: gen_phy {
phy = <&gen_phy>;
+config PHY_SANDBOX
depends on SANDBOX
help
int initialized;
int on;
bool?
blank line between decls and rest of code
return -EIO;
priv->on = 1;
blank line before return true/false better than 0/1 I think
return -EIO;
priv->on = 0;
priv->on = 0;
priv->on = 0;
priv->on = 0;
.id = UCLASS_PHY,
check ordering
This should go below dm.h
drop extra blank ilne
&dev_method1));
This should be able to use ut_assertok() once the function returns an error code.
1.9.1
Great test, thanks.
This phy is found on omap platforms with sata capabilities. Except for the part related to the DM and the PHY framework, the code is basically a copy paste from arch/arm/mach-omap2/pipe3-phy.c
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/phy/Kconfig | 18 +++ drivers/phy/Makefile | 1 + drivers/phy/ti-pipe3-phy.c | 365 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 384 insertions(+) create mode 100644 drivers/phy/ti-pipe3-phy.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 032b932..b9a8093 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -38,4 +38,22 @@ config PHY_SANDBOX unit tests for the generic phy framework
+config PIPE3_PHY + bool "Support omap's PIPE3 PHY" + depends on GENERIC_PHY && ARCH_OMAP2 + help + Support for the omap PIPE3 phy for sata + + This PHY is found on omap devices supporting SATA such as dra7, am57x + and omap5 + +config SPL_PIPE3_PHY + bool "Support omap's PIPE3 PHY in SPL" + depends on SPL_GENERIC_PHY && ARCH_OMAP2 + help + Support for the omap PIPE3 phy for sata in SPL + + This PHY is found on omap devices supporting SATA such as dra7, am57x + and omap5 + endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 0125844..701f7c8 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -1,3 +1,4 @@ obj-$(CONFIG_$(SPL_)GENERIC_PHY) += phy-uclass.o obj-$(CONFIG_PHY_SANDBOX) += sandbox-phy.o +obj-$(CONFIG_$(SPL_)PIPE3_PHY) += ti-pipe3-phy.o
diff --git a/drivers/phy/ti-pipe3-phy.c b/drivers/phy/ti-pipe3-phy.c new file mode 100644 index 0000000..3964823 --- /dev/null +++ b/drivers/phy/ti-pipe3-phy.c @@ -0,0 +1,365 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * Written by Jean-Jacques Hiblot jjhiblot@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <dm/device.h> +#include <generic-phy.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <syscon.h> +#include <regmap.h> + +/* PLLCTRL Registers */ +#define PLL_STATUS 0x00000004 +#define PLL_GO 0x00000008 +#define PLL_CONFIGURATION1 0x0000000C +#define PLL_CONFIGURATION2 0x00000010 +#define PLL_CONFIGURATION3 0x00000014 +#define PLL_CONFIGURATION4 0x00000020 + +#define PLL_REGM_MASK 0x001FFE00 +#define PLL_REGM_SHIFT 9 +#define PLL_REGM_F_MASK 0x0003FFFF +#define PLL_REGM_F_SHIFT 0 +#define PLL_REGN_MASK 0x000001FE +#define PLL_REGN_SHIFT 1 +#define PLL_SELFREQDCO_MASK 0x0000000E +#define PLL_SELFREQDCO_SHIFT 1 +#define PLL_SD_MASK 0x0003FC00 +#define PLL_SD_SHIFT 10 +#define SET_PLL_GO 0x1 +#define PLL_TICOPWDN BIT(16) +#define PLL_LDOPWDN BIT(15) +#define PLL_LOCK 0x2 +#define PLL_IDLE 0x1 + +/* Software rest for the SATA PLL (in CTRL_CORE_SMA_SW_0 register)*/ +#define SATA_PLL_SOFT_RESET (1<<18) + +/* PHY POWER CONTROL Register */ +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK 0x003FC000 +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT 0xE + +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_MASK 0xFFC00000 +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_SHIFT 0x16 + +#define OMAP_CTRL_PIPE3_PHY_TX_RX_POWERON 0x3 +#define OMAP_CTRL_PIPE3_PHY_TX_RX_POWEROFF 0x0 + + +#define PLL_IDLE_TIME 100 /* in milliseconds */ +#define PLL_LOCK_TIME 100 /* in milliseconds */ + +struct omap_pipe3 { + void __iomem *pll_ctrl_base; + void __iomem *power_reg; + void __iomem *pll_reset_reg; + struct pipe3_dpll_map *dpll_map; +}; + + +struct pipe3_dpll_params { + u16 m; + u8 n; + u8 freq:3; + u8 sd; + u32 mf; +}; + +struct pipe3_dpll_map { + unsigned long rate; + struct pipe3_dpll_params params; +}; + +static inline u32 omap_pipe3_readl(void __iomem *addr, unsigned offset) +{ + return readl(addr + offset); +} + +static inline void omap_pipe3_writel(void __iomem *addr, unsigned offset, + u32 data) +{ + writel(data, addr + offset); +} + +static struct pipe3_dpll_params *omap_pipe3_get_dpll_params(struct omap_pipe3 + *pipe3) +{ + u32 rate; + struct pipe3_dpll_map *dpll_map = pipe3->dpll_map; + + rate = get_sys_clk_freq(); + + for (; dpll_map->rate; dpll_map++) { + if (rate == dpll_map->rate) + return &dpll_map->params; + } + + printf("%s: No DPLL configuration for %u Hz SYS CLK\n", + __func__, rate); + return NULL; +} + +static int omap_pipe3_wait_lock(struct omap_pipe3 *pipe3) +{ + u32 val; + int timeout = PLL_LOCK_TIME; + + do { + mdelay(1); + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_STATUS); + if (val & PLL_LOCK) + break; + } while (--timeout); + + if (!(val & PLL_LOCK)) { + printf("%s: DPLL failed to lock\n", __func__); + return -EBUSY; + } + + return 0; +} + +static int omap_pipe3_dpll_program(struct omap_pipe3 *pipe3) +{ + u32 val; + struct pipe3_dpll_params *dpll_params; + + dpll_params = omap_pipe3_get_dpll_params(pipe3); + if (!dpll_params) { + printf("%s: Invalid DPLL parameters\n", __func__); + return -EINVAL; + } + + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_CONFIGURATION1); + val &= ~PLL_REGN_MASK; + val |= dpll_params->n << PLL_REGN_SHIFT; + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_CONFIGURATION1, val); + + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_CONFIGURATION2); + val &= ~PLL_SELFREQDCO_MASK; + val |= dpll_params->freq << PLL_SELFREQDCO_SHIFT; + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_CONFIGURATION2, val); + + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_CONFIGURATION1); + val &= ~PLL_REGM_MASK; + val |= dpll_params->m << PLL_REGM_SHIFT; + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_CONFIGURATION1, val); + + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_CONFIGURATION4); + val &= ~PLL_REGM_F_MASK; + val |= dpll_params->mf << PLL_REGM_F_SHIFT; + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_CONFIGURATION4, val); + + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_CONFIGURATION3); + val &= ~PLL_SD_MASK; + val |= dpll_params->sd << PLL_SD_SHIFT; + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_CONFIGURATION3, val); + + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_GO, SET_PLL_GO); + + return omap_pipe3_wait_lock(pipe3); +} + +static void omap_control_pipe3_power(struct omap_pipe3 *pipe3, int on) +{ + u32 val, rate; + + val = readl(pipe3->power_reg); + + rate = get_sys_clk_freq(); + rate = rate/1000000; + + if (on) { + val &= ~(OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK | + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_MASK); + val |= OMAP_CTRL_PIPE3_PHY_TX_RX_POWERON << + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT; + val |= rate << + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_SHIFT; + } else { + val &= ~OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK; + val |= OMAP_CTRL_PIPE3_PHY_TX_RX_POWEROFF << + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT; + } + + writel(val, pipe3->power_reg); +} + +static int pipe3_power_on(struct udevice *dev) +{ + int ret; + u32 val; + struct omap_pipe3 *pipe3 = dev_get_priv(dev); + + /* Program the DPLL only if not locked */ + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_STATUS); + if (!(val & PLL_LOCK)) { + ret = omap_pipe3_dpll_program(pipe3); + if (ret) + return ret; + } else { + /* else just bring it out of IDLE mode */ + val = omap_pipe3_readl(pipe3->pll_ctrl_base, + PLL_CONFIGURATION2); + if (val & PLL_IDLE) { + val &= ~PLL_IDLE; + omap_pipe3_writel(pipe3->pll_ctrl_base, + PLL_CONFIGURATION2, val); + ret = omap_pipe3_wait_lock(pipe3); + if (ret) + return ret; + } + } + + /* Power up the PHY */ + omap_control_pipe3_power(pipe3, 1); + + return 0; +} + +static int pipe3_power_off(struct udevice *dev) +{ + u32 val; + int timeout = PLL_IDLE_TIME; + struct omap_pipe3 *pipe3 = dev_get_priv(dev); + + /* Power down the PHY */ + omap_control_pipe3_power(pipe3, 0); + + /* Put DPLL in IDLE mode */ + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_CONFIGURATION2); + val |= PLL_IDLE; + omap_pipe3_writel(pipe3->pll_ctrl_base, PLL_CONFIGURATION2, val); + + /* wait for LDO and Oscillator to power down */ + do { + mdelay(1); + val = omap_pipe3_readl(pipe3->pll_ctrl_base, PLL_STATUS); + if ((val & PLL_TICOPWDN) && (val & PLL_LDOPWDN)) + break; + } while (--timeout); + + if (!(val & PLL_TICOPWDN) || !(val & PLL_LDOPWDN)) { + printf("%s: Failed to power down DPLL: PLL_STATUS 0x%x\n", + __func__, val); + return -EBUSY; + } + + return 0; +} + +static int pipe3_reset(struct udevice *dev) +{ + u32 val; + struct omap_pipe3 *pipe3 = dev_get_priv(dev); + + val = readl(pipe3->pll_reset_reg); + writel(val | SATA_PLL_SOFT_RESET, pipe3->pll_reset_reg); + mdelay(1); + writel(val & ~SATA_PLL_SOFT_RESET, pipe3->pll_reset_reg); + return 0; +} + +static void *get_reg(struct udevice *dev, const char *name) +{ + struct udevice *syscon; + struct regmap *regmap; + const fdt32_t *cell; + int len, err; + void *base; + + err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, + name, &syscon); + if (err) { + error("unable to find syscon device for %s (%d)\n", + name, err); + return NULL; + } + + regmap = syscon_get_regmap(syscon); + if (IS_ERR(regmap)) { + error("unable to find regmap for %s (%ld)\n", + name, PTR_ERR(regmap)); + return NULL; + } + + cell = fdt_getprop(gd->fdt_blob, dev->of_offset, name, + &len); + if (len < 2*sizeof(fdt32_t)) { + error("offset not available for %s\n", name); + return NULL; + } + + base = regmap_get_range(regmap, 0); + if (!base) + return NULL; + + return fdtdec_get_number(cell + 1, 1) + base; +} + +static int pipe3_phy_probe(struct udevice *dev) +{ + fdt_addr_t addr; + fdt_size_t sz; + struct omap_pipe3 *pipe3 = dev_get_priv(dev); + + addr = dev_get_addr_size_index(dev, 2, &sz); + if (addr == FDT_ADDR_T_NONE) { + error("missing pll ctrl address\n"); + return -EINVAL; + } + + pipe3->pll_ctrl_base = map_physmem(addr, sz, MAP_NOCACHE); + if (!pipe3->pll_ctrl_base) { + error("unable