[U-Boot] [PATCH 1/1] ARM: DRA72x: fix io delay calibration for ethernet
Ethernet on DRA72x EVM is not working as the io delay calibration value is not correct. Fixing this with the correct values and verified this on DRA72x EVM with tftp file transfer
Cc: Nishanth Menon nm@ti.com Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- board/ti/dra7xx/mux_data.h | 48 +++++++++++++++++++++++----------------------- 1 file changed, 24 insertions(+), 24 deletions(-)
diff --git a/board/ti/dra7xx/mux_data.h b/board/ti/dra7xx/mux_data.h index c9301a5..0ca3c51 100644 --- a/board/ti/dra7xx/mux_data.h +++ b/board/ti/dra7xx/mux_data.h @@ -156,30 +156,30 @@ const struct pad_conf_entry early_padconf[] = {
#ifdef CONFIG_IODELAY_RECALIBRATION const struct iodelay_cfg_entry iodelay_cfg_array[] = { - {0x6F0, 480, 0}, /* RGMMI0_RXC_IN */ - {0x6FC, 111, 1641}, /* RGMMI0_RXCTL_IN */ - {0x708, 272, 1116}, /* RGMMI0_RXD0_IN */ - {0x714, 243, 1260}, /* RGMMI0_RXD1_IN */ - {0x720, 0, 1614}, /* RGMMI0_RXD2_IN */ - {0x72C, 105, 1673}, /* RGMMI0_RXD3_IN */ - {0x740, 531, 120}, /* RGMMI0_TXC_OUT */ - {0x74C, 11, 60}, /* RGMMI0_TXCTL_OUT */ - {0x758, 7, 120}, /* RGMMI0_TXD0_OUT */ - {0x764, 0, 0}, /* RGMMI0_TXD1_OUT */ - {0x770, 276, 120}, /* RGMMI0_TXD2_OUT */ - {0x77C, 440, 120}, /* RGMMI0_TXD3_OUT */ - {0xAB0, 702, 0}, /* CFG_VIN2A_D18_IN */ - {0xABC, 136, 976}, /* CFG_VIN2A_D19_IN */ - {0xAD4, 210, 1357}, /* CFG_VIN2A_D20_IN */ - {0xAE0, 189, 1462}, /* CFG_VIN2A_D21_IN */ - {0xAEC, 232, 1278}, /* CFG_VIN2A_D22_IN */ - {0xAF8, 0, 1397}, /* CFG_VIN2A_D23_IN */ - {0xA70, 1551, 115}, /* CFG_VIN2A_D12_OUT */ - {0xA7C, 816, 0}, /* CFG_VIN2A_D13_OUT */ - {0xA88, 876, 0}, /* CFG_VIN2A_D14_OUT */ - {0xA94, 312, 0}, /* CFG_VIN2A_D15_OUT */ - {0xAA0, 58, 0}, /* CFG_VIN2A_D16_OUT */ - {0xAAC, 0, 0}, /* CFG_VIN2A_D17_OUT */ + {0x6F0, 359, 0}, /* RGMMI0_RXC_IN */ + {0x6FC, 129, 1896}, /* RGMMI0_RXCTL_IN */ + {0x708, 80, 1391}, /* RGMMI0_RXD0_IN */ + {0x714, 196, 1522}, /* RGMMI0_RXD1_IN */ + {0x720, 40, 1860}, /* RGMMI0_RXD2_IN */ + {0x72C, 0, 1956}, /* RGMMI0_RXD3_IN */ + {0x740, 0, 220}, /* RGMMI0_TXC_OUT */ + {0x74C, 1820, 180}, /* RGMMI0_TXCTL_OUT */ + {0x758, 1740, 440}, /* RGMMI0_TXD0_OUT */ + {0x764, 1740, 240}, /* RGMMI0_TXD1_OUT */ + {0x770, 1680, 380}, /* RGMMI0_TXD2_OUT */ + {0x77C, 1740, 440}, /* RGMMI0_TXD3_OUT */ + {0xAB0, 596, 0}, /* CFG_VIN2A_D18_IN */ + {0xABC, 314, 980}, /* CFG_VIN2A_D19_IN */ + {0xAD4, 241, 1536}, /* CFG_VIN2A_D20_IN */ + {0xAE0, 103, 1689}, /* CFG_VIN2A_D21_IN */ + {0xAEC, 161, 1563}, /* CFG_VIN2A_D22_IN */ + {0xAF8, 0, 1613}, /* CFG_VIN2A_D23_IN */ + {0xA70, 0, 200}, /* CFG_VIN2A_D12_OUT */ + {0xA7C, 1560, 140}, /* CFG_VIN2A_D13_OUT */ + {0xA88, 1700, 0}, /* CFG_VIN2A_D14_OUT */ + {0xA94, 1260, 0}, /* CFG_VIN2A_D15_OUT */ + {0xAA0, 1400, 0}, /* CFG_VIN2A_D16_OUT */ + {0xAAC, 1290, 0}, /* CFG_VIN2A_D17_OUT */ }; #endif
Yeah, I missed this. Thanks for the patch.
