[U-Boot] [PATCH] MC : Report extra reserved memory to Linux
For MC, 512 MB DDR is reserved because of MC's alignment requirement. But for MC binaries needing 128MB or 256MB DDR memory, rest of the memory is a waste. So reporting this extra memory to Linux through dtb memory fixup.
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- board/freescale/lx2160a/lx2160a.c | 27 ++++++++++++++++++++++++++- drivers/net/fsl-mc/mc.c | 13 +++++++++++++ include/fsl-mc/fsl_mc.h | 1 + 3 files changed, 40 insertions(+), 1 deletion(-)
diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ad72eed..3cbb7d1 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -532,8 +532,15 @@ void board_quiesce_devices(void) int ft_board_setup(void *blob, bd_t *bd) { int i; + bool mc_memory_bank = false; + +#ifdef CONFIG_FSL_MC_ENET + u64 base[CONFIG_NR_DRAM_BANKS + 1]; + u64 size[CONFIG_NR_DRAM_BANKS + 1]; +#else u64 base[CONFIG_NR_DRAM_BANKS]; u64 size[CONFIG_NR_DRAM_BANKS]; +#endif
ft_cpu_setup(blob, bd);
@@ -556,7 +563,25 @@ int ft_board_setup(void *blob, bd_t *bd) size[2] = gd->arch.resv_ram - base[2]; #endif
- fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS); +#ifdef CONFIG_FSL_MC_ENET + fdt_fixup_mc_ddr(&base[3], &size[3]); + + if (base[3] != 0) { + for (i = 0; i <= CONFIG_NR_DRAM_BANKS; i++) { + if (base[i] == 0 && size[i] == 0) { + base[i] = base[3]; + size[i] = size[3]; + break; + } + } + if (i == CONFIG_NR_DRAM_BANKS) + mc_memory_bank = true; + } +#endif + if (mc_memory_bank) + fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS + 1); + else + fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS);
#ifdef CONFIG_USB fsl_fdt_fixup_dr_usb(blob, bd); diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index dddc9cc..79a38d6 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -285,6 +285,19 @@ static int mc_fixup_dpl_mac_addr(void *blob, int dpmac_id, MC_FIXUP_DPL); }
+void fdt_fixup_mc_ddr(u64* base, u64* size) +{ + u64 mc_size = mc_get_dram_block_size(); + + if (mc_size < MC_DRAM_BLOCK_DEFAULT_SIZE) { + *base = mc_get_dram_addr() + mc_size; + *size = MC_DRAM_BLOCK_DEFAULT_SIZE - mc_size; + } else { + *base = 0; + *size = 0; + } +} + void fdt_fsl_mc_fixup_iommu_map_entry(void *blob) { u32 *prop; diff --git a/include/fsl-mc/fsl_mc.h b/include/fsl-mc/fsl_mc.h index aef40d3..30f961b 100644 --- a/include/fsl-mc/fsl_mc.h +++ b/include/fsl-mc/fsl_mc.h @@ -54,6 +54,7 @@ struct mc_ccsr_registers { void fdt_fsl_mc_fixup_iommu_map_entry(void *blob); int get_mc_boot_status(void); int get_dpl_apply_status(void); +void fdt_fixup_mc_ddr(u64 *base, u64* size); #ifdef CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET int get_aiop_apply_status(void); #endif
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- board/freescale/lx2160a/lx2160a.c | 28 +++++++++++++++++++++++++++- drivers/net/fsl-mc/mc.c | 13 +++++++++++++ include/fsl-mc/fsl_mc.h | 1 + 3 files changed, 41 insertions(+), 1 deletion(-)
diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ad72eed..b763f6d 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -532,8 +532,15 @@ void board_quiesce_devices(void) int ft_board_setup(void *blob, bd_t *bd) { int i; + bool mc_memory_bank = false; + +#ifdef CONFIG_FSL_MC_ENET + u64 base[CONFIG_NR_DRAM_BANKS + 1]; + u64 size[CONFIG_NR_DRAM_BANKS + 1]; +#else u64 base[CONFIG_NR_DRAM_BANKS]; u64 size[CONFIG_NR_DRAM_BANKS]; +#endif
@@ -556,7 +563,26 @@ int ft_board_setup(void *blob, bd_t *bd) size[2] = gd->arch.resv_ram - base[2]; #endif
- fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS); +#ifdef CONFIG_FSL_MC_ENET + fdt_fixup_mc_ddr(&base[3], &size[3]); + + if (base[3] != 0) { + for (i = 0; i <= CONFIG_NR_DRAM_BANKS; i++) { + if (base[i] == 0 && size[i] == 0) { + base[i] = base[3]; + size[i] = size[3]; + break; + } + } + if (i == CONFIG_NR_DRAM_BANKS) + mc_memory_bank = true; + } +#endif + if (mc_memory_bank) + fdt_fixup_memory_banks( + blob, base, size, CONFIG_NR_DRAM_BANKS + 1); + else + fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS);
#ifdef CONFIG_USB fsl_fdt_fixup_dr_usb(blob, bd); diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index dddc9cc..d7a2e8f 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -285,6 +285,19 @@ static int mc_fixup_dpl_mac_addr(void *blob, int dpmac_id, MC_FIXUP_DPL); }
+void fdt_fixup_mc_ddr(u64 *base, u64 *size) +{ + u64 mc_size = mc_get_dram_block_size(); + + if (mc_size < MC_DRAM_BLOCK_DEFAULT_SIZE) { + *base = mc_get_dram_addr() + mc_size; + *size = MC_DRAM_BLOCK_DEFAULT_SIZE - mc_size; + } else { + *base = 0; + *size = 0; + } +} + void fdt_fsl_mc_fixup_iommu_map_entry(void *blob) { u32 *prop; diff --git a/include/fsl-mc/fsl_mc.h b/include/fsl-mc/fsl_mc.h index aef40d3..492a714 100644 --- a/include/fsl-mc/fsl_mc.h +++ b/include/fsl-mc/fsl_mc.h @@ -54,6 +54,7 @@ struct mc_ccsr_registers { void fdt_fsl_mc_fixup_iommu_map_entry(void *blob); int get_mc_boot_status(void); int get_dpl_apply_status(void); +void fdt_fixup_mc_ddr(u64 *base, u64 *size); #ifdef CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET int get_aiop_apply_status(void); #endif
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Reviewed-by: Ashish Kumar Ashish.Kumar@nxp.com --- board/freescale/lx2160a/lx2160a.c | 28 +++++++++++++++++++++++++++- drivers/net/fsl-mc/mc.c | 13 +++++++++++++ include/fsl-mc/fsl_mc.h | 1 + 3 files changed, 41 insertions(+), 1 deletion(-)
-----Original Message----- From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Sent: Wednesday, March 13, 2019 10:41 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Subject: [PATCH v3] MC : Report extra reserved memory to Linux
Update subject as
driver: net: mc: Report extra reserved memory to Linux
This change should be done for other DPAA2 platform also.
- bool mc_memory_bank = false;
- u64 base[CONFIG_NR_DRAM_BANKS + 1];
- u64 size[CONFIG_NR_DRAM_BANKS + 1];
Please don't use magic number. Adding "1"is not providing any info
+#else
- fdt_fixup_mc_ddr(&base[3], &size[3]);
- if (base[3] != 0) {
base[i] = base[3];
size[i] = size[3];
break;
- if (mc_memory_bank)
- else
Why are you doing fixup? Ideally you should mark it reserved.
--pk
Meenakshi Aggarwal
Prabhakar Kushwaha
