[PATCH] usb: Fix test dependency on ext4write command
The tests test_usb_ext4load_ext4write, test_usb_ext2load and test_usb_load depend on the command ext4write being present not just the feature of being able to write to an ext4 file system. So update their dependencies to include the ext4write command itself. This will prevent spurious test failures when running the USB tests against USB storage with an ext2/ext4 partition but no ext4write command available.
Fixes: 1c5b6edad381 ("test/py: usb: Add tests for USB device") Signed-off-by: Andrew Goodbody andrew.goodbody@linaro.org ---
test/py/tests/test_usb.py | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/test/py/tests/test_usb.py b/test/py/tests/test_usb.py index fb3d20f082..b86fc290c7 100644 --- a/test/py/tests/test_usb.py +++ b/test/py/tests/test_usb.py @@ -382,7 +382,7 @@ def test_usb_ext4ls(u_boot_console):
@pytest.mark.buildconfigspec('cmd_usb') @pytest.mark.buildconfigspec('cmd_ext4') -@pytest.mark.buildconfigspec('ext4_write') +@pytest.mark.buildconfigspec('cmd_ext4_write') @pytest.mark.buildconfigspec('cmd_memory') def test_usb_ext4load_ext4write(u_boot_console): devices, controllers, storage_device = test_usb_part(u_boot_console) @@ -469,7 +469,7 @@ def test_usb_ext2ls(u_boot_console): @pytest.mark.buildconfigspec('cmd_usb') @pytest.mark.buildconfigspec('cmd_ext2') @pytest.mark.buildconfigspec('cmd_ext4') -@pytest.mark.buildconfigspec('ext4_write') +@pytest.mark.buildconfigspec('cmd_ext4_write') @pytest.mark.buildconfigspec('cmd_memory') def test_usb_ext2load(u_boot_console): devices, controllers, storage_device = test_usb_part(u_boot_console) @@ -543,6 +543,7 @@ def test_usb_ls(u_boot_console): pytest.skip('No partition detected')
@pytest.mark.buildconfigspec('cmd_usb') +@pytest.mark.buildconfigspec('cmd_ext4_write') @pytest.mark.buildconfigspec('cmd_fs_generic') def test_usb_load(u_boot_console): devices, controllers, storage_device = test_usb_part(u_boot_console)
+CC test expert Simon
Reviewed-by: Love Kumar love.kumar@amd.com
Ping
diff --git a/test/py/tests/test_usb.py b/test/py/tests/test_usb.py index fb3d20f082..b86fc290c7 100644 --- a/test/py/tests/test_usb.py +++ b/test/py/tests/test_usb.py @@ -382,7 +382,7 @@ def test_usb_ext4ls(u_boot_console): @pytest.mark.buildconfigspec('cmd_usb') @pytest.mark.buildconfigspec('cmd_ext4') -@pytest.mark.buildconfigspec('ext4_write') +@pytest.mark.buildconfigspec('cmd_ext4_write') @pytest.mark.buildconfigspec('cmd_memory') def test_usb_ext4load_ext4write(u_boot_console): devices, controllers, storage_device = test_usb_part(u_boot_console) @@ -469,7 +469,7 @@ def test_usb_ext2ls(u_boot_console): @pytest.mark.buildconfigspec('cmd_usb') @pytest.mark.buildconfigspec('cmd_ext2') @pytest.mark.buildconfigspec('cmd_ext4') -@pytest.mark.buildconfigspec('ext4_write') +@pytest.mark.buildconfigspec('cmd_ext4_write') @pytest.mark.buildconfigspec('cmd_memory') def test_usb_ext2load(u_boot_console): devices, controllers, storage_device = test_usb_part(u_boot_console) @@ -543,6 +543,7 @@ def test_usb_ls(u_boot_console): pytest.skip('No partition detected') @pytest.mark.buildconfigspec('cmd_usb') +@pytest.mark.buildconfigspec('cmd_ext4_write') @pytest.mark.buildconfigspec('cmd_fs_generic') def test_usb_load(u_boot_console): devices, controllers, storage_device = test_usb_part(u_boot_console)
Ping
Simon ?
Andrew Goodbody
Kumar, Love