to remap pll ctrl\n"); + return -EINVAL; + } + + pipe3->power_reg = get_reg(dev, "syscon-phy-power"); + if (!pipe3->power_reg) + return -EINVAL; + + pipe3->pll_reset_reg = get_reg(dev, "syscon-pllreset"); + if (!pipe3->pll_reset_reg) + return -EINVAL; + + pipe3->dpll_map = (struct pipe3_dpll_map *)dev_get_driver_data(dev); + + return 0; +} + +static struct pipe3_dpll_map dpll_map_sata[] = { + {12000000, {1000, 7, 4, 6, 0} }, /* 12 MHz */ + {16800000, {714, 7, 4, 6, 0} }, /* 16.8 MHz */ + {19200000, {625, 7, 4, 6, 0} }, /* 19.2 MHz */ + {20000000, {600, 7, 4, 6, 0} }, /* 20 MHz */ + {26000000, {461, 7, 4, 6, 0} }, /* 26 MHz */ + {38400000, {312, 7, 4, 6, 0} }, /* 38.4 MHz */ + { }, /* Terminator */ +}; + +static const struct udevice_id pipe3_phy_ids[] = { + { .compatible = "ti,phy-pipe3-sata", .data = (ulong)&dpll_map_sata }, + { } +}; + +static struct generic_phy_ops pipe3_phy_ops = { + .power_on = pipe3_power_on, + .power_off = pipe3_power_off, + .reset = pipe3_reset +}; + +U_BOOT_DRIVER(pipe3_phy) = { + .name = "pipe3_phy", + .id = UCLASS_PHY, + .of_match = pipe3_phy_ids, + .ops = &pipe3_phy_ops, + .probe = pipe3_phy_probe, + .priv_auto_alloc_size = sizeof(struct omap_pipe3), +};
This is needed to probe devices under that bus such as the SATA PHY.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- arch/arm/dts/omap5-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi index 6305f57..9247314 100644 --- a/arch/arm/dts/omap5-u-boot.dtsi +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -10,6 +10,10 @@ /{ ocp { u-boot,dm-pre-reloc; + + ocp2scp@4a090000 { + compatible = "ti,omap-ocp2scp", "simple-bus"; + }; }; };
Implement a sata driver for Synopsys DWC sata device based on U-boot driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/block/Kconfig | 10 +++++ drivers/block/Makefile | 1 + drivers/block/dwc_ahci.c | 100 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 111 insertions(+) create mode 100644 drivers/block/dwc_ahci.c
diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index 88e66e2..b3d35bd 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -48,4 +48,14 @@ config SATA_CEVA ZynqMP. Support up to 2 external devices. Complient with SATA 3.1 and AHCI 1.3 specifications with hot-plug detect feature.
+ +config DWC_AHCI + bool "Enable Synopsys DWC AHCI driver support" + select SCSI_AHCI + select GENERIC_PHY + depends on DM_SCSI + help + Enable this driver to support Sata devices through + Synopsys DWC AHCI module. + endmenu diff --git a/drivers/block/Makefile b/drivers/block/Makefile index a72feec..cffe498 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -11,6 +11,7 @@ ifndef CONFIG_BLK obj-y += blk_legacy.o endif
+obj-$(CONFIG_DWC_AHCI) += dwc_ahci.o obj-$(CONFIG_AHCI) += ahci-uclass.o obj-$(CONFIG_DM_SCSI) += scsi-uclass.o obj-$(CONFIG_SCSI_AHCI) += ahci.o diff --git a/drivers/block/dwc_ahci.c b/drivers/block/dwc_ahci.c new file mode 100644 index 0000000..ca32841 --- /dev/null +++ b/drivers/block/dwc_ahci.c @@ -0,0 +1,100 @@ +/* + * DWC SATA platform driver + * + * (C) Copyright 2016 + * Texas Instruments Incorporated, <www.ti.com> + * + * Author: Mugunthan V N mugunthanvnm@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <ahci.h> +#include <scsi.h> +#include <sata.h> +#include <asm/arch/sata.h> +#include <asm/io.h> +#include <generic-phy.