[U-Boot] [PATCH v2] imx: support i.MX8QM ROM 7720 a1 board
Hello list,
this is the first version of this patch that boots properly the linux kernel on my i.MX8QM Board. It's still based on v2019.07. Please skip v1 because its not working.
Best Regards,
Oliver
Oliver Graute (1): imx: support i.MX8QM ROM 7720 a1 board
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8qm-rom7720-a1.dts | 373 ++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 7 + arch/arm/mach-imx/mkimage_fit_atf.sh | 3 + board/freescale/imx8qm_rom7720_a1/Kconfig | 14 + board/freescale/imx8qm_rom7720_a1/MAINTAINERS | 6 + board/freescale/imx8qm_rom7720_a1/Makefile | 11 + board/freescale/imx8qm_rom7720_a1/README | 70 ++++ .../imx8qm_rom7720_a1/imx8qm_rom7720_a1.c | 181 +++++++++ .../freescale/imx8qm_rom7720_a1/imximage.cfg | 21 + board/freescale/imx8qm_rom7720_a1/spl.c | 228 +++++++++++ configs/imx8qm_rom7720_a1_4G_defconfig | 82 ++++ include/configs/imx8qm_rom7720.h | 189 +++++++++ 13 files changed, 1186 insertions(+) create mode 100644 arch/arm/dts/imx8qm-rom7720-a1.dts create mode 100644 board/freescale/imx8qm_rom7720_a1/Kconfig create mode 100644 board/freescale/imx8qm_rom7720_a1/MAINTAINERS create mode 100644 board/freescale/imx8qm_rom7720_a1/Makefile create mode 100644 board/freescale/imx8qm_rom7720_a1/README create mode 100644 board/freescale/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c create mode 100644 board/freescale/imx8qm_rom7720_a1/imximage.cfg create mode 100644 board/freescale/imx8qm_rom7720_a1/spl.c create mode 100644 configs/imx8qm_rom7720_a1_4G_defconfig create mode 100644 include/configs/imx8qm_rom7720.h
Add i.MX8QM ROM 7720a1 board support
Boot log as below: U-Boot 2019.07-00001-g6c912ea4d4 (Aug 28 2019 - 13:01:45 +0200)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
Model: Advantech iMX8QM Qseven series Board: ROM-7720-A1 4GB Build: SCFW 65afe5f6 Boot: SD2 DRAM: 3.9 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 Net: eth0: ethernet@5b040000Could not get PHY for FEC1: addr 1 , eth-1: ethernet@5b050000 Hit any key to stop autoboot: 0
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com ---
These changes are based on this vendor tree: https://github.com/ADVANTECH-Corp/uboot-imx6.git
I adapted the files and compared them with code from similar imx8qm-mek board
Changes for v2: - cleanup of u-boot environment - set power mode SC_R_DC_0 for full boot of linux kernel - enabled usdhc2 - enabled FEC defines - updated README.md - enabled readwrite for nfs rootfs - removed include of environment header
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 20dbc2ff84..54c1f40085 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -613,6 +613,7 @@ dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ fsl-imx8qm-mek.dtb \ + imx8qm-rom7720-a1.dtb \ fsl-imx8qxp-colibri.dtb \ fsl-imx8qxp-mek.dtb
diff --git a/arch/arm/dts/imx8qm-rom7720-a1.dts b/arch/arm/dts/imx8qm-rom7720-a1.dts new file mode 100644 index 0000000000..5f9ac955ed --- /dev/null +++ b/arch/arm/dts/imx8qm-rom7720-a1.dts @@ -0,0 +1,373 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2017 NXP + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x80000000 0x00020000; + +#include "fsl-imx8qm.dtsi" + +/ { + model = "Advantech iMX8QM Qseven series"; + compatible = "fsl,imx8qm-mek", "fsl,imx8qm"; + + chosen { + bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x5a060000,115200"; + stdout-path = &lpuart0; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + user { + label = "heartbeat"; + gpios = <&gpio2 15 0>; + default-state = "on"; + linux,default-trigger = "heartbeat"; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usb_otg1_vbus: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 3 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usdhc2_vmmc: usdhc2_vmmc { + compatible = "regulator-fixed"; + regulator-name = "sw-3p3-sd1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_1>; + + imx8qm-mek { + pinctrl_hog_1: hoggrp-1 { + fsl,pins = < + SC_P_USB_SS3_TC0_LSIO_GPIO4_IO03 0x06000048 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB_PAD 0x000014a0 + SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000048 + SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000048 + SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x00000060 + SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC 0x00000060 + SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x00000060 + SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x00000060 + SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2 0x00000060 + SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3 0x00000060 + SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC 0x00000060 + SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x00000060 + SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x00000060 + SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x00000060 + SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2 0x00000060 + SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3 0x00000060 + >; + }; + + pinctrl_fec2: fec2grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETA_PAD 0x000014a0 + SC_P_ENET1_RGMII_TX_CTL_CONN_ENET1_RGMII_TX_CTL 0x00000060 + SC_P_ENET1_RGMII_TXC_CONN_ENET1_RGMII_TXC 0x00000060 + SC_P_ENET1_RGMII_TXD0_CONN_ENET1_RGMII_TXD0 0x00000060 + SC_P_ENET1_RGMII_TXD1_CONN_ENET1_RGMII_TXD1 0x00000060 + SC_P_ENET1_RGMII_TXD2_CONN_ENET1_RGMII_TXD2 0x00000060 + SC_P_ENET1_RGMII_TXD3_CONN_ENET1_RGMII_TXD3 0x00000060 + SC_P_ENET1_RGMII_RXC_CONN_ENET1_RGMII_RXC 0x00000060 + SC_P_ENET1_RGMII_RX_CTL_CONN_ENET1_RGMII_RX_CTL 0x00000060 + SC_P_ENET1_RGMII_RXD0_CONN_ENET1_RGMII_RXD0 0x00000060 + SC_P_ENET1_RGMII_RXD1_CONN_ENET1_RGMII_RXD1 0x00000060 + SC_P_ENET1_RGMII_RXD2_CONN_ENET1_RGMII_RXD2 0x00000060 + SC_P_ENET1_RGMII_RXD3_CONN_ENET1_RGMII_RXD3 0x00000060 + >; + }; + + pinctrl_lpuart0: lpuart0grp { + fsl,pins = < + SC_P_UART0_RX_DMA_UART0_RX 0x06000020 + SC_P_UART0_TX_DMA_UART0_TX 0x06000020 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x06000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x06000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x06000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + SC_P_USDHC1_DATA6_LSIO_GPIO5_IO21 0x00000021 + SC_P_USDHC1_DATA7_LSIO_GPIO5_IO22 0x00000021 + SC_P_USDHC1_RESET_B_LSIO_GPIO4_IO07 0x00000021 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000041 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000021 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000021 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000021 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000021 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000021 + /* WP */ + SC_P_USDHC2_WP_LSIO_GPIO4_IO11 0x00000021 + /* CD */ + SC_P_USDHC2_CD_B_LSIO_GPIO4_IO12 0x00000021 + >; + }; + + pinctrl_lpi2c1: lpi2c1grp { + fsl,pins = < + SC_P_GPT0_CLK_DMA_I2C1_SCL 0x06000020 + SC_P_GPT0_CAPTURE_DMA_I2C1_SDA 0x06000020 + /* + * Change the default alt function from SCL/SDA to others, + * to avoid select input conflict with GPT0 + */ + SC_P_USB_SS3_TC0_LSIO_GPIO4_IO03 0x0700004c + SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04 0x0700004c + SC_P_USB_SS3_TC2_LSIO_GPIO4_IO05 0x0700004c + SC_P_USB_SS3_TC3_LSIO_GPIO4_IO06 0x0700004c + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + SC_P_SPDIF0_TX_LSIO_GPIO2_IO15 0x00000021 + >; + }; + }; +}; + +&gpio2 { + status = "okay"; +}; + +&gpio4 { + status = "okay"; +}; + +&gpio5 { + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + bus-width = <4>; + cd-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio4 11 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii"; + phy-handle = <ðphy0>; + fsl,ar8031-phy-fixup; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + + ethphy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; + }; +}; + +&fec2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec2>; + phy-mode = "rgmii"; + phy-handle = <ðphy1>; + fsl,ar8031-phy-fixup; + fsl,magic-packet; + status = "okay"; +}; + +&i2c1 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpi2c1>; + status = "okay"; + + pca9557_a: gpio@18 { + compatible = "nxp,pca9557"; + reg = <0x18>; + gpio-controller; + #gpio-cells = <2>; + }; + + pca9557_b: gpio@19 { + compatible = "nxp,pca9557"; + reg = <0x19>; + gpio-controller; + #gpio-cells = <2>; + }; + + pca9557_c: gpio@1b { + compatible = "nxp,pca9557"; + reg = <0x1b>; + gpio-controller; + #gpio-cells = <2>; + }; + + pca9557_d: gpio@1f { + compatible = "nxp,pca9557"; + reg = <0x1f>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&lpuart0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart0>; + status = "okay"; +}; + +&lpuart1 { + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index bbe323d5ca..09b985884f 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -42,6 +42,12 @@ config TARGET_IMX8QM_MEK select BOARD_LATE_INIT select IMX8QM
+config TARGET_IMX8QM_ROM7720_A1 + bool "Support i.MX8QM ROM-7720-A1" + select BOARD_LATE_INIT + select SUPPORT_SPL + select IMX8QM + config TARGET_IMX8QXP_MEK bool "Support i.MX8QXP MEK board" select BOARD_LATE_INIT @@ -50,6 +56,7 @@ config TARGET_IMX8QXP_MEK endchoice
source "board/freescale/imx8qm_mek/Kconfig" +source "board/freescale/imx8qm_rom7720_a1/Kconfig" source "board/freescale/imx8qxp_mek/Kconfig" source "board/toradex/apalis-imx8/Kconfig" source "board/toradex/colibri-imx8x/Kconfig" diff --git a/arch/arm/mach-imx/mkimage_fit_atf.sh b/arch/arm/mach-imx/mkimage_fit_atf.sh index 38c9858e84..75ac8e7ed2 100755 --- a/arch/arm/mach-imx/mkimage_fit_atf.sh +++ b/arch/arm/mach-imx/mkimage_fit_atf.sh @@ -19,6 +19,9 @@ else ls -lct $BL31 | awk '{print $5}' >&2 fi
+echo "ATF_LOAD_ADDR=$ATF_LOAD_ADDR" >&2 +echo "BL33_LOAD_ADDR=$BL33_LOAD_ADDR" >&2 + BL32="tee.bin"
if [ ! -f $BL32 ]; then diff --git a/board/freescale/imx8qm_rom7720_a1/Kconfig b/board/freescale/imx8qm_rom7720_a1/Kconfig new file mode 100644 index 0000000000..7041567d44 --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8QM_ROM7720_A1 + +config SYS_BOARD + default "imx8qm_rom7720_a1" + +config SYS_VENDOR + default "freescale" + +config SYS_CONFIG_NAME + default "imx8qm_rom7720" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/freescale/imx8qm_rom7720_a1/MAINTAINERS b/board/freescale/imx8qm_rom7720_a1/MAINTAINERS new file mode 100644 index 0000000000..c5553d5ad9 --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8QM ROM 7720 a1 BOARD +M: Oliver Graute oliver.graute@kococonnector.com +S: Maintained +F: board/freescale/imx8qm_rom7720_a1/ +F: include/configs/imx8qm_rom7720.h +F: configs/imx8qm_rom7720_a1_4G_defconfig diff --git a/board/freescale/imx8qm_rom7720_a1/Makefile b/board/freescale/imx8qm_rom7720_a1/Makefile new file mode 100644 index 0000000000..51c5de251c --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/Makefile @@ -0,0 +1,11 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8qm_rom7720_a1.