[U-Boot] [PATCH v2 1/2] mx25: add CPU revision 1.2
tested on a MCIMX257CJM4A which now reports : CPU: Freescale i.MX25 rev1.2 at 399 MHz
Signed-off-by: Eric Bénard eric@eukrea.com Acked-by: Otavio Salvador otavio@ossystems.com.br --- v2 : rebased against 2012.10-rc1, added Otavio's ack
arch/arm/cpu/arm926ejs/mx25/generic.c | 3 +++ arch/arm/include/asm/arch-mx25/imx-regs.h | 1 + 2 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index a5c15ce..3b7f327 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -140,6 +140,9 @@ u32 get_cpu_rev(void) case 0x01: system_rev |= CHIP_REV_1_1; break; + case 0x02: + system_rev |= CHIP_REV_1_2; + break; default: system_rev |= 0x8000; break; diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index 672f9d7..e780296 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -357,5 +357,6 @@ struct aips_regs {
#define CHIP_REV_1_0 0x10 #define CHIP_REV_1_1 0x11 +#define CHIP_REV_1_2 0x12
#endif /* _IMX_REGS_H */
this board is based on an i.MX25 from Freescale. It consists of a SOM containing : - NAND flash (internal or external boot supported and tested) - mDDR (64MB tested) - ethernet PHY connected in RMII mode (tested) and a baseboard containing : - a serial transceiver on UART1 (tested) - a SDCard connector on eSDHC1 (tested but disabled until Benoît's fix gets applied)
bootlog : U-Boot 2012.10-rc1-00003-gdd12be5 (Sep 23 2012 - 13:53:21)
CPU: Freescale i.MX25 rev1.2 at 399 MHz Reset cause: POR
DRAM: 64 MiB NAND: 256 MiB MMC: In: serial Out: serial Err: serial Net: FEC Hit any key to stop autoboot: 0
Signed-off-by: Eric Bénard eric@eukrea.com --- v2: rebased against 2012.10-rc1, disabled eSDHC until proper fix from Benoît gets applied, updated bootlog.
MAINTAINERS | 2 + board/eukrea/cpuimx25/Makefile | 44 +++++++ board/eukrea/cpuimx25/config.mk | 5 + board/eukrea/cpuimx25/cpuimx25.c | 123 ++++++++++++++++++ board/eukrea/cpuimx25/imximage.cfg | 55 ++++++++ board/eukrea/cpuimx25/lowlevel_init.S | 113 ++++++++++++++++ boards.cfg | 2 + include/configs/cpuimx25.h | 198 +++++++++++++++++++++++++++++ nand_spl/board/eukrea/cpuimx25/Makefile | 79 ++++++++++++ nand_spl/board/eukrea/cpuimx25/config.mk | 1 + nand_spl/board/eukrea/cpuimx25/u-boot.lds | 83 ++++++++++++ 11 files changed, 705 insertions(+), 0 deletions(-) create mode 100644 board/eukrea/cpuimx25/Makefile create mode 100644 board/eukrea/cpuimx25/config.mk create mode 100644 board/eukrea/cpuimx25/cpuimx25.c create mode 100644 board/eukrea/cpuimx25/imximage.cfg create mode 100644 board/eukrea/cpuimx25/lowlevel_init.S create mode 100644 include/configs/cpuimx25.h create mode 100644 nand_spl/board/eukrea/cpuimx25/Makefile create mode 100644 nand_spl/board/eukrea/cpuimx25/config.mk create mode 100644 nand_spl/board/eukrea/cpuimx25/u-boot.lds
diff --git a/MAINTAINERS b/MAINTAINERS index aa54fe1..94e759f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -606,6 +606,8 @@ Eric Benard eric@eukrea.com cpuat91 ARM920T cpu9260 ARM926EJS (AT91SAM9260 SoC) cpu9G20 ARM926EJS (AT91SAM9G20 SoC) + cpuimx25 i.MX25 + cpuimx25nand i.MX25
Ajay Bhargav ajay.bhargav@einfochips.com
