[PATCH 0/1] drivers:spi:fix some typos
Fix some typos in spi drivers
Pengfei Fan (1): drivers:spi:fix some typos
drivers/spi/bcm63xx_hsspi.c | 2 +- drivers/spi/cadence_qspi.c | 2 +- drivers/spi/fsl_dspi.c | 4 ++-- drivers/spi/mtk_snfi_spi.c | 4 ++-- drivers/spi/mvebu_a3700_spi.c | 2 +- drivers/spi/omap3_spi.c | 2 +- drivers/spi/rk_spi.c | 2 +- drivers/spi/sh_qspi.c | 2 +- drivers/spi/spi-aspeed-smc.c | 4 ++-- drivers/spi/spi-qup.c | 2 +- drivers/spi/spi-sifive.c | 2 +- 11 files changed, 14 insertions(+), 14 deletions(-)
Signed-off-by: Pengfei Fan fanpengfei1@eswincomputing.com --- drivers/spi/bcm63xx_hsspi.c | 2 +- drivers/spi/cadence_qspi.c | 2 +- drivers/spi/fsl_dspi.c | 4 ++-- drivers/spi/mtk_snfi_spi.c | 4 ++-- drivers/spi/mvebu_a3700_spi.c | 2 +- drivers/spi/omap3_spi.c | 2 +- drivers/spi/rk_spi.c | 2 +- drivers/spi/sh_qspi.c | 2 +- drivers/spi/spi-aspeed-smc.c | 4 ++-- drivers/spi/spi-qup.c | 2 +- drivers/spi/spi-sifive.c | 2 +- 11 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/drivers/spi/bcm63xx_hsspi.c b/drivers/spi/bcm63xx_hsspi.c index 47002f8b56..4d714adc4a 100644 --- a/drivers/spi/bcm63xx_hsspi.c +++ b/drivers/spi/bcm63xx_hsspi.c @@ -210,7 +210,7 @@ static void bcm63xx_hsspi_deactivate_cs(struct bcm63xx_hsspi_priv *priv) * claimed. This way, the dummy CS is restored to its inactive value when * transfers are issued and the desired CS is preserved in its active value * all the time. This hack is also used in the upstream linux driver and - * allows keeping CS active between trasnfers even if the HW doesn't give + * allows keeping CS active between transfers even if the HW doesn't give * this possibility. */ static int bcm63xx_hsspi_xfer(struct udevice *dev, unsigned int bitlen, diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index ab0a681c83..973f455e23 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -392,7 +392,7 @@ static int cadence_spi_of_to_plat(struct udevice *bus)
plat->is_dma = dev_read_bool(bus, "cdns,is-dma");
- /* All other paramters are embedded in the child node */ + /* All other parameters are embedded in the child node */ subnode = dev_read_first_subnode(bus); if (!ofnode_valid(subnode)) { printf("Error: subnode with SPI flash config missing!\n"); diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index 62444e408a..8e5cc5552f 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -491,7 +491,7 @@ static int fsl_dspi_probe(struct udevice *bus)
dm_spi_bus = dev_get_uclass_priv(bus);
- /* cpu speical pin muxing configure */ + /* cpu special pin muxing configure */ cpu_dspi_port_conf();
/* get input clk frequency */ @@ -600,7 +600,7 @@ static int fsl_dspi_of_to_plat(struct udevice *bus) plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency", FSL_DSPI_DEFAULT_SCK_FREQ);
- debug("DSPI: regs=%pa, max-frequency=%d, endianess=%s, num-cs=%d\n", + debug("DSPI: regs=%pa, max-frequency=%d, endianness=%s, num-cs=%d\n", &plat->regs_addr, plat->speed_hz, plat->flags & DSPI_FLAG_REGMAP_ENDIAN_BIG ? "be" : "le", plat->num_chipselect); diff --git a/drivers/spi/mtk_snfi_spi.c b/drivers/spi/mtk_snfi_spi.c index 5ea62776b4..3decb3744d 100644 --- a/drivers/spi/mtk_snfi_spi.c +++ b/drivers/spi/mtk_snfi_spi.c @@ -153,7 +153,7 @@ static void mtk_snfi_copy_to_gpram(struct mtk_snfi_priv *priv,
/* * The output data will always be copied to the beginning of - * the GPRAM. Uses word write for better performace. + * the GPRAM. Uses word write for better performance. * * Trailing bytes in the last word are not cared. */ @@ -180,7 +180,7 @@ static void mtk_snfi_copy_from_gpram(struct mtk_snfi_priv *priv, u8 *cache,
