[U-Boot] [PATCH v5 1/3] armv8:fsl-layerscape: Consolidate registers space defination for CCI-400 bus
CoreLink Cache Coherent Interconnect (CCI) is ARM BUS which provides full cache coherency between two clusters of multi-core CPUs and I/O coherency for devices and I/O masters.
This patch add new CONFIG defination "SYS_FSL_HAS_CCI400" and moves existing register space definaton of CCI-400 bus from immap_lsch2 to fsl_immap, so that it can be used for both chasis 2 and chasis 3.
"CONFIG_SYS_CCI400_ADDR" is depricated and new SYS_CCI400_OFFSET is introduced in Kconfig
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- v3: This is v3 for https://patchwork.ozlabs.org/patch/731464/ v4: Header file included in middle of the file in cpu.c v5: Moving ls1021aqds to 2/3-armv7 of this patch-set
README | 9 ++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 13 ++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 +++-- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 49 --------------------- board/freescale/ls1012afrdm/ls1012afrdm.c | 4 +- board/freescale/ls1012aqds/ls1012aqds.c | 4 +- board/freescale/ls1012ardb/ls1012ardb.c | 3 +- include/fsl_immap.h | 51 ++++++++++++++++++++++ 9 files changed, 88 insertions(+), 56 deletions(-)
diff --git a/README b/README index 3735916..a66a7ae 100644 --- a/README +++ b/README @@ -312,6 +312,15 @@ Many of the options are named exactly as the corresponding Linux kernel configuration options. The intention is to make it easier to build a config tool - later.
+- ARM Platform Bus Type(CCI): + CoreLink Cache Coherent Interconnect (CCI) is ARM BUS which + provides full cache coherency between two clusters of multi-core + CPUs and I/O coherency for devices and I/O masters + + CONFIG_SYS_FSL_HAS_CCI400 + + Defined For SoC that has cache coherent interconnect + CCN-400
The following options need to be configured:
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5825f9b..1132969 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -84,6 +84,7 @@ config ARCH_LS2080A
config FSL_LSCH2 bool + select SYS_FSL_HAS_CCI400 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_5 select SYS_FSL_SEC_BE @@ -247,6 +248,15 @@ config QSPI_AHB_INIT But some QSPI flash size up to 64MBytes, so initialize the QSPI AHB bus for those flashes to support the full QSPI flash size.
+config SYS_CCI400_OFFSET + hex "Offset for CCI400 base" + depends on SYS_FSL_HAS_CCI400 + default 0x3090000 if ARCH_LS1088A + default 0x180000 if FSL_LSCH2 + help + Offset for CCI400 base + CCI400 base addr = CCSRBAR + CCI400_OFFSET + config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A @@ -254,6 +264,9 @@ config SYS_FSL_IFC_BANK_COUNT default 4 if ARCH_LS1046A default 8 if ARCH_LS2080A
+config SYS_FSL_HAS_CCI400 + bool + config SYS_FSL_HAS_DP_DDR bool
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index c6fede3..ec58065 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -16,6 +16,7 @@ #include <asm/arch/soc.h> #include <asm/arch/cpu.h> #include <asm/arch/speed.h> +#include <fsl_immap.h> #include <asm/arch/mp.h> #include <efi_loader.h> #include <fm_eth.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index aee1ffa..ddb7d82 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <fsl_immap.h> #include <fsl_ifc.h> #include <ahci.h> #include <scsi.h> @@ -285,7 +286,8 @@ static void erratum_a008850_early(void) { #ifdef CONFIG_SYS_FSL_ERRATUM_A008850 /* part 1 of 2 */ - struct ccsr_cci400 __iomem *cci = (void *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 __iomem *cci = (void *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); struct ccsr_ddr __iomem *ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR;
