Peculiar problem executing boot.scr
Hello,
I have a very peculiar problem.
I have a very simple boot.scr script so that u-boot can load it and run it.
My set up is a Raspberry 3 B (32 bit)
Sript is
Fatload mmc 0:1 ${kernel_addr_r} kernel7.img
Bootz ${kernel_addr_r} - ${fdt_addr}
When u-boot stops autocounting, finds the script loads it and the error message is
-à ‘ailed to find kernel7.img ß--
Instead of F for word Failed, prints ‘ailed.
If I stop auto counting and enter the commands of script by hand it runs and loads kernel as expected
As a matter of fact whatever command I add to the script gives an error
Example : if I add printenv the error is “can not find command”
I can not understand what the problem is.
Has anyone encountered such a problem ??
Thank you
Tasos
On Mon, 14 Nov 2022 at 06:50, Tasos Terzidis terzanasta@gmail.com wrote:
Hello,
Sript is
Can you post the whole console output so we can see version, etc.?
I cannot immediately even find that 'Failed to find %s' string in U-Boot.
Tasos Terzidis
