[U-Boot] [PATCH RESEND] mmc: sdhci: fix the compiler warning when disable CONFIG_MMC_SDMA
When disabled CONFIG_MMC_SDMA, variable caps didn't use. This patch fixes the compiler error for -Wunused-but-set-variable
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/sdhci.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 60108fd..7ddb549 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -575,10 +575,10 @@ int sdhci_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg) #else int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) { +#ifdef CONFIG_MMC_SDMA unsigned int caps;
caps = sdhci_readl(host, SDHCI_CAPABILITIES); -#ifdef CONFIG_MMC_SDMA if (!(caps & SDHCI_CAN_DO_SDMA)) { printf("%s: Your controller doesn't support SDMA!!\n", __func__);
Jaehoon Chung
