[U-Boot] [PATCH] spl: mmc: Skip RAW mode ARGS sectors if not defined
RAW mode ARGS sector doesn't have to be used for all falcon boot. Skip loading ARGS sectors if not defined.
Signed-off-by: York Sun york.sun@nxp.com --- common/spl/spl_mmc.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index db5be3d..0b2f059 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -191,9 +191,11 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, static int mmc_load_image_raw_os(struct spl_image_info *spl_image, struct mmc *mmc) { - unsigned long count; int ret;
+#if defined(CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR) + unsigned long count; + count = blk_dread(mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, @@ -204,6 +206,7 @@ static int mmc_load_image_raw_os(struct spl_image_info *spl_image, #endif return -1; } +#endif /* CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR */
ret = mmc_load_image_raw_sector(spl_image, mmc, CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR);
York Sun
