[PATCH v3 0/5] Add support for booting EFI FIT images
Currently the only way to run an EFI binary like GRUB2 is via the 'bootefi' command, which cannot be used in a verified boot scenario.
The obvious solution to this limitation is to add support for booting FIT images containing those EFI binaries.
The implementation relies on a new image type - IH_OS_EFI - which can be created by using 'os = "efi"' inside an ITS file:
/ { #address-cells = <1>;
images { efi-grub { description = "GRUB EFI"; data = /incbin/("bootarm.efi"); type = "kernel_noload"; arch = "arm"; os = "efi"; compression = "none"; load = <0x0>; entry = <0x0>; hash-1 { algo = "sha256"; }; }; };
configurations { default = "config-grub"; config-grub { kernel = "efi-grub"; signature-1 { algo = "sha256,rsa2048"; sign-images = "kernel"; }; }; }; };
The bootm command has been extended to handle the IH_OS_EFI images. To enable this feature, a new configuration option has been added: BOOTM_EFI
I tested the solution using the 'qemu_arm' board:
=> load scsi 0:1 ${kernel_addr_r} efi-image.fit => bootm ${kernel_addr_r}#config-grub
Changes in v3: * Rebase patches on Heinrich Schuchardt's patch series v3: efi_loader: prepare for FIT images https://lists.denx.de/pipermail/u-boot/2019-December/393677.html This fixes implicitly the sandbox issue 'phys_to_virt: Cannot map sandbox address' since efi_install_fdt() is now expecting a pointer to addressable memory instead of a physical address. * Get rid of 'EFI/BOOT/' prefix used in ITS samples * Add a python test to verify the implementation in sandbox environment
Changes in v2: * Rebase patches on Heinrich Schuchardt's patch series: efi_loader: prepare for FIT images https://lists.denx.de/pipermail/u-boot/2019-December/393192.html * Add sample configuration: doc/uImage.FIT/uefi.its * Update uefi documentation: doc/uefi/uefi.rst
Cristian Ciocaltea (5): image: Add IH_OS_EFI for EFI chain-load boot bootm: Add a bootm command for type IH_OS_EFI doc: Add sample uefi.its image description file doc: uefi.rst: Document launching UEFI binaries from FIT images test/py: Create a test for launching UEFI binaries from FIT images
cmd/Kconfig | 7 + common/bootm_os.c | 56 ++++++++ common/image-fit.c | 3 +- common/image.c | 1 + doc/uImage.FIT/uefi.its | 67 ++++++++++ doc/uefi/uefi.rst | 34 +++++ include/image.h | 1 + test/py/tests/test_efi_fit.py | 233 ++++++++++++++++++++++++++++++++++ 8 files changed, 401 insertions(+), 1 deletion(-) create mode 100644 doc/uImage.FIT/uefi.its create mode 100644 test/py/tests/test_efi_fit.py
Add a new OS type to be used for chain-loading an EFI compatible firmware or boot loader like GRUB2, possibly in a verified boot scenario.
