[PATCH] efi_driver: simplify efi_bl_bind()
blk_create_devicef() is what blk_create_device() + device_set_name_alloced() really does. The resultant name will be a bit changed.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_driver/efi_block_device.c | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/lib/efi_driver/efi_block_device.c b/lib/efi_driver/efi_block_device.c index 0937e3595a43..b81c75868eb4 100644 --- a/lib/efi_driver/efi_block_device.c +++ b/lib/efi_driver/efi_block_device.c @@ -159,15 +159,11 @@ static int efi_bl_bind(efi_handle_t handle, void *interface) sprintf(name, "efiblk#%d", devnum);
/* Create driver model udevice for the EFI block io device */ - ret = blk_create_device(parent, "efi_blk", name, IF_TYPE_EFI, devnum, - io->media->block_size, - (lbaint_t)io->media->last_block, &bdev); + ret = blk_create_devicef(parent, "efi_blk", name, IF_TYPE_EFI, devnum, + io->media->block_size, + (lbaint_t)io->media->last_block, &bdev); if (ret) return ret; - if (!bdev) - return -ENOENT; - /* Set the DM_FLAG_NAME_ALLOCED flag to avoid a memory leak */ - device_set_name_alloced(bdev);
plat = dev_get_plat(bdev); plat->handle = handle;
without the patch after a device has been generated by the UEFI subsystem:
=> dm tree
Class Index Probed Driver Name
----------------------------------------- root 0 [ + ] root_driver root_driver mmc 2 [ + ] mmc_sandbox |-- mmc0
blk 2 [ + ] mmc_blk | `-- mmc0.blk blk 3 [ + ] efi_blk `-- efiblk#0
with the patch:
=> dm tree
blk 2 [ + ] mmc_blk | `-- mmc0.blk blk 3 [ + ] efi_blk `-- root_driver.efiblk#0
Prepending 'root_driver.' to the name seems to not match the rest of the tree.
Best regards
Heinrich
- ret = blk_create_devicef(parent, "efi_blk", name, IF_TYPE_EFI, devnum,
if (ret) return ret;(lbaint_t)io->media->last_block, &bdev);
if (!bdev)
return -ENOENT;
=> dm tree
with the patch:
=> dm tree
Is there anything wrong with the new "name"?
blk_create_devicef() creates a name with the parent's name + '.' + a given name. In this case, you specifies the dm root object as the device's parent. So "root_driver.efiblk#0" is a natural name like mmc0.blk and others.
Another block device example:
root 0 [ + ] root_driver root_driver pci 0 [ + ] pci_generic_ecam |-- pcie@10000000 pci_generi 0 [ ] pci_generic_drv | |-- pci_0:0.0 virtio 32 [ + ] virtio-pci.l | |-- virtio-pci.l#0 ethernet 0 [ + ] virtio-net | | `-- virtio-net#32 ahci 0 [ + ] ahci_pci | `-- ahci_pci scsi 0 [ + ] ahci_scsi | `-- ahci_scsi blk 0 [ ] scsi_blk | |-- ahci_scsi.id0lun0 blk 1 [ ] scsi_blk | `-- ahci_scsi.id1lun0
If you really don't like "root_driver." prefix, you can create the "efi" object as the generic parent for EFI devices, and then you will see "efi.blk#0". (This is also the way[1] that I took in my previous integration patch.
But in either way, it's just a name. Who cares.
-Takahiro Akashi
[1] https://lists.denx.de/pipermail/u-boot/2019-February/357929.html
Best regards
Heinrich
if (!bdev)
return -ENOENT;
On Mon, 13 Sept 2021 at 00:02, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
AKASHI Takahiro
