[U-Boot] [PATCH v4 0/9] imx6ul: Add Engicam Is.IoT MX6UL support
This patch set support Engicam Is.IoT MX6UL board support.
Changes for v4: - Rebase to master
Changes for v3: - Rebase to master
Changes for v2: - Skiped eMMC node patch - Rebase to master
Jagan Teki (9): configs: imx6: Don't define USDHC2_BASE_ADDR arm: imx6ul: Add Engicam Is.IoT MX6UL Starter Kit initial support arm: dts: imx6ul-isiot: Add I2C nodes imx6: isiotmx6ul: Add I2C support arm: dts: imx6ul-isiot: Add FEC node imx6: isiotmx6ul: Add FEC support imx6: isiotmx6ul: Add NAND support imx6: isiotmx6ul: Add nandboot env support imx6ul: isiotmx6ul: Enable I2C support
arch/arm/cpu/armv7/mx6/Kconfig | 13 ++ arch/arm/dts/Makefile | 4 +- arch/arm/dts/imx6ul-isiot-mmc.dts | 50 ++++++ arch/arm/dts/imx6ul-isiot-nand.dts | 50 ++++++ arch/arm/dts/imx6ul-isiot.dtsi | 142 +++++++++++++++ board/engicam/isiotmx6ul/Kconfig | 12 ++ board/engicam/isiotmx6ul/MAINTAINERS | 7 + board/engicam/isiotmx6ul/Makefile | 6 + board/engicam/isiotmx6ul/README | 28 +++ board/engicam/isiotmx6ul/isiotmx6ul.c | 316 ++++++++++++++++++++++++++++++++++ configs/imx6ul_isiot_mmc_defconfig | 41 +++++ configs/imx6ul_isiot_nand_defconfig | 42 +++++ include/configs/imx6qdl_icore.h | 2 +- include/configs/imx6ul_geam.h | 2 +- include/configs/imx6ul_isiot.h | 205 ++++++++++++++++++++++ 15 files changed, 917 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/imx6ul-isiot-mmc.dts create mode 100644 arch/arm/dts/imx6ul-isiot-nand.dts create mode 100644 arch/arm/dts/imx6ul-isiot.dtsi create mode 100644 board/engicam/isiotmx6ul/Kconfig create mode 100644 board/engicam/isiotmx6ul/MAINTAINERS create mode 100644 board/engicam/isiotmx6ul/Makefile create mode 100644 board/engicam/isiotmx6ul/README create mode 100644 board/engicam/isiotmx6ul/isiotmx6ul.c create mode 100644 configs/imx6ul_isiot_mmc_defconfig create mode 100644 configs/imx6ul_isiot_nand_defconfig create mode 100644 include/configs/imx6ul_isiot.h
USDHC base address will assigned by SPL using fsl_esdhc_initialize and u-boot with devicetree, hence no remove base address assignment in config files.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/configs/imx6qdl_icore.h | 2 +- include/configs/imx6ul_geam.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index eb83d23..5a28b15 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -147,7 +147,7 @@ #ifdef CONFIG_FSL_USDHC # define CONFIG_SYS_MMC_ENV_DEV 0 # define CONFIG_SYS_FSL_USDHC_NUM 1 -# define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR +# define CONFIG_SYS_FSL_ESDHC_ADDR 0 #endif
/* NAND */ diff --git a/include/configs/imx6ul_geam.h b/include/configs/imx6ul_geam.h index 23fa3ee..8bffacd 100644 --- a/include/configs/imx6ul_geam.h +++ b/include/configs/imx6ul_geam.h @@ -145,7 +145,7 @@ #ifdef CONFIG_FSL_USDHC # define CONFIG_SYS_MMC_ENV_DEV 0 # define CONFIG_SYS_FSL_USDHC_NUM 1 -# define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR +# define CONFIG_SYS_FSL_ESDHC_ADDR 0 #endif
/* NAND */
/* NAND */
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Boot from MMC: ------------- U-Boot SPL 2017.01-rc2-gba3c151-dirty (Jan 02 2017 - 16:59:33) Trying to boot from MMC1
U-Boot 2017.01-rc2-gba3c151-dirty (Jan 02 2017 - 16:59:33 +0100)
CPU: Freescale i.MX6UL rev1.1 528 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 33C Reset cause: POR Model: Engicam Is.IoT MX6UL Starterkit DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 isiotmx6ul>
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 11 ++ arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx6ul-isiot-mmc.dts | 50 +++++++ arch/arm/dts/imx6ul-isiot.dtsi | 92 +++++++++++++ board/engicam/isiotmx6ul/Kconfig | 12 ++ board/engicam/isiotmx6ul/MAINTAINERS | 6 + board/engicam/isiotmx6ul/Makefile | 6 + board/engicam/isiotmx6ul/README | 28 ++++ board/engicam/isiotmx6ul/isiotmx6ul.c | 247 ++++++++++++++++++++++++++++++++++ configs/imx6ul_isiot_mmc_defconfig | 36 +++++ include/configs/imx6ul_isiot.h | 142 +++++++++++++++++++ 11 files changed, 632 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6ul-isiot-mmc.dts create mode 100644 arch/arm/dts/imx6ul-isiot.dtsi create mode 100644 board/engicam/isiotmx6ul/Kconfig create mode 100644 board/engicam/isiotmx6ul/MAINTAINERS create mode 100644 board/engicam/isiotmx6ul/Makefile create mode 100644 board/engicam/isiotmx6ul/README create mode 100644 board/engicam/isiotmx6ul/isiotmx6ul.c create mode 100644 configs/imx6ul_isiot_mmc_defconfig create mode 100644 include/configs/imx6ul_isiot.h
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index c646966..72780d7 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -205,6 +205,16 @@ config TARGET_MX6UL_GEAM select DM_THERMAL select SUPPORT_SPL
