[PATCH 0/4] console: remove #ifdef CONFIG when it is possible
Use 'if (IS_ENABLED(CONFIG...))' instead of '#if or #ifdef' where possible
This patchset can applied on master branch after the serie [1] (for the new order of test in function putc() and puts() done in "console: allow to record console output before ready" )
I will push a separate serie to remove the remaining #ifdef CONFIG_VIDCONSOLE_AS_LCD
And I remove the sandox code in [2] (with the associated tests #ifdef CONFIG_SANDBOX)
[1] http://patchwork.ozlabs.org/project/uboot/list/?series=217079 "log: don't build the trace buffer when log is not ready"
[2] http://patchwork.ozlabs.org/project/uboot/patch/20201127114927.2.Ida70f4fb15... "[2/2] console: sandbox: remove unnecessary sandbox code"
Patrick Delaunay (4): console: remove #ifdef CONFIG when it is possible console: add function console_devices_set console: remove #ifdef CONFIG_CONSOLE_RECORD console: add console_tstc_check helper function for CONSOLE_MUX
common/console.c | 291 ++++++++++++++++++++++++++--------------------- 1 file changed, 164 insertions(+), 127 deletions(-)
Remove #ifdef or #ifndef for CONFIG when it is possible to simplify the console.c code and respect the U-Boot coding rules.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
common/console.c | 149 +++++++++++++++++++---------------------------- 1 file changed, 61 insertions(+), 88 deletions(-)
diff --git a/common/console.c b/common/console.c index c3d552bb3e..6fc3957024 100644 --- a/common/console.c +++ b/common/console.c @@ -44,14 +44,15 @@ static int on_console(const char *name, const char *value, enum env_op op, case env_op_create: case env_op_overwrite:
-#if CONFIG_IS_ENABLED(CONSOLE_MUX) - if (iomux_doenv(console, value)) - return 1; -#else - /* Try assigning specified device */ - if (console_assign(console, value) < 0) - return 1; -#endif + if (CONFIG_IS_ENABLED(CONSOLE_MUX)) { + if (iomux_doenv(console, value)) + return 1; + } else { + /* Try assigning specified device */ + if (console_assign(console, value) < 0) + return 1; + } + return 0;
case env_op_delete: @@ -69,14 +70,13 @@ U_BOOT_ENV_CALLBACK(console, on_console); static int on_silent(const char *name, const char *value, enum env_op op, int flags) { -#if !CONFIG_IS_ENABLED(SILENT_CONSOLE_UPDATE_ON_SET) - if (flags & H_INTERACTIVE) - return 0; -#endif -#if !CONFIG_IS_ENABLED(SILENT_CONSOLE_UPDATE_ON_RELOC) - if ((flags & H_INTERACTIVE) == 0) - return 0; -#endif + if (!CONFIG_IS_ENABLED(SILENT_CONSOLE_UPDATE_ON_SET)) + if (flags & H_INTERACTIVE) + return 0; + + if (!CONFIG_IS_ENABLED(SILENT_CONSOLE_UPDATE_ON_RELOC)) + if ((flags & H_INTERACTIVE) == 0) + return 0;
if (value != NULL) gd->flags |= GD_FLG_SILENT; @@ -159,14 +159,13 @@ static bool console_dev_is_serial(struct stdio_dev *sdev) { bool is_serial;
-#ifdef CONFIG_DM_SERIAL - if (sdev->flags & DEV_FLAGS_DM) { + if (IS_ENABLED(CONFIG_DM_SERIAL) && (sdev->flags & DEV_FLAGS_DM)) { struct udevice *dev = sdev->priv;
is_serial = device_get_uclass_id(dev) == UCLASS_SERIAL; - } else -#endif - is_serial = !strcmp(sdev->name, "serial"); + } else { + is_serial = !strcmp(sdev->name, "serial"); + }
return is_serial; } @@ -350,13 +349,12 @@ int fgetc(int file) if (console_tstc(file)) return console_getc(file); #endif -#ifdef CONFIG_WATCHDOG /* * If the watchdog must be rate-limited then it should * already be handled in board-specific code. */ - udelay(1); -#endif + if (IS_ENABLED(CONFIG_WATCHDOG)) + udelay(1); } }
@@ -406,10 +404,8 @@ int fprintf(int file, const char *fmt, ...)
