[U-Boot] [PATCH] ppc4xx: Remove bogus comment from start.S
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/start.S | 17 +++-------------- 1 files changed, 3 insertions(+), 14 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index 65195f5..c36c13b 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -48,21 +48,10 @@ *------------------------------------------------------------------------------- */
-/* U-Boot - Startup Code for AMCC 4xx PowerPC based Embedded Boards - * - * - * The processor starts at 0xfffffffc and the code is executed - * from flash/rom. - * in memory, but as long we don't jump around before relocating. - * board_init lies at a quite high address and when the cpu has - * jumped there, everything is ok. - * This works because the cpu gives the FLASH (CS0) the whole - * address space at startup, and board_init lies as a echo of - * the flash somewhere up there in the memorymap. - * - * board_init will change CS0 to be positioned at the correct - * address and (s)dram will be positioned at address 0 +/* + * Startup code for IBM/AMCC PowerPC 4xx (PPC4xx) based boards */ + #include <asm-offsets.h> #include <config.h> #include <asm/ppc4xx.h>
Dear Stefan Roese,
- The processor starts at 0xfffffffc and the code is executed
- from flash/rom.
- in memory, but as long we don't jump around before relocating.
- board_init lies at a quite high address and when the cpu has
- jumped there, everything is ok.
- This works because the cpu gives the FLASH (CS0) the whole
- address space at startup, and board_init lies as a echo of
- the flash somewhere up there in the memorymap.
- board_init will change CS0 to be positioned at the correct
- address and (s)dram will be positioned at address 0
- Startup code for IBM/AMCC PowerPC 4xx (PPC4xx) based boards
It appears that the old comment contained some information about how booting and especially address resolution works on 4xx. Is there some way to keep this (non-obvious, at least to me) information, instead of just deleting it?
Hi Wolfgang,
The old comment was really screwed up. I'll send a patch with a (hopefully) better description shortly.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
