[U-Boot] [PATCH] omap3: omap3_logic: Finish enabling fastboot on MUSB
Either the USB and Fastboot were never finished, or somehow it got lost. This puts enough hooks back into omap3logic to enable fastboot and hopefully prepare it for Kconfig conversion.
Signed-off-by: Adam Ford aford173@gmail.com --- board/logicpd/omap3som/omap3logic.c | 31 +++++++++++++++++++++++++++++++ configs/omap3_logic_defconfig | 5 +++-- 2 files changed, 34 insertions(+), 2 deletions(-)
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index f8b9f68..f73441b 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -33,6 +33,10 @@ #include <linux/usb/gadget.h> #include <linux/usb/musb.h> #include "omap3logic.h" +#ifdef CONFIG_USB_EHCI_HCD +#include <usb.h> +#include <asm/ehci-omap.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -139,6 +143,33 @@ static struct musb_hdrc_platform_data musb_plat = { }; #endif
+#if defined(CONFIG_USB_EHCI_HCD) && !defined(CONFIG_SPL_BUILD) +/* Call usb_stop() before starting the kernel */ +void show_boot_progress(int val) +{ + if (val == BOOTSTAGE_ID_RUN_OS) + usb_stop(); +} + +static struct omap_usbhs_board_data usbhs_bdata = { + .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[1] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED +}; + +int ehci_hcd_init(int index, enum usb_init_type init, + struct ehci_hccr **hccr, struct ehci_hcor **hcor) +{ + return omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); +} + +int ehci_hcd_stop(int index) +{ + return omap_ehci_hcd_stop(); +} + +#endif /* CONFIG_USB_EHCI_HCD */ +
/* * Routine: misc_init_r diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 464a41f..84bded3 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -22,10 +22,9 @@ CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x240000 # CONFIG_CMD_EEPROM is not set # CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y -# CONFIG_CMD_USB is not set -# CONFIG_CMD_FPGA is not set CONFIG_CMD_CACHE=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y @@ -38,7 +37,9 @@ CONFIG_MMC_OMAP36XX_PINS=y CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y +CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="TI"
Adam Ford