Bellow is sample ITS file that generates a FIT image supporting secure boot. Please note the presence of 'os = "efi";' line, which identifies the currently introduced OS type:
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com --- common/image-fit.c | 3 ++- common/image.c | 1 + include/image.h | 1 + 3 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 5c63c769de..19e313bf41 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1925,7 +1925,8 @@ int fit_image_load(bootm_headers_t *images, ulong addr, image_type == IH_TYPE_FPGA || fit_image_check_os(fit, noffset, IH_OS_LINUX) || fit_image_check_os(fit, noffset, IH_OS_U_BOOT) || - fit_image_check_os(fit, noffset, IH_OS_OPENRTOS); + fit_image_check_os(fit, noffset, IH_OS_OPENRTOS) || + fit_image_check_os(fit, noffset, IH_OS_EFI);
/* * If either of the checks fail, we should report an error, but diff --git a/common/image.c b/common/image.c index f17fa40c49..2e0e2b0e7f 100644 --- a/common/image.c +++ b/common/image.c @@ -134,6 +134,7 @@ static const table_entry_t uimage_os[] = { { IH_OS_OPENRTOS, "openrtos", "OpenRTOS", }, #endif { IH_OS_OPENSBI, "opensbi", "RISC-V OpenSBI", }, + { IH_OS_EFI, "efi", "EFI Firmware" },
{ -1, "", "", }, }; diff --git a/include/image.h b/include/image.h index f4d2aaf53e..4a280b78e7 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ enum { IH_OS_ARM_TRUSTED_FIRMWARE, /* ARM Trusted Firmware */ IH_OS_TEE, /* Trusted Execution Environment */ IH_OS_OPENSBI, /* RISC-V OpenSBI */ + IH_OS_EFI, /* EFI Firmware (e.g. GRUB2) */
IH_OS_COUNT, };
images { efi-grub { description = "GRUB EFI"; data = /incbin/("bootarm.efi"); type = "kernel_noload"; arch = "arm"; os = "efi"; compression = "none"; load = <0x0>; entry = <0x0>; hash-1 { algo = "sha256"; }; }; }; configurations { default = "config-grub"; config-grub { kernel = "efi-grub"; signature-1 { algo = "sha256,rsa2048"; sign-images = "kernel"; }; }; };
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Add support for booting EFI binaries contained in FIT images. A typical usage scenario is chain-loading GRUB2 in a verified boot environment.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com --- cmd/Kconfig | 7 ++++++ common/bootm_os.c | 56 +++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index cf982ff65e..39fa87082d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -263,6 +263,13 @@ config CMD_BOOTI help Boot an AArch64 Linux Kernel image from memory.
+config BOOTM_EFI + bool "Support booting EFI OS images" + depends on CMD_BOOTEFI + default y + help + Support booting EFI images via the bootm command. + config BOOTM_LINUX bool "Support booting Linux OS images" depends on CMD_BOOTM || CMD_BOOTZ || CMD_BOOTI diff --git a/common/bootm_os.c b/common/bootm_os.c index 6fb7d658da..96792430da 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -6,10 +6,12 @@
#include <common.h> #include <bootm.h> +#include <efi_loader.h> #include <env.h> #include <fdt_support.h> #include <linux/libfdt.h> #include <malloc.h> +#include <mapmem.h> #include <vxworks.h> #include <tee/optee.h>
@@ -462,6 +464,57 @@ static int do_bootm_tee(int flag, int argc, char * const argv[], } #endif
+#ifdef CONFIG_BOOTM_EFI +static int do_bootm_efi(int flag, int argc, char * const argv[], + bootm_headers_t *images) +{ + int ret; + efi_status_t efi_ret; + void *image_buf; + + if (flag != BOOTM_STATE_OS_GO) + return 0; + + /* Locate FDT, if provided */ + ret = bootm_find_images(flag, argc, argv); + if (ret) + return ret; + + /* Initialize EFI drivers */ + efi_ret = efi_init_obj_list(); + if (efi_ret != EFI_SUCCESS) { + printf("## Failed to initialize UEFI sub-system: r = %lu\n", + efi_ret & ~EFI_ERROR_MASK); + return 1; + } + + /* Install device tree */ + efi_ret = efi_install_fdt(images->ft_len + ? images->ft_addr : EFI_FDT_USE_INTERNAL); + if (efi_ret != EFI_SUCCESS) { + printf("## Failed to install device tree: r = %lu\n", + efi_ret & ~EFI_ERROR_MASK); + return 1; + } + + /* Run EFI image */ + printf("## Transferring control to EFI (at address %08lx) ...\n", + images->ep); + bootstage_mark(BOOTSTAGE_ID_RUN_OS); + + image_buf = map_sysmem(images->ep, images->os.image_len); + + efi_ret = efi_run_image(image_buf, images->os.image_len); + if (efi_ret != EFI_SUCCESS) { + printf("## Failed to run EFI image: r = %lu\n", + efi_ret & ~EFI_ERROR_MASK); + return 1; + } + + return 0; +} +#endif + static boot_os_fn *boot_os[] = { [IH_OS_U_BOOT] = do_bootm_standalone, #ifdef CONFIG_BOOTM_LINUX @@ -498,6 +551,9 @@ static boot_os_fn *boot_os[] = { #ifdef CONFIG_BOOTM_OPTEE [IH_OS_TEE] = do_bootm_tee, #endif +#ifdef CONFIG_BOOTM_EFI + [IH_OS_EFI] = do_bootm_efi, +#endif };
/* Allow for arch specific config before we boot */
You missed the current changes in common/bootm_os.c. I will rebase the patch.