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct dwc_ahci_priv { + void *base; + void *wrapper_base; +}; + +static int dwc_ahci_ofdata_to_platdata(struct udevice *dev) +{ + struct dwc_ahci_priv *priv = dev_get_priv(dev); + struct scsi_platdata *plat = dev_get_platdata(dev); + fdt_addr_t addr; + + plat->max_id = fdtdec_get_uint(gd->fdt_blob, dev->of_offset, "max-id", + CONFIG_SYS_SCSI_MAX_SCSI_ID); + plat->max_lun = fdtdec_get_uint(gd->fdt_blob, dev->of_offset, + "max-lun", CONFIG_SYS_SCSI_MAX_LUN); + + priv->base = map_physmem(dev_get_addr(dev), sizeof(void *), + MAP_NOCACHE); + + addr = dev_get_addr_index(dev, 1); + if (addr != FDT_ADDR_T_NONE) { + priv->wrapper_base = map_physmem(addr, sizeof(void *), + MAP_NOCACHE); + } else { + priv->wrapper_base = NULL; + } + + return 0; +} + +static int dwc_ahci_probe(struct udevice *dev) +{ + struct dwc_ahci_priv *priv = dev_get_priv(dev); + int ret; + struct udevice *phy = dm_generic_phy_get(dev, "phys"); + + if (IS_ERR(phy)) { + error("can't get the phy from DT\n"); + return PTR_ERR(phy); + } + + ret = generic_phy_init(phy); + if (ret) { + error("unable to initialize the sata phy\n"); + return ret; + } + + ret = generic_phy_power_on(phy); + if (ret) { + error("unable to power on the sata phy\n"); + return ret; + } + + if (priv->wrapper_base) { + u32 val = TI_SATA_IDLE_NO | TI_SATA_STANDBY_NO; + + /* Enable SATA module, No Idle, No Standby */ + writel(val, priv->wrapper_base + TI_SATA_SYSCONFIG); + } + + return ahci_init(priv->base); +} + +static const struct udevice_id dwc_ahci_ids[] = { + { .compatible = "snps,dwc-ahci" }, + { } +}; + +U_BOOT_DRIVER(dwc_ahci) = { + .name = "dwc_ahci", + .id = UCLASS_SCSI, + .of_match = dwc_ahci_ids, + .ofdata_to_platdata = dwc_ahci_ofdata_to_platdata, + .probe = dwc_ahci_probe, + .priv_auto_alloc_size = sizeof(struct dwc_ahci_priv), + .platdata_auto_alloc_size = sizeof(struct scsi_platdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
This is a cosmetic change. target and LUN have kind of the same role in this function. One of them was passed as a parameter and the other was embedded in a structure. For consistency, pass both of them as parameters.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- common/scsi.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/common/scsi.c b/common/scsi.c index fb5b407..d55ba89 100644 --- a/common/scsi.c +++ b/common/scsi.c @@ -473,14 +473,15 @@ static void scsi_init_dev_desc(struct blk_desc *dev_desc, int devnum) * scsi_detect_dev - Detect scsi device * * @target: target id + * @lun: target lun * @dev_desc: block device description * * The scsi_detect_dev detects and fills a dev_desc structure when the device is - * detected. The LUN number is taken from the struct blk_desc *dev_desc. + * detected. * * Return: 0 on success, error value otherwise */ -static int scsi_detect_dev(int target, struct blk_desc *dev_desc) +static int scsi_detect_dev(int target, int lun, struct blk_desc *dev_desc) { unsigned char perq, modi; lbaint_t capacity; @@ -488,7 +489,7 @@ static int scsi_detect_dev(int target, struct blk_desc *dev_desc) ccb *pccb = (ccb *)&tempccb;
pccb->target = target; - pccb->lun = dev_desc->lun; + pccb->lun = lun; pccb->pdata = (unsigned char *)&tempbuff; pccb->datalen = 512; scsi_setup_inquiry(pccb); @@ -599,8 +600,7 @@ int scsi_scan(int mode) bdesc = dev_get_uclass_platdata(bdev);