diff --git a/board/eukrea/cpuimx25/Makefile b/board/eukrea/cpuimx25/Makefile new file mode 100644 index 0000000..46131fd --- /dev/null +++ b/board/eukrea/cpuimx25/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2009 DENX Software Engineering +# Author: John Rigby jcrigby@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := cpuimx25.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/eukrea/cpuimx25/config.mk b/board/eukrea/cpuimx25/config.mk new file mode 100644 index 0000000..18b2883 --- /dev/null +++ b/board/eukrea/cpuimx25/config.mk @@ -0,0 +1,5 @@ +ifdef CONFIG_NAND_SPL +CONFIG_SYS_TEXT_BASE = 0x810c0000 +else +CONFIG_SYS_TEXT_BASE = 0x81200000 +endif diff --git a/board/eukrea/cpuimx25/cpuimx25.c b/board/eukrea/cpuimx25/cpuimx25.c new file mode 100644 index 0000000..72fa8a5 --- /dev/null +++ b/board/eukrea/cpuimx25/cpuimx25.c @@ -0,0 +1,123 @@ +/* + * (C) Copyright 2009 DENX Software Engineering + * (C) Copyright 2012 Eukrea Electromatique <www.eukrea.com> + * Eric Benard eric@eukrea.com + * + * Based on tx25.c: + * Author: John Rigby jrigby@gmail.com + * + * Based on imx27lite.c: + * Copyright (C) 2008,2009 Eric Jarrige jorasse@users.sourceforge.net + * Copyright (C) 2009 Ilya Yanok yanok@emcraft.com + * And: + * RedBoot tx25_misc.c Copyright (C) 2009 Red Hat + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/imx25-pinmux.h> +#include <asm/gpio.h> +#include <asm/arch/sys_proto.h> +#include <mmc.h> +#include <fsl_esdhc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg esdhc_cfg[1] = { + {IMX_MMC_SDHC1_BASE}, +}; +#endif + +int board_init() +{ +#ifdef CONFIG_MXC_UART + mx25_uart1_init_pins(); +#endif + /* board id for linux */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + return 0; +} + +int board_late_init(void) +{ +#ifdef CONFIG_FEC_MXC + mx25_fec_init_pins(); +#endif + return 0; +} + +int dram_init(void) +{ + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = get_ram_size((void *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); +} + +int checkboard(void) +{ + printf("Eukrea Electromatique CPUIMX25\n"); + return 0; +} + +#ifdef CONFIG_FSL_ESDHC +int board_mmc_getcd(struct mmc *mmc) +{ + struct iomuxc_mux_ctl *muxctl; + struct iomuxc_pad_ctl *padctl; + struct gpio_regs *gpio2 = (struct gpio_regs *)IMX_GPIO2_BASE; + u32 val; + + muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; + padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; + + writel(MX25_PIN_MUX_MODE(5), &muxctl->pad_de_b); + + writel(0x0, &padctl->pad_de_b); + + val = readl(&gpio2->gpio_dir) & ~(1 << 20); + writel(val, &gpio2->gpio_dir); + val = readl(&gpio2->gpio_dr) & (1 << 20); + return val ? 0 : 1; + +} + +int board_mmc_init(bd_t *bis) +{ + struct iomuxc_mux_ctl *muxctl; + struct iomuxc_pad_ctl *padctl; + u32 sdhc1_mux_mode = MX25_PIN_MUX_MODE(0) | MX25_PIN_MUX_SION; + muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; + writel(sdhc1_mux_mode, &muxctl->pad_sd1_cmd); + writel(sdhc1_mux_mode, &muxctl->pad_sd1_clk); + writel(sdhc1_mux_mode, &muxctl->pad_sd1_data0); + writel(sdhc1_mux_mode, &muxctl->pad_sd1_data1); + writel(sdhc1_mux_mode, &muxctl->pad_sd1_data2); + writel(sdhc1_mux_mode, &muxctl->pad_sd1_data3); + return fsl_esdhc_initialize(bis, &esdhc_cfg[0]); +} +#endif diff --git a/board/eukrea/cpuimx25/imximage.cfg b/board/eukrea/cpuimx25/imximage.cfg new file mode 100644 index 0000000..c0b7b20 --- /dev/null +++ b/board/eukrea/cpuimx25/imximage.cfg @@ -0,0 +1,55 @@ +# +# (C) Copyright 2009 +# Stefano Babic DENX