/* Skip if running at lower exception level */ @@ -304,7 +306,8 @@ void erratum_a008850_post(void) { #ifdef CONFIG_SYS_FSL_ERRATUM_A008850 /* part 2 of 2 */ - struct ccsr_cci400 __iomem *cci = (void *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 __iomem *cci = (void *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); struct ccsr_ddr __iomem *ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; u32 tmp;
@@ -439,7 +442,8 @@ int setup_chip_volt(void)
void fsl_lsch2_early_init_f(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR;
#ifdef CONFIG_LAYERSCAPE_NS_ACCESS diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 8ad199f..560ad4e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -15,7 +15,6 @@ #define CONFIG_SYS_DCSR_COP_CCP_ADDR (CONFIG_SYS_DCSRBAR + 0x02008040)
#define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) -#define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) #define CONFIG_SYS_GIC400_ADDR (CONFIG_SYS_IMMR + 0x00400000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) #define SYS_FSL_QSPI_ADDR (CONFIG_SYS_IMMR + 0x00550000) @@ -543,54 +542,6 @@ struct ccsr_serdes { u8 res_19a0[0x2000-0x19a0]; /* from 0x19a0 to 0x1fff */ };
-#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 -#define CCI400_CTRLORD_EN_BARRIER 0 -#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 -#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 -#define CCI400_SNOOP_REQ_EN 0x00000001 - -/* CCI-400 registers */ -struct ccsr_cci400 { - u32 ctrl_ord; /* Control Override */ - u32 spec_ctrl; /* Speculation Control */ - u32 secure_access; /* Secure Access */ - u32 status; /* Status */ - u32 impr_err; /* Imprecise Error */ - u8 res_14[0x100 - 0x14]; - u32 pmcr; /* Performance Monitor Control */ - u8 res_104[0xfd0 - 0x104]; - u32 pid[8]; /* Peripheral ID */ - u32 cid[4]; /* Component ID */ - struct { - u32 snoop_ctrl; /* Snoop Control */ - u32 sha_ord; /* Shareable Override */ - u8 res_1008[0x1100 - 0x1008]; - u32 rc_qos_ord; /* read channel QoS Value Override */ - u32 wc_qos_ord; /* read channel QoS Value Override */ - u8 res_1108[0x110c - 0x1108]; - u32 qos_ctrl; /* QoS Control */ - u32 max_ot; /* Max OT */ - u8 res_1114[0x1130 - 0x1114]; - u32 target_lat; /* Target Latency */ - u32 latency_regu; /* Latency Regulation */ - u32 qos_range; /* QoS Range */ - u8 res_113c[0x2000 - 0x113c]; - } slave[5]; /* Slave Interface */ - u8 res_6000[0x9004 - 0x6000]; - u32 cycle_counter; /* Cycle counter */ - u32 count_ctrl; /* Count Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_9010[0xa000 - 0x9010]; - struct { - u32 event_select; /* Event Select */ - u32 event_count; /* Event Count */ - u32 counter_ctrl; /* Counter Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_a010[0xb000 - 0xa010]; - } pcounter[4]; /* Performance Counter */ - u8 res_e004[0x10000 - 0xe004]; -}; - /* MMU 500 */ #define SMMU_SCR0 (SMMU_BASE + 0x0) #define SMMU_SCR1 (SMMU_BASE + 0x4) diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 25d22d2..9afd1c4 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -71,7 +71,9 @@ int board_early_init_f(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); + /* * Set CCI-400 control override register to enable barrier * transaction diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 97ab340..406194d 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -106,8 +106,8 @@ int misc_init_r(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *) - CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET);