+config TARGET_MX6UL_ISIOT + bool "Support Engicam Is.IoT MX6UL" + select MX6UL + select OF_CONTROL + select DM + select DM_GPIO + select DM_MMC + select DM_THERMAL + select SUPPORT_SPL + config TARGET_MX6ULL_14X14_EVK bool "Support mx6ull_14x14_evk" select MX6ULL @@ -313,6 +323,7 @@ source "board/embest/mx6boards/Kconfig" source "board/engicam/geam6ul/Kconfig" source "board/engicam/icorem6/Kconfig" source "board/engicam/icorem6_rqs/Kconfig" +source "board/engicam/isiotmx6ul/Kconfig" source "board/freescale/mx6qarm2/Kconfig" source "board/freescale/mx6qsabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6a7924e..e83308c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -313,7 +313,8 @@ dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ imx6dl-icore-rqs.dtb \ imx6q-icore.dtb \ imx6q-icore-rqs.dtb \ - imx6ul-geam-kit.dtb + imx6ul-geam-kit.dtb \ + imx6ul-isiot-mmc.dtb
dtb-$(CONFIG_MX7) += imx7-colibri.dtb
diff --git a/arch/arm/dts/imx6ul-isiot-mmc.dts b/arch/arm/dts/imx6ul-isiot-mmc.dts new file mode 100644 index 0000000..bb5086a --- /dev/null +++ b/arch/arm/dts/imx6ul-isiot-mmc.dts @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "imx6ul-isiot.dtsi" + +/ { + model = "Engicam Is.IoT MX6UL MMC Starterkit"; + compatible = "engicam,imx6ul-isiot", "fsl,imx6ul"; +}; diff --git a/arch/arm/dts/imx6ul-isiot.dtsi b/arch/arm/dts/imx6ul-isiot.dtsi new file mode 100644 index 0000000..6108a1a --- /dev/null +++ b/arch/arm/dts/imx6ul-isiot.dtsi @@ -0,0 +1,92 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include "imx6ul.dtsi" + +/ { + memory { + reg = <0x80000000 0x20000000>; + }; + + chosen { + stdout-path = &uart1; + }; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; + bus-width = <4>; + no-1-8-v; + status = "okay"; +}; + +&iomuxc { + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 + MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10059 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 + >; + }; +}; diff --git a/board/engicam/isiotmx6ul/Kconfig b/board/engicam/isiotmx6ul/Kconfig new file mode 100644 index 0000000..213ffad --- /dev/null +++ b/board/engicam/isiotmx6ul/Kconfig @@ -0,0 +1,12 @@ +if TARGET_MX6UL_ISIOT + +config SYS_BOARD + default "isiotmx6ul" + +config SYS_VENDOR + default "engicam" + +config SYS_CONFIG_NAME + default "imx6ul_isiot" + +endif diff --git a/board/engicam/isiotmx6ul/MAINTAINERS b/board/engicam/isiotmx6ul/MAINTAINERS new file mode 100644 index 0000000..0258531 --- /dev/null +++ b/board/engicam/isiotmx6ul/MAINTAINERS @@ -0,0 +1,6 @@ +GEAM6UL BOARD +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: board/engicam/isiotmx6ul +F: include/configs/imx6ul_isiot.h +F: configs/imx6ul_isiot_mmc_defconfig diff --git a/board/engicam/isiotmx6ul/Makefile b/board/engicam/isiotmx6ul/Makefile new file mode 100644 index 0000000..f4f8c78 --- /dev/null +++ b/board/engicam/isiotmx6ul/Makefile @@ -0,0 +1,6 @@ +# Copyright (C) 2016 Amarula Solutions B.V. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := isiotmx6ul.o diff --git a/board/engicam/isiotmx6ul/README b/board/engicam/isiotmx6ul/README new file mode 100644 index 0000000..1d177ac --- /dev/null +++ b/board/engicam/isiotmx6ul/README @@ -0,0 +1,28 @@ +How to use U-Boot on Engicam Is.IoT MX6UL Starter Kit: +----------------------------------------------------- + +- Configure U-Boot for Engicam Is.IoT MX6UL + +$ make mrproper +$ make imx6ul_isiot_mmc_defconfig +$ make + +This will generate the SPL image called SPL and the u-boot-dtb.img. + +- Flash the SPL image into the micro SD card: + +sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync + +- Flash the u-boot-dtb.img image into the micro SD card: + +sudo dd if=u-boot-dtb.img of=/dev/mmcblk0 bs=1k seek=69; sync + +- Jumper settings: + +MMC Boot: JM3 Closed + +- Connect the Serial cable between the Starter Kit and the PC for the console. +(J28 is the Linux Serial console connector) + +- Insert the micro SD card in the board, power it up and U-Boot messages should +come up. diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c new file mode 100644 index 0000000..c0b18c3 --- /dev/null +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -0,0 +1,247 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * Author: Jagan Teki jagan@amarulasolutions.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/sizes.h> + +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/iomux-v3.