[PATCH v2 1/3] mmc: Fix MMC_CMD_STOP_TRANSMISSION response type and add comment
The MMC_CMD_STOP_TRANSMISSION response is R1 for read transfers per JEDEC Standard No. 84-B51 Page 126 . Correct the response type and add a comment about it.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- V2: New patch --- Cc: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org Cc: Hai Pham hai.pham.ud@renesas.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Loic Poulain loic.poulain@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Takeshi Kihara takeshi.kihara.df@renesas.com --- drivers/mmc/mmc.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 965bc8f0dba..f9b2f940389 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -427,7 +427,12 @@ static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start, if (blkcnt > 1) { cmd.cmdidx = MMC_CMD_STOP_TRANSMISSION; cmd.cmdarg = 0; - cmd.resp_type = MMC_RSP_R1b; + /* + * JEDEC Standard No. 84-B51 Page 126 + * CMD12 STOP_TRANSMISSION R1/R1b[3] + * NOTE 3 R1 for read cases and R1b for write cases. + */ + cmd.resp_type = MMC_RSP_R1; if (mmc_send_cmd(mmc, &cmd, NULL)) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) pr_err("mmc fail to send stop cmd\n");
If a tuning command times out, the card could still be processing it, which will cause problems for recovery. The eMMC specification section 6.6 Data transfer mode (cont’d) claims that CMD12 can be used to stop CMD21: " The relationship between the various data transfer modes is summarized (see Figure 27): - All data read commands can be aborted any time by the stop command (CMD12). The data transfer will terminate and the Device will return to the Transfer State. The read commands are: ... send tuning block (CMD21) .... " Add a function that does that.
Based on Linux commit [1] and [2].
[1] e711f0309109 ("mmc: mmc: Introduce mmc_abort_tuning()") [2] 21adc2e45f4e ("mmc: Improve function name when aborting a tuning cmd")
Reviewed-by: Takeshi Kihara takeshi.kihara.df@renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org [Marek: Update commit message, quote relevant part of the specification. Rename to mmc_send_stop_transmission(). Remove tuning opcode check, this is controller driver specific. Deduplicate part of mmc_read_blocks() using this function.] --- V2: Support both read and write transmission stop --- Cc: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org Cc: Hai Pham hai.pham.ud@renesas.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Loic Poulain loic.poulain@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Takeshi Kihara takeshi.kihara.df@renesas.com --- drivers/mmc/mmc.c | 26 +++++++++++++++++--------- include/mmc.h | 2 ++ 2 files changed, 19 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index f9b2f940389..d5922d842e8 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -398,6 +398,22 @@ int mmc_send_tuning(struct mmc *mmc, u32 opcode, int *cmd_error) } #endif
+int mmc_send_stop_transmission(struct mmc *mmc, bool read) +{ + struct mmc_cmd cmd; + + cmd.cmdidx = MMC_CMD_STOP_TRANSMISSION; + cmd.cmdarg = 0; + /* + * JEDEC Standard No. 84-B51 Page 126 + * CMD12 STOP_TRANSMISSION R1/R1b[3] + * NOTE 3 R1 for read cases and R1b for write cases. + */ + cmd.resp_type = read ? MMC_RSP_R1 : MMC_RSP_R1b; + + return mmc_send_cmd(mmc, &cmd, NULL); +} + static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start, lbaint_t blkcnt) { @@ -425,15 +441,7 @@ static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start, return 0;
if (blkcnt > 1) { - cmd.cmdidx = MMC_CMD_STOP_TRANSMISSION; - cmd.cmdarg = 0; - /* - * JEDEC Standard No. 84-B51 Page 126 - * CMD12 STOP_TRANSMISSION R1/R1b[3] - * NOTE 3 R1 for read cases and R1b for write cases. - */ - cmd.resp_type = MMC_RSP_R1; - if (mmc_send_cmd(mmc, &cmd, NULL)) { + if (mmc_send_stop_transmission(mmc, true)) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) pr_err("mmc fail to send stop cmd\n"); #endif diff --git a/include/mmc.h b/include/mmc.h index b8fbff150de..b47d2e1a895 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -558,6 +558,8 @@ int mmc_deferred_probe(struct mmc *mmc); int mmc_reinit(struct mmc *mmc); int mmc_get_b_max(struct mmc *mmc, void *dst, lbaint_t blkcnt); int mmc_hs400_prepare_ddr(struct mmc *mmc); +int mmc_send_stop_transmission(struct mmc *mmc, bool read); + #else struct mmc_ops { int (*send_cmd)(struct mmc *mmc,
When tuning command (CMD21) fails with command error, call mmc_send_stop_transmission() to send stop command (CMD12).
Reviewed-by: Takeshi Kihara takeshi.kihara.df@renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org [Marek: Add dev_dbg() message in case tuning abort fails Move tuning opcode check from mmc_abort_tuning()] --- V2: Update on previous patch changes --- Cc: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org Cc: Hai Pham hai.pham.ud@renesas.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Loic Poulain loic.poulain@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Takeshi Kihara takeshi.kihara.df@renesas.com --- drivers/mmc/renesas-sdhi.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 280d96dbc2d..484712b919e 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -611,6 +611,17 @@ int renesas_sdhi_execute_tuning(struct udevice *dev, uint opcode) priv->smpcmp |= BIT(i);
mdelay(1); + + /* + * eMMC specification specifies that CMD12 can be used to stop a tuning + * command, but SD specification does not, so do nothing unless it is + * eMMC. + */ + if (ret && (opcode == MMC_CMD_SEND_TUNING_BLOCK_HS200)) { + ret = mmc_send_stop_transmission(mmc, true); + if (ret < 0) + dev_dbg(dev, "Tuning abort fail (%d)\n", ret); + } }
ret = renesas_sdhi_select_tuning(priv, taps);
On 6/14/2023 9:42 PM, Marek Vasut wrote:
Caution: This is an external email. Please take care when clicking links or opening attachments. When in doubt, report the message using the 'Report this email' button
Sorry, I may miss one point. CMD12 for SD is R1b. But CMD12 for eMMC is R1 and R1b.
I am not sure how we should do with current code.
Thanks, Peng.
V2: New patch
#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) pr_err("mmc fail to send stop cmd\n");cmd.resp_type = MMC_RSP_R1; if (mmc_send_cmd(mmc, &cmd, NULL)) {
-- 2.39.2
Peng Fan
