fitImage align 8-byte for ARM64
Hi!
I have had trouble booting a fitImage packed kernel for dragonboard410c, which is an ARM64 platform. After days and days of debugging, I found that the fdt is 4-byte aligned. But within the linux kernel, Documentation/arm64/booting.txt says, fdt must be 8 byte aligned.
If I change the alignment by means of fdt_high, the Kernel boots, otherwise, it hangs.
Is there an option to align the fitImage to 8-byte boundaries, and if not, is it feasible to submit a patch or will this never have a chance to get merged?!
Thanks and Regards,
Matthias Schöpfer
On Mon, Jan 06, 2020 at 01:47:25PM +0100, Matthias Schoepfer wrote:
Hi!
That's interesting. It sounds like you need to look at boot_relocate_fdt() perhaps? Thanks!
Hi Tom,
thanks for your reply. As far as I can understand this code, only if fdt_high is set to 0xffffffffffffffff (which is the very case for dragonboard410c) a not aligned mapping of the fdt can happen. In this case, the address is images->ft_addr, which I *think* comes from the fitImage creation?!
I wonder, whether just removing fdt_high is a valid solution...
Regards,
Matthias
Hi!
On Mon, Jan 06, 2020 at 04:22:02PM +0100, Matthias Schoepfer wrote:
Hi Tom,
Ah. Yes, generally speaking fdt_high shouldn't be set as it stops us from relocating things to ensure alignment. Making use of bootm_size instead (to ensure that everything is within a certain area of memory) is better for the general case. So please, update the default environment and CC the board maintainer, thanks!
Hi Tom, Simon,
Hi!
When I use the FIT image, I met another issue:
- The emmc/sd read is by block which is 512byte;
- The FIT image header is always not 512byte align, and the entry of
image in FIT is always not aligned to block;
- The image read from block device always need memory coppy which
make it slow.
I can truncate the image in FIT align to 512 byte, but not able to make the
header which is dtb 512byte align, any idea to implement this?
Thanks,
- Kever
On Tue, Jan 07, 2020 at 09:25:53AM +0800, Kever Yang wrote:
Hi Tom, Simon,
Hi!
make it slow.
I don't quite follow, sorry. Don't you control where the image will be written to in eMMC?
Hi Kever,
Hi Tom, Simon,
Hi!
make it slow.
In the SPL FIT implementation, it reads the blocks from MMC in such a way that the first byte of the image is at the required load address, and the FIT metadata is before that. See spl_load_simple_fit().
Kever Yang
Matthias Schoepfer
