[U-Boot] [PATCH] ARM: omapl138_lcdk: Remove dead RMII code
The omapl138-lcdk does not need to care about RMII code. It appears to be more legacy code when branched from the da850-evm. This patch removes the #ifdefs and #defines related to the enabling/disabling and checking for that option.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 27a51d6a78..ce146550f9 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -108,12 +108,6 @@ const struct pinmux_config nand_pins[] = {
#endif
-#ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII -#define HAS_RMII 1 -#else -#define HAS_RMII 0 -#endif - const struct pinmux_resource pinmuxes[] = { PINMUX_ITEM(uart_pins), PINMUX_ITEM(i2c_pins), @@ -216,7 +210,7 @@ int board_init(void) #ifdef CONFIG_DRIVER_TI_EMAC if (davinci_configure_pin_mux(emac_pins, ARRAY_SIZE(emac_pins)) != 0) return 1; - davinci_emac_mii_mode_sel(HAS_RMII); + davinci_emac_mii_mode_sel(0); #endif /* CONFIG_DRIVER_TI_EMAC */
/* enable the console UART */ @@ -289,17 +283,6 @@ static void dspwake(void) REG(PSC0_MDCTL + (15 * 4)) |= 0x100; }
-#ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII -/** - * rmii_hw_init - * - */ -int rmii_hw_init(void) -{ - return 0; -} -#endif /* CONFIG_DRIVER_TI_EMAC_USE_RMII */ - int misc_init_r(void) { uint8_t tmp[20], addr[10]; @@ -325,12 +308,6 @@ int misc_init_r(void) } }
-#ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII - /* Select RMII fucntion through the expander */ - if (rmii_hw_init()) - printf("RMII hardware init failed!!!\n"); -#endif - dspwake();
Adam Ford