Right, sorry. I have already rebased the patch and I will resubmit it as soon as I finalize the changes on pytest.
Thanks!
This patch adds an example FIT image description file demonstrating the usage of bootm command to securely launch UEFI binaries.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/uImage.FIT/uefi.its | 67 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 doc/uImage.FIT/uefi.its
diff --git a/doc/uImage.FIT/uefi.its b/doc/uImage.FIT/uefi.its new file mode 100644 index 0000000000..378ca4ed8d --- /dev/null +++ b/doc/uImage.FIT/uefi.its @@ -0,0 +1,67 @@ +/* + * Example FIT image description file demonstrating the usage of the + * bootm command to launch UEFI binaries. + * + * Two boot configurations are available to enable booting GRUB2 on QEMU, + * the former uses a FDT blob contained in the FIT image, while the later + * relies on the FDT provided by the board emulator. + */ + +/dts-v1/; + +/ { + description = "GRUB2 EFI and QEMU FDT blob"; + #address-cells = <1>; + + images { + efi-grub { + description = "GRUB EFI Firmware"; + data = /incbin/("bootarm.efi"); + type = "kernel_noload"; + arch = "arm"; + os = "efi"; + compression = "none"; + load = <0x0>; + entry = <0x0>; + hash-1 { + algo = "sha256"; + }; + }; + + fdt-qemu { + description = "QEMU DTB"; + data = /incbin/("qemu-arm.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + hash-1 { + algo = "sha256"; + }; + }; + }; + + configurations { + default = "config-grub-fdt"; + + config-grub-fdt { + description = "GRUB EFI Boot w/ FDT"; + kernel = "efi-grub"; + fdt = "fdt-qemu"; + signature-1 { + algo = "sha256,rsa2048"; + key-name-hint = "dev"; + sign-images = "kernel", "fdt"; + }; + }; + + config-grub-nofdt { + description = "GRUB EFI Boot w/o FDT"; + kernel = "efi-grub"; + signature-1 { + algo = "sha256,rsa2048"; + key-name-hint = "dev"; + sign-images = "kernel"; + }; + }; + }; +};
This patch adds a new section "Launching a UEFI binary from a FIT image" documenting the usage of the CONFIG_BOOTM_EFI extension to bootm command that offers a verified boot alternative for UEFI binaries such as GRUB2.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/uefi/uefi.rst | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/doc/uefi/uefi.rst b/doc/uefi/uefi.rst index db942df694..a8fd886d6b 100644 --- a/doc/uefi/uefi.rst +++ b/doc/uefi/uefi.rst @@ -63,6 +63,40 @@ The environment variable 'bootargs' is passed as load options in the UEFI system table. The Linux kernel EFI stub uses the load options as command line arguments.
+Launching a UEFI binary from a FIT image +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +A signed FIT image can be used to securely boot a UEFI image via the +bootm command. This feature is available if U-Boot is configured with:: + + CONFIG_BOOTM_EFI=y + +A sample configuration is provided as file doc/uImage.FIT/uefi.its. + +Below you find the output of an example session starting GRUB:: + + => load mmc 0:1 ${kernel_addr_r} image.fit + 4620426 bytes read in 83 ms (53.1 MiB/s) + => bootm ${kernel_addr_r}#config-grub-nofdt + ## Loading kernel from FIT Image at 40400000 ... + Using 'config-grub-nofdt' configuration + Verifying Hash Integrity ... sha256,rsa2048:dev+ OK + Trying 'efi-grub' kernel subimage + Description: GRUB EFI Firmware + Created: 2019-11-20 8:18:16 UTC + Type: Kernel Image (no loading done) + Compression: uncompressed + Data Start: 0x404000d0 + Data Size: 450560 Bytes = 440 KiB + Hash algo: sha256 + Hash value: 4dbee00021112df618f58b3f7cf5e1595533d543094064b9ce991e8b054a9eec + Verifying Hash Integrity ... sha256+ OK + XIP Kernel Image (no loading done) + ## Transferring control to EFI (at address 404000d0) ... + Welcome to GRUB! + +See doc/uImage.FIT/howto.txt for an introduction to FIT images. + Executing the boot manager ~~~~~~~~~~~~~~~~~~~~~~~~~~
This test verifies the implementation of the 'bootm' extension that handles UEFI binaries inside FIT images (enabled via CONFIG_BOOTM_EFI).