Tested this on DRA72-evm. Tested-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
- {0x6F0, 359, 0}, /* RGMMI0_RXC_IN */
- {0x6FC, 129, 1896}, /* RGMMI0_RXCTL_IN */
- {0x708, 80, 1391}, /* RGMMI0_RXD0_IN */
- {0x714, 196, 1522}, /* RGMMI0_RXD1_IN */
- {0x720, 40, 1860}, /* RGMMI0_RXD2_IN */
- {0x72C, 0, 1956}, /* RGMMI0_RXD3_IN */
- {0x740, 0, 220}, /* RGMMI0_TXC_OUT */
- {0x74C, 1820, 180}, /* RGMMI0_TXCTL_OUT */
- {0x758, 1740, 440}, /* RGMMI0_TXD0_OUT */
- {0x764, 1740, 240}, /* RGMMI0_TXD1_OUT */
- {0x770, 1680, 380}, /* RGMMI0_TXD2_OUT */
- {0x77C, 1740, 440}, /* RGMMI0_TXD3_OUT */
- {0xAB0, 596, 0}, /* CFG_VIN2A_D18_IN */
- {0xABC, 314, 980}, /* CFG_VIN2A_D19_IN */
- {0xAD4, 241, 1536}, /* CFG_VIN2A_D20_IN */
- {0xAE0, 103, 1689}, /* CFG_VIN2A_D21_IN */
- {0xAEC, 161, 1563}, /* CFG_VIN2A_D22_IN */
- {0xAF8, 0, 1613}, /* CFG_VIN2A_D23_IN */
- {0xA70, 0, 200}, /* CFG_VIN2A_D12_OUT */
- {0xA7C, 1560, 140}, /* CFG_VIN2A_D13_OUT */
- {0xA88, 1700, 0}, /* CFG_VIN2A_D14_OUT */
- {0xA94, 1260, 0}, /* CFG_VIN2A_D15_OUT */
- {0xAA0, 1400, 0}, /* CFG_VIN2A_D16_OUT */
- {0xAAC, 1290, 0}, /* CFG_VIN2A_D17_OUT */
}; #endif
This description is not entirely accurate. I propose the following: we currently use in-development IODelay values for J6eco which are proposed in the data sheet, however, DRA72x EVM uses DP83865 ethernet Phy over RGMII. The PHY characteristics and routing choices made on the EVM, make the current iodelay values fail ethernet communication.
Instead, we need to choose custom values for DRA72x-evm specifically designed for the PHY and routing on the platform for ethernet to function.
Add a comment for custom values for J6-evm
Comment here providing that these values are for u-boot using RGMII1 configuration on VIN2a_x pins.
}; #endif
Otherwise, the values look good. Along with the mentioned changes, please feel free to Add: Reviewed-by: Nishanth Menon nm@ti.com
Lokesh Vutla
Mugunthan V N
Nishanth Menon