/* Set CCI-400 control override register to enable barrier * transaction */ diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index a21e4c4..c6c1c71 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -104,7 +104,8 @@ int board_early_init_f(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); /* * Set CCI-400 control override register to enable barrier * transaction diff --git a/include/fsl_immap.h b/include/fsl_immap.h index b1c4fe7..4f5a19c 100644 --- a/include/fsl_immap.h +++ b/include/fsl_immap.h @@ -133,4 +133,55 @@ struct ccsr_ddr { u8 res_e5c[164]; u32 debug[64]; /* debug_1 to debug_64 */ }; + +#ifdef CONFIG_SYS_FSL_HAS_CCI400 +#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 +#define CCI400_CTRLORD_EN_BARRIER 0 +#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 +#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 +#define CCI400_SNOOP_REQ_EN 0x00000001 + +/* CCI-400 registers */ +struct ccsr_cci400 { + u32 ctrl_ord; /* Control Override */ + u32 spec_ctrl; /* Speculation Control */ + u32 secure_access; /* Secure Access */ + u32 status; /* Status */ + u32 impr_err; /* Imprecise Error */ + u8 res_14[0x100 - 0x14]; + u32 pmcr; /* Performance Monitor Control */ + u8 res_104[0xfd0 - 0x104]; + u32 pid[8]; /* Peripheral ID */ + u32 cid[4]; /* Component ID */ + struct { + u32 snoop_ctrl; /* Snoop Control */ + u32 sha_ord; /* Shareable Override */ + u8 res_1008[0x1100 - 0x1008]; + u32 rc_qos_ord; /* read channel QoS Value Override */ + u32 wc_qos_ord; /* read channel QoS Value Override */ + u8 res_1108[0x110c - 0x1108]; + u32 qos_ctrl; /* QoS Control */ + u32 max_ot; /* Max OT */ + u8 res_1114[0x1130 - 0x1114]; + u32 target_lat; /* Target Latency */ + u32 latency_regu; /* Latency Regulation */ + u32 qos_range; /* QoS Range */ + u8 res_113c[0x2000 - 0x113c]; + } slave[5]; /* Slave Interface */ + u8 res_6000[0x9004 - 0x6000]; + u32 cycle_counter; /* Cycle counter */ + u32 count_ctrl; /* Count Control */ + u32 overflow_status; /* Overflow Flag Status */ + u8 res_9010[0xa000 - 0x9010]; + struct { + u32 event_select; /* Event Select */ + u32 event_count; /* Event Count */ + u32 counter_ctrl; /* Counter Control */ + u32 overflow_status; /* Overflow Flag Status */ + u8 res_a010[0xb000 - 0xa010]; + } pcounter[4]; /* Performance Counter */ + u8 res_e004[0x10000 - 0xe004]; +}; +#endif + #endif /* __FSL_IMMAP_H */
This patch add new CONFIG defination "FSL_SYS_HAS_CCI400" and removes register space definaton of CCI-400 bus from immap_ls102xa to fsl_immap, since same is defined there already
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v3: This is v3 for https://patchwork.ozlabs.org/patch/731464/ v4: No change v5: Moving ls1021aqds here
arch/arm/cpu/armv7/ls102xa/Kconfig | 12 ++++++ arch/arm/cpu/armv7/ls102xa/soc.c | 3 +- arch/arm/include/asm/arch-ls102xa/config.h | 1 - arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 49 +---------------------- board/freescale/ls1021aqds/ls1021aqds.c | 9 +++-- 5 files changed, 22 insertions(+), 52 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 6a013b2..61dd522 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -5,6 +5,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009663 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 + select SYS_FSL_HAS_CCI400 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE if SYS_FSL_DDR @@ -48,9 +49,20 @@ config SECURE_BOOT Enable Freescale Secure Boot feature. Normally selected by defconfig. If unsure, do not change.
