[U-Boot] [PATCH v3 0/2]
1/2: refactors a little because NDS32 actually need not the symbolic link 2/2: introduce a new config to avoid broken symbolic links.
Masahiro Yamada (2): nds32: include <asm/arch-*/*.h> instead of <asm/arch/*.h> kbuild: create symbolic link only for ARM, AVR32, SPARC, PowerPC, x86
arch/Kconfig | 7 +++++++ arch/powerpc/Kconfig | 3 +++ include/configs/adp-ag101.h | 2 +- include/configs/adp-ag101p.h | 2 +- include/configs/adp-ag102.h | 2 +- scripts/Makefile.autoconf | 2 ++ 6 files changed, 15 insertions(+), 3 deletions(-)
There are only two SoC-specific headers for this architecture: - arch/nds32/include/asm/arch-ag101/ag101.h - arch/nds32/include/asm/arch-ag102/ag102.h
Those two have different file names, so there is no advantage to include them via symbolic linked directory.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/configs/adp-ag101.h | 2 +- include/configs/adp-ag101p.h | 2 +- include/configs/adp-ag102.h | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/adp-ag101.h b/include/configs/adp-ag101.h index 4d52ba1..141fc99 100644 --- a/include/configs/adp-ag101.h +++ b/include/configs/adp-ag101.h @@ -9,7 +9,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#include <asm/arch/ag101.h> +#include <asm/arch-ag101/ag101.h>
/* * CPU and Board Configuration Options diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 06860b5..4296c6b 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -9,7 +9,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
/* * CPU and Board Configuration Options diff --git a/include/configs/adp-ag102.h b/include/configs/adp-ag102.h index 026696c..0c7573a 100644 --- a/include/configs/adp-ag102.h +++ b/include/configs/adp-ag102.h @@ -8,7 +8,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#include <asm/arch/ag102.h> +#include <asm/arch-ag102/ag102.h>
The symbolic link to SoC/CPU specific header directory is created during the build, while it is only necessary for ARM, AVR32, SPARC, x86, and some CPUs of PowerPC. For the other architectures, it just results in a broken symbolic link.
Introduce CONFIG_CREATE_ARCH_SYMLINK to not create unneeded symbolic links.
Changes in v3: - Fix AVR32 build error - Rebase on u-boot/master (commit 4905dfc)
Changes in v2: - Use 'ifdef CONFIG_CREATE_ARCH_SYMLINK' for readability
arch/Kconfig | 7 +++++++ arch/powerpc/Kconfig | 3 +++ scripts/Makefile.autoconf | 2 ++ 3 files changed, 12 insertions(+)
diff --git a/arch/Kconfig b/arch/Kconfig index afa1d6c..e952bb1 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -1,3 +1,6 @@ +config CREATE_ARCH_SYMLINK + bool + config HAVE_GENERIC_BOARD bool
@@ -18,12 +21,14 @@ config ARC
config ARM bool "ARM architecture" + select CREATE_ARCH_SYMLINK select HAVE_PRIVATE_LIBGCC if !ARM64 select HAVE_GENERIC_BOARD select SUPPORT_OF_CONTROL
config AVR32 bool "AVR32 architecture" + select CREATE_ARCH_SYMLINK select HAVE_GENERIC_BOARD select SYS_GENERIC_BOARD
@@ -84,9 +89,11 @@ config SH
config SPARC bool "SPARC architecture" + select CREATE_ARCH_SYMLINK
config X86 bool "x86 architecture" + select CREATE_ARCH_SYMLINK select HAVE_PRIVATE_LIBGCC select HAVE_GENERIC_BOARD select SYS_GENERIC_BOARD diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index 3b3f446..18451d3 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -22,9 +22,11 @@ config MPC8260
config MPC83xx bool "MPC83xx" + select CREATE_ARCH_SYMLINK
config MPC85xx bool "MPC85xx" + select CREATE_ARCH_SYMLINK
config MPC86xx bool "MPC86xx" @@ -34,6 +36,7 @@ config 8xx
config 4xx bool "PPC4xx" + select CREATE_ARCH_SYMLINK
endchoice
diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index 36bfa17..d668982 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -107,6 +107,7 @@ include/config.h: scripts/Makefile.autoconf create_symlink FORCE # Otherwise, create a symbolic link to arch/$(ARCH)/include/asm/arch-$(SOC). PHONY += create_symlink create_symlink: +ifdef CONFIG_CREATE_ARCH_SYMLINK ifneq ($(KBUILD_SRC),) $(Q)mkdir -p include/asm $(Q)if [ -d $(KBUILD_SRC)/arch/$(ARCH)/mach-$(SOC)/include/mach ]; then \ @@ -123,6 +124,7 @@ else fi; \ ln -fsn $$dest arch/$(ARCH)/include/asm/arch endif +endif
PHONY += FORCE FORCE:
On 15 July 2015 at 05:59, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v3:
Changes in v2:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org
Masahiro Yamada