/* * Read aligned data from GPRAM to buffer first. - * Uses word read for better performace. + * Uses word read for better performance. */ i = 0; while (pos < end) { diff --git a/drivers/spi/mvebu_a3700_spi.c b/drivers/spi/mvebu_a3700_spi.c index b1dce048ad..52882e8b26 100644 --- a/drivers/spi/mvebu_a3700_spi.c +++ b/drivers/spi/mvebu_a3700_spi.c @@ -84,7 +84,7 @@ static void spi_cs_deactivate(struct mvebu_spi_plat *plat, int cs) * The XFER_RDY flag is checked every time before accessing SPI_DOUT * and SPI_DIN register. * - * The number of transfers to be triggerred is decided by @bytelen. + * The number of transfers to be triggered is decided by @bytelen. * * Return: 0 - cool * -ETIMEDOUT - XFER_RDY flag timeout diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index ea38a0ffba..1cbb5d46fd 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -142,7 +142,7 @@ static int omap3_spi_read(struct omap3_spi_priv *priv, unsigned int len, } }
- /* Disable the channel to prevent furher receiving */ + /* Disable the channel to prevent further receiving */ if (i == (len - 1)) omap3_spi_set_enable(priv, OMAP3_MCSPI_CHCTRL_DIS);
diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index cb80be77ae..66b20fce9b 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -485,7 +485,7 @@ static int rockchip_spi_xfer(struct udevice *dev, unsigned int bitlen, /* * In case that there's a transmit-component, we need to wait * until the control goes idle before we can disable the SPI - * control logic (as this will implictly flush the FIFOs). + * control logic (as this will implicitly flush the FIFOs). */ if (out) { ret = rkspi_wait_till_not_busy(regs); diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c index 5ba8a8ea79..23af77f3df 100644 --- a/drivers/spi/sh_qspi.c +++ b/drivers/spi/sh_qspi.c @@ -160,7 +160,7 @@ static int sh_qspi_xfer_common(struct sh_qspi_slave *ss, unsigned int bitlen, }
if (bitlen % 8) { - printf("%s: bitlen is not 8bit alined %d", __func__, bitlen); + printf("%s: bitlen is not 8bit aligned %d", __func__, bitlen); return 1; }
diff --git a/drivers/spi/spi-aspeed-smc.c b/drivers/spi/spi-aspeed-smc.c index a3c9633382..4b6ea9f8e9 100644 --- a/drivers/spi/spi-aspeed-smc.c +++ b/drivers/spi/spi-aspeed-smc.c @@ -270,7 +270,7 @@ static int ast2500_adjust_decoded_size(struct udevice *bus) flashes[cs].ahb_decoded_sz = priv->info->min_decoded_sz;
/* - * If commnad mode or normal mode is used, the start address of a + * If command mode or normal mode is used, the start address of a * decoded range should be multiple of its related flash size. * Namely, the total decoded size from flash 0 to flash N should * be multiple of the size of flash (N + 1). @@ -404,7 +404,7 @@ static int ast2600_adjust_decoded_size(struct udevice *bus) flashes[cs].ahb_decoded_sz = 0;
/* - * If commnad mode or normal mode is used, the start address of a + * If command mode or normal mode is used, the start address of a * decoded range should be multiple of its related flash size. * Namely, the total decoded size from flash 0 to flash N should * be multiple of the size of flash (N + 1). diff --git a/drivers/spi/spi-qup.c b/drivers/spi/spi-qup.c index cdea5405f6..7b64532e50 100644 --- a/drivers/spi/spi-qup.c +++ b/drivers/spi/spi-qup.c @@ -233,7 +233,7 @@ static unsigned char qup_spi_read_byte(struct udevice *dev) }
/* - * Function to check wheather Input or Output FIFO + * Function to check whether Input or Output FIFO * has data to be serviced */ static int qup_spi_check_fifo_status(struct udevice *dev, u32 reg_addr) diff --git a/drivers/spi/spi-sifive.c b/drivers/spi/spi-sifive.c index 0a00df0ac7..ea372a05f8 100644 --- a/drivers/spi/spi-sifive.c +++ b/drivers/spi/spi-sifive.c @@ -350,7 +350,7 @@ static int sifive_spi_set_speed(struct udevice *bus, uint speed) if (speed > spi->freq) speed = spi->freq;
- /* Cofigure max speed */ + /* Configure max speed */ scale = (DIV_ROUND_UP(spi->freq >> 1, speed) - 1) & SIFIVE_SPI_SCKDIV_DIV_MASK; writel(scale, spi->regs + SIFIVE_SPI_REG_SCKDIV);
On Sat, 3 Dec 2022 at 01:26, Pengfei Fan fanpengfei1@eswincomputing.com wrote:
if (bitlen % 8) {
But we should not be using __func__. Better:
log_warning("bitlen is not 8bit aligned %d", bitlen);
Also need to put this at the very top of the file:
#define LOG_CATEGORY UCLASS_SPI
Thank you for your suggestions. The next patch will be modified according to your suggestions.
Thanks, Pengfei Fan
2022-12-05 05:17:05 "Simon Glass" sjg@chromium.org 写道:
if (bitlen % 8) {
Pengfei Fan
樊鹏飞