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +#ifdef CONFIG_SPL_BUILD +#include <libfdt.h> +#include <spl.h> + +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-ddr.h> + +/* MMC board initialization is needed till adding DM support in SPL */ +#if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) +#include <mmc.h> +#include <fsl_esdhc.h> + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + /* VSELECT */ + MX6_PAD_GPIO1_IO05__USDHC1_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL), + /* CD */ + MX6_PAD_UART1_RTS_B__GPIO1_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* RST_B */ + MX6_PAD_GPIO1_IO09__GPIO1_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 19) + +struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC1_BASE_ADDR, 0, 4}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + gpio_direction_input(USDHC1_CD_GPIO); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + default: + printf("Warning - USDHC%d controller not supporting\n", + i + 1); + return 0; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} +#endif /* CONFIG_FSL_ESDHC */ + +static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { + .grp_addds = 0x00000030, + .grp_ddrmode_ctl = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ddr_type = 0x000c0000, +}; + +static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_dqm0 = 0x00000030, + .dram_dqm1 = 0x00000030, + .dram_ras = 0x00000030, + .dram_cas = 0x00000030, + .dram_odt0 = 0x00000030, + .dram_odt1 = 0x00000030, + .dram_sdba2 = 0x00000000, + .dram_sdclk_0 = 0x00000008, + .dram_sdqs0 = 0x00000038, + .dram_sdqs1 = 0x00000030, + .dram_reset = 0x00000030, +}; + +static struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x00070007, + .p0_mpdgctrl0 = 0x41490145, + .p0_mprddlctl = 0x40404546, + .p0_mpwrdlctl = 0x4040524D, +}; + +struct mx6_ddr_sysinfo ddr_sysinfo = { + .dsize = 0, + .cs_density = 20, + .ncs = 1, + .cs1_mirror = 0, + .rtt_wr = 2, + .rtt_nom = 1, /* RTT_Nom = RZQ/2 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .ddr_type = DDR_TYPE_DDR3, +}; + +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 800, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0xFFFFFFFF, &ccm->CCGR0); + writel(0xFFFFFFFF, &ccm->CCGR1); + writel(0xFFFFFFFF, &ccm->CCGR2); + writel(0xFFFFFFFF, &ccm->CCGR3); + writel(0xFFFFFFFF, &ccm->CCGR4); + writel(0xFFFFFFFF, &ccm->CCGR5); + writel(0xFFFFFFFF, &ccm->CCGR6); + writel(0xFFFFFFFF, &ccm->CCGR7); +} + +static void spl_dram_init(void) +{ + mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + + /* iomux and setup of i2c */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif /* CONFIG_SPL_BUILD */ diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig new file mode 100644 index 0000000..66eb59f --- /dev/null +++ b/configs/imx6ul_isiot_mmc_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_MX6UL_ISIOT=y +CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-mmc" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="imx6ul-isiot-emmc.dtb" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="isiotmx6ul> " +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_BLK is not set +# CONFIG_DM_MMC_OPS is not set +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h new file mode 100644 index 0000000..aba43fc --- /dev/null +++ b/include/configs/imx6ul_isiot.h @@ -0,0 +1,142 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * Configuration settings for the Engicam Is.IoT MX6UL Starter Kits. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __IMX6UL_ISIOT_CONFIG_H +#define __IMX6UL_ISIOT_CONFIG_H + +#include <linux/sizes.h> +#include "mx6_common.h" + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) + +/* Total Size of Environment Sector */ +#define CONFIG_ENV_SIZE SZ_128K + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Environment */ +#ifndef CONFIG_ENV_IS_NOWHERE +/* Environment in MMC */ +# if defined(CONFIG_ENV_IS_IN_MMC) +# define CONFIG_ENV_OFFSET 0x100000 +# endif +#endif + +/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=uImage\0" \ + "fit_image=fit.itb\0" \ + "splashpos=m,m\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x87800000\0" \ + "boot_fdt=try\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "loadfit=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${fit_image}\0" \ + "fitboot=echo Booting FIT image from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi\0" + +# define CONFIG_BOOTCOMMAND \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadfit; then " \ + "run fitboot; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x8000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_SP_OFFSET) + +/* FIT */ +#ifdef CONFIG_FIT +# define CONFIG_HASH_VERIFY +# define CONFIG_SHA1 +# define CONFIG_SHA256 +# define CONFIG_IMAGE_FORMAT_LEGACY +#endif + +/* UART */ +#ifdef CONFIG_MXC_UART +# define CONFIG_MXC_UART_BASE UART1_BASE +#endif + +/* MMC */ +#ifdef CONFIG_FSL_USDHC +# define CONFIG_SYS_MMC_ENV_DEV 0 +# define CONFIG_SYS_FSL_USDHC_NUM 1 +# define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#endif + +/* SPL */ +#ifdef CONFIG_SPL +# define CONFIG_SPL_MMC_SUPPORT + +# include "imx6_spl.h" +# ifdef CONFIG_SPL_BUILD +# undef CONFIG_DM_GPIO +# undef CONFIG_DM_MMC +# endif +#endif + +#endif /* __IMX6UL_ISIOT_CONFIG_H */
Hi Jagan,
Boot from MMC:
- bool "Support Engicam Is.IoT MX6UL"
- select MX6UL
- select OF_CONTROL
- select DM
- select DM_GPIO
- select DM_MMC
- select DM_THERMAL
- select SUPPORT_SPL
- imx6ul-geam-kit.dtb \
- imx6ul-isiot-mmc.dtb
- Copyright (C) 2016 Amarula Solutions B.V.