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif diff --git a/board/freescale/imx8qm_rom7720_a1/README b/board/freescale/imx8qm_rom7720_a1/README new file mode 100644 index 0000000000..eabca8b07a --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/README @@ -0,0 +1,70 @@ +U-Boot for the NXP i.MX8QM ROM 7720a1 board + +Quick Start +=========== + +- Build the ARM Trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Get imx-mkimage +- Build U-Boot +- Build imx-mkimage +- Flash the binary into the SD card +- Boot + +Get and Build the ARM Trusted firmware +====================================== + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ git checkout origin/imx_4.14.78_1.0.0_ga -b imx_4.14.78_1.0.0_ga +$ make PLAT=imx8qm bl31 + +Get scfw_tcm.bin and ahab-container.img +============================== + +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-sc-firmware-1.1.bin +$ chmod +x imx-sc-firmware-1.1.bin +$ ./imx-sc-firmware-1.1.bin +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin +$ chmod +x firmware-imx-8.0.bin +$ ./firmware-imx-8.0.bin + +Build U-Boot +============ + +$ export ATF_LOAD_ADDR=0x80000000 +$ export BL33_LOAD_ADDR=0x80020000 +$ make imx8qm_rom7720_a1_4G_defconfig +$ make flash.bin +$ dd if=u-boot.itb of=flash.bin bs=512 seek=854 + +Get imx-mkimage +============================== + +$ git clone https://source.codeaurora.org/external/imx/imx-mkimage/ +$ cd imx-mkimage +$ git checkout rel_imx_4.14.78_1.0.0_ga -b rel_imx_4.14.78_1.0.0_ga +$ cd iMX8QM/ + +Copy the following binaries to iMX8QM folder: + +$ cp imx-atf/build/imx8qm/release/bl31.bin . +$ cp u-boot/u-boot.bin . + +Copy the following firmwares U-Boot folder : + +$ cp firmware-imx-8.0/firmware/seco/mx8qm-ahab-container.img . +$ cp imx-sc-firmware-1.1/mx8qm-val-scfw-tcm.bin scfw_tcm.bin + +$ make SOC=iMX8QM flash_linux_m4 + +Flash the binary into the SD card +================================= + +Burn the flash.bin binary to SD card offset 32KB: + +$ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync + +Boot +==== +Set Boot switch SW2: 1100. diff --git a/board/freescale/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c b/board/freescale/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c new file mode 100644 index 0000000000..1f57c639a9 --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c @@ -0,0 +1,181 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + * Copyright (C) 2019 Oliver Graute oliver.graute@kococonnector.com + */ + +#include <common.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +static iomux_cfg_t uart0_pads[] = { + SC_P_UART0_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + SC_P_UART0_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx8_iomux_setup_multiple_pads(uart0_pads, ARRAY_SIZE(uart0_pads)); +} + +int board_early_init_f(void) +{ + int ret; + /* Set UART0 clock root to 80 MHz */ + sc_pm_clock_rate_t rate = 80000000; + + /* Power up UART0 */ + ret = sc_pm_set_resource_power_mode(-1, SC_R_UART_0, SC_PM_PW_MODE_ON); + if (ret) + return ret; + + ret = sc_pm_set_clock_rate(-1, SC_R_UART_0, 2, &rate); + if (ret) + return ret; + + /* Enable UART0 clock root */ + ret = sc_pm_clock_enable(-1, SC_R_UART_0, 2, true, false); + if (ret) + return ret; + + setup_iomux_uart(); + + sc_pm_set_resource_power_mode(-1, SC_R_DC_0, SC_PM_PW_MODE_ON); + sc_pm_set_resource_power_mode(-1, SC_R_GPIO_5, SC_PM_PW_MODE_ON); + + return 0; +} + +#if IS_ENABLED(CONFIG_DM_GPIO) +static void board_gpio_init(void) +{ + /* TODO */ +} +#else +static inline void board_gpio_init(void) {} +#endif + +#if IS_ENABLED(CONFIG_FEC_MXC) +#include <miiphy.h> + +int board_phy_config(struct phy_device *phydev) +{ +#ifdef CONFIG_FEC_ENABLE_MAX7322 + u8 value; + + /* This is needed to drive the pads to 1.8V instead of 1.5V */ + i2c_set_bus_num(CONFIG_MAX7322_I2C_BUS); + + if (!i2c_probe(CONFIG_MAX7322_I2C_ADDR)) { + /* Write 0x1 to enable O0 output, this device has no addr */ + /* hence addr length is 0 */ + value = 0x1; + if (i2c_write(CONFIG_MAX7322_I2C_ADDR, 0, 0, &value, 1)) + printf("MAX7322 write failed\n"); + } else { + printf("MAX7322 Not found\n"); + } + mdelay(1); +#endif + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +void build_info(void) +{ + u32 sc_build = 0, sc_commit = 0; + + /* Get SCFW build and commit id */ + sc_misc_build_info(-1, &sc_build, &sc_commit); + if (!sc_build) { + printf("SCFW does not support build info\n"); + sc_commit = 0; /* Display 0 if build info is not supported */ + } + printf("Build: SCFW %x\n", sc_commit); +} + +int checkboard(void) +{ + puts("Board: ROM-7720-A1 4GB\n"); + + build_info(); + print_bootinfo(); + + return 0; +} + +int board_init(void) +{ + /* Power up base board */ + sc_pm_set_resource_power_mode(-1, SC_R_BOARD_R1, SC_PM_PW_MODE_ON); + + board_gpio_init(); + + return 0; +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); +} + +/* + * Board specific reset that is system reset. + */ +void reset_cpu(ulong addr) +{ + /* TODO */ +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "ROM-7720-A1"); + env_set("board_rev", "iMX8QM"); +#endif + + env_set("sec_boot", "no"); +#ifdef CONFIG_AHAB_BOOT + env_set("sec_boot", "yes"); +#endif + + return 0; +} diff --git a/board/freescale/imx8qm_rom7720_a1/imximage.cfg b/board/freescale/imx8qm_rom7720_a1/imximage.cfg new file mode 100644 index 0000000000..e324c7ca37 --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/imximage.cfg @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QM */ +SOC_TYPE IMX8QM +/* Append seco container image */ +APPEND mx8qm-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qm-val-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/freescale/imx8qm_rom7720_a1/spl.c b/board/freescale/imx8qm_rom7720_a1/spl.c new file mode 100644 index 0000000000..2888d0661c --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/spl.c @@ -0,0 +1,228 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + */ +#include <common.h> +#include <dm.h> +#include <spl.h> +#include <fsl_esdhc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ESDHC_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ESDHC_CLK_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_INPUT_PAD_CTRL ((SC_PAD_CONFIG_OD_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_NORMAL_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define FSPI_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define GPIO_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define I2C_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_LOW << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) +#ifdef CONFIG_FSL_ESDHC + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 22) +#define USDHC2_CD_GPIO IMX_GPIO_NR(4, 12) + +static struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, + {USDHC3_BASE_ADDR, 0, 4}, +}; + +static iomux_cfg_t emmc0[] = { + SC_P_EMMC0_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_EMMC0_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA4 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA5 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA6 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA7 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_STROBE | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +static iomux_cfg_t usdhc2_sd[] = { + SC_P_USDHC2_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_USDHC2_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_WP | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_CD_B | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + * mmc2 USDHC3 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + ret = sc_pm_set_resource_power_mode(-1, SC_R_SDHC_0, SC_PM_PW_MODE_ON); + if (ret != SC_ERR_NONE) + return ret; + + imx8_iomux_setup_multiple_pads(emmc0, ARRAY_SIZE(emmc0)); + init_clk_usdhc(0); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + case 1: + ret = sc_pm_set_resource_power_mode(-1, SC_R_SDHC_2, SC_PM_PW_MODE_ON); + if (ret != SC_ERR_NONE) + return ret; + ret = sc_pm_set_resource_power_mode(-1, SC_R_GPIO_4, SC_PM_PW_MODE_ON); + if (ret != SC_ERR_NONE) + return ret; + + imx8_iomux_setup_multiple_pads(usdhc2_sd, ARRAY_SIZE(usdhc2_sd)); + init_clk_usdhc(2); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + gpio_request(USDHC2_CD_GPIO, "sd2_cd"); + gpio_direction_input(USDHC2_CD_GPIO); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return 0; + } + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + } + + return ret; +} + +#endif /* CONFIG_FSL_ESDHC */ + +void spl_dram_init(void) +{ + /* do nothing for now */ +} + +void spl_board_init(void) +{ +#if defined(CONFIG_SPL_SPI_SUPPORT) + if (sc_rm_is_resource_owned(-1, SC_R_FSPI_0)) { + if (sc_pm_set_resource_power_mode(-1, SC_R_FSPI_0, SC_PM_PW_MODE_ON)) { + puts("Warning: failed to initialize FSPI0\n"); + } + } +#endif + + /* DDR initialization */ + spl_dram_init(); + + puts("Normal Boot\n"); +} + +void spl_board_prepare_for_boot(void) +{ +#if defined(CONFIG_SPL_SPI_SUPPORT) + if (sc_rm_is_resource_owned(-1, SC_R_FSPI_0)) { + if (sc_pm_set_resource_power_mode(-1, SC_R_FSPI_0, SC_PM_PW_MODE_OFF)) { + puts("Warning: failed to turn off FSPI0\n"); + } + } +#endif +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig new file mode 100644 index 0000000000..0384bfca48 --- /dev/null +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_IMX8QM_ROM7720_A1=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=4 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/imx8qm_rom7720_a1/imximage.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8qm-rom7720-a1" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPL_TINY_MEMSET=y +# CONFIG_EFI_LOADER is not set +CONFIG_ARCH_MISC_INIT +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h new file mode 100644 index 0000000000..a50c03830f --- /dev/null +++ b/include/configs/imx8qm_rom7720.h @@ -0,0 +1,189 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + */ + +#ifndef __IMX8QM_ROM7720_H +#define __IMX8QM_ROM7720_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> +#define CONFIG_REMAKE_ELF +/* Flat Device Tree Definitions */ +#define CONFIG_OF_BOARD_SETUP + +#undef CONFIG_BOOTM_NETBSD + +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define USDHC1_BASE_ADDR 0x5B010000 +#define USDHC2_BASE_ADDR 0x5B020000 +#define USDHC3_BASE_ADDR 0x5B030000 +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +/* FUSE command */ +#define CONFIG_CMD_FUSE + +#ifdef CONFIG_AHAB_BOOT +#define AHAB_ENV "sec_boot=yes\0" +#else +#define AHAB_ENV "sec_boot=no\0" +#endif + +/* Boot M4 */ +#define M4_BOOT_ENV \ + "m4_0_image=m4_0.bin\0" \ + "m4_1_image=m4_1.bin\0" \ + "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_0_image}\0" \ + "loadm4image_1=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_1_image}\0" \ + "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0" \ + "m4boot_1=run loadm4image_1; dcache flush; bootaux ${loadaddr} 1\0" \ + +#ifdef CONFIG_NAND_BOOT +#define MFG_NAND_PARTITION "mtdparts=gpmi-nand:128m(boot),32m(kernel),16m(dtb),8m(misc),-(rootfs) " +#else +#define MFG_NAND_PARTITION "" +#endif + +#define CONFIG_MFG_ENV_SETTINGS \ + "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ + "rdinit=/linuxrc " \ + "g_mass_storage.stall=0 g_mass_storage.removable=1 " \ + "g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF "\ + "g_mass_storage.iSerialNumber="" "\ + MFG_NAND_PARTITION \ + "clk_ignore_unused "\ + "\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr} ${fdt_addr};\0" \ + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + M4_BOOT_ENV \ + AHAB_ENV \ + "script=boot.scr\0" \ + "image=Image\0" \ + "panel=NULL\0" \ + "console=ttyLP0\0" \ + "fdt_addr=0x83000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "boot_fdt=try\0" \ + "fdt_file=imx8qm-rom7720-a1.dtb\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} earlycon\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp rw earlycon\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +/* Default environment is in SD */ +#define CONFIG_ENV_SIZE 0x2000 + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_ENV_OFFSET (4 * 1024 * 1024) +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#else +#define CONFIG_ENV_OFFSET (64 * SZ_64K) +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ +#endif + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* On LPDDR4 board, USDHC1 is for eMMC, USDHC2 is for SD on CPU board, + * USDHC3 is for SD on base board On DDR4 board, USDHC1 is mux for NAND, + * USDHC2 is for SD, USDHC3 is for SD on base board + */ +#define CONFIG_SYS_MMC_ENV_DEV 2 /* USDHC3 */ +#define CONFIG_MMCROOT "/dev/mmcblk2p2" /* USDHC3 */ +#define CONFIG_SYS_FSL_USDHC_NUM 3 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (32 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE 0x80000000 /* 2 GB */ +/* LPDDR4 board total DDR is 6GB, DDR4 board total DDR is 4 GB */ +#define PHYS_SDRAM_2_SIZE 0x80000000 /* 2 GB */ + +#define CONFIG_SYS_MEMTEST_START 0xA0000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_1_SIZE >> 2)) + +/* Serial */ +#define CONFIG_BAUDRATE 115200 + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +/* Networking */ +#define CONFIG_FEC_XCV_TYPE RGMII +#define FEC_QUIRK_ENET_MAC + +#endif /* __IMX8QM_ROM7720_H */
Subject: [PATCH v2] imx: support i.MX8QM ROM 7720 a1 board
Please use imx/master or upstream master branch for your development.
Regards, Peng.
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub. com%2FADVANTECH-Corp%2Fuboot-imx6.git&data=02%7C01%7Cpeng.f an%40nxp.com%7C005702a90967449b2a7808d72bb5dc4a%7C686ea1d3bc2 b4c6fa92cd99c5c301635%7C0%7C0%7C637025932415631263&sdata=I 9xkcdDOGgrHPZdbhSl6aLTcg%2FTKq7KnOrZALbTbXH0%3D&reserved=0
Changes for v2:
- enabled usdhc2
- updated README.md
- imx8qm-rom7720-a1.dtb \ fsl-imx8qxp-colibri.dtb \ fsl-imx8qxp-mek.dtb
- Copyright (C) 2016 Freescale Semiconductor, Inc.
- Copyright 2017 NXP
+/dts-v1/;
- model = "Advantech iMX8QM Qseven series";
- compatible = "fsl,imx8qm-mek", "fsl,imx8qm";
- chosen {
- leds {
user {
- regulators {
#size-cells = <0>;
reg = <0>;
enable-active-high;
enable-active-high;
+&iomuxc {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_hog_1>;
- imx8qm-mek {
fsl,pins = <
fsl,pins = <
0x000014a0SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB_PAD
0x06000048SC_P_ENET0_MDC_CONN_ENET0_MDC
0x06000048SC_P_ENET0_MDIO_CONN_ENET0_MDIO
- SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x00000060
0x00000060SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC
0x00000060SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0
0x00000060SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1
0x00000060SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2
0x00000060SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3
0x00000060SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC
- SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x00000060
0x00000060SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0
0x00000060SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1
0x00000060SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2
0x00000060SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3
fsl,pins = <
0x000014a0SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETA_PAD
- SC_P_ENET1_RGMII_TX_CTL_CONN_ENET1_RGMII_TX_CTL 0x00000060
0x00000060SC_P_ENET1_RGMII_TXC_CONN_ENET1_RGMII_TXC
0x00000060SC_P_ENET1_RGMII_TXD0_CONN_ENET1_RGMII_TXD0
0x00000060SC_P_ENET1_RGMII_TXD1_CONN_ENET1_RGMII_TXD1
0x00000060SC_P_ENET1_RGMII_TXD2_CONN_ENET1_RGMII_TXD2
0x00000060SC_P_ENET1_RGMII_TXD3_CONN_ENET1_RGMII_TXD3
0x00000060SC_P_ENET1_RGMII_RXC_CONN_ENET1_RGMII_RXC
- SC_P_ENET1_RGMII_RX_CTL_CONN_ENET1_RGMII_RX_CTL 0x00000060
0x00000060SC_P_ENET1_RGMII_RXD0_CONN_ENET1_RGMII_RXD0
0x00000060SC_P_ENET1_RGMII_RXD1_CONN_ENET1_RGMII_RXD1
0x00000060SC_P_ENET1_RGMII_RXD2_CONN_ENET1_RGMII_RXD2
0x00000060SC_P_ENET1_RGMII_RXD3_CONN_ENET1_RGMII_RXD3
fsl,pins = <
fsl,pins = <
0x06000041SC_P_EMMC0_CLK_CONN_EMMC0_CLK
0x00000021SC_P_EMMC0_CMD_CONN_EMMC0_CMD
0x00000021SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0
0x00000021SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1
0x00000021SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2