scsi_init_dev_desc_priv(bdesc); - bdesc->lun = lun; - ret = scsi_detect_dev(i, bdesc); + ret = scsi_detect_dev(i, lun, bdesc); if (ret) { device_unbind(bdev); continue; @@ -630,8 +630,8 @@ int scsi_scan(int mode) scsi_max_devs = 0; for (i = 0; i < CONFIG_SYS_SCSI_MAX_SCSI_ID; i++) { for (lun = 0; lun < CONFIG_SYS_SCSI_MAX_LUN; lun++) { - scsi_dev_desc[scsi_max_devs].lun = lun; - ret = scsi_detect_dev(i, &scsi_dev_desc[scsi_max_devs]); + ret = scsi_detect_dev(i, lun, + &scsi_dev_desc[scsi_max_devs]); if (ret) continue;
We might want to get information about the scsi device without initializing the partition.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- common/scsi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/scsi.c b/common/scsi.c index d55ba89..972ef338 100644 --- a/common/scsi.c +++ b/common/scsi.c @@ -540,7 +540,6 @@ static int scsi_detect_dev(int target, int lun, struct blk_desc *dev_desc) dev_desc->blksz = blksz; dev_desc->log2blksz = LOG2(dev_desc->blksz); dev_desc->type = perq; - part_init(&dev_desc[0]); removable: return 0; } @@ -605,6 +604,7 @@ int scsi_scan(int mode) device_unbind(bdev); continue; } + part_init(bdesc);
if (mode == 1) { printf(" Device %d: ", 0); @@ -634,6 +634,7 @@ int scsi_scan(int mode) &scsi_dev_desc[scsi_max_devs]); if (ret) continue; + part_init(&scsi_dev_desc[scsi_max_devs]);
With DM_SCSI enabled, blk_create_devicef() is called with blkz = 0, leading to a divide-by-0 exception. scsi_detect_dev() can be used to get the required parameters (block size and number of blocks) from the drive before calling blk_create_devicef().
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- common/scsi.c | 85 ++++++++++++++++++++++++++++++++++------------------------- 1 file changed, 49 insertions(+), 36 deletions(-)
diff --git a/common/scsi.c b/common/scsi.c index 972ef338..c456f5a 100644 --- a/common/scsi.c +++ b/common/scsi.c @@ -549,6 +549,52 @@ removable: * to the user if mode = 1 */ #if defined(CONFIG_DM_SCSI) +static int do_scsi_scan_one(struct udevice *dev, int id, int lun, int mode) +{ + int ret; + struct udevice *bdev; + struct blk_desc bd; + struct blk_desc *bdesc; + char str[10]; + + /* + * detect the scsi driver to get information about its geometry (block + * size, number of blocks) and other parameters (ids, type, ...) + */ + scsi_init_dev_desc_priv(&bd); + if (scsi_detect_dev(id, lun, &bd)) + return -ENODEV; + + /* + * Create only one block device and do detection + * to make sure that there won't be a lot of + * block devices created + */ + snprintf(str, sizeof(str), "id%dlun%d", id, lun); + ret = blk_create_devicef(dev, "scsi_blk", str, IF_TYPE_SCSI, -1, + bd.blksz, bd.blksz * bd.lba, &bdev); + if (ret) { + debug("Can't create device\n"); + return ret; + } + + bdesc = dev_get_uclass_platdata(bdev); + bdesc->target = id; + bdesc->lun = lun; + bdesc->removable = bd.removable; + bdesc->type = bd.type; + memcpy(&bdesc->vendor, &bd.vendor, sizeof(bd.vendor)); + memcpy(&bdesc->product, &bd.product, sizeof(bd.product)); + memcpy(&bdesc->revision, &bd.revision, sizeof(bd.revision)); + part_init(bdesc); + + if (mode == 1) { + printf(" Device %d: ", 0); + dev_print(bdesc); + } + return 0; +} + int scsi_scan(int mode) { unsigned char i, lun; @@ -576,42 +622,9 @@ int scsi_scan(int mode) /* Get controller platdata */ plat = dev_get_platdata(dev);
