[U-Boot] [PATCH] ARM: uniphier: reserve memory for DRAM PHY training on PH1-LD20
The DRAM PHY on PH1-LD20 is able to calibrate PHY parameters periodically. This improves PHY adjustment against the voltage and temperature deviation. Instead, it requires 64 byte scratch memory in each DRAM channel for the dynamic training. The memory regions must be reserved in DT before jumping to the kernel.
The scratch area can be anywhere in each DRAM channel, but the DRAM init code in SPL currently assigns it at the end of each channel. So, it makes sense to reserve the regions dynamically by U-Boot instead of statically embedding it in the DT in Linux. Anyway, a boot-loader should know much more about memory initialization than the kernel.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/Kconfig | 1 + arch/arm/mach-uniphier/Kconfig | 1 + arch/arm/mach-uniphier/dram_init.c | 40 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 42 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e75c4c0..5aaae96 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -801,6 +801,7 @@ config ARCH_UNIPHIER select SPL select OF_CONTROL select SPL_OF_CONTROL + select OF_LIBFDT select DM select SPL_DM select DM_GPIO diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index ae763ad..b2374db 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -32,6 +32,7 @@ config ARCH_UNIPHIER_LD20 bool "UniPhier PH1-LD20 SoC" select ARM64 select SPL_SEPARATE_BSS + select OF_BOARD_SETUP
endchoice
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index ef0e2e8..06300de 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -9,6 +9,9 @@ #include <fdtdec.h> #include <linux/err.h>
+#include "init.h" +#include "soc-info.h" + DECLARE_GLOBAL_DATA_PTR;
static const void *get_memory_reg_prop(const void *fdt, int *lenp) @@ -81,3 +84,40 @@ void dram_init_banksize(void) (unsigned long)gd->bd->bi_dram[i].size); } } + +#ifdef CONFIG_OF_BOARD_SETUP +/* + * The DRAM PHY requires 64 byte scratch area in each DRAM channel + * for its dynamic PHY training feature. + */ +int ft_board_setup(void *fdt, bd_t *bd) +{ + const struct uniphier_board_data *param; + unsigned long rsv_addr; + const unsigned long rsv_size = 64; + int ch, ret; + + if (uniphier_get_soc_type() != SOC_UNIPHIER_LD20) + return 0; + + param = uniphier_get_board_param(); + if (!param) { + printf("failed to get board parameter\n"); + return -ENOENT; + } + + for (ch = 0; ch < param->dram_nr_ch; ch++) { + rsv_addr = param->dram_ch[ch].base + param->dram_ch[ch].size; + rsv_addr -= rsv_size; + + ret = fdt_add_mem_rsv(fdt, rsv_addr, rsv_size); + if (ret) + return ret; + + printf(" Reserved memory region for DRAM PHY training: addr=%lx size=%lx\n", + rsv_addr, rsv_size); + } + + return 0; +} +#endif
Masahiro Yamada