- Copyright (C) 2016 Engicam S.r.l.
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
I have seen that a lot of files slipped into mainline, and I have myself not paid enough attention befeore (see your imx6ul-geam-kit.dts for example).
But we moved some years ago to SPDX-License-Identifier. Other DTS files are using this as well without copying the whole license. Could you do this here, too ? It would be also nice if you plan to fix this for all Engicam's boards, thanks !
+/dts-v1/;
- model = "Engicam Is.IoT MX6UL MMC Starterkit";
- compatible = "engicam,imx6ul-isiot", "fsl,imx6ul";
Ditto.
+config SYS_BOARD
- default "isiotmx6ul"
+config SYS_VENDOR
- default "engicam"
- default "imx6ul_isiot"
Should you not add the DTS files ?
+- Jumper settings:
- Author: Jagan Teki jagan@amarulasolutions.com
- MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
- /* Address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- gd->ram_size = imx_ddr_size();
- PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \
- PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- /* VSELECT */
- MX6_PAD_GPIO1_IO05__USDHC1_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- /* CD */
- MX6_PAD_UART1_RTS_B__GPIO1_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* RST_B */
- MX6_PAD_GPIO1_IO09__GPIO1_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL),
- {USDHC1_BASE_ADDR, 0, 4},
- struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv;
- int ret = 0;
- switch (cfg->esdhc_base) {
- case USDHC1_BASE_ADDR:
break;
- return ret;
- int i, ret;
- According to the board_mmc_init() the following map is done:
- (U-boot device node) (Physical Port)
- mmc0 USDHC1
- for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) {
switch (i) {
case 0:
break;
default:
i + 1);
if (ret) {
return ret;
- .grp_addds = 0x00000030,
- .grp_ddrmode_ctl = 0x00020000,
- .grp_b0ds = 0x00000030,
- .grp_ctlds = 0x00000030,
- .grp_b1ds = 0x00000030,
- .grp_ddrpke = 0x00000000,
- .grp_ddrmode = 0x00020000,
- .grp_ddr_type = 0x000c0000,
- .dram_dqm0 = 0x00000030,
- .dram_dqm1 = 0x00000030,
- .dram_ras = 0x00000030,
- .dram_cas = 0x00000030,
- .dram_odt0 = 0x00000030,
- .dram_odt1 = 0x00000030,
- .dram_sdba2 = 0x00000000,
- .dram_sdclk_0 = 0x00000008,
- .dram_sdqs0 = 0x00000038,
- .dram_sdqs1 = 0x00000030,
- .dram_reset = 0x00000030,
- .p0_mpwldectrl0 = 0x00070007,
- .p0_mpdgctrl0 = 0x41490145,
- .p0_mprddlctl = 0x40404546,
- .p0_mpwrdlctl = 0x4040524D,
- .dsize = 0,
- .cs_density = 20,
- .ncs = 1,
- .cs1_mirror = 0,
- .rtt_wr = 2,
- .rtt_nom = 1, /* RTT_Nom = RZQ/2 */
- .walat = 1, /* Write additional latency */
- .ralat = 5, /* Read additional latency */
- .mif3_mode = 3, /* Command prediction working mode */
- .bi_on = 1, /* Bank interleaving enabled */
- .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */
- .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */
- .ddr_type = DDR_TYPE_DDR3,
- .mem_speed = 800,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 15,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- writel(0xFFFFFFFF, &ccm->CCGR0);
- writel(0xFFFFFFFF, &ccm->CCGR1);
- writel(0xFFFFFFFF, &ccm->CCGR2);
- writel(0xFFFFFFFF, &ccm->CCGR3);
- writel(0xFFFFFFFF, &ccm->CCGR4);
- writel(0xFFFFFFFF, &ccm->CCGR5);
- writel(0xFFFFFFFF, &ccm->CCGR6);
- writel(0xFFFFFFFF, &ccm->CCGR7);
Just a mention here: why do you activate all clocks instead of just what you really need ?
- mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs);
- mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr);
- /* setup AIPS and disable watchdog */
- arch_cpu_init();
- ccgr_init();
- /* iomux and setup of i2c */
- board_early_init_f();
- /* setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- /* DDR initialization */
- spl_dram_init();
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- /* load/boot image from boot device */
- board_init_r(NULL, 0);
- Configuration settings for the Engicam Is.IoT MX6UL Starter Kits.