- for (i = 0; i < plat->max_id; i++) { - for (lun = 0; lun < plat->max_lun; lun++) { - struct udevice *bdev; /* block device */ - /* block device description */ - struct blk_desc *bdesc; - char str[10]; - - /* - * Create only one block device and do detection - * to make sure that there won't be a lot of - * block devices created - */ - snprintf(str, sizeof(str), "id%dlun%d", i, lun); - ret = blk_create_devicef(dev, "scsi_blk", - str, IF_TYPE_SCSI, - -1, 0, 0, &bdev); - if (ret) { - debug("Can't create device\n"); - return ret; - } - bdesc = dev_get_uclass_platdata(bdev); - - scsi_init_dev_desc_priv(bdesc); - ret = scsi_detect_dev(i, lun, bdesc); - if (ret) { - device_unbind(bdev); - continue; - } - part_init(bdesc); - - if (mode == 1) { - printf(" Device %d: ", 0); - dev_print(bdesc); - } /* if mode */ - } /* next LUN */ - } + for (i = 0; i < plat->max_id; i++) + for (lun = 0; lun < plat->max_lun; lun++) + do_scsi_scan_one(dev, i, lun, mode); }
Enable disk driver model for dra7xx_evm as dwc_ahci supports driver model. As a consequence we must also enable CONFIG_BLK and CONFIG_DM_USB.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- configs/dra7xx_evm_defconfig | 12 +++++++++++- configs/dra7xx_hs_evm_defconfig | 11 ++++++++++- 2 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 42f87b3..8bc395f 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -59,7 +59,13 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" CONFIG_DM=y CONFIG_SPL_DM=y -# CONFIG_BLK is not set +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_BLK=y +CONFIG_DM_SCSI=y +CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y @@ -89,6 +95,7 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y @@ -101,3 +108,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_SPL_GENERIC_PHY=y +CONFIG_PIPE3_PHY=y +CONFIG_SPL_PIPE3_PHY=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 871604f..40ac3d5 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -64,7 +64,12 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" CONFIG_DM=y CONFIG_SPL_DM=y -# CONFIG_BLK is not set +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_DM_SCSI=y +CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y @@ -94,6 +99,7 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y @@ -106,3 +112,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_SPL_GENERIC_PHY=y +CONFIG_PIPE3_PHY=y +CONFIG_SPL_PIPE3_PHY=y
Hi all,
This is the VERSION 3 of the series. Sorry for the confusion, I messed up while preparing the patches.
Jean-Jacques
changes since v2:
- Added unit tests for generic PHY uclass.
- Changed the generic phy API to use a 'struct udevice*' to reference the phy device.
- Don't modify anymore the root Makefile.
- Updated the Kconfig with more details on the PHY framework.
- Use a Unique Lincense Identifier (SPDX)
- Use omap5-u-boot.dtsi to mark the ocp2scp bus as compatible with "simple-bus"
- Split scsi_scan() in 2 for clarity. The function was becoming too long.
changes since v1:
- changed the way the 'old' sata code is compiled out when DM_SCSI is enabled.
- added a new framework for PHY management.
- added a new driver for the PIPE3 phy and use it in the dwc_ahci driver.
- changed the interface of scsi_detect_dev() and moved the call part_init() out of it.
- modified the fix to scsi_scan() in order to call scsi_detect_dev() only once.
- the max_lun and max_id parameters are now taken from the device-tree.
- Updated the defconfig changes to include the PHY driver and its dependencies.
Jean-Jacques Hiblot
