[U-Boot] [PATCH] ppc4xx: Implement is_pci_host() for 405 CPUs
This patch implements the is_pci_host() function in a similiar way as it is used on 440 targets.
The former path with CONFIG_PCI_HOST == PCI_HOST_AUTO does not build on 405EP targets because checking the PCI arbiter is different. So putting the fixed code into a separate function makes the code more readable.
Also using is_pci_host() on 405 brings 405 and 440 PCI code a little bit closer.
In preparation for an upcoming 405EP based PMC module I made this function weak so that it can be overwritten from board specific code.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- cpu/ppc4xx/4xx_pci.c | 19 ++++++++++++++++--- 1 files changed, 16 insertions(+), 3 deletions(-)
diff --git a/cpu/ppc4xx/4xx_pci.c b/cpu/ppc4xx/4xx_pci.c index 99b8e2f..31ca85d 100644 --- a/cpu/ppc4xx/4xx_pci.c +++ b/cpu/ppc4xx/4xx_pci.c @@ -99,6 +99,19 @@ ushort pmc405_pci_subsys_deviceid(void);
/*#define DEBUG*/
+int __is_pci_host(struct pci_controller *hose) +{ +#if defined(CONFIG_405GP) + if (mfdcr(strap) & PSR_PCI_ARBIT_EN) + return 1; +#elif defined (CONFIG_405EP) + if (mfdcr(cpc0_pci) & CPC0_PCI_ARBIT_EN) + return 1; +#endif + return 0; +} +int is_pci_host(struct pci_controller *hose) __attribute__((weak, alias("__is_pci_host"))); + /*-----------------------------------------------------------------------------+ * pci_init. Initializes the 405GP PCI Configuration regs. *-----------------------------------------------------------------------------*/ @@ -270,7 +283,7 @@ void pci_405gp_init(struct pci_controller *hose) */ pci_write_config_word(PCIDEVID_405GP, PCI_SUBSYSTEM_VENDOR_ID, CONFIG_SYS_PCI_SUBSYS_VENDORID); #ifdef CONFIG_CPCI405 - if (mfdcr(strap) & PSR_PCI_ARBIT_EN) + if (is_pci_host(hose)) pci_write_config_word(PCIDEVID_405GP, PCI_SUBSYSTEM_ID, CONFIG_SYS_PCI_SUBSYS_DEVICEID); else pci_write_config_word(PCIDEVID_405GP, PCI_SUBSYSTEM_ID, CONFIG_SYS_PCI_SUBSYS_DEVICEID2); @@ -295,7 +308,7 @@ void pci_405gp_init(struct pci_controller *hose)
#if (CONFIG_PCI_HOST != PCI_HOST_ADAPTER) #if (CONFIG_PCI_HOST == PCI_HOST_AUTO) - if ((mfdcr(strap) & PSR_PCI_ARBIT_EN) || + if (is_pci_host(hose) || (((s = getenv("pciscan")) != NULL) && (strcmp(s, "yes") == 0))) #endif { @@ -325,7 +338,7 @@ void pci_405gp_init(struct pci_controller *hose) * Scan the PCI bus and configure devices found. *--------------------------------------------------------------------------*/ #if (CONFIG_PCI_HOST == PCI_HOST_AUTO) - if ((mfdcr(strap) & PSR_PCI_ARBIT_EN) || + if (is_pci_host(hose) || (((s = getenv("pciscan")) != NULL) && (strcmp(s, "yes") == 0))) #endif {
Applied to ppc4xx. Thanks.
Best regards, Stefan
Matthias Fuchs
Stefan Roese