Software Engineering sbabic@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# Boot Device : one of +# nand, sd, spi + +BOOT_FROM nand + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register + +# MDDR init +DATA 4 0xb8001010 0x00000004 +DATA 4 0xb8001000 0x92100000 +DATA 1 0x80000400 0x12344321 +DATA 4 0xb8001000 0xa2100000 +DATA 4 0x80000000 0x12344321 +DATA 4 0x80000000 0x12344321 +DATA 4 0xb8001000 0xb2100000 +DATA 1 0x80000033 0xda +DATA 1 0x81000000 0xff +DATA 4 0xb8001000 0x82216080 +DATA 4 0xb8001004 0x00295729 +DATA 4 0x53f80008 0x20034000 + +# Enable the clocks +DATA 4 0x53f8000c 0x1fffffff +DATA 4 0x53f80010 0xffffffff +DATA 4 0x53f80014 0xfdfff diff --git a/board/eukrea/cpuimx25/lowlevel_init.S b/board/eukrea/cpuimx25/lowlevel_init.S new file mode 100644 index 0000000..76e4e6f --- /dev/null +++ b/board/eukrea/cpuimx25/lowlevel_init.S @@ -0,0 +1,113 @@ +/* + * (C) Copyright 2009 DENX Software Engineering + * (C) Copyright 2012 Eukrea Electromatique <www.eukrea.com> + * Eric Benard eric@eukrea.com + * + * Based on tx25 and zmx25: + * Author: John Rigby jrigby@gmail.com + * + * Based on U-Boot and RedBoot sources for several different i.mx + * platforms. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/macro.h> +#include <asm/arch/macro.h> +#include <asm/arch/imx-regs.h> +#include <generated/asm-offsets.h> + +.macro init_m3if + write32 0xb8003000, 0x1 +.endm + +.macro init_clocks + write32 0x53f80064, 0x00000000 + write32 0x53f80008, 0x20034000 + + /* + * enable all implemented clocks in all three + * clock control registers + */ + write32 0x53f8000c, 0x1fffffff + write32 0x53f80010, 0xffffffff + write32 0x53f80014, 0xfdfff +.endm + +.macro init_lpddr + /* Skip SDRAM initialization if we run from RAM */ + cmp pc, #0x80000000 + bls 1f + cmp pc, #0x90000000 + bhi 1f + + mov pc, lr + +1: ldr r0, =IMX_ESDRAMC_BASE + ldr r2, =IMX_SDRAM_BANK0_BASE + + /* + * reset SDRAM controller + * then wait for initialization to complete + */ + ldr r1, =(1 << 1) | (1 << 2) | (1 << 3) + str r1, [r0, #ESDRAMC_ESDMISC] +2: ldr r3, [r0, #ESDRAMC_ESDMISC] + tst r3, #(1 << 31) + beq 2b + ldr r1, =(1 << 2) + str r1, [r0, #ESDRAMC_ESDMISC] + + ldr r1, =0x00295729 + str r1, [r0, #ESDRAMC_ESDCFG0] + + /* control | precharge */ + ldr r1, =0x92100000 + str r1, [r0, #ESDRAMC_ESDCTL0] + /* dram command encoded in address */ + strb r1, [r2, #0x400] + + /* auto refresh */ + ldr r1, =0xa2100000 + str r1, [r0, #ESDRAMC_ESDCTL0] + /* read dram twice to auto refresh */ + str r3, [r2] + str r3, [r2] + + /* control | load mode */ + ldr r1, =0xb2100000 + str r1, [r0, #ESDRAMC_ESDCTL0] + + /* mode register of lpddram */ + strb r1, [r2, #0x33] + + /* extended mode register of lpddrram */ + ldr r2, =0x81000000 + strb r1, [r2] + + /* control | normal */ + ldr r1, =0x82216080 + str r1, [r0, #ESDRAMC_ESDCTL0] +.endm + +.globl lowlevel_init +lowlevel_init: + init_aips + init_max + init_m3if + init_clocks + init_lpddr + mov pc, lr diff --git a/boards.cfg b/boards.cfg index 091c79f..2cd6e4d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -176,6 +176,8 @@ dockstar arm arm926ejs - Seagate tk71 arm arm926ejs tk71 karo kirkwood devkit3250 arm arm926ejs devkit3250 timll lpc32xx jadecpu arm arm926ejs jadecpu syteco mb86r0x +cpuimx25 arm arm926ejs cpuimx25 eukrea mx25 