[U-Boot] [RFC PATCH 1/2] video: add a function to acquire the GraphicDevice of cfb_console
Sometimes the GraphicDevice of cfb_console is useful at other place.
Add a function to acquire it, so that the graphics hardware (especially the framebuffer) can be reused.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- drivers/video/cfb_console.c | 5 +++++ include/video_fb.h | 2 ++ 2 files changed, 7 insertions(+)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index c0b1b8dc17..c80ed1646f 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -2199,3 +2199,8 @@ int video_get_screen_columns(void) { return CONSOLE_COLS; } + +GraphicDevice *video_get_graphic_device(void) +{ + return pGD; +}; diff --git a/include/video_fb.h b/include/video_fb.h index b008853f30..29f2b24648 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -89,4 +89,6 @@ void video_set_lut ( unsigned char b /* blue */ );
+GraphicDevice *video_get_graphic_device(void); + #endif /*_VIDEO_FB_H_ */
As cfb_console now can expose its GraphicDevice, use it in the implementation of EFI GOP protocol, so that the graphics framebuffer can be passed to EFI applications.
Tested on an Allwinner H3 board with out-of-tree display support.
cmd/bootefi.c | 2 +- lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_gop.c | 29 ++++++++++++++++++++++++----- 3 files changed, 26 insertions(+), 6 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 97a0fc9c7c..c0636ba5a3 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -210,7 +210,7 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt) #ifdef CONFIG_PARTITIONS efi_disk_register(); #endif -#ifdef CONFIG_LCD +#if defined CONFIG_LCD || defined CONFIG_CFB_CONSOLE efi_gop_register(); #endif #ifdef CONFIG_NET diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index fa8b91a526..e88c99528c 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -17,6 +17,7 @@ obj-$(CONFIG_CMD_BOOTEFI_HELLO) += helloworld_efi.o obj-y += efi_image_loader.o efi_boottime.o efi_runtime.o efi_console.o obj-y += efi_memory.o obj-$(CONFIG_LCD) += efi_gop.o +obj-$(CONFIG_CFB_CONSOLE) += efi_gop.o obj-$(CONFIG_PARTITIONS) += efi_disk.o obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += efi_smbios.o diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 286ad83097..86f9aa2d70 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -13,6 +13,7 @@ #include <lcd.h> #include <malloc.h> #include <video.h> +#include <video_fb.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -80,8 +81,10 @@ static efi_status_t EFIAPI gop_blt(struct efi_gop *this, void *buffer, switch (gopobj->bpix) { #ifdef CONFIG_DM_VIDEO case VIDEO_BPP32: -#else +#elif defined CONFIG_LCD case LCD_COLOR32: +#elif defined CONFIG_CFB_CONSOLE + case GDF_32BIT_X888RGB: #endif for (i = 0; i < height; i++) { u32 *dest = fb + ((i + dy) * line_len32) + @@ -117,7 +120,7 @@ static efi_status_t EFIAPI gop_blt(struct efi_gop *this, void *buffer,
#ifdef CONFIG_DM_VIDEO video_sync_all(); -#else +#elif defined CONFIG_LCD lcd_sync(); #endif
@@ -144,7 +147,7 @@ int efi_gop_register(void) row = video_get_ysize(vdev); fb_base = (uintptr_t)priv->fb; fb_size = priv->fb_size; -#else +#elif defined CONFIG_LCD int line_len;
bpix = panel_info.vl_bpix; @@ -152,15 +155,29 @@ int efi_gop_register(void) row = panel_info.vl_row; fb_base = gd->fb_base; fb_size = lcd_get_size(&line_len); +#elif defined CONFIG_CFB_CONSOLE + GraphicDevice *pGD; + + pGD = video_get_graphic_device(); + bpix = pGD->gdfIndex; + col = pGD->winSizeX; + row = pGD->winSizeY; + fb_base = pGD->frameAdrs; + if (pGD->memSize) + fb_size = pGD->memSize; + else + fb_size = pGD->plnSizeX * row; #endif
switch (bpix) { #ifdef CONFIG_DM_VIDEO case VIDEO_BPP16: case VIDEO_BPP32: -#else +#elif defined CONFIG_LCD case LCD_COLOR32: case LCD_COLOR16: +#elif defined CONFIG_CFB_CONSOLE + case GDF_32BIT_X888RGB: #endif break; default: @@ -185,8 +202,10 @@ int efi_gop_register(void)
#ifdef CONFIG_DM_VIDEO if (bpix == VIDEO_BPP32) { -#else +#elif defined CONFIG_LCD if (bpix == LCD_COLOR32) { +#elif defined CONFIG_CFB_CONSOLE + if (bpix == GDF_32BIT_X888RGB) { #endif /* With 32bit color space we can directly expose the fb */ gopobj->mode.fb_base = fb_base;
Instead of adding support on legacy CFB console driver, can we use the DM video driver instead?
Regards, Bin
Please can you use driver-model video instead.
Bin Meng
Icenowy Zheng