int getchar(void) { -#ifdef CONFIG_DISABLE_CONSOLE - if (gd->flags & GD_FLG_DISABLE_CONSOLE) + if (IS_ENABLED(CONFIG_DISABLE_CONSOLE) && (gd->flags & GD_FLG_DISABLE_CONSOLE)) return 0; -#endif
if (!gd->have_console) return 0; @@ -434,10 +430,8 @@ int getchar(void)
int tstc(void) { -#ifdef CONFIG_DISABLE_CONSOLE - if (gd->flags & GD_FLG_DISABLE_CONSOLE) + if (IS_ENABLED(CONFIG_DISABLE_CONSOLE) && (gd->flags & GD_FLG_DISABLE_CONSOLE)) return 0; -#endif
if (!gd->have_console) return 0; @@ -485,10 +479,8 @@ static void print_pre_console_buffer(int flushpoint) char buf_out[CONFIG_PRE_CON_BUF_SZ + 1]; char *buf_in;
-#ifdef CONFIG_SILENT_CONSOLE - if (gd->flags & GD_FLG_SILENT) + if (IS_ENABLED(CONFIG_SILENT_CONSOLE) && (gd->flags & GD_FLG_SILENT)) return; -#endif
buf_in = map_sysmem(CONFIG_PRE_CON_BUF_ADDR, CONFIG_PRE_CON_BUF_SZ); if (gd->precon_buf_idx > CONFIG_PRE_CON_BUF_SZ) @@ -530,25 +522,20 @@ void putc(const char c) return; } #endif -#ifdef CONFIG_DEBUG_UART /* if we don't have a console yet, use the debug UART */ - if (!(gd->flags & GD_FLG_SERIAL_READY)) { + if (IS_ENABLED(CONFIG_DEBUG_UART) && !(gd->flags & GD_FLG_SERIAL_READY)) { printch(c); return; } -#endif -#ifdef CONFIG_SILENT_CONSOLE - if (gd->flags & GD_FLG_SILENT) { + + if (IS_ENABLED(CONFIG_SILENT_CONSOLE) && (gd->flags & GD_FLG_SILENT)) { if (!(gd->flags & GD_FLG_DEVINIT)) pre_console_putc(c); return; } -#endif
-#ifdef CONFIG_DISABLE_CONSOLE - if (gd->flags & GD_FLG_DISABLE_CONSOLE) + if (IS_ENABLED(CONFIG_DISABLE_CONSOLE) && (gd->flags & GD_FLG_DISABLE_CONSOLE)) return; -#endif
if (!gd->have_console) return pre_console_putc(c); @@ -578,8 +565,8 @@ void puts(const char *s) return; } #endif -#ifdef CONFIG_DEBUG_UART - if (!(gd->flags & GD_FLG_SERIAL_READY)) { + + if (IS_ENABLED(CONFIG_DEBUG_UART) && !(gd->flags & GD_FLG_SERIAL_READY)) { while (*s) { int ch = *s++;
@@ -587,19 +574,15 @@ void puts(const char *s) } return; } -#endif -#ifdef CONFIG_SILENT_CONSOLE - if (gd->flags & GD_FLG_SILENT) { + + if (IS_ENABLED(CONFIG_SILENT_CONSOLE) && (gd->flags & GD_FLG_SILENT)) { if (!(gd->flags & GD_FLG_DEVINIT)) pre_console_puts(s); return; } -#endif
if (!gd->have_console) return pre_console_puts(s); @@ -772,19 +755,19 @@ int console_assign(int file, const char *devname) /* return true if the 'silent' flag is removed */ static bool console_update_silent(void) { -#ifdef CONFIG_SILENT_CONSOLE - if (env_get("silent")) { - gd->flags |= GD_FLG_SILENT; - } else { - unsigned long flags = gd->flags; + unsigned long flags = gd->flags;
- gd->flags &= ~GD_FLG_SILENT; + if (!IS_ENABLED(CONFIG_SILENT_CONSOLE)) + return false;
- return !!(flags & GD_FLG_SILENT); + if (env_get("silent")) { + gd->flags |= GD_FLG_SILENT; + return false; } -#endif
- return false; + gd->flags &= ~GD_FLG_SILENT; + + return !!(flags & GD_FLG_SILENT); }
int console_announce_r(void) @@ -843,12 +826,8 @@ int console_init_r(void) { char *stdinname, *stdoutname, *stderrname; struct stdio_dev *inputdev = NULL, *outputdev = NULL, *errdev = NULL; -#ifdef CONFIG_SYS_CONSOLE_ENV_OVERWRITE int i; -#endif /* CONFIG_SYS_CONSOLE_ENV_OVERWRITE */ -#if CONFIG_IS_ENABLED(CONSOLE_MUX) int iomux_err = 0; -#endif int flushpoint;
