[U-Boot] [RFC PATCH] common: miiphyutil: Work and report phy address in hex in mdio cmd
It is confusing that mdio commands work and report phy id as decimal value when mii is working with hex values.
For example: ZynqMP> mdio list gem: 21 - TI DP83867 <--> ethernet@ff0e0000 ZynqMP> mdio read ethernet@ff0e0000 0 Reading from bus gem PHY at address 21: 0 - 0x1140 ZynqMP> mii dump 21 0 Incorrect PHY address. Range should be 0-31 ... ZynqMP> mii dump 15 0. (1140) -- PHY control register -- (8000:0000) 0.15 = 0 reset
U-Boot normally takes hex values that's why this patch is changing mdio command to handle hex instead of changing mii command to handle decimal values.
cmd/mdio.c | 6 +++--- common/miiphyutil.c | 2 +- drivers/net/zynq_gem.c | 2 +- 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/cmd/mdio.c b/cmd/mdio.c index fb13d050752a..21dc103736e7 100644 --- a/cmd/mdio.c +++ b/cmd/mdio.c @@ -27,12 +27,12 @@ static uint last_reg_hi; static int extract_range(char *input, int *plo, int *phi) { char *end; - *plo = simple_strtol(input, &end, 0); + *plo = simple_strtol(input, &end, 16); if (end == input) return -1;
if ((*end == '-') && *(++end)) - *phi = simple_strtol(end, NULL, 0); + *phi = simple_strtol(end, NULL, 16); else if (*end == '\0') *phi = *plo; else @@ -79,7 +79,7 @@ static int mdio_read_ranges(struct phy_device *phydev, struct mii_dev *bus,
printf("Reading from bus %s\n", bus->name); for (addr = addrlo; addr <= addrhi; addr++) { - printf("PHY at address %d:\n", addr); + printf("PHY at address %x:\n", addr);
for (devad = devadlo; devad <= devadhi; devad++) { for (reg = reglo; reg <= reghi; reg++) { diff --git a/common/miiphyutil.c b/common/miiphyutil.c index d8ebb384dbfa..aca18db52a00 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -135,7 +135,7 @@ void mdio_list_devices(void) struct phy_device *phydev = bus->phymap[i];
if (phydev) { - printf("%d - %s", i, phydev->drv->name); + printf("%x - %s", i, phydev->drv->name);
if (phydev->dev) printf(" <--> %s\n", phydev->dev->name); diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 3319e10467d0..526eac658ac5 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -706,7 +706,7 @@ static int zynq_gem_ofdata_to_platdata(struct udevice *dev)
priv->emio = fdtdec_get_bool(gd->fdt_blob, dev->of_offset, "xlnx,emio");
- printf("ZYNQ GEM: %lx, phyaddr %d, interface %s\n", (ulong)priv->iobase, + printf("ZYNQ GEM: %lx, phyaddr %x, interface %s\n", (ulong)priv->iobase, priv->phyaddr, phy_string_for_interface(priv->interface));
- *plo = simple_strtol(input, &end, 16);
Hi, the last parameter 0 of function simple_strtol should mean it can recognize the integer automatic as hex value if the data is beginning with 0x, as octet value if beginning with 0, else decimal value. So this code has no problem. I checked the implementation of function simple_strtol and found the following code: if (!base) base = 10; So I think we should fix the implementation of simple_strtol.
else if (*end == '\0') *phi = *plo; else*phi = simple_strtol(end, NULL, 16);
Maybe '0x%x' is more clear than '%x'.
if (phydev) {
Ditto.
- printf("ZYNQ GEM: %lx, phyaddr %x, interface %s\n", (ulong)priv->iobase,
Ditto.
Regards, Dongpo
yes. I have checked that implementation too. But the question is if this is aligned with others U-Boot parameters. It is confusing that with one command uses 21 as dec, another 15 or 0x15.
That's why will be worth to synchronize this.
md is one example where all is taken as hex.
ZynqMP> md 15 10 00000015: 00000000 00000000 01000000 00000000 ................ 00000025: 00000000 00000000 00000000 00000000 ................ 00000035: 00000000 00000000 00000000 00000000 ................ 00000045: 00000000 00000000 00000000 00000000 ................ ZynqMP> md f 10 0000000f: fe5000ff 000000ff 00000000 00000000 ..P............. 0000001f: 00000100 00000000 00000000 00000000 ................ 0000002f: 00000000 00000000 00000000 00000000 ................ 0000003f: 00000000 00000000 00000000 00000000 ................ ZynqMP> md 0xf 10 0000000f: fe5000ff 000000ff 00000000 00000000 ..P............. 0000001f: 00000100 00000000 00000000 00000000 ................ 0000002f: 00000000 00000000 00000000 00000000 ................ 0000003f: 00000000 00000000 00000000 00000000 ................
No problem to report hex values with 0x prefix.
Thanks, Michal
I checked the md command, the code is: addr = simple_strtoul(argv[1], NULL, 16); length = simple_strtoul(argv[2], NULL, 16); That's to say, you must consider the input addr and length as hex value if you want to use the md command.
Right and this is just one example where it is expected hex value. IIRC this is quite common for other commands too that's why I sent this path to start discussion about it.
Thanks, Michal
Dongpo Li
Joe Hershberger
Michal Simek
