[U-Boot] [PATCH] image: fix build when CONFIG_NR_DRAM_BANKS is disabled on ARM
31 Mar
2015
31 Mar
'15
9:31 p.m.
common/image.c currently implicitly depends on CONFIG_NR_DRAM_BANKS when CONFIG_ARM is enabled. Make this requirement explicit.
Signed-off-by: Matt Porter mporter@konsulko.com --- common/image.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/image.c b/common/image.c index a911aa9..13e68a0 100644 --- a/common/image.c +++ b/common/image.c @@ -460,7 +460,7 @@ phys_size_t getenv_bootm_size(void) tmp = 0;
-#if defined(CONFIG_ARM) +#if defined(CONFIG_ARM) && defined(CONFIG_NR_DRAM_BANKS) return gd->bd->bi_dram[0].size - tmp; #else return gd->bd->bi_memsize - tmp;
2.1.4
3691
Matt Porter