/* update silent for env loaded from flash (initr_env) */ @@ -874,14 +853,14 @@ int console_init_r(void) inputdev = search_device(DEV_FLAGS_INPUT, stdinname); outputdev = search_device(DEV_FLAGS_OUTPUT, stdoutname); errdev = search_device(DEV_FLAGS_OUTPUT, stderrname); -#if CONFIG_IS_ENABLED(CONSOLE_MUX) - iomux_err = iomux_doenv(stdin, stdinname); - iomux_err += iomux_doenv(stdout, stdoutname); - iomux_err += iomux_doenv(stderr, stderrname); - if (!iomux_err) - /* Successful, so skip all the code below. */ - goto done; -#endif + if (CONFIG_IS_ENABLED(CONSOLE_MUX)) { + iomux_err = iomux_doenv(stdin, stdinname); + iomux_err += iomux_doenv(stdout, stdoutname); + iomux_err += iomux_doenv(stderr, stderrname); + if (!iomux_err) + /* Successful, so skip all the code below. */ + goto done; + } } /* if the devices are overwritten or not found, use default device */ if (inputdev == NULL) { @@ -907,25 +886,22 @@ int console_init_r(void) console_doenv(stdin, inputdev); }
-#if CONFIG_IS_ENABLED(CONSOLE_MUX) done: -#endif
-#ifndef CONFIG_SYS_CONSOLE_INFO_QUIET - stdio_print_current_devices(); -#endif /* CONFIG_SYS_CONSOLE_INFO_QUIET */ + if (!IS_ENABLED(CONFIG_SYS_CONSOLE_INFO_QUIET)) + stdio_print_current_devices(); + #ifdef CONFIG_VIDCONSOLE_AS_LCD if (strstr(stdoutname, CONFIG_VIDCONSOLE_AS_NAME)) printf("Warning: Please change '%s' to 'vidconsole' in stdout/stderr environment vars\n", CONFIG_VIDCONSOLE_AS_NAME); #endif
-#ifdef CONFIG_SYS_CONSOLE_ENV_OVERWRITE - /* set the environment variables (will overwrite previous env settings) */ - for (i = 0; i < MAX_FILES; i++) { - env_set(stdio_names[i], stdio_devices[i]->name); + if (IS_ENABLED(CONFIG_SYS_CONSOLE_ENV_OVERWRITE)) { + /* set the environment variables (will overwrite previous env settings) */ + for (i = 0; i < MAX_FILES; i++) + env_set(stdio_names[i], stdio_devices[i]->name); } -#endif /* CONFIG_SYS_CONSOLE_ENV_OVERWRITE */
gd->flags |= GD_FLG_DEVINIT; /* device initialization completed */
@@ -956,18 +932,16 @@ int console_init_r(void) else flushpoint = PRE_CONSOLE_FLUSHPOINT2_EVERYTHING_BUT_SERIAL;
-#ifdef CONFIG_SPLASH_SCREEN /* * suppress all output if splash screen is enabled and we have * a bmp to display. We redirect the output from frame buffer * console to serial console in this case or suppress it if * "silent" mode was requested. */ - if (env_get("splashimage") != NULL) { + if (IS_ENABLED(CONFIG_SPLASH_SCREEN) && env_get("splashimage")) { if (!(gd->flags & GD_FLG_SILENT)) outputdev = search_device (DEV_FLAGS_OUTPUT, "serial"); } -#endif
/* Scan devices looking for input and output devices */ list_for_each(pos, list) { @@ -1001,9 +975,8 @@ int console_init_r(void) #endif }
/* Setting environment variables */ for (i = 0; i < MAX_FILES; i++) {
Add a new function to access to console_devices only defined if CONFIG_IS_ENABLED(CONSOLE_MUX).
