Hi people!
I work with based on AT91RM9200 board. (SDRAM 16Mbitx16) When i use "#define CONFIG_SKIP_LOWLEVEL_INIT" and "#define CONFIG_SKIP_RELOCATE_UBOOT" then U-BOOT does not work.
But if to change a lines in file "/cpu/arm920t/at91rm9200/lowlevel_init.S" :
ldr r0, =SMRDATA ldr r1, _MTEXT_BASE sub r0, r0, r1 add r2, r0, #32 //this number valid for me and ldr r0, =SMRDATA1 ldr r1, _MTEXT_BASE sub r0, r0, r1 add r2, r0, #160 //this number valid for me
to a line
ldr r0, =SMRDATA add r2, r0, #32 //this number valid for me and ldr r0, =SMRDATA1 add r2, r0, #160 //this number valid for me
works correctly
How to solve a problem? Thank
Alexandr
------------------------------------------------------- This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Alexandr Kuleschov