cpuimx25:IMX_CONFIG=board/eukrea/cpuimx25/imximage.cfg +cpuimx25nand arm arm926ejs cpuimx25 eukrea mx25 cpuimx25:NAND_U_BOOT mx25pdk arm arm926ejs mx25pdk freescale mx25 mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg tx25 arm arm926ejs tx25 karo mx25 zmx25 arm arm926ejs zmx25 syteco mx25 diff --git a/include/configs/cpuimx25.h b/include/configs/cpuimx25.h new file mode 100644 index 0000000..dc0a1d6 --- /dev/null +++ b/include/configs/cpuimx25.h @@ -0,0 +1,198 @@ +/* + * (C) Copyright 2009 DENX Software Engineering + * (C) Copyright 2012 Eukrea Electromatique <www.eukrea.com> + * Eric Benard eric@eukrea.com + * + * Based on tx25.c: + * Author: John Rigby jrigby@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Eukrea CPUIMX25 board - SoC Configuration + */ +#define CONFIG_MX25 +#define CONFIG_MX25_CLK32 32768 /* OSC32K frequency */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* 256 kB for U-Boot */ + +#ifndef MACH_TYPE_EUKREA_CPUIMX25SD +#define MACH_TYPE_EUKREA_CPUIMX25SD 2820 +#endif + +#define CONFIG_MACH_TYPE MACH_TYPE_EUKREA_CPUIMX25SD + +#ifdef CONFIG_NAND_SPL +/* Start copying real U-boot from the second page */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x800 +#define CONFIG_SYS_NAND_U_BOOT_SIZE (CONFIG_SYS_MONITOR_LEN - \ + CONFIG_SYS_NAND_U_BOOT_OFFS) + +#define CONFIG_SYS_NAND_U_BOOT_DST (0x81200000) +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST + +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_SPARE_SIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#endif + +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* + * Memory Info + */ +/* malloc() len */ +#define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ +/* + * Board has 2 32MB banks of DRAM but there is a bug when using + * both so only the first is configured + */ +#define CONFIG_NR_DRAM_BANKS 1 + +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x04000000 + +/* 8MB DRAM test */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1+0x0800000) + +/* + * Serial Info + */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE +#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ + +#define CONFIG_MXC_GPIO + +/* + * MMC + */ +#if 0 +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR (0x53FB4000) +#define CONFIG_SYS_FSL_ESDHC_NUM 1 +#define CONFIG_SYS_FSL_ESDHC_USE_PIO 1 +#endif + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* + * Flash & Environment + */ +/* No NOR flash present */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_OFFSET CONFIG_SYS_MONITOR_LEN +#define CONFIG_ENV_SIZE (128 * 1024) /* 128 kB NAND block size */ +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) + +/* NAND */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_NAND_MXC +#define CONFIG_NAND_MXC_V1_1 +#define CONFIG_MXC_NAND_REGS_BASE (0xBB000000) +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE (0xBB000000) +#define CONFIG_JFFS2_NAND +#define CONFIG_MXC_NAND_HWECC +#define CONFIG_SYS_NAND_LARGEPAGE + +/* U-Boot general configuration */ +#define CONFIG_SYS_PROMPT "CPUIMX25 U-Boot > " +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +/* Print buffer sz */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP + +/* U-Boot commands */ +#include <config_cmd_default.h> +#define CONFIG_CMD_NAND +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING + +/* + * Ethernet + */ +#define CONFIG_FEC_MXC +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_MII +#define CONFIG_CMD_NET +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BOOTDELAY 5 + +#define CONFIG_LOADADDR 0x81000000 /* loadaddr env var */ +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define xstr(s) str(s) +#define str(s) #s + +#define CONFIG_HOSTNAME "eukrea-cpuimx25" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs}" \ + " console=ttymxc0,${baudrate}\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "addmisc=setenv bootargs ${bootargs}\0" \ + "u-boot="CONFIG_HOSTNAME"/u-boot-"CONFIG_HOSTNAME".bin\0" \ + "kernel_addr_r=" xstr(CONFIG_LOADADDR) "\0" \ + "hostname="CONFIG_HOSTNAME"\0" \ + "bootfile="CONFIG_HOSTNAME"/uImage-"CONFIG_HOSTNAME".bin\0" \ + "rootpath=/srv/nfs/"CONFIG_HOSTNAME"\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile};" \ + "run nfsargs addip addtty addmtd addmisc;" \ + "bootm\0" \ + "bootcmd=run net_nfs\0" \ + "load=tftp ${loadaddr} ${u-boot}\0" \ + "update=nand erase 0 40000;nand write ${loadaddr} 0 40000\0" \ + "upd=run load update\0" \ + +/* additions for new relocation code, must be added to all boards */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ + GENERATED_GBL_DATA_SIZE) + +#endif /* __CONFIG_H */ diff --git a/nand_spl/board/eukrea/cpuimx25/Makefile b/nand_spl/board/eukrea/cpuimx25/Makefile new file mode 100644 index 0000000..d8b19c6 --- /dev/null +++ b/nand_spl/board/eukrea/cpuimx25/Makefile @@ -0,0 +1,79 @@ +# +# (C) Copyright 2009 DENX Software Engineering +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundatio; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk +include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk + +nandobj := $(OBJTREE)/nand_spl/ + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ + $(LDFLAGS_FINAL) +AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL + +SOBJS = start.o lowlevel_init.o +COBJS = nand_boot_fsl_nfc.o + +SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c +SRCS += $(SRCTREE)/arch/arm/cpu/arm926ejs/start.S +SRCS += $(SRCTREE)/board/eukrea/cpuimx25/lowlevel_init.S +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(nandobj)board/$(BOARDDIR) + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $@ + +$(nandobj)u-boot.lds: $(LDSCRIPT) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + +######################################################################### + +$(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm926ejs/%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/board/eukrea/cpuimx25/%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/nand_spl/%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/eukrea/cpuimx25/config.mk b/nand_spl/board/eukrea/cpuimx25/config.mk new file mode 100644 index 0000000..68afbf1 --- /dev/null +++ b/nand_spl/board/eukrea/cpuimx25/config.mk @@ -0,0 +1 @@ +PAD_TO := 2048 diff --git a/nand_spl/board/eukrea/cpuimx25/u-boot.lds b/nand_spl/board/eukrea/cpuimx25/u-boot.lds new file mode 100644 index 0000000..d2b08f6 --- /dev/null +++ b/nand_spl/board/eukrea/cpuimx25/u-boot.lds @@ -0,0 +1,83 @@ +/* + * (C) Copyright 2009 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + lowlevel_init.o (.text) + nand_boot_fsl_nfc.o (.text) + *(.text) + . = 2K; + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { + *(.data) + } + + . = ALIGN(4); + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + _end = .; + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + . = ALIGN(4); + __bss_end__ = .; + } + + /DISCARD/ : { *(.bss*) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynsym*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.hash*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +}