0x00000021SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3
0x00000021SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4
0x00000021SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5
0x00000021SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6
0x00000021SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7
0x06000041SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE
0x00000021SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B
fsl,pins = <
0x06000040SC_P_EMMC0_CLK_CONN_EMMC0_CLK
0x00000020SC_P_EMMC0_CMD_CONN_EMMC0_CMD
0x00000020SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0
0x00000020SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1
0x00000020SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2
0x00000020SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3
0x00000020SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4
0x00000020SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5
0x00000020SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6
0x00000020SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7
0x06000040SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE
0x00000020SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B
fsl,pins = <
fsl,pins = <
0x00000021SC_P_USDHC1_RESET_B_LSIO_GPIO4_IO07
fsl,pins = <
0x06000041SC_P_USDHC1_CLK_CONN_USDHC1_CLK
0x00000021SC_P_USDHC1_CMD_CONN_USDHC1_CMD
0x00000021SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0
0x00000021SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1
0x00000021SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2
0x00000021SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3
0x00000021SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT
fsl,pins = <
0x06000040SC_P_USDHC1_CLK_CONN_USDHC1_CLK
0x00000020SC_P_USDHC1_CMD_CONN_USDHC1_CMD
0x00000020SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0
0x00000020SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1
0x00000020SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2
0x00000020SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3
0x00000020SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT
fsl,pins = <
fsl,pins = <
0x06000041SC_P_USDHC2_CLK_CONN_USDHC2_CLK
0x00000021SC_P_USDHC2_CMD_CONN_USDHC2_CMD
0x00000021SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0
0x00000021SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1
0x00000021SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2
0x00000021SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3
/* WP */
0x00000021SC_P_USDHC2_WP_LSIO_GPIO4_IO11
/* CD */
fsl,pins = <
0x06000020SC_P_GPT0_CAPTURE_DMA_I2C1_SDA
others,
fsl,pins = <
+&gpio2 {
- status = "okay";
+&gpio4 {
- status = "okay";
+&gpio5 {
- status = "okay";
+&usdhc1 {
- pinctrl-names = "default", "state_100mhz", "state_200mhz";
- pinctrl-0 = <&pinctrl_usdhc1>;
- pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
- bus-width = <8>;
- non-removable;
- status = "okay";
+&usdhc2 {
- pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
- pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
- pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
- bus-width = <4>;
- cd-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>;
- wp-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>;
- vmmc-supply = <®_usdhc2_vmmc>;
- status = "okay";
+&usdhc3 {
- pinctrl-0 = <&pinctrl_usdhc3>;
- bus-width = <4>;
- cd-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>;
- wp-gpios = <&gpio4 11 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&fec1 {
- pinctrl-0 = <&pinctrl_fec1>;
- phy-mode = "rgmii";
- phy-handle = <ðphy0>;
- fsl,ar8031-phy-fixup;
- fsl,magic-packet;
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <0>;
reg = <1>;
+&fec2 {
- pinctrl-0 = <&pinctrl_fec2>;
- phy-handle = <ðphy1>;
- fsl,magic-packet;
- status = "okay";
+&i2c1 {
- #address-cells = <1>;
- #size-cells = <0>;
- clock-frequency = <100000>;
- pinctrl-0 = <&pinctrl_lpi2c1>;
- status = "okay";
- pca9557_a: gpio@18 {
reg = <0x18>;
gpio-controller;
#gpio-cells = <2>;
- pca9557_b: gpio@19 {
reg = <0x19>;
gpio-controller;
#gpio-cells = <2>;
- pca9557_c: gpio@1b {
reg = <0x1b>;
gpio-controller;
#gpio-cells = <2>;
- pca9557_d: gpio@1f {
reg = <0x1f>;
gpio-controller;
#gpio-cells = <2>;
+&lpuart0 {
- pinctrl-0 = <&pinctrl_lpuart0>;
- status = "okay";
+&lpuart1 {
- status = "okay";
- bool "Support i.MX8QM ROM-7720-A1"
- select BOARD_LATE_INIT
- select SUPPORT_SPL
- select IMX8QM
+echo "ATF_LOAD_ADDR=$ATF_LOAD_ADDR" >&2 echo +"BL33_LOAD_ADDR=$BL33_LOAD_ADDR" >&2
BL32="tee.bin"
+config SYS_BOARD
- default "imx8qm_rom7720_a1"
+config SYS_VENDOR
- default "freescale"
- default "imx8qm_rom7720"
+$ git clone +https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsourc +e.codeaurora.org%2Fexternal%2Fimx%2Fimx-atf&data=02%7C01%7Cp eng.fan +%40nxp.com%7C005702a90967449b2a7808d72bb5dc4a%7C686ea1d3bc2b 4c6fa92cd99 +c5c301635%7C0%7C0%7C637025932415631263&sdata=NsfQvlj2WeU 4nUy7sOJEDx +UNFrrHnNdL2FUDIyec8GQ%3D&reserved=0 +$ cd imx-atf/ +$ git checkout origin/imx_4.14.78_1.0.0_ga -b imx_4.14.78_1.0.0_ga $ +make PLAT=imx8qm bl31
