[PATCH] arm: mvebu: env_sf_get_env_addr() missing check for CONFIG_ENV_IS_IN_SPI_FLASH
The CONFIG_ENV_OFFSET is undefined if boot device is UART (CONFIG_MVEBU_SPL_BOOT_DEVICE_UART), or envs are not stored on flash (CONFIG_ENV_IS_NOWHERE). Check for CONFIG_ENV_IS_IN_SPI_FLASH as the first condition to determine whether env_sf_get_env_addr() should be provided.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
arch/arm/mach-mvebu/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 7c62a5dbb6..6dd729ae6e 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -36,7 +36,7 @@ static const struct mbus_win windows[] = { };
/* SPI0 CS0 Flash of size MBUS_SPI_SIZE is mapped to address MBUS_SPI_BASE */ -#if CONFIG_ENV_SPI_BUS == 0 && CONFIG_ENV_SPI_CS == 0 && \ +#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) && CONFIG_ENV_SPI_BUS == 0 && CONFIG_ENV_SPI_CS == 0 && \ CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE <= MBUS_SPI_SIZE void *env_sf_get_env_addr(void) {
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan Roese
Stefan Roese
Tony Dinh
