[RESEND PATCH 0/2] clk patches from 'Add DM support for omap PWM backlight' series
As suggested by Grygorii Strashko I have removed these patches from the 'Add DM support for omap PWM backlight' series and grouped them into this one. The patches have already been reviewed by Simon Glass.
Dario Binacchi (2): clk: remove a redundant header arch: sandbox: fix typo in clk.h
arch/sandbox/include/asm/clk.h | 26 +++++++++++++------------- include/linux/clk-provider.h | 1 - 2 files changed, 13 insertions(+), 14 deletions(-)
The linux/err.h header file was included twice.
Signed-off-by: Dario Binacchi dariobin@libero.it Reviewed-by: Simon Glass sjg@chromium.org ---
include/linux/clk-provider.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/linux/clk-provider.h b/include/linux/clk-provider.h index c871ea646d..cc9c430512 100644 --- a/include/linux/clk-provider.h +++ b/include/linux/clk-provider.h @@ -12,7 +12,6 @@ #include <linux/bitops.h> #include <linux/err.h> #include <clk-uclass.h> -#include <linux/err.h>
struct udevice;
Fix the 'devivce' typo in arch/sandbox/include/asm/clk.h.
arch/sandbox/include/asm/clk.h | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/sandbox/include/asm/clk.h b/arch/sandbox/include/asm/clk.h index 0294baee27..68a8687f57 100644 --- a/arch/sandbox/include/asm/clk.h +++ b/arch/sandbox/include/asm/clk.h @@ -74,7 +74,7 @@ int sandbox_clk_query_requested(struct udevice *dev, int id); * sandbox_clk_test_get - Ask the sandbox clock test device to request its * clocks. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_get(struct udevice *dev); @@ -83,7 +83,7 @@ int sandbox_clk_test_get(struct udevice *dev); * sandbox_clk_test_devm_get - Ask the sandbox clock test device to request its * clocks using the managed API. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_devm_get(struct udevice *dev); @@ -92,7 +92,7 @@ int sandbox_clk_test_devm_get(struct udevice *dev); * sandbox_clk_test_get_bulk - Ask the sandbox clock test device to request its * clocks with the bulk clk API. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_get_bulk(struct udevice *dev); @@ -100,7 +100,7 @@ int sandbox_clk_test_get_bulk(struct udevice *dev); * sandbox_clk_test_get_rate - Ask the sandbox clock test device to query a * clock's rate. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @id: The test device's clock ID to query. * @return: The rate of the clock. */ @@ -118,7 +118,7 @@ ulong sandbox_clk_test_round_rate(struct udevice *dev, int id, ulong rate); * sandbox_clk_test_set_rate - Ask the sandbox clock test device to set a * clock's rate. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @id: The test device's clock ID to configure. * @return: The new rate of the clock. */ @@ -127,7 +127,7 @@ ulong sandbox_clk_test_set_rate(struct udevice *dev, int id, ulong rate); * sandbox_clk_test_enable - Ask the sandbox clock test device to enable a * clock. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @id: The test device's clock ID to configure. * @return: 0 if OK, or a negative error code. */ @@ -136,7 +136,7 @@ int sandbox_clk_test_enable(struct udevice *dev, int id); * sandbox_clk_test_enable_bulk - Ask the sandbox clock test device to enable * all clocks in it's clock bulk struct. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_enable_bulk(struct udevice *dev); @@ -144,7 +144,7 @@ int sandbox_clk_test_enable_bulk(struct udevice *dev); * sandbox_clk_test_disable - Ask the sandbox clock test device to disable a * clock. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @id: The test device's clock ID to configure. * @return: 0 if OK, or a negative error code. */ @@ -153,7 +153,7 @@ int sandbox_clk_test_disable(struct udevice *dev, int id); * sandbox_clk_test_disable_bulk - Ask the sandbox clock test device to disable * all clocks in it's clock bulk struct. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_disable_bulk(struct udevice *dev); @@ -161,7 +161,7 @@ int sandbox_clk_test_disable_bulk(struct udevice *dev); * sandbox_clk_test_free - Ask the sandbox clock test device to free its * clocks. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_free(struct udevice *dev); @@ -169,7 +169,7 @@ int sandbox_clk_test_free(struct udevice *dev); * sandbox_clk_test_release_bulk - Ask the sandbox clock test device to release * all clocks in it's clock bulk struct. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_release_bulk(struct udevice *dev); @@ -177,7 +177,7 @@ int sandbox_clk_test_release_bulk(struct udevice *dev); * sandbox_clk_test_valid - Ask the sandbox clock test device to check its * clocks are valid. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_valid(struct udevice *dev); @@ -185,7 +185,7 @@ int sandbox_clk_test_valid(struct udevice *dev); * sandbox_clk_test_valid - Ask the sandbox clock test device to check its * clocks are valid. * - * @dev: The sandbox clock test (client) devivce. + * @dev: The sandbox clock test (client) device. * @return: 0 if OK, or a negative error code. */ struct clk *sandbox_clk_test_get_devm_clk(struct udevice *dev, int id);
Applied to u-boot-ti/for-rc branch.
Thanks and regards, Lokesh
Dario Binacchi
Lokesh Vutla