+$ wget +https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww .n +xp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-sc-firmware-1.1.bin &data +=02%7C01%7Cpeng.fan%40nxp.com%7C005702a90967449b2a7808d72bb5 dc4a%7C686e +a1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637025932415631263&a mp;sdata=Q4p +dc4J5%2FAARdXCcgAxeVicxfILbc3Ok3miVG5EGuac%3D&reserved=0 +$ chmod +x imx-sc-firmware-1.1.bin +$ ./imx-sc-firmware-1.1.bin +$ wget +https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww .n +xp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-8.0.bin&a mp;data=02 +%7C01%7Cpeng.fan%40nxp.com%7C005702a90967449b2a7808d72bb5dc4 a%7C686ea1d +3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637025932415641257&s data=iRTjtK +1CCqCTAGFDVVnEMjLwc%2FkyBUuiloQiOiBknpo%3D&reserved=0 +$ chmod +x firmware-imx-8.0.bin +$ ./firmware-imx-8.0.bin
+$ git clone +https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsourc +e.codeaurora.org%2Fexternal%2Fimx%2Fimx-mkimage%2F&data=02% 7C01%7Cp +eng.fan%40nxp.com%7C005702a90967449b2a7808d72bb5dc4a%7C686ea1 d3bc2b4c6f +a92cd99c5c301635%7C0%7C0%7C637025932415641257&sdata=tJG0 PZxeQ6AaRnT +heFUIPQrQemBC9Wqh5Uip%2B9ih5SE%3D&reserved=0 +$ cd imx-mkimage +$ git checkout rel_imx_4.14.78_1.0.0_ga -b rel_imx_4.14.78_1.0.0_ga $ +cd iMX8QM/
- Copyright 2017-2018 NXP
- Copyright (C) 2019 Oliver Graute oliver.graute@kococonnector.com
- SC_P_UART0_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- SC_P_UART0_TX | MUX_PAD_CTRL(UART_PAD_CTRL), };
- imx8_iomux_setup_multiple_pads(uart0_pads,
ARRAY_SIZE(uart0_pads)); }
- int ret;
- /* Set UART0 clock root to 80 MHz */
- sc_pm_clock_rate_t rate = 80000000;
- /* Power up UART0 */
- ret = sc_pm_set_resource_power_mode(-1, SC_R_UART_0,
SC_PM_PW_MODE_ON);
- if (ret)
return ret;
- ret = sc_pm_set_clock_rate(-1, SC_R_UART_0, 2, &rate);
- if (ret)
return ret;
- /* Enable UART0 clock root */
- ret = sc_pm_clock_enable(-1, SC_R_UART_0, 2, true, false);
- if (ret)
return ret;
- setup_iomux_uart();
- sc_pm_set_resource_power_mode(-1, SC_R_DC_0,
SC_PM_PW_MODE_ON);
- sc_pm_set_resource_power_mode(-1, SC_R_GPIO_5,
SC_PM_PW_MODE_ON);
- /* TODO */
+} +#else +static inline void board_gpio_init(void) {} #endif
+int board_phy_config(struct phy_device *phydev) { #ifdef +CONFIG_FEC_ENABLE_MAX7322
- u8 value;
- /* This is needed to drive the pads to 1.8V instead of 1.5V */
- i2c_set_bus_num(CONFIG_MAX7322_I2C_BUS);
- if (!i2c_probe(CONFIG_MAX7322_I2C_ADDR)) {
value = 0x1;
- } else {
- mdelay(1);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100);
- if (phydev->drv->config)
+} +#endif
- u32 sc_build = 0, sc_commit = 0;
- /* Get SCFW build and commit id */
- sc_misc_build_info(-1, &sc_build, &sc_commit);
- if (!sc_build) {
- printf("Build: SCFW %x\n", sc_commit); }
- puts("Board: ROM-7720-A1 4GB\n");
- build_info();
- print_bootinfo();
- /* Power up base board */
- sc_pm_set_resource_power_mode(-1, SC_R_BOARD_R1,
SC_PM_PW_MODE_ON);
- board_gpio_init();
- puts("\nDDR ");
- Board specific reset that is system reset.
- /* TODO */
+#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) {
+} +#endif
- return devno;
- env_set("board_name", "ROM-7720-A1");
- env_set("board_rev", "iMX8QM");
- env_set("sec_boot", "no");
- env_set("sec_boot", "yes");
- Copyright 2018 NXP
+/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QM */ +SOC_TYPE IMX8QM +/* Append seco container image */ +APPEND mx8qm-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ IMAGE SCU +mx8qm-val-scfw-tcm.bin +/* Add ATF image with exec attribute */ IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ DATA A35 u-boot-dtb.bin +0x80020000 diff --git a/board/freescale/imx8qm_rom7720_a1/spl.c b/board/freescale/imx8qm_rom7720_a1/spl.c new file mode 100644 index 0000000000..2888d0661c --- /dev/null +++ b/board/freescale/imx8qm_rom7720_a1/spl.c @@ -0,0 +1,228 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
(SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) #ifdef
CONFIG_FSL_ESDHC
- {USDHC1_BASE_ADDR, 0, 8},
- {USDHC2_BASE_ADDR, 0, 4},
- {USDHC3_BASE_ADDR, 0, 4},
- SC_P_EMMC0_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL),
- SC_P_EMMC0_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA4 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA5 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA6 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_DATA7 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_EMMC0_STROBE | MUX_PAD_CTRL(ESDHC_PAD_CTRL), };
- SC_P_USDHC2_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL),
- SC_P_USDHC2_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_USDHC2_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_USDHC2_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_USDHC2_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_USDHC2_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_USDHC2_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL),
- SC_P_USDHC2_WP | MUX_MODE_ALT(3) |
- SC_P_USDHC2_CD_B | MUX_MODE_ALT(3) |
- int i, ret;
* mmc0 USDHC1
* mmc1 USDHC2
* mmc2 USDHC3
- for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) {
switch (i) {
case 0:
SC_PM_PW_MODE_ON);
return ret;
ARRAY_SIZE(emmc0));
init_clk_usdhc(0);
break;
case 1:
SC_PM_PW_MODE_ON);
return ret;
SC_PM_PW_MODE_ON);
return ret;
init_clk_usdhc(2);
break;
default:
if (ret) {
return ret;
- struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv;
- int ret = 0;
- switch (cfg->esdhc_base) {
- case USDHC1_BASE_ADDR:
ret = 1;
break;
- case USDHC2_BASE_ADDR:
break;
- case USDHC3_BASE_ADDR:
break;
- return ret;
- /* do nothing for now */
- if (sc_rm_is_resource_owned(-1, SC_R_FSPI_0)) {
- /* DDR initialization */
- spl_dram_init();
- puts("Normal Boot\n");
+#endif +}
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) {
