[U-Boot] [PATCH] fdt_resize(): fix actualsize calculations with unaligned blobs
The code in fdt_resize() to extend the fdt size to end on a page boundary is wrong for fdt's not located at an address aligned on a page boundary. What's even worse, the code would make actualsize shrink rather than grow if (blob & 0xfff) was bigger than the amount of padding added by ALIGN(), causing fdt_add_mem_rsv to fail.
Fix it by aligning end address (blob + size) to a page boundary instead. For aligned fdt's this is equivalent to what we had before.
Signed-off-by: Peter Korsgaard jacmet@sunsite.dk --- This was already discussed back in October: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/48912 But the commit (f242a08871) only fixed part of the problem. common/fdt_support.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 5a83bca..a79bc08 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -610,7 +610,7 @@ int fdt_resize(void *blob) fdt_size_dt_strings(blob) + sizeof(struct fdt_reserve_entry);
/* Make it so the fdt ends on a page boundary */ - actualsize = ALIGN(actualsize, 0x1000); + actualsize = ALIGN(actualsize + ((uint)blob & 0xfff), 0x1000); actualsize = actualsize - ((uint)blob & 0xfff);
/* Change the fdt header to reflect the correct size */
Applied to u-boot-fdt. I will call for Wolfgang to pull shortly.
Thanks, gvb
Jerry Van Baren
Peter Korsgaard