Signed-off-by: Eric Bénarderic@eukrea.com
diff --git a/MAINTAINERS b/MAINTAINERS index aa54fe1..94e759f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -606,6 +606,8 @@ Eric Benarderic@eukrea.com cpuat91 ARM920T cpu9260 ARM926EJS (AT91SAM9260 SoC) cpu9G20 ARM926EJS (AT91SAM9G20 SoC)
cpuimx25 i.MX25
cpuimx25nand i.MX25
Ajay Bhargavajay.bhargav@einfochips.com
diff --git a/board/eukrea/cpuimx25/Makefile b/board/eukrea/cpuimx25/Makefile new file mode 100644 index 0000000..46131fd --- /dev/null +++ b/board/eukrea/cpuimx25/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2009 DENX Software Engineering +# Author: John Rigbyjcrigby@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
- $(call cmd_link_o_target, $(OBJS) $(SOBJS))
- (C) Copyright 2009 DENX Software Engineering
- (C) Copyright 2012 Eukrea Electromatique<www.eukrea.com>
- Eric Benarderic@eukrea.com
- Based on tx25.c:
- Author: John Rigbyjrigby@gmail.com
- Based on imx27lite.c:
- Copyright (C) 2008,2009 Eric Jarrigejorasse@users.sourceforge.net
- Copyright (C) 2009 Ilya Yanokyanok@emcraft.com
- And:
- RedBoot tx25_misc.c Copyright (C) 2009 Red Hat
- MA 02111-1307 USA
+#include<common.h> +#include<asm/io.h> +#include<asm/arch/imx-regs.h> +#include<asm/arch/imx25-pinmux.h> +#include<asm/gpio.h> +#include<asm/arch/sys_proto.h> +#include<mmc.h> +#include<fsl_esdhc.h>
- {IMX_MMC_SDHC1_BASE},
+}; +#endif
- mx25_uart1_init_pins();
- /* board id for linux */
- gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
- mx25_fec_init_pins();
- /* dram_init must store complete ramsize in gd->ram_size */
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1,
PHYS_SDRAM_1_SIZE);
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = get_ram_size((void *)PHYS_SDRAM_1,
PHYS_SDRAM_1_SIZE);
- printf("Eukrea Electromatique CPUIMX25\n");
- struct iomuxc_mux_ctl *muxctl;
- struct iomuxc_pad_ctl *padctl;
- struct gpio_regs *gpio2 = (struct gpio_regs *)IMX_GPIO2_BASE;
- u32 val;
- muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE;
- padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE;
- writel(MX25_PIN_MUX_MODE(5),&muxctl->pad_de_b);
- writel(0x0,&padctl->pad_de_b);
- val = readl(&gpio2->gpio_dir)& ~(1<< 20);
- writel(val,&gpio2->gpio_dir);
- val = readl(&gpio2->gpio_dr)& (1<< 20);
- return val ? 0 : 1;
- u32 sdhc1_mux_mode = MX25_PIN_MUX_MODE(0) | MX25_PIN_MUX_SION;
- writel(sdhc1_mux_mode,&muxctl->pad_sd1_cmd);
- writel(sdhc1_mux_mode,&muxctl->pad_sd1_clk);
- writel(sdhc1_mux_mode,&muxctl->pad_sd1_data0);
- writel(sdhc1_mux_mode,&muxctl->pad_sd1_data1);
- writel(sdhc1_mux_mode,&muxctl->pad_sd1_data2);
- writel(sdhc1_mux_mode,&muxctl->pad_sd1_data3);
- return fsl_esdhc_initialize(bis,&esdhc_cfg[0]);
+BOOT_FROM nand
- Based on tx25 and zmx25:
- Based on U-Boot and RedBoot sources for several different i.mx
- platforms.