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com --- test/py/tests/test_efi_fit.py | 233 ++++++++++++++++++++++++++++++++++ 1 file changed, 233 insertions(+) create mode 100644 test/py/tests/test_efi_fit.py
diff --git a/test/py/tests/test_efi_fit.py b/test/py/tests/test_efi_fit.py new file mode 100644 index 0000000000..52b415b198 --- /dev/null +++ b/test/py/tests/test_efi_fit.py @@ -0,0 +1,233 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright (c) 2019, Cristian Ciocaltea cristian.ciocaltea@gmail.com + +# Test launching UEFI binaries from FIT images. + +import os +import pytest +import u_boot_utils as util + +# Define the parametrized ITS data to be used for FIT image generation. +its_data = ''' +/dts-v1/; + +/ { + description = "EFI image with FDT blob"; + #address-cells = <1>; + + images { + efi { + description = "Sandbox EFI"; + data = /incbin/("%(efi-bin)s"); + type = "%(kernel-type)s"; + arch = "sandbox"; + os = "efi"; + compression = "%(efi-comp)s"; + load = <0x0>; + entry = <0x0>; + }; + fdt { + description = "Sandbox FDT"; + data = /incbin/("%(fdt-bin)s"); + type = "flat_dt"; + arch = "sandbox"; + compression = "%(fdt-comp)s"; + }; + }; + + configurations { + default = "config-efi-fdt"; + config-efi-fdt { + description = "EFI FIT w/ FDT"; + kernel = "efi"; + fdt = "fdt"; + }; + config-efi-nofdt { + description = "EFI FIT w/o FDT"; + kernel = "efi"; + }; + }; +}; +''' + +# Define the parametrized FDT data. +fdt_data = ''' +/dts-v1/; + +/ { + model = "Sandbox %(fdt_type) EFI FIT Boot Test "; + compatible = "sandbox"; + + reset@0 { + compatible = "sandbox,reset"; + }; +}; +''' + +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('bootm_efi') +@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.requiredtool('dtc') +def test_efi_fit(u_boot_console): + """Test handling of UEFI binaries inside FIT images. + + The tests are trying to launch U-Boot's helloworld.efi embedded into + FIT images, in uncompressed or gzip compressed format. + + Additionally, a sample FDT blob is created and embedded into the above + mentioned FIT images, in uncompressed or gzip compressed format. + + The following test cases are currently defined and enabled: + - Launch uncompressed FIT EFI & FIT FDT + - Launch compressed FIT EFI & FIT FDT + - Launch uncompressed FIT EFI & internal FDT + - Launch compressed FIT EFI & internal FDT + """ + + def make_fpath(fname): + """Compute the path of a given (temporary) file. + + Args: + fname: The name of a file within U-Boot build dir. + Return: + The computed file path. + """ + return os.path.join(u_boot_console.config.build_dir, fname) + + def make_efi(fname, comp): + """Create an UEFI binary. + + This simply copies lib/efi_loader/helloworld.efi into U-Boot + build dir and, optionally, compresses the file using gzip. + + Args: + fname: The target file name within U-Boot build dir. + comp: Flag to enable gzip compression. + Return: + The path of the created file. + """ + bin_path = make_fpath(fname) + os.system('cp %s %s' % (make_fpath('lib/efi_loader/helloworld.efi'), bin_path)) + if comp: + util.run_and_log(u_boot_console, ['gzip', '-f', bin_path]) + bin_path += '.gz' + return bin_path + + def make_dtb(fdt_type, comp): + """Create a sample DTB file. + + Creates a DTS file and compiles it to a DTB. + + Args: + fdt_type: The type of the FDT, i.e. internal, user. + comp: Flag to enable gzip compression. + Returns: + The path of the created file. + """ + dts = make_fpath('test-efi-fit-sandbox-%s.dts' % fdt_type) + dtb = make_fpath('test-efi-fit-sandbox-%s.dtb' % fdt_type) + with open(dts, 'w') as fd: + fd.write(fdt_data) + util.run_and_log(u_boot_console, ['dtc', dts, '-O', 'dtb', '-o', dtb]) + if comp: + util.run_and_log(u_boot_console, ['gzip', '-f', dtb]) + dtb += '.gz' + return dtb + + def make_fit(efi_comp, fdt_comp): + """Create a sample FIT image. + + Runs 'mkimage' to create a FIT image within U-Boot build dir. + Args: + efi_comp: Enable gzip compression for the EFI binary. + fdt_comp: Enable gzip compression for the FDT blob. + Return: + The path of the created file. + """ + # Generate resources referenced by ITS. + its_params = { + 'efi-bin' : os.path.basename( + make_efi('test-efi-fit-sandbox.efi', efi_comp)), + 'kernel-type' : 'kernel' if efi_comp else 'kernel_noload', + 'efi-comp' : 'gzip' if efi_comp else 'none', + 'fdt-bin' : os.path.basename(make_dtb('user', fdt_comp)), + 'fdt-comp' : 'gzip' if fdt_comp else 'none', + } + + # Generate a test ITS file. + its_path = make_fpath('test-efi-fit.its') + with open(its_path, 'w') as fd: + fd.write(its_data % its_params) + + # Build the test ITS. + fit_path = make_fpath('test-efi-fit.fit') + util.run_and_log(u_boot_console, + [make_fpath('tools/mkimage'), '-f', its_path, fit_path]) + return fit_path + + def file_size(fpath): + """Get the size of a file. + + Args: + fname: Path of the file to check. + Return: + The size of file in bytes. + """ + return os.stat(fpath).st_size + + def launch_efi(enable_fdt, enable_comp): + """Launch a UEFI binary from a FIT image. + + Creates a test FIT image containing a fake UEFI binary and tries + to run it via the 'bootm' command in the U-Boot console. + + Args: + enable_fdt: Flag to enable using the FDT blob inside FIT image. + enable_comp: Flag to enable gzip compression on EFI and FDT content. + """ + # Create test FIT image. + fit_img_path = make_fit(enable_comp, enable_comp) + + # Select boot configuration. + fit_config = 'config-efi-fdt' if enable_fdt else 'config-efi-nofdt' + + # Run U-Boot commands. + with u_boot_console.log.section('Boot EFI FIT %s' % fit_config): + output = u_boot_console.run_command( + 'host load hostfs - $kernel_addr_r %s' % fit_img_path) + + expected_text = '%d bytes read' % file_size(fit_img_path) + assert(expected_text in output) + + output = u_boot_console.run_command( + 'bootm ${kernel_addr_r}#%s' % fit_config) + + if enable_fdt: + expected_text = 'Booting using the fdt blob' + assert(expected_text in output) + + expected_text = 'Hello, world' + assert expected_text in output + expected_text = '## Application terminated, r = 0' + assert expected_text in output + + try: + # Use our own device tree file, will be restored afterwards. + control_dtb = make_dtb('internal', False) + old_dtb = u_boot_console.config.dtb + u_boot_console.config.dtb = control_dtb + + # Run tests + # - fdt ON, gzip OFF + launch_efi(True, False) + # - fdt ON, gzip ON + launch_efi(True, True) + # - fdt OFF, gzip OFF + launch_efi(False, False) + # - fdt OFF, gzip ON + launch_efi(False, True) + + finally: + # Go back to the original U-Boot with the correct dtb. + u_boot_console.config.dtb = old_dtb + u_boot_console.restart_uboot()
- description = "EFI image with FDT blob";
- #address-cells = <1>;
- images {
efi {
arch = "sandbox";
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
arch = "sandbox";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- model = "Sandbox %(fdt_type) EFI FIT Boot Test ";
- compatible = "sandbox";
- reset@0 {
This produces a warning:
+dtc ./test-efi-fit-sandbox-internal.dts -O dtb -o ./test-efi-fit-sandbox-internal.dtb ./test-efi-fit-sandbox-internal.dts:8.13-10.7: Warning (unit_address_vs_reg): /reset@0: node has a unit name, but no reg property
This test looks ok in principal. But why should we restrict it to the sandbox?
Best regards
Heinrich
- """Test handling of UEFI binaries inside FIT images.
- The tests are trying to launch U-Boot's helloworld.efi embedded into
- FIT images, in uncompressed or gzip compressed format.
- Additionally, a sample FDT blob is created and embedded into the above
- mentioned FIT images, in uncompressed or gzip compressed format.
- The following test cases are currently defined and enabled:
- def make_fpath(fname):
Args:
Return:
- def make_efi(fname, comp):
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
- def make_dtb(fdt_type, comp):
Args:
Returns:
fd.write(fdt_data)
if comp:
dtb += '.gz'
return dtb
- def make_fit(efi_comp, fdt_comp):
Args:
Return:
its_params = {
return fit_path
- def file_size(fpath):
Args:
Return:
- def launch_efi(enable_fdt, enable_comp):
Args:
if enable_fdt:
- try:
# Run tests
# - fdt ON, gzip ON
- finally:
- images {
efi {
arch = "sandbox";
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
arch = "sandbox";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- reset@0 {
A similar sample is also used by test_fit.py and test_vboot.py, which expose the same warning, that's why I initially ignored it. If acceptable, I can suppress it via '-W no-unit_address_vs_reg'.
Let me see how this should work on real hardware, I'm going to test on qemu for the moment.
Best regards
Heinrich
Args:
Return:
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
Args:
Returns:
fd.write(fdt_data)
if comp:
dtb += '.gz'
return dtb
Args:
Return:
its_params = {
return fit_path
Args:
Return:
Args:
if enable_fdt:
- try:
# Run tests
# - fdt ON, gzip ON
- finally:
- images {
efi {
arch = "sandbox";
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
arch = "sandbox";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- reset@0 {
reset@0 includes a unit-address. So a reg property is expected. How about:
/dts-v1/;
/ { #address-cells = <1>; #size-cells = <0>;
model = "Sandbox %(fdt_type) EFI FIT Boot Test "; compatible = "sandbox";
reset@0 { compatible = "sandbox,reset"; reg = <0>; }; };
Best regards
Heinrich
Best regards
Heinrich
Args:
Return:
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
Args:
Returns:
fd.write(fdt_data)
if comp:
dtb += '.gz'
return dtb
Args:
Return:
its_params = {
return fit_path
Args:
Return:
Args:
if enable_fdt:
- try:
# Run tests
# - fdt ON, gzip ON
- finally:
- images {
efi {
arch = "sandbox";
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
arch = "sandbox";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- reset@0 {
/dts-v1/;
Yes, that's a much better approach. It works fine, thanks!
Best regards
Heinrich
Best regards
Heinrich
Args:
Return:
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
Args:
Returns:
fd.write(fdt_data)
if comp:
dtb += '.gz'
return dtb
Args:
Return:
its_params = {
return fit_path
Args:
Return:
Args:
if enable_fdt:
- try:
# Run tests
# - fdt ON, gzip ON
- finally:
Device trees cannot be used in conjunction with ACPI tables when booting via UEFI. Currently this concerns only x86 and x86_64 but Phytec is working on an arm64 board which shall provide an ACPI table. So you probably want to check CONFIG_GENERATE_ACPI_TABLE instead of the board type, e.g.
@pytest.mark.notbuildconfigspec('generate_acpi_table')
Best regards
Heinrich
Thanks for the hint!
For some strange reason, whatever I put in the 'notbuildconfigspec' marker causes the test to be skipped:
[-] Section: test_efi_fit TIME: NOW: 2019/12/18 17:33:14.976576 TIME: SINCE-PREV: 0:00:00.192132 TIME: SINCE-START: 0:00:00.192132 SKIPPED: ('[...]/uboot/test/py/conftest.py', 463, 'Skipped: .config feature "bootm_efi" enabled')
I don't really understand the connection to 'bootm_efi'. If I comment out the 'bootm_efi' marker, the reported status becomes:
SKIPPED: ('[].../uboot/test/py/conftest.py', 463, 'Skipped: .config feature "cmd_bootefi_hello_compile" enabled')
So it seems 'notbuildconfigspec' gets its parameter from the first active 'buildconfigspec' statement. This is my current test:
#@pytest.mark.buildconfigspec('bootm_efi') @pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') #@pytest.mark.notbuildconfigspec('generate_acpi_table') @pytest.mark.notbuildconfigspec('fake_item') @pytest.mark.requiredtool('dtc')
Best regards
Heinrich
Cristian Ciocaltea