- /* Just empty function now - can't decide what to choose */
- debug("%s: %s\n", __func__, name);
+} +#endif
- /* Clear global data */
- memset((void *)gd, 0, sizeof(gd_t));
- arch_cpu_init();
- board_early_init_f();
- timer_init();
- preloader_console_init();
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- board_init_r(NULL, 0);
+} diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig new file mode 100644 index 0000000000..0384bfca48 --- /dev/null +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_IMX8QM_ROM7720_A1=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=4 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/imx8qm_ro m7720_a1/imximage.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8qm-rom7720-a1" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPL_TINY_MEMSET=y +# CONFIG_EFI_LOADER is not set +CONFIG_ARCH_MISC_INIT +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h new file mode 100644 index 0000000000..a50c03830f --- /dev/null +++ b/include/configs/imx8qm_rom7720.h @@ -0,0 +1,189 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- "m4_0_image=m4_0.bin\0" \
- "m4_1_image=m4_1.bin\0" \
- "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr}
${m4_0_image}\0" \
- "loadm4image_1=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr}
${m4_1_image}\0" \
- "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0"
- "m4boot_1=run loadm4image_1; dcache flush; bootaux ${loadaddr} 1\0"
- "mfgtool_args=setenv bootargs console=${console},${baudrate} " \
"g_mass_storage.iSerialNumber=\"\" "\
"\0" \
- "initrd_addr=0x83800000\0" \
- "initrd_high=0xffffffffffffffff\0" \
- "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr}
+${fdt_addr};\0" \
- CONFIG_MFG_ENV_SETTINGS \
- M4_BOOT_ENV \
- AHAB_ENV \
- "script=boot.scr\0" \
- "image=Image\0" \
- "panel=NULL\0" \
- "console=ttyLP0\0" \
- "fdt_addr=0x83000000\0" \
- "fdt_high=0xffffffffffffffff\0" \
- "boot_fdt=try\0" \
- "fdt_file=imx8qm-rom7720-a1.dtb\0" \
- "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \
- "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \
- "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \
- "mmcautodetect=yes\0" \
- "mmcargs=setenv bootargs console=${console},${baudrate}
- "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr}
${script};\0" \
- "bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
- "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr}
${image}\0" \
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0"
- "mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
"else " \
"fi; " \
"else " \
"fi;\0" \
- "netargs=setenv bootargs console=${console},${baudrate} " \
"root=/dev/nfs " \
- "netboot=echo Booting from net ...; " \
"run netargs; " \
"else " \
"fi; " \
"else " \
"fi; " \
"else " \
"booti; " \
"fi;\0"
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
- USDHC3 is for SD on base board On DDR4 board, USDHC1 is mux for
+NAND,
- USDHC2 is for SD, USDHC3 is for SD on base board */
2.17.1
ok I can apply the Patch on imx custodian tree. But I run into some wired linking errors. For the first there exist already a patch from Igor which is not applied in tree yet.
https://lists.denx.de/pipermail/u-boot/2019-August/380468.html
The next errors are multiple defintions of some functions:
drivers/mmc/fsl_esdhc_imx.o: In function `fdt_fixup_esdhc': /home/graute/test/u-boot-imx/drivers/mmc/fsl_esdhc_imx.c:1382: multiple definition of `fdt_fixup_esdhc' drivers/mmc/fsl_esdhc.o:/home/graute/test/u-boot-imx/drivers/mmc/fsl_esdhc.c:932: first defined here drivers/mmc/fsl_esdhc_imx.o:/home/graute/test/u-boot-imx/drivers/mmc/fsl_esdhc_imx.c:1661: multiple definition of `_u_boot_list_2_driver_2_fsl_esdhc' drivers/mmc/fsl_esdhc.o:/home/graute/test/u-boot-imx/drivers/mmc/fsl_esdhc.c:1101: first defined here scripts/Makefile.build:355: recipe for target 'drivers/mmc/built-in.o' failed make[2]: *** [drivers/mmc/built-in.o] Error 1 scripts/Makefile.build:432: recipe for target 'drivers/mmc' failed make[1]: *** [drivers/mmc] Error 2 Makefile:1588: recipe for target 'drivers' failed make: *** [drivers] Error 2
Someone a clue howto fix these errors?
Best Regards,
Oliver
Subject: Re: [PATCH v2] imx: support i.MX8QM ROM 7720 a1 board
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.d enx.de%2Fpipermail%2Fu-boot%2F2019-August%2F380468.html&data= 02%7C01%7Cpeng.fan%40nxp.com%7Cdb77a2fa070947d5750f08d72d1f91c8 %7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C1%7C637027485924189 364&sdata=5C0gakvz584z8HUpPfp1NZ4YhW9etYixErARrEQwr8s%3D&a mp;reserved=0
Please not enable FSL_ESDHC and FSL_ESDHC_IMX both. Only FSL_ESDHC_IMX is ok.
Regards, Peng.
drivers/mmc/fsl_esdhc.o:/home/graute/test/u-boot-imx/drivers/mmc/fsl_es dhc.c:932: first defined here drivers/mmc/fsl_esdhc_imx.o:/home/graute/test/u-boot-imx/drivers/mmc/f sl_esdhc_imx.c:1661: multiple definition of `_u_boot_list_2_driver_2_fsl_esdhc' drivers/mmc/fsl_esdhc.o:/home/graute/test/u-boot-imx/drivers/mmc/fsl_es dhc.c:1101: first defined here scripts/Makefile.build:355: recipe for target 'drivers/mmc/built-in.o' failed make[2]: *** [drivers/mmc/built-in.o] Error 1 scripts/Makefile.build:432: recipe for target 'drivers/mmc' failed make[1]: *** [drivers/mmc] Error 2 Makefile:1588: recipe for target 'drivers' failed make: *** [drivers] Error 2
Best Regards,
Oliver
thx for the fast reply. That hint worked.
Oliver
Oliver Graute
Peng Fan