- "script=boot.scr\0" \
- "image=uImage\0" \
- "fit_image=fit.itb\0" \
- "splashpos=m,m\0" \
- "console=ttymxc0\0" \
- "fdt_high=0xffffffff\0" \
- "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "fdt_addr=0x87800000\0" \
- "boot_fdt=try\0" \
- "mmcdev=0\0" \
- "mmcpart=1\0" \
- "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \
- "mmcautodetect=yes\0" \
- "mmcargs=setenv bootargs console=${console},${baudrate} " \
- "loadbootscript=" \
- "bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
- "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \
- "loadfit=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${fit_image}\0" \
- "fitboot=echo Booting FIT image from mmc ...; " \
"run mmcargs; " \
- "mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
"else " \
"bootm; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"fi\0"
- "if mmc rescan; then " \
"else " \
"run fitboot; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
"fi; " \
- "fi"
n Fri, Jan 27, 2017 at 1:38 PM, Stefano Babic sbabic@denx.de wrote:
Hi Jagan,
Boot from MMC:
select MX6UL
select OF_CONTROL
select DM
select DM_GPIO
select DM_MMC
select DM_THERMAL
select SUPPORT_SPL
imx6ul-geam-kit.dtb
- whole.
Yes for boards, I will prepare patch.
For devicetress, since the base dtsi files copied from Linux, we keep the license as it is. I am not sure all other dts(i) files use the SPDX-License-Identifier. example imx6sll-evk, imx6ull-14x14-evk and all sunxi .
+/dts-v1/;
Ditto.
+config SYS_BOARD
+config SYS_VENDOR
default "engicam"
Good idea, I will add.
+- Jumper settings:
/* VSELECT */
/* CD */
/* RST_B */
int ret = 0;
break;
return ret;
int i, ret;
* mmc0 USDHC1
switch (i) {
case 0:
break;
default:
i + 1);
if (ret) {
return ret;
.dsize = 0,
.cs_density = 20,
.ncs = 1,
.cs1_mirror = 0,
.rtt_wr = 2,
.mem_speed = 800,
.density = 4,
.width = 16,
.banks = 8,
.rowaddr = 15,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
May be yes, but it's better to have full clock initialization so-that nothing broke during SPL runtime.
thanks!
Hi Jagan, Tom,
Hi Jagan,
Boot from MMC:
select MX6UL
select OF_CONTROL
select DM
select DM_GPIO
select DM_MMC
select DM_THERMAL
select SUPPORT_SPL
imx6ul-geam-kit.dtb
- whole.
It is true that some files slipped into mainline copying again all license stuff - and several files ported from Linux was adjusting for SPDX.
Tom, what do you think ?
+/dts-v1/;
Ditto.
+config SYS_BOARD
+config SYS_VENDOR
default "engicam"
+- Jumper settings:
/* VSELECT */
/* CD */
/* RST_B */
int ret = 0;
break;
return ret;
int i, ret;
* mmc0 USDHC1
switch (i) {
case 0:
break;
default:
i + 1);
if (ret) {
return ret;
.dsize = 0,
.cs_density = 20,
.ncs = 1,
.cs1_mirror = 0,
.rtt_wr = 2,
.mem_speed = 800,
.density = 4,
.width = 16,
.banks = 8,
.rowaddr = 15,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
You are the board maintainer, and it is your decision. Anyway, clocks are not disable in u-boot, and they can remain on in Linux, because they are set just if needed. Some kernels had disabled in the past for some platform (I know OMAP3) all not required clocks, but this was in the era before DT. Kernel just supposes that nothing is set.
Hi
On 28 Jan 2017 1:25 p.m., "Stefano Babic" sbabic@denx.de wrote:
Hi Jagan, Tom,
Hi Jagan,
Boot from MMC:
Kconfig
select MX6UL
select OF_CONTROL
select DM
select DM_GPIO
select DM_MMC
select DM_THERMAL
select SUPPORT_SPL
imx6ul-geam-kit.dtb
- whole.
+/dts-v1/;
dtsi
Ditto.
+config SYS_BOARD
+config SYS_VENDOR
default "engicam"
README
+- Jumper settings:
console.
messages should
PAD_CTL_HYS)
/* VSELECT */
/* CD */
/* RST_B */
int ret = 0;
break;
return ret;
int i, ret;
* mmc0 USDHC1
switch (i) {
case 0:
break;
default:
supporting\n",
i + 1);
if (ret) {
%d\n", i);
return ret;
.dsize = 0,
.cs_density = 20,
.ncs = 1,
.cs1_mirror = 0,
.rtt_wr = 2,
.mem_speed = 800,
.density = 4,
.width = 16,
.banks = 8,
.rowaddr = 15,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
I agree with Stefano. Clocks part should clean up. We have done in the past for OMAP architecture
Michael
Best regards, Stefano Babic _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Sat, Jan 28, 2017 at 1:39 PM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Hi Jagan, Tom,
Hi Jagan,
Boot from MMC:
Kconfig
select MX6UL
select OF_CONTROL
select DM
select DM_GPIO
select DM_MMC
select DM_THERMAL
select SUPPORT_SPL
imx6ul-geam-kit.dtb
- whole.
+/dts-v1/;
dtsi
Ditto.
+config SYS_BOARD
+config SYS_VENDOR
default "engicam"
README
+- Jumper settings:
console.
messages should
PAD_CTL_HYS)
/* VSELECT */
/* CD */
/* RST_B */
int ret = 0;
break;
return ret;
int i, ret;
* mmc0 USDHC1
switch (i) {
case 0:
break;
default:
supporting\n",
i + 1);
if (ret) {
%d\n", i);
return ret;
.dsize = 0,
.cs_density = 20,
.ncs = 1,
.cs1_mirror = 0,
.rtt_wr = 2,
.mem_speed = 800,
.density = 4,
.width = 16,
.banks = 8,
.rowaddr = 15,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
I would like to go-ahead with these now, since many of i.MX(even other engicam) boards does the same. I will need to look into it and prepare patches for all.
thanks!
Hi Jagan,
Just because I (or someone else) did not note this isuse in the past, it does not mean that this is a good reason to go on doing wrongly.
Fix this, and you will have time later to send patches for the other boards.
On Sat, Jan 28, 2017 at 01:25:05PM +0100, Stefano Babic wrote:
Hi Jagan, Tom,
Hi Jagan,
Boot from MMC:
select MX6UL
select OF_CONTROL
select DM
select DM_GPIO
select DM_MMC
select DM_THERMAL
select SUPPORT_SPL
imx6ul-geam-kit.dtb
- whole.
The DT files we copy from the kernel are the exception to the rule, they should just keep the usual full license header they come in with. This is even "easier" to do now, given that we can append any U-Boot centric bits into a -uboot.dtsi file and keep the upstream DT files unmodified entirely.
Add I2C nodes for Engicam Is.IoT MX6UL module.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6ul-isiot.dtsi | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/dts/imx6ul-isiot.dtsi b/arch/arm/dts/imx6ul-isiot.dtsi index 6108a1a..1a474ca 100644 --- a/arch/arm/dts/imx6ul-isiot.dtsi +++ b/arch/arm/dts/imx6ul-isiot.dtsi @@ -56,6 +56,20 @@ }; };
+&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + clock_frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + &uart1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; @@ -72,6 +86,20 @@ };
&iomuxc { + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 + MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0 + MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = < MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1
Add I2C support for Engicam Is.IoT MX6UL module.
isiotmx6ul> i2c bus Bus 0: i2c@021a0000 Bus 1: i2c@021a4000 isiotmx6ul> i2c dev 0 Setting bus to 0 isiotmx6ul> i2c dev Current bus is 0 isiotmx6ul> i2c speed 100000 Setting bus speed to 100000 Hz isiotmx6ul> i2c probe Valid chip addresses: 00 2C 44 78 isiotmx6ul> i2c md 2C 0xff 00ff: 00 00 00 00 0f f0 01 64 ff ff 00 00 00 00 00 00 .......d........
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + configs/imx6ul_isiot_mmc_defconfig | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 72780d7..b81e18c 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -211,6 +211,7 @@ config TARGET_MX6UL_ISIOT select OF_CONTROL select DM select DM_GPIO + select DM_I2C select DM_MMC select DM_THERMAL select SUPPORT_SPL diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig index 66eb59f..7a7be23 100644 --- a/configs/imx6ul_isiot_mmc_defconfig +++ b/configs/imx6ul_isiot_mmc_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_PROMPT="isiotmx6ul> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y @@ -29,6 +30,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set +CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y
- select DM_I2C select DM_MMC select DM_THERMAL select SUPPORT_SPL
Add FEC node for Engicam Is.IoT MX6UL module.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6ul-isiot.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/imx6ul-isiot.dtsi b/arch/arm/dts/imx6ul-isiot.dtsi index 1a474ca..346079a 100644 --- a/arch/arm/dts/imx6ul-isiot.dtsi +++ b/arch/arm/dts/imx6ul-isiot.dtsi @@ -56,6 +56,13 @@ }; };
+&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + phy-mode = "rmii"; + status = "okay"; +}; + &i2c1 { clock-frequency = <100000>; pinctrl-names = "default"; @@ -86,6 +93,21 @@ };
&iomuxc { + pinctrl_enet1: enet1grp { + fsl,pins = < + MX6UL_PAD_ENET2_RX_DATA0__ENET1_MDIO 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA1__ENET1_MDC 0x1b0b0 + MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 + MX6UL_PAD_ENET2_RX_EN__GPIO2_IO10 0x1b0b0 + >; + }; + pinctrl_i2c1: i2c1grp { fsl,pins = < MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0
+&fec1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_enet1>;
- phy-mode = "rmii";
- status = "okay";
&iomuxc {
- pinctrl_enet1: enet1grp {
fsl,pins = <
- pinctrl_i2c1: i2c1grp { fsl,pins = < MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0
Add FEC support for Engicam Is.IoT MX6UL module.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + configs/imx6ul_isiot_mmc_defconfig | 3 +++ include/configs/imx6ul_isiot.h | 10 ++++++++++ 3 files changed, 14 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index b81e18c..46b2b59 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -210,6 +210,7 @@ config TARGET_MX6UL_ISIOT select MX6UL select OF_CONTROL select DM + select DM_ETH select DM_GPIO select DM_I2C select DM_MMC diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig index 7a7be23..8ecdd8e 100644 --- a/configs/imx6ul_isiot_mmc_defconfig +++ b/configs/imx6ul_isiot_mmc_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y @@ -32,6 +34,7 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set +CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index aba43fc..5a3e05a 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -128,6 +128,16 @@ # define CONFIG_SYS_FSL_ESDHC_ADDR 0 #endif
+/* Ethernet */ +#ifdef CONFIG_FEC_MXC +# define CONFIG_FEC_MXC_PHYADDR 0 +# define CONFIG_FEC_XCV_TYPE RMII + +# define CONFIG_MII +# define CONFIG_PHYLIB +# define CONFIG_PHY_SMSC +#endif + /* SPL */ #ifdef CONFIG_SPL # define CONFIG_SPL_MMC_SUPPORT
Add NAND support for Engicam Is.IoT MX6UL board.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx6ul-isiot-nand.dts | 50 +++++++++++++++++++++++++ board/engicam/isiotmx6ul/MAINTAINERS | 1 + board/engicam/isiotmx6ul/isiotmx6ul.c | 69 +++++++++++++++++++++++++++++++++++ configs/imx6ul_isiot_nand_defconfig | 39 ++++++++++++++++++++ include/configs/imx6ul_isiot.h | 25 ++++++++++++- 6 files changed, 185 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx6ul-isiot-nand.dts create mode 100644 configs/imx6ul_isiot_nand_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e83308c..09e3bdb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -314,7 +314,8 @@ dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ imx6q-icore.dtb \ imx6q-icore-rqs.dtb \ imx6ul-geam-kit.dtb \ - imx6ul-isiot-mmc.dtb + imx6ul-isiot-mmc.dtb \ + imx6ul-isiot-nand.dtb
diff --git a/arch/arm/dts/imx6ul-isiot-nand.dts b/arch/arm/dts/imx6ul-isiot-nand.dts new file mode 100644 index 0000000..12a3528 --- /dev/null +++ b/arch/arm/dts/imx6ul-isiot-nand.dts @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "imx6ul-isiot.dtsi" + +/ { + model = "Engicam Is.IoT MX6UL NAND Starterkit"; + compatible = "engicam,imx6ul-isiot", "fsl,imx6ul"; +}; diff --git a/board/engicam/isiotmx6ul/MAINTAINERS b/board/engicam/isiotmx6ul/MAINTAINERS index 0258531..e99e02e 100644 --- a/board/engicam/isiotmx6ul/MAINTAINERS +++ b/board/engicam/isiotmx6ul/MAINTAINERS @@ -4,3 +4,4 @@ S: Maintained F: board/engicam/isiotmx6ul F: include/configs/imx6ul_isiot.h F: configs/imx6ul_isiot_mmc_defconfig +F: configs/imx6ul_isiot_nand_defconfig diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index c0b18c3..ae3465f 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -37,11 +37,80 @@ int board_early_init_f(void) return 0; }
+#ifdef CONFIG_NAND_MXS + +#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) +#define GPMI_PAD_CTRL1 (PAD_CTL_DSE_40ohm | PAD_CTL_SPEED_MED | \ + PAD_CTL_SRE_FAST) +#define GPMI_PAD_CTRL2 (GPMI_PAD_CTRL0 | GPMI_PAD_CTRL1) + +static iomux_v3_cfg_t const nand_pads[] = { + MX6_PAD_NAND_DATA00__RAWNAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA01__RAWNAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA02__RAWNAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA03__RAWNAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA04__RAWNAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA05__RAWNAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA06__RAWNAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_DATA07__RAWNAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_CLE__RAWNAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_ALE__RAWNAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_RE_B__RAWNAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_WE_B__RAWNAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_WP_B__RAWNAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + MX6_PAD_NAND_READY_B__RAWNAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), +}; + +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nand_pads, ARRAY_SIZE(nand_pads)); + + clrbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK); + + /* + * config gpmi and bch clock to 100 MHz + * bch/gpmi select PLL2 PFD2 400M + * 100M = 400M / 4 + */ + clrbits_le32(&mxc_ccm->cscmr1, + MXC_CCM_CSCMR1_BCH_CLK_SEL | + MXC_CCM_CSCMR1_GPMI_CLK_SEL); + clrsetbits_le32(&mxc_ccm->cscdr1, + MXC_CCM_CSCDR1_BCH_PODF_MASK | + MXC_CCM_CSCDR1_GPMI_PODF_MASK, + (3 << MXC_CCM_CSCDR1_BCH_PODF_OFFSET) | + (3 << MXC_CCM_CSCDR1_GPMI_PODF_OFFSET)); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} +#endif /* CONFIG_NAND_MXS */ + int board_init(void) { /* Address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+#ifdef CONFIG_NAND_MXS + setup_gpmi_nand(); +#endif return 0; }
diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig new file mode 100644 index 0000000..2af146f --- /dev/null +++ b/configs/imx6ul_isiot_nand_defconfig @@ -0,0 +1,39 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_MX6UL_ISIOT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" +CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="imx6ul-isiot-nand.dtb" +CONFIG_SPL=y +CONFIG_SPL_DMA_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="isiotmx6ul> " +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_BLK is not set +# CONFIG_DM_MMC_OPS is not set +CONFIG_NAND_MXS=y +CONFIG_FEC_MXC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index 5a3e05a..b137848 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -27,6 +27,10 @@ /* Environment in MMC */ # if defined(CONFIG_ENV_IS_IN_MMC) # define CONFIG_ENV_OFFSET 0x100000 +/* Environment in NAND */ +# elif defined(CONFIG_ENV_IS_IN_NAND) +# define CONFIG_ENV_OFFSET 0x400000 +# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE # endif #endif
@@ -128,6 +132,21 @@ # define CONFIG_SYS_FSL_ESDHC_ADDR 0 #endif
+/* NAND */ +#ifdef CONFIG_NAND_MXS +# define CONFIG_SYS_MAX_NAND_DEVICE 1 +# define CONFIG_SYS_NAND_BASE 0x40000000 +# define CONFIG_SYS_NAND_5_ADDR_CYCLE +# define CONFIG_SYS_NAND_ONFI_DETECTION +# define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +# define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 + +/* APBH DMA */ +# define CONFIG_APBH_DMA +# define CONFIG_APBH_DMA_BURST +# define CONFIG_APBH_DMA_BURST8 +#endif + /* Ethernet */ #ifdef CONFIG_FEC_MXC # define CONFIG_FEC_MXC_PHYADDR 0 @@ -140,7 +159,11 @@
/* SPL */ #ifdef CONFIG_SPL -# define CONFIG_SPL_MMC_SUPPORT +# ifdef CONFIG_NAND_MXS +# define CONFIG_SPL_NAND_SUPPORT +# else +# define CONFIG_SPL_MMC_SUPPORT +# endif
# include "imx6_spl.h" # ifdef CONFIG_SPL_BUILD
Add config options for booting Linux from NAND in UBI format.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6ul_isiot_nand_defconfig | 1 + include/configs/imx6ul_isiot.h | 32 +++++++++++++++++++++++++++++++- 2 files changed, 32 insertions(+), 1 deletion(-)
diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 2af146f..d1a9fad 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_PROMPT="isiotmx6ul> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_UBI=y CONFIG_CMD_GPIO=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index b137848..10311d0 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -48,9 +48,12 @@ "mmcdev=0\0" \ "mmcpart=1\0" \ "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "nandroot=ubi0:rootfs rootfstype=ubifs\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \ "root=${mmcroot}\0" \ + "ubiargs=setenv bootargs console=${console},${baudrate} " \ + "ubi.mtd=5 root=${nandroot} ${mtdparts}\0" \ "loadbootscript=" \ "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ "bootscript=echo Running bootscript from mmc ...; " \ @@ -75,8 +78,21 @@ "fi; " \ "else " \ "bootm; " \ - "fi\0" + "fi\0" \ + "nandboot=echo Booting from nand ...; " \ + "if mtdparts; then " \ + "echo Starting nand boot ...; " \ + "else " \ + "mtdparts default; " \ + "fi; " \ + "run ubiargs; " \ + "nand read ${loadaddr} kernel 0x800000; " \ + "nand read ${fdt_addr} dtb 0x100000; " \ + "bootm ${loadaddr} - ${fdt_addr}\0"
+#ifdef CONFIG_NAND_MXS +# define CONFIG_BOOTCOMMAND "run nandboot" +#else # define CONFIG_BOOTCOMMAND \ "if mmc rescan; then " \ "if run loadbootscript; then " \ @@ -91,6 +107,7 @@ "fi; " \ "fi; " \ "fi" +#endif
/* Miscellaneous configurable options */ #define CONFIG_SYS_MEMTEST_START 0x80000000 @@ -141,6 +158,19 @@ # define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE # define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
+/* MTD device */ +# define CONFIG_MTD_DEVICE +# define CONFIG_CMD_MTDPARTS +# define CONFIG_MTD_PARTITIONS +# define MTDIDS_DEFAULT "nand0=gpmi-nand" +# define MTDPARTS_DEFAULT "mtdparts=gpmi-nand:2m(spl),2m(uboot)," \ + "1m(env),8m(kernel),1m(dtb),-(rootfs)" + +/* UBI */ +# define CONFIG_CMD_UBIFS +# define CONFIG_RBTREE +# define CONFIG_LZO + /* APBH DMA */ # define CONFIG_APBH_DMA # define CONFIG_APBH_DMA_BURST
Enable I2C support for Engicam Is.IoT NAND module.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6ul_isiot_nand_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index d1a9fad..6f1a054 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_CMD_I2C=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y @@ -36,5 +37,6 @@ CONFIG_NAND_MXS=y CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_SYS_I2C_MXC=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y
Jagan Teki
Stefano Babic
