[U-Boot] [PATCH] uniphier: increase the firmware size in update command environment
If a bigger EL32 is used, fip.bin can be larger than the currently assumed boot firmware size. Adjust the update commands.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/configs/uniphier.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 5ab06f6..920e9b6 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -197,17 +197,17 @@ "tftpboot $second_image && " \ "mmc write $loadaddr 0 100 && " \ "tftpboot $third_image && " \ - "mmc write $loadaddr 100 700\0" \ + "mmc write $loadaddr 100 f00\0" \ "nandupdate=nand erase 0 0x00100000 &&" \ "tftpboot $second_image && " \ "nand write $loadaddr 0 0x00020000 && " \ "tftpboot $third_image && " \ - "nand write $loadaddr 0x00020000 0x000e0000\0" \ + "nand write $loadaddr 0x00020000 0x001e0000\0" \ "usbupdate=usb start &&" \ "tftpboot $second_image && " \ "usb write $loadaddr 0 100 && " \ "tftpboot $third_image && " \ - "usb write $loadaddr 100 700\0" \ + "usb write $loadaddr 100 f00\0" \ BOOT_IMAGES \ LINUXBOOT_ENV_SETTINGS
2018-02-02 14:16 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier.
Masahiro Yamada