+config SYS_CCI400_OFFSET + hex "Offset for CCI400 base" + depends on SYS_FSL_HAS_CCI400 + default 0x180000 + help + Offset for CCI400 base. + CCI400 base addr = CCSRBAR + CCI400_OFFSET + config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
+config SYS_FSL_HAS_CCI400 + bool + config SYS_FSL_SRDS_1 bool
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index b84a1a6..c043b82 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -80,7 +80,8 @@ void erratum_a010315(void) int arch_soc_init(void) { struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
#ifdef CONFIG_LAYERSCAPE_NS_ACCESS diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index fc954c5..ff0fc47 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -20,7 +20,6 @@
#define SYS_FSL_GIC_ADDR (CONFIG_SYS_IMMR + 0x00400000) #define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) -#define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) #define CONFIG_SYS_FSL_CSU_ADDR (CONFIG_SYS_IMMR + 0x00510000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x00560000) diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index c34fd63..1415b0b 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -6,6 +6,7 @@
#ifndef __ASM_ARCH_LS102XA_IMMAP_H_ #define __ASM_ARCH_LS102XA_IMMAP_H_ +#include <fsl_immap.h>
#define SVR_MAJ(svr) (((svr) >> 4) & 0xf) #define SVR_MIN(svr) (((svr) >> 0) & 0xf) @@ -374,53 +375,7 @@ struct ccsr_serdes { u8 res_a00[0x1000-0xa00]; /* from 0xa00 to 0xfff */ };
-#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 -#define CCI400_CTRLORD_EN_BARRIER 0 -#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 -#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 -#define CCI400_SNOOP_REQ_EN 0x00000001 - -/* CCI-400 registers */ -struct ccsr_cci400 { - u32 ctrl_ord; /* Control Override */ - u32 spec_ctrl; /* Speculation Control */ - u32 secure_access; /* Secure Access */ - u32 status; /* Status */ - u32 impr_err; /* Imprecise Error */ - u8 res_14[0x100 - 0x14]; - u32 pmcr; /* Performance Monitor Control */ - u8 res_104[0xfd0 - 0x104]; - u32 pid[8]; /* Peripheral ID */ - u32 cid[4]; /* Component ID */ - struct { - u32 snoop_ctrl; /* Snoop Control */ - u32 sha_ord; /* Shareable Override */ - u8 res_1008[0x1100 - 0x1008]; - u32 rc_qos_ord; /* read channel QoS Value Override */ - u32 wc_qos_ord; /* read channel QoS Value Override */ - u8 res_1108[0x110c - 0x1108]; - u32 qos_ctrl; /* QoS Control */ - u32 max_ot; /* Max OT */ - u8 res_1114[0x1130 - 0x1114]; - u32 target_lat; /* Target Latency */ - u32 latency_regu; /* Latency Regulation */ - u32 qos_range; /* QoS Range */ - u8 res_113c[0x2000 - 0x113c]; - } slave[5]; /* Slave Interface */ - u8 res_6000[0x9004 - 0x6000]; - u32 cycle_counter; /* Cycle counter */ - u32 count_ctrl; /* Count Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_9010[0xa000 - 0x9010]; - struct { - u32 event_select; /* Event Select */ - u32 event_count; /* Event Count */ - u32 counter_ctrl; /* Counter Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_a010[0xb000 - 0xa010]; - } pcounter[4]; /* Performance Counter */ - u8 res_e004[0x10000 - 0xe004]; -}; +
/* AHCI (sata) register map */ struct ccsr_ahci { diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index d81d8ab..8b3f4ad 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -204,7 +204,8 @@ int board_early_init_f(void) #ifdef CONFIG_SPL_BUILD void board_init_f(ulong dummy) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
#ifdef CONFIG_NAND_BOOT @@ -425,7 +426,8 @@ int misc_init_r(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
#ifdef CONFIG_SYS_FSL_ERRATUM_A010315 @@ -460,7 +462,8 @@ int board_init(void) #if defined(CONFIG_DEEP_SLEEP) void board_sleep_prepare(void) { - struct ccsr_cci400 __iomem *cci = (void *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 __iomem *cci = (void *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
major = get_soc_major_rev();
This config is depricated and new config SYS_CCI400_OFFSET is introduced in Kconfig
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v3: This is v3 for https://patchwork.ozlabs.org/patch/731464/ v4: No change v5: NO change
scripts/config_whitelist.txt | 1 - 1 file changed, 1 deletion(-)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2dacf79..a4c0c6e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2490,7 +2490,6 @@ CONFIG_SYS_CACHE_STASHING CONFIG_SYS_CADMUS_BASE_REG CONFIG_SYS_CBSIZE CONFIG_SYS_CCCR -CONFIG_SYS_CCI400_ADDR CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR_PHYS_HIGH
v3: This is v3 for https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwork... v4: Header file included in middle of the file in cpu.c v5: Moving ls1021aqds to 2/3-armv7 of this patch-set
Squashed three patches into one commit. Applied to fsl-qoriq master. Thanks.
York
Ashish Kumar
York Sun
