[U-Boot-Users] Large initramfs
Hello,
I'm having trouble getting U-boot (based on 1.3.0) to boot a MV Pro 5.0 (based on 2.6.18) kernel image with a large built-in initramfs on the PPC440 Taishan eval board. The boot process hangs after the output of "Finalizing device tree..." I'm attempting to boot the cuImage target.
I've made modifications to U-boot for preparations for our own PPC440 design. One of the changes was to the file ../lib_ppc/board.c to remove the logic that forces the command line and bd_info structure into the first 8 MB of memory. However, that didn't help.
I can boot the kernel image if it's built without the initramfs. That is, I can get past this hang scenario. Obviously things aren't all that great without out an initramfs or initrd but it seems to prove that the built kernel and my U-boot modifications fundamentally works and leads me to believe the problem is related to the initramfs or its size.
Does anybody have any experience using a kernel+initramfs that is larger than 8MB? Larger than 16MB?
Any help/comments would be greatly appreciated.
Bill T.
Boot progress 80 (0x50) Using ppc_4xx_eth0 device TFTP from server 10.10.5.112; our IP address is 10.10.5.207 Filename 'cuImage.taishan3'. Load address: 0x8000000 Loading: ##############################################################. .... done Bytes transferred = 25962438 (18c27c6 hex) Boot progress 81 (0x51) Boot progress 84 (0x54) Boot progress 1 (0x1) ## Booting image at 08000000 ... Boot progress 2 (0x2) Boot progress 3 (0x3) Image Name: Linux-2.6.18_pro500-440gx_taisha Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 25962374 Bytes = 24.8 MB Load Address: 01c00000 Entry Point: 01c0040c Verifying Checksum ... OK Boot progress 4 (0x4) Boot progress 5 (0x5) Boot progress 6 (0x6) Uncompressing Kernel Image ... OK Boot progress 7 (0x7) Boot progress 8 (0x8) ## Current stack ends at 0x0FEBE180 => set upper limit to 0x0FEBD980 ## cmdline at 0x0FEBD880 ... 0x0FEBD8DE Boot progress 14 (0xe) No initrd ## Transferring control to Linux (at address 01c0040c) ... Boot progress 15 (0xf) Calling kernel(0x1c0040c): (0febd7d0, 00000000, 00000000, 0febd880, 0febd8de) CPU clock-frequency <- 0x2f34f600 (792MHz) CPU timebase-frequency <- 0x2f34f600 (792MHz) /plb: clock-frequency <- bcd3d80 (198MHz) /plb/opb: clock-frequency <- 3ef1480 (66MHz) /plb/opb/ebc: clock-frequency <- 3ef1480 (66MHz) /plb/opb/serial@40000200: clock-frequency <- a8c000 (11MHz) /plb/opb/serial@40000300: clock-frequency <- a8c000 (11MHz) Memory <- <0x0 0x0 0x10000000> (256MB) ENET0: local-mac-address <- 02:0c:4f:35:00:16 ENET1: local-mac-address <- 31:2e:32:00:55:2d
zImage starting: loaded at 0x01c00000 (sp: 0x03732ed0) Allocating 0x1b27ea4 bytes for kernel ... gunzipping (0x00000000 <- 0x01c0e000:0x03731378)...done 0x1afa0c0 bytes
Linux/PowerPC load: ip=10.10.5.207:10.10.5.112:10.10.5.1:255.255.255.0:eval1:eth0:off panic=1 console=ttyS1,115200 Finalizing device tree... flat tree at 0x373f3a0
Templeton, Bill
