[U-Boot] [PATCH] disk: fix unaligned access in efi partitions
start_sect is not aligned to a 4 byte boundary thus causing exceptions on ARM platforms. Access this field via the get_unaligned macro.
Signed-off-by: Marc Dietrich marvin24@gmx.de --- disk/part_efi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index b3fd0e9..6678a4c 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -30,6 +30,7 @@ * * This limits the maximum size of addressable storage to < 2 Terra Bytes */ +#include <asm/unaligned.h> #include <common.h> #include <command.h> #include <ide.h> @@ -505,7 +506,7 @@ err: static int pmbr_part_valid(struct partition *part) { if (part->sys_ind == EFI_PMBR_OSTYPE_EFI_GPT && - le32_to_cpu(part->start_sect) == 1UL) { + le32_to_cpu(get_unaligned(&part->start_sect)) == 1UL) { return 1; }
Hi Marc,
- This limits the maximum size of addressable storage to < 2 Terra Bytes
return 1; }le32_to_cpu(get_unaligned(&part->start_sect)) == 1UL) {
Suits me :) but did you not say the same issue was also affecting nr_sects?
Also, beside the asm/unaligned.h file I gave as an example, other header files in include/linux/unaligned/ exist that provide alignment-related macros, notably with _le and _be versions. Maybe you can find one that combines the effects of both le32_to_cpu() and get_unaligned()?
Amicalement,
Albert,
return 1;
I checked again and this field is never read - only written to but to an aligned buffer. So there shouldn't be a problem.
I looks like get_unaligned does the job for us already, so we can leave the le32_to_cpu out. But I cannot test it here because of missing big endian machine with efi and my two brain halfs are already swapped until confusion (start_sect is defined as _le32).
Albert, I like to get a fix for this into 2013.04 if possible. Maybe someone with more endian experience can look at it quickly.
Marc
Looking at include/linux/unaligned/generic.h, I think you can just use:
__get_unaligned_le(&part->start_sect) == 1UL
I don't believe the __le32 marking of the start_sect field will have any effect, since the implementation of __get_unaligned_le accesses the variable byte-by-byte.
Albert ARIBAUD
Marc Dietrich
Stephen Warren