This path allows to remove #if CONFIG_IS_ENABLED(CONSOLE_MUX) in console_getc function.
common/console.c | 20 +++++++++++++------- 1 file changed, 13 insertions(+), 7 deletions(-)
diff --git a/common/console.c b/common/console.c index 6fc3957024..9a63eaa664 100644 --- a/common/console.c +++ b/common/console.c @@ -177,6 +177,11 @@ static struct stdio_dev *tstcdev; struct stdio_dev **console_devices[MAX_FILES]; int cd_count[MAX_FILES];
+static void __maybe_unused console_devices_set(int file, struct stdio_dev *dev) +{ + console_devices[file][0] = dev; +} + /* * This depends on tstc() always being called before getchar(). * This is guaranteed to be true because this routine is called @@ -275,6 +280,11 @@ static inline void console_doenv(int file, struct stdio_dev *dev) } #endif #else + +static void __maybe_unused console_devices_set(int file, struct stdio_dev *dev) +{ +} + static inline int console_getc(int file) { return stdio_devices[file]->getc(stdio_devices[file]); @@ -961,18 +971,14 @@ int console_init_r(void) if (outputdev != NULL) { console_setfile(stdout, outputdev); console_setfile(stderr, outputdev); -#if CONFIG_IS_ENABLED(CONSOLE_MUX) - console_devices[stdout][0] = outputdev; - console_devices[stderr][0] = outputdev; -#endif + console_devices_set(stdout, outputdev); + console_devices_set(stderr, outputdev); }
/* Initializes input console */ if (inputdev != NULL) { console_setfile(stdin, inputdev); -#if CONFIG_IS_ENABLED(CONSOLE_MUX) - console_devices[stdin][0] = inputdev; -#endif + console_devices_set(stdin, inputdev); }
Add helper functions to access to gd->console_out and gd->console_in with membuff API and replace the #ifdef CONFIG_CONSOLE_RECORD test by if (IS_ENABLED(CONFIG_CONSOLE_RECORD)) to respect the U-Boot coding rule.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com # Conflicts: # common/console.c ---
common/console.c | 86 +++++++++++++++++++++++++++++++++++++----------- 1 file changed, 66 insertions(+), 20 deletions(-)
diff --git a/common/console.c b/common/console.c index 9a63eaa664..0b864444bb 100644 --- a/common/console.c +++ b/common/console.c @@ -88,6 +88,56 @@ static int on_silent(const char *name, const char *value, enum env_op op, U_BOOT_ENV_CALLBACK(silent, on_silent); #endif
+#ifdef CONFIG_CONSOLE_RECORD +/* helper function: access to gd->console_out and gd->console_in */ +static void console_record_putc(const char c) +{ + if (gd->console_out.start) + membuff_putbyte((struct membuff *)&gd->console_out, c); +} + +static void console_record_puts(const char *s) +{ + if (gd->console_out.start) + membuff_put((struct membuff *)&gd->console_out, s, strlen(s)); +} + +static int console_record_getc(void) +{ + if (!gd->console_in.start) + return -1; + + return membuff_getbyte((struct membuff *)&gd->console_in); +} + +static int console_record_tstc(void) +{ + if (gd->console_in.start) { + if (membuff_peekbyte((struct membuff *)&gd->console_in) != -1) + return 1; + } + return 0; +} +#else +static void console_record_putc(char c) +{ +} + +static void console_record_puts(const char *s) +{ +} + +static int console_record_getc(void) +{ + return -1; +} + +static int console_record_tstc(void) +{ + return 0; +} +#endif + #if CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV) /* * if overwrite_console returns 1, the stdin, stderr and stdout @@ -420,15 +470,13 @@ int getchar(void) if (!gd->have_console) return 0;
-#ifdef CONFIG_CONSOLE_RECORD - if (gd->console_in.start) { - int ch; + if (IS_ENABLED(CONFIG_CONSOLE_RECORD)) { + int ch = console_record_getc();
- ch = membuff_getbyte((struct membuff *)&gd->console_in); if (ch != -1) - return 1; + return ch; } -#endif + if (gd->flags & GD_FLG_DEVINIT) { /* Get from the standard input */ return fgetc(stdin); @@ -445,12 +493,10 @@ int tstc(void)
