[U-Boot] GUID/UUID string representation
Hello,
Commit d718ded056eefb6239bd2e0a57b7f6d99c6e9e4b introduced translation of UUID binary data to GUID string representation.
So, for example, if I use the 'gpt' command to create a partition table and pass a 'uuid' parameter like this: => gpt write mmc 0 "uuid_disk=${uuid_disk};start=2MiB,name=linux,size=64MiB,uuid=43f1961b-ce4c-4e6c-8f22-2230c5d532bd;"
As a result, when I print the partition table I get: => part list mmc 0
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00001000 0x00020fff "linux" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 1b96f143-4cce-6c4e-8f22-2230c5d532bd
which prints the GUID string representation of my supplied UUID (with endian change on the first three parts).
The command 'part uuid' (despite its name) returns this same GUID representation: => part uuid mmc 0 1b96f143-4cce-6c4e-8f22-2230c5d532bd
I have some questions: - Why is preferred the GUID representation when listing the partition table? - Should the 'part uuid' return the UUID representation instead of the GUID? - Should there be a 'part uuid' and a 'part guid' commands that return the different representations? - Isn't it a bit inconsistent that the 'gpt' command reads the 'uuid' parameter in UUID string representation and the 'part uuid' and 'part list' represent the number in GUID?
It may all sound as a futile discussion but in v2013.04 I had some variables to store the UUID numbers for my partitions that I used to generate the partition table, and then compared these variables with the values returned by 'part uuid' (as strings). Now on v2015.04 the strings do not match due to this endianness change on the representation.
Thanks -- Hector
On 07/30/2015 05:19 AM, Palacios, Hector wrote:
Hello,
I don't recall being aware of a difference between "GUID" and "UUID" representation.
The data format and terminology implemented in "part uuid" and "part list" were driven by the Linux kernel's root=PARTUUID command-line option, which "part uuid" was implemented to support. I imagine the phrase "UUID" in the kernel was intended to mean "a unique ID" rather than implying anything about the specific UUID-vs-GUID data format?
representations?
Perhaps in retrospect given your information about GUID-vs-UUID, the command naming might have been chosen differently
True. I would consider this a bug in the gpt command, which IIRC was added after the part command.
Is the GUID format useful elsewhere?
Perhaps the solution is to add flags to "gpt" and "part" that tell it which format to parse/emit? Presumably we'd also need to add a command to convert strings between GUID and UUID formats, since the kernel is presumably always going to want what it currently wants for the root=PARTUUID command-line option.
Hello,
On 07/30/2015 01:19 PM, Palacios, Hector wrote:
Hello,
Because it's defined by the specification and is the same as in the kernel. Please look at Apendix A of UEFI specification[1], which says about GUID text representation, which is simply shown in the table. The binary format of guid is consistent with RFC4122[2], which says that both guid and uuid are binary equal, but different represented by text.
[1]: http://www.uefi.org/sites/default/files/resources/UEFI%202_5.pdf [2]: https://www.ietf.org/rfc/rfc4122.txt
You can check it by printing gpt with:
'mmc part' - let's store the guids somewhere
Then mount the same disk in linux, and next do:
'ls -lhgG /dev/disk/by-partuuid/'
You can see, that even if the name is 'by-partuuid', the ids are displayed as GUIDs. Probably there is a bug with the path name, since uuid is a reserved name for "universally unique identifier".
It returns a string representation of partition id, which is GUID text format.
representations?
I don't think so, because there is only one text format in the standard.
You're right. This is inconsistent for string comparison - we can't just compare the UUID string with GUID, even if the 16 bytes binary buffer is the same. I don't know why GPT support was introduced with uuid names, we have a functions to convert it in lib/uuid.c, so additional command could be added - but I think cleanup is better.
Thanks
Hector
Thank you for pointing this issue.
After looking into the code, I found a bug in function gpt_fill_header(), which converts string to GUID, but it shouldn't, since we pass UUID's to gpt command.
So what can we do to fix this inconsistency:
- change the variable uuid_* to guid_* in the $partitions. This is a string representation compatible with specification.
- update str_format argument to UUID_STR_GUID in gen_rand_uuid_str() calls in gpt command.
Update uuid format argument in uuid_str_to_bin() calls: - update UUID_STR_FORMAT_STD to FORMAT_GUID in gpt_fill_pte()
- leave UUID_STR_FORMAT_GUID in gpt_fill_header() - it is bug when UUID is generated in gpt command.
Stephen, is that good for you?
On 07/31/2015 05:31 AM, Przemyslaw Marczak wrote:
Hello,
Hello,
table?
GUID?
Thanks
Hector
I'm not completely sure what the implications of those changes are without tracking down all those functions. However, if it means zero changes to the text output of the "part list" and "part uuid" commands, then that seems fine.
Palacios, Hector
Przemyslaw Marczak
Stephen Warren
