[U-Boot] [Patch v2] powerpc/mpc85xx: Add workaround for erratum A006379
Erratum A006379 says CPCHDBCR0 bit field [10:14] has incorrect default value after POR. The workaround is to set this field before enabling CPC to 0x1e.
Erratum A006379 applies to T4240 rev 1.0 B4860 rev 1.0, 2.0
Signed-off-by: York Sun yorksun@freescale.com --- Change log: v2: Add a list of SoC impacted by this erratum Add a function to detect whether workaround should be applied at runtime Add fsl_errata.h to host the prototype of the new function
arch/powerpc/cpu/mpc85xx/cmd_errata.c | 5 +++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 7 +++++++ arch/powerpc/include/asm/config_mpc85xx.h | 2 ++ arch/powerpc/include/asm/fsl_errata.h | 24 ++++++++++++++++++++++++ arch/powerpc/include/asm/immap_85xx.h | 1 + 5 files changed, 39 insertions(+) create mode 100644 arch/powerpc/include/asm/fsl_errata.h
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index c441bd2..1e5a43f 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -7,6 +7,7 @@ #include <common.h> #include <command.h> #include <linux/compiler.h> +#include <asm/fsl_errata.h> #include <asm/processor.h> #include "fsl_corenet_serdes.h"
@@ -245,6 +246,10 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_A006593 puts("Work-around for Erratum A006593 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A006379 + if (has_erratum_a006379()) + puts("Work-around for Erratum A006379 enabled\n"); +#endif #ifdef CONFIG_SYS_FSL_ERRATUM_SEC_A003571 if (IS_SVR_REV(svr, 1, 0)) puts("Work-around for Erratum A003571 enabled\n"); diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 6036333..22c0c54 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -19,6 +19,7 @@ #include <asm/io.h> #include <asm/cache.h> #include <asm/mmu.h> +#include <asm/fsl_errata.h> #include <asm/fsl_law.h> #include <asm/fsl_serdes.h> #include <asm/fsl_srio.h> @@ -160,6 +161,12 @@ static void enable_cpc(void) #ifdef CONFIG_SYS_FSL_ERRATUM_A006593 setbits_be32(&cpc->cpchdbcr0, 1 << (31 - 21)); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A006379 + if (has_erratum_a006379()) { + setbits_be32(&cpc->cpchdbcr0, + CPC_HDBCR0_SPLRU_LEVEL_EN); + } +#endif
out_be32(&cpc->cpccsr0, CPC_CSR0_CE | CPC_CSR0_PE); /* Read back to sync write */ diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index bec8966..6986ade 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -593,6 +593,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004468 #define CONFIG_SYS_FSL_ERRATUM_A_004934 #define CONFIG_SYS_FSL_ERRATUM_A005871 +#define CONFIG_SYS_FSL_ERRATUM_A006379 #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_PCI_VER_3_X @@ -617,6 +618,7 @@ #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_ERRATUM_A_004934 #define CONFIG_SYS_FSL_ERRATUM_A005871 +#define CONFIG_SYS_FSL_ERRATUM_A006379 #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000
diff --git a/arch/powerpc/include/asm/fsl_errata.h b/arch/powerpc/include/asm/fsl_errata.h new file mode 100644 index 0000000..780dfcf --- /dev/null +++ b/arch/powerpc/include/asm/fsl_errata.h @@ -0,0 +1,24 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_FSL_ERRATA_H +#define _ASM_FSL_ERRATA_H + +#include <common.h> + +#ifdef CONFIG_SYS_FSL_ERRATUM_A006379 +static inline bool has_erratum_a006379(void) +{ + u32 svr = get_svr(); + if (((SVR_SOC_VER(svr) == SVR_T4240) && SVR_MAJ(svr) <= 1) || + ((SVR_SOC_VER(svr) == SVR_B4860) && SVR_MAJ(svr) <= 2)) + return true; + + return false; +} +#endif + +#endif diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 3a10d77..a938143 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1671,6 +1671,7 @@ typedef struct cpc_corenet { #define CPC_HDBCR0_CDQ_SPEC_DIS 0x08000000 #define CPC_HDBCR0_TAG_ECC_SCRUB_DIS 0x01000000 #define CPC_HDBCR0_DATA_ECC_SCRUB_DIS 0x00400000 +#define CPC_HDBCR0_SPLRU_LEVEL_EN 0x003c0000 #endif /* CONFIG_SYS_FSL_CPC */
/* Global Utilities Block */
York Sun
