[PATCH 1/1] efi_loader: boot options should relate to the ESP
* Only generate removable media entries for EFI system partitions. * Only offer EFI system partitions for boot options in the eficonfig command.
Fixes: c416f1c0bcab ("bootmenu: add removable media entries") Fixes: 87d791423ac6 ("eficonfig: menu-driven addition of UEFI boot option") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- cmd/eficonfig.c | 6 ++++-- lib/efi_loader/efi_bootmgr.c | 3 ++- 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 34a59cb15d..c066b28b6b 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -626,8 +626,10 @@ static efi_status_t eficonfig_select_volume(struct eficonfig_select_file_info *f efi_handle_t *volume_handles = NULL; struct efi_simple_file_system_protocol *v;
- ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, - NULL, &count, (efi_handle_t **)&volume_handles); + /* Find all EFI system partitions */ + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, + &efi_system_partition_guid, + NULL, &count, &volume_handles); if (ret != EFI_SUCCESS) { eficonfig_print_msg("No block device found!"); return ret; diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 48153bd5ff..9e84391186 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -1047,8 +1047,9 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) efi_handle_t *volume_handles = NULL; struct eficonfig_media_boot_option *opt = NULL;
+ /* Find all EFI system partitions */ ret = efi_locate_handle_buffer_int(BY_PROTOCOL, - &efi_simple_file_system_protocol_guid, + &efi_system_partition_guid, NULL, &count, (efi_handle_t **)&volume_handles); if (ret != EFI_SUCCESS)
Hi Heinrich,
On Tue, 5 Dec 2023 at 11:38, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- Only generate removable media entries for EFI system partitions.
- Only offer EFI system partitions for boot options in the eficonfig command.
UEFI specification v2.10 section '3.5 Boot Mechanisms' says "EFI can boot from a device using the EFI_SIMPLE_FILE_SYSTEM_PROTOCOL or the EFI_LOAD_FILE_PROTOCOL."
So in my understanding of the UEFI spec, I think efi_simple_file_system_protocol_guid is correct here.
In EDK II reference implementation[0], it enumerates all block_io_protocol devices and eliminates logical partitions. Should we do the same? If yes, I can prepare the patch on this.
[0] https://github.com/tianocore/edk2/blob/master/MdeModulePkg/Library/UefiBootM...
Regards, Masahisa Kojima
-- 2.40.1
On 05.12.23 07:23, Masahisa Kojima wrote:
Hi Heinrich,
This is what the boot options look like on an EDK II system:
$ efibootmgr -v BootCurrent: 000D Timeout: 3 seconds BootOrder: 000D,000B,000C,0003,0004,0005,0006,0007,0008,0009,000A,0000,0001,0002 Boot0000* UiApp FvVol(5eda4200-2c5f-43cb-9da3-0baf74b1b30c)/FvFile(462caa21-7614-4503-836e-8ab6f4662331) Boot0001* helloworld VenHw(0d51905b-b77e-452a-a2c0-eca0cc8d514a,000054f20000000000)/Sata(1,65535,0)/HD(1,GPT,40c323d0-6b76-47c4-bc82-e05bf5d23c9f,0x2000,0x200000)/File(\helloworld.efi)h.e.l.l.o. .w.o.r.l.d... Boot0002* UEFI Crucial_CT128M550SSD1 14270C7CFEFE VenHw(0d51905b-b77e-452a-a2c0-eca0cc8d514a,000054f20000000000)/Sata(1,65535,0)N.....YM....R,Y. Boot0003* UEFI eMMC Device VenHw(0d51905b-b77e-452a-a2c0-eca0cc8d514a,00006ef00000000000)/eMMC(0)/Ctrl(0x0)N.....YM....R,Y. Boot0004* UEFI eMMC Device 2 VenHw(0d51905b-b77e-452a-a2c0-eca0cc8d514a,00006ef00000000000)/eMMC(0)/Ctrl(0x1)N.....YM....R,Y. Boot0005* UEFI eMMC Device 3 VenHw(0d51905b-b77e-452a-a2c0-eca0cc8d514a,00006ef00000000000)/eMMC(0)/Ctrl(0x2)N.....YM....R,Y. Boot0006* UEFI PXEv4 (MAC:000000000001) MAC(000000000001,1)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y. Boot0007* UEFI PXEv4 (MAC:000000000002) MAC(000000000002,1)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y. Boot0008* UEFI PXEv4 (MAC:000000000003) MAC(000000000003,1)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y. Boot0009* UEFI PXEv4 (MAC:000000000004) MAC(000000000004,1)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y. Boot000A* UEFI Shell FvVol(5eda4200-2c5f-43cb-9da3-0baf74b1b30c)/FvFile(7c04a583-9e3e-4f1c-ad65-e05268d0b4d1) Boot000B* UEFI HL-DT-ST DVDRAM GTC0N VenHw(0d51905b-b77e-452a-a2c0-eca0cc8d514a,000054f40000000000)/Sata(1,65535,0)N.....YM....R,Y. Boot000C* ubuntu HD(1,GPT,5a1ba4fc-f9b4-4da2-b5e1-065e9cd10e3a,0x800,0x100000)/File(\EFI\ubuntu\grubaa64.efi) Boot000D* grub HD(1,GPT,5a1ba4fc-f9b4-4da2-b5e1-065e9cd10e3a,0x800,0x100000)/File(\EFI\grub\shimaa64.efi) Boot1001* helloworld HD(1,GPT,40c323d0-6b76-47c4-bc82-e05bf5d23c8f,0x2000,0x200000)/File(helloworld.efi)
As you described autogenerated boot options are on block device level irrespective of the existence of an ESP.
EDK II does not to care if /EFI/BOOT/BOOT<ARCH>.EFI is on a partition with the ESP partition type.
We should try to mimic the EDK II behavior.
Best regards
Heinrich
-- 2.40.1
On Wed, Dec 6, 2023 at 9:31 AM Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
I believe the UEFI spec allows VFAT partition type as well ESP partition type. For example a lot of Raspberry Pis won't load their firmware of a ESP partition type but will off VFAT even though they are essentially the same thing.
From: Peter Robinson pbrobinson@gmail.com Date: Wed, 6 Dec 2023 10:44:59 +0000
Hi Heinrich,
Right. And therefore OpenBSD/arm64 uses partition type 0x0C; this works with all EFI implementations that we have tested so far (including EDK II and some proprietary implementations).
Mark Kettenis
Masahisa Kojima
Peter Robinson
