Re: [U-Boot] [PATCH v3 0/5] Fix SPI read and Enable required configs for Exynos5
Hi Jagan,
There is v3 for this series - Is that correct or this is the final version for this series?
Yes, v3 is the final version. This is v3. Please review and let me know your comments.
On Mon, Jun 9, 2014 at 3:55 PM, Akshay Saraswat akshay.s@samsung.com wrote:
Hi Minkyu,
Please review this patch set.
This patch set intends to -
- Fix SPI flash reading.
- Enable saving environment at the end of flash.
- Increase SPL size.
- Enable USB booting for all Exynos5 Socs.
Changes since v2: - Added "Acked-by" & "Tested-by". - Changed assignment for *rxp in 1/5. Changes since v1: - Added check for step in 1/5. - Added new config for SPI flash size in 2/5. - Made spl footprint 30 KB instead of 32 in 3/5. - Added "Acked-by" in 4/5. - Introduced new patch 5/5.
Akshay Saraswat (4): Exynos: SPI: Fix reading data from SPI flash Exynos5: Config: Place environment at the end of SPI flash Exynos5: Config: Increase SPL footprint for Exynos5420 Exynos5: Config: Enable USB boot mode for all Exynos5 SoCs
Michael Pratt (1): Exynos: Split 5250 and 5420 memory bank configuration
drivers/spi/exynos_spi.c | 5 +++++ include/configs/exynos5-dt.h | 15 ++++++++++----- include/configs/exynos5250-dt.h | 13 +++++++------ include/configs/exynos5420.h | 6 ++++++ 4 files changed, 28 insertions(+), 11 deletions(-)
thanks!
Jagan.
Regards, Akshay Saraswat
On Mon, Jun 9, 2014 at 6:07 PM, Akshay Saraswat akshay.s@samsung.com wrote:
Hi Jagan,
This shows v2 - Can you please resend the series again.
Hi Minkyu,
thanks!
Akshay Saraswat
Jagan Teki