- MA 02111-1307 USA
+#include<asm/macro.h> +#include<asm/arch/macro.h> +#include<asm/arch/imx-regs.h> +#include<generated/asm-offsets.h>
+.macro init_m3if
- write32 0xb8003000, 0x1
+.endm
+.macro init_clocks
- write32 0x53f80064, 0x00000000
- write32 0x53f80008, 0x20034000
- write32 0x53f8000c, 0x1fffffff
- write32 0x53f80010, 0xffffffff
- write32 0x53f80014, 0xfdfff
+.endm
Why the clock init is in two places? imximage.cfg and this file. Am I missing something?
~Vikram
Hi Vikram,
Le Sun, 23 Sep 2012 23:02:18 +0530, Vikram Narayanan vikram186@gmail.com a écrit :
imximage.cfg for internal boot, lowlevel_init.S for external boot.
Eric
Hi Eric,
There is a main issue with these patches. According to some discussion in previous threads and hopefully I do not misinterprete Wolfgang's will about the direction that U-Boot will have in future, the nand_spl code is obsolete and it remains for the already supported boards.
However, new boards must implement SPL using the SPL framework. New boards using nand_spl will not be integrated in mainline.
config.mk is obsolete in board's directory. We removed most of these config.mk. It must not be used anymore.
Maybe you can drop the #ifdef, CONFIG_MXC_UART should always be set
- u32 val;
- writel(MX25_PIN_MUX_MODE(5), &muxctl->pad_de_b);
Why is the setup of the iomux here and not in board_mmc_init ?
- (C) Copyright 2012 Eukrea Electromatique <www.eukrea.com>
- Eric Benard eric@eukrea.com
- Author: John Rigby jrigby@gmail.com
- platforms.
- MA 02111-1307 USA
+.macro init_m3if
+.endm
+.macro init_clocks
+.endm
+.macro init_lpddr
- /* Skip SDRAM initialization if we run from RAM */
- cmp pc, #0x80000000
- bls 1f
- cmp pc, #0x90000000
- bhi 1f
- mov pc, lr
- ldr r2, =IMX_SDRAM_BANK0_BASE
- ldr r1, =(1 << 1) | (1 << 2) | (1 << 3)
- str r1, [r0, #ESDRAMC_ESDMISC]
- tst r3, #(1 << 31)
- beq 2b
- ldr r1, =(1 << 2)
- ldr r1, =0x00295729
- str r1, [r0, #ESDRAMC_ESDCFG0]
- /* control | precharge */
- ldr r1, =0x92100000
- str r1, [r0, #ESDRAMC_ESDCTL0]
- /* dram command encoded in address */
- strb r1, [r2, #0x400]
- /* auto refresh */
- ldr r1, =0xa2100000
- /* read dram twice to auto refresh */
- str r3, [r2]
- str r3, [r2]
- /* control | load mode */
- ldr r1, =0xb2100000
- /* mode register of lpddram */
- strb r1, [r2, #0x33]
- /* extended mode register of lpddrram */
- ldr r2, =0x81000000
- strb r1, [r2]
- /* control | normal */
- ldr r1, =0x82216080
+.endm
- init_aips
- init_max
- init_m3if
- init_clocks
- init_lpddr
- mov pc, lr
- Based on tx25.c:
- MA 02111-1307 USA
- Eukrea CPUIMX25 board - SoC Configuration
A recent patch drop this. You should not need it. See commit 1b2080f3388b70c4c37b69830f73a61c50cdd505.
As I explained, NAND_SPL should not be used for new boards.
- MMC
+#if 0
This is dead code. Drop it.
Sorry, not accepted anymore.
Best regards, Stefano Babic
Hi Stefano,
else that would have been to easy ;-) OK I'll look at this SPL framework based on your serie introducing woorburn board,
Thanks ! Eric
Applied to u-boot-imx, next branch, