[U-Boot] [PATCH] pinctrl: rockchip: Add 32bit writing function for rk3288 gpio0 pinctrl
There are no higher 16 writing corresponding bits for pmu_gpio0's iomux/drive/pull at rk3288, need to read the value from register firstly. Add the flag to distinguish it from normal registers.
Signed-off-by: David Wu david.wu@rock-chips.com --- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 17 ++++++-- .../pinctrl/rockchip/pinctrl-rockchip-core.c | 39 ++++++++++++++----- drivers/pinctrl/rockchip/pinctrl-rockchip.h | 33 ++++++++++++++++ 3 files changed, 76 insertions(+), 13 deletions(-)
diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3288.c b/drivers/pinctrl/rockchip/pinctrl-rk3288.c index 60585f3208..8b6ce11a63 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3288.c @@ -92,10 +92,19 @@ static void rk3288_calc_drv_reg_and_bit(struct rockchip_pin_bank *bank, }
static struct rockchip_pin_bank rk3288_pin_banks[] = { - PIN_BANK_IOMUX_FLAGS(0, 24, "gpio0", IOMUX_SOURCE_PMU, - IOMUX_SOURCE_PMU, - IOMUX_SOURCE_PMU, - IOMUX_UNROUTED + PIN_BANK_IOMUX_DRV_PULL_FLAGS(0, 24, "gpio0", + IOMUX_SOURCE_PMU | IOMUX_WRITABLE_32BIT, + IOMUX_SOURCE_PMU | IOMUX_WRITABLE_32BIT, + IOMUX_SOURCE_PMU | IOMUX_WRITABLE_32BIT, + IOMUX_UNROUTED, + DRV_TYPE_WRITABLE_32BIT, + DRV_TYPE_WRITABLE_32BIT, + DRV_TYPE_WRITABLE_32BIT, + 0, + PULL_TYPE_WRITABLE_32BIT, + PULL_TYPE_WRITABLE_32BIT, + PULL_TYPE_WRITABLE_32BIT, + 0 ), PIN_BANK_IOMUX_FLAGS(1, 32, "gpio1", IOMUX_UNROUTED, IOMUX_UNROUTED, diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c index b84b079064..ce935656f0 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c @@ -228,7 +228,13 @@ static int rockchip_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) } }
- data = (mask << (bit + 16)); + if (mux_type & IOMUX_WRITABLE_32BIT) { + regmap_read(regmap, reg, &data); + data &= ~(mask << bit); + } else { + data = (mask << (bit + 16)); + } + data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data);
@@ -252,7 +258,8 @@ static int rockchip_set_drive_perpin(struct rockchip_pin_bank *bank, int reg, ret, i; u32 data, rmask_bits, temp; u8 bit; - int drv_type = bank->drv[pin_num / 8].drv_type; + /* Where need to clean the special mask for rockchip_perpin_drv_list */ + int drv_type = bank->drv[pin_num / 8].drv_type & (~DRV_TYPE_IO_MASK);
debug("setting drive of GPIO%d-%d to %d\n", bank->bank_num, pin_num, strength); @@ -324,10 +331,15 @@ static int rockchip_set_drive_perpin(struct rockchip_pin_bank *bank, return -EINVAL; }
- /* enable the write to the equivalent lower bits */ - data = ((1 << rmask_bits) - 1) << (bit + 16); - data |= (ret << bit); + if (bank->drv[pin_num / 8].drv_type & DRV_TYPE_WRITABLE_32BIT) { + regmap_read(regmap, reg, &data); + data &= ~(((1 << rmask_bits) - 1) << bit); + } else { + /* enable the write to the equivalent lower bits */ + data = ((1 << rmask_bits) - 1) << (bit + 16); + }
+ data |= (ret << bit); ret = regmap_write(regmap, reg, data); return ret; } @@ -375,7 +387,11 @@ static int rockchip_set_pull(struct rockchip_pin_bank *bank, case RK3288: case RK3368: case RK3399: - pull_type = bank->pull_type[pin_num / 8]; + /* + * Where need to clean the special mask for + * rockchip_pull_list. + */ + pull_type = bank->pull_type[pin_num / 8] & (~PULL_TYPE_IO_MASK); ret = -EINVAL; for (i = 0; i < ARRAY_SIZE(rockchip_pull_list[pull_type]); i++) { @@ -390,10 +406,15 @@ static int rockchip_set_pull(struct rockchip_pin_bank *bank, return ret; }
- /* enable the write to the equivalent lower bits */ - data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16); - data |= (ret << bit); + if (bank->pull_type[pin_num / 8] & PULL_TYPE_WRITABLE_32BIT) { + regmap_read(regmap, reg, &data); + data &= ~(((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << bit); + } else { + /* enable the write to the equivalent lower bits */ + data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16); + }
+ data |= (ret << bit); ret = regmap_write(regmap, reg, data); break; default: diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip.h b/drivers/pinctrl/rockchip/pinctrl-rockchip.h index bc809630c1..5a6849c996 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip.h +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip.h @@ -26,6 +26,7 @@ enum rockchip_pinctrl_type { #define IOMUX_SOURCE_PMU BIT(2) #define IOMUX_UNROUTED BIT(3) #define IOMUX_WIDTH_3BIT BIT(4) +#define IOMUX_WRITABLE_32BIT BIT(5)
/** * Defined some common pins constants @@ -49,6 +50,9 @@ struct rockchip_iomux { int offset; };
+#define DRV_TYPE_IO_MASK GENMASK(31, 16) +#define DRV_TYPE_WRITABLE_32BIT BIT(31) + /** * enum type index corresponding to rockchip_perpin_drv_list arrays index. */ @@ -61,6 +65,9 @@ enum rockchip_pin_drv_type { DRV_TYPE_MAX };
+#define PULL_TYPE_IO_MASK GENMASK(31, 16) +#define PULL_TYPE_WRITABLE_32BIT BIT(31) + /** * enum type index corresponding to rockchip_pull_list arrays index. */ @@ -200,6 +207,32 @@ struct rockchip_pin_bank { }, \ }
+#define PIN_BANK_IOMUX_DRV_PULL_FLAGS(id, pins, label, iom0, iom1, \ + iom2, iom3, drv0, drv1, drv2, \ + drv3, pull0, pull1, pull2, \ + pull3) \ + { \ + .bank_num = id, \ + .nr_pins = pins, \ + .name = label, \ + .iomux = { \ + { .type = iom0, .offset = -1 }, \ + { .type = iom1, .offset = -1 }, \ + { .type = iom2, .offset = -1 }, \ + { .type = iom3, .offset = -1 }, \ + }, \ + .drv = { \ + { .drv_type = drv0, .offset = -1 }, \ + { .drv_type = drv1, .offset = -1 }, \ + { .drv_type = drv2, .offset = -1 }, \ + { .drv_type = drv3, .offset = -1 }, \ + }, \ + .pull_type[0] = pull0, \ + .pull_type[1] = pull1, \ + .pull_type[2] = pull2, \ + .pull_type[3] = pull3, \ + } + #define PIN_BANK_IOMUX_FLAGS_DRV_FLAGS_OFFSET_PULL_FLAGS(id, pins, \ label, iom0, iom1, iom2, \ iom3, drv0, drv1, drv2, \
IOMUX_SOURCE_PMU,
IOMUX_SOURCE_PMU,
IOMUX_UNROUTED
- PIN_BANK_IOMUX_DRV_PULL_FLAGS(0, 24, "gpio0",
IOMUX_UNROUTED,
0,
PIN_BANK_IOMUX_FLAGS(1, 32, "gpio1", IOMUX_UNROUTED, IOMUX_UNROUTED,0 ),
- if (mux_type & IOMUX_WRITABLE_32BIT) {
- } else {
This can not be optimised out by the compiler (for all the other platforms that don’t need it). Please structure this (and the entire driver) to not pull in unneeded baggage that is only used by one or a few devices.
} else {
ret = -EINVAL; for (i = 0; i < ARRAY_SIZE(rockchip_pull_list[pull_type]); i++) {pull_type = bank->pull_type[pin_num / 8] & (~PULL_TYPE_IO_MASK);
} else {
- Defined some common pins constants
- enum type index corresponding to rockchip_perpin_drv_list arrays index.
- enum type index corresponding to rockchip_pull_list arrays index.
pull3) \
.bank_num = id, \
.nr_pins = pins, \
.name = label, \
.iomux = { \
.drv = { \
#define PIN_BANK_IOMUX_FLAGS_DRV_FLAGS_OFFSET_PULL_FLAGS(id, pins, \ label, iom0, iom1, iom2, \ iom3, drv0, drv1, drv2, \ -- 2.19.1
David,
I am applying this one as a last-minute fix for 2019.4. However, I’ll still need the v2 for the next cycle, as I my review comments still apply.
Thanks, Philipp.
On 12.02.2019, at 12:55, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
IOMUX_SOURCE_PMU,
IOMUX_SOURCE_PMU,
IOMUX_UNROUTED
IOMUX_UNROUTED,
0,
- } else {
} else {
} else {
pull3) \
.bank_num = id, \
.nr_pins = pins, \
.name = label, \
.iomux = { \
.drv = { \
U-Boot mailing list U-Boot@lists.denx.de mailto:U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot https://lists.denx.de/listinfo/u-boot
Hi Philipp,
在 2019/3/29 下午10:40, Philipp Tomsich 写道:
David,
Sorry, there was a lot of things in March. I think I could push v2 at this week.
Thanks, Philipp.
On 12.02.2019, at 12:55, Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com> wrote:
On 12.02.2019, at 12:51, David Wu <david.wu@rock-chips.com mailto:david.wu@rock-chips.com> wrote:
Signed-off-by: David Wu <david.wu@rock-chips.com
static struct rockchip_pin_bank rk3288_pin_banks[] = { -PIN_BANK_IOMUX_FLAGS(0, 24, "gpio0", IOMUX_SOURCE_PMU, - IOMUX_SOURCE_PMU, - IOMUX_SOURCE_PMU, - IOMUX_UNROUTED +PIN_BANK_IOMUX_DRV_PULL_FLAGS(0, 24, "gpio0", + IOMUX_SOURCE_PMU | IOMUX_WRITABLE_32BIT, + IOMUX_SOURCE_PMU | IOMUX_WRITABLE_32BIT, + IOMUX_SOURCE_PMU | IOMUX_WRITABLE_32BIT, + IOMUX_UNROUTED, + DRV_TYPE_WRITABLE_32BIT, + DRV_TYPE_WRITABLE_32BIT, + DRV_TYPE_WRITABLE_32BIT, + 0, + PULL_TYPE_WRITABLE_32BIT, + PULL_TYPE_WRITABLE_32BIT, + PULL_TYPE_WRITABLE_32BIT, + 0 ), PIN_BANK_IOMUX_FLAGS(1, 32, "gpio1", IOMUX_UNROUTED, IOMUX_UNROUTED, diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c index b84b079064..ce935656f0 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c @@ -228,7 +228,13 @@ static int rockchip_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) } }
-data = (mask << (bit + 16)); +if (mux_type & IOMUX_WRITABLE_32BIT) { +regmap_read(regmap, reg, &data); +data &= ~(mask << bit); +} else { +data = (mask << (bit + 16)); +}
@@ -252,7 +258,8 @@ static int rockchip_set_drive_perpin(struct rockchip_pin_bank *bank, int reg, ret, i; u32 data, rmask_bits, temp; u8 bit; -int drv_type = bank->drv[pin_num / 8].drv_type; +/* Where need to clean the special mask for rockchip_perpin_drv_list */ +int drv_type = bank->drv[pin_num / 8].drv_type & (~DRV_TYPE_IO_MASK);
-/* enable the write to the equivalent lower bits */ -data = ((1 << rmask_bits) - 1) << (bit + 16); -data |= (ret << bit); +if (bank->drv[pin_num / 8].drv_type & DRV_TYPE_WRITABLE_32BIT) { +regmap_read(regmap, reg, &data); +data &= ~(((1 << rmask_bits) - 1) << bit); +} else { +/* enable the write to the equivalent lower bits */ +data = ((1 << rmask_bits) - 1) << (bit + 16); +}
+data |= (ret << bit); ret = regmap_write(regmap, reg, data); return ret; } @@ -375,7 +387,11 @@ static int rockchip_set_pull(struct rockchip_pin_bank *bank, case RK3288: case RK3368: case RK3399: -pull_type = bank->pull_type[pin_num / 8]; +/* +* Where need to clean the special mask for +* rockchip_pull_list. +*/ +pull_type = bank->pull_type[pin_num / 8] & (~PULL_TYPE_IO_MASK); ret = -EINVAL; for (i = 0; i < ARRAY_SIZE(rockchip_pull_list[pull_type]); i++) { @@ -390,10 +406,15 @@ static int rockchip_set_pull(struct rockchip_pin_bank *bank, return ret; }
-/* enable the write to the equivalent lower bits */ -data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16); -data |= (ret << bit); +if (bank->pull_type[pin_num / 8] & PULL_TYPE_WRITABLE_32BIT) { +regmap_read(regmap, reg, &data); +data &= ~(((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << bit); +} else { +/* enable the write to the equivalent lower bits */ +data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16); +}
+data |= (ret << bit); ret = regmap_write(regmap, reg, data); break; default: diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip.h b/drivers/pinctrl/rockchip/pinctrl-rockchip.h index bc809630c1..5a6849c996 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip.h +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip.h @@ -26,6 +26,7 @@ enum rockchip_pinctrl_type { #define IOMUX_SOURCE_PMUBIT(2) #define IOMUX_UNROUTEDBIT(3) #define IOMUX_WIDTH_3BITBIT(4) +#define IOMUX_WRITABLE_32BITBIT(5)
@@ -49,6 +50,9 @@ struct rockchip_iomux { intoffset; };
+#define DRV_TYPE_IO_MASKGENMASK(31, 16) +#define DRV_TYPE_WRITABLE_32BITBIT(31)
+#define PULL_TYPE_IO_MASKGENMASK(31, 16) +#define PULL_TYPE_WRITABLE_32BITBIT(31)
*/ @@ -200,6 +207,32 @@ struct rockchip_pin_bank { },\ }
+#define PIN_BANK_IOMUX_DRV_PULL_FLAGS(id, pins, label, iom0, iom1,\ + iom2, iom3, drv0, drv1, drv2,\ + drv3, pull0, pull1, pull2,\ + pull3)\ +{\ +.bank_num= id,\ +.nr_pins= pins,\ +.name= label,\ +.iomux= {\ +{ .type = iom0, .offset = -1 },\ +{ .type = iom1, .offset = -1 },\ +{ .type = iom2, .offset = -1 },\ +{ .type = iom3, .offset = -1 },\ +},\ +.drv= {\ +{ .drv_type = drv0, .offset = -1 },\ +{ .drv_type = drv1, .offset = -1 },\ +{ .drv_type = drv2, .offset = -1 },\ +{ .drv_type = drv3, .offset = -1 },\ +},\ +.pull_type[0] = pull0,\ +.pull_type[1] = pull1,\ +.pull_type[2] = pull2,\ +.pull_type[3] = pull3,\ +}
#define PIN_BANK_IOMUX_FLAGS_DRV_FLAGS_OFFSET_PULL_FLAGS(id, pins,\ label, iom0, iom1, iom2, \ iom3, drv0, drv1, drv2, \ -- 2.19.1
David Wu
Philipp Tomsich