if (!gd->have_console) return 0; -#ifdef CONFIG_CONSOLE_RECORD - if (gd->console_in.start) { - if (membuff_peekbyte((struct membuff *)&gd->console_in) != -1) - return 1; - } -#endif + + if (IS_ENABLED(CONFIG_CONSOLE_RECORD) && console_record_tstc()) + return 1; + if (gd->flags & GD_FLG_DEVINIT) { /* Test the standard input */ return ftstc(stdin); @@ -521,10 +567,10 @@ void putc(const char c) { if (!gd) return; -#ifdef CONFIG_CONSOLE_RECORD - if ((gd->flags & GD_FLG_RECORD) && gd->console_out.start) - membuff_putbyte((struct membuff *)&gd->console_out, c); -#endif + + if (IS_ENABLED(CONFIG_CONSOLE_RECORD) && (gd->flags & GD_FLG_RECORD)) + console_record_putc(c); + #ifdef CONFIG_SANDBOX /* sandbox can send characters to stdout before it has a console */ if (!(gd->flags & GD_FLG_SERIAL_READY)) { @@ -564,10 +610,10 @@ void puts(const char *s) { if (!gd) return; -#ifdef CONFIG_CONSOLE_RECORD - if ((gd->flags & GD_FLG_RECORD) && gd->console_out.start) - membuff_put((struct membuff *)&gd->console_out, s, strlen(s)); -#endif + + if (IS_ENABLED(CONFIG_CONSOLE_RECORD) && (gd->flags & GD_FLG_RECORD)) + console_record_puts(s); + #ifdef CONFIG_SANDBOX /* sandbox can send characters to stdout before it has a console */ if (!(gd->flags & GD_FLG_SERIAL_READY)) {
Hi Patrick,
# common/console.c
But see below
return -1;
return 1;
return -1;
+} +#endif
- if overwrite_console returns 1, the stdin, stderr and stdout
int ch;
return 1;
return ch; }
-#endif
return 1;
-#endif
return 1;
-#endif
Given your functions above I wonder why you need the IS_ENABLED() here? Maybe even move the gd-.flags check into those functions?
-#endif
#ifdef CONFIG_SANDBOX /* sandbox can send characters to stdout before it has a console */ if (!(gd->flags & GD_FLG_SERIAL_READY)) { -- 2.17.1
On 12/12/20 4:39 PM, Simon Glass wrote:
Hi Patrick,
# common/console.c
But see below
return -1;
return 1;
return -1;
+} +#endif
- #if CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV) /*
int ch;
return 1;
return ch; }
-#endif
return 1;
-#endif
return 1;
-#endif
In fact it is not needed.
I limit the difference to easy the review and to be coherent with other test on flags, for example:
But you are right it is more elegant if I move the 2 tests in the helper function.
I will do it it in V2
Regards,
Patrick
Add the helper function console_tstc_check() and replace the test #if CONFIG_IS_ENABLED(CONSOLE_MUX) to a simple if to respect the U-Boot coding rule.
No functional change.
common/console.c | 36 ++++++++++++++++++++++++------------ 1 file changed, 24 insertions(+), 12 deletions(-)
diff --git a/common/console.c b/common/console.c index 0b864444bb..c570cd88cf 100644 --- a/common/console.c +++ b/common/console.c @@ -248,6 +248,12 @@ static int console_getc(int file) return ret; }
+/* Upper layer may have already called tstc(): check the saved result */ +static bool console_tstc_check(void) +{ + return !!tstcdev; +} + static int console_tstc(int file) { int i, ret; @@ -340,6 +346,11 @@ static inline int console_getc(int file) return stdio_devices[file]->getc(stdio_devices[file]); }
+static bool console_tstc_check(void) +{ + return false; +} + static inline int console_tstc(int file) { return stdio_devices[file]->tstc(stdio_devices[file]); @@ -397,18 +408,19 @@ int fgetc(int file) */ for (;;) { WATCHDOG_RESET(); -#if CONFIG_IS_ENABLED(CONSOLE_MUX) - /* - * Upper layer may have already called tstc() so - * check for that first. - */ - if (tstcdev != NULL) - return console_getc(file); - console_tstc(file); -#else - if (console_tstc(file)) - return console_getc(file); -#endif + if (CONFIG_IS_ENABLED(CONSOLE_MUX)) { + /* + * Upper layer may have already called tstc() so + * check for that first. + */ + if (console_tstc_check()) + return console_getc(file); + console_tstc(file); + } else { + if (console_tstc(file)) + return console_getc(file); + } + /* * If the watchdog must be rate-limited then it should * already be handled in board-specific code.
Hi Patrick,
This is checking if we actually have a device, right? I think has_tstcdev() would be better.
Also could you add a comment in the testcdev variable declaration as to what this variable actually is for?
return !!tstcdev;
return false;
console_tstc(file);
-#else
-#endif
console_tstc(file);
} else {
-- 2.17.1
Patrick DELAUNAY
Patrick Delaunay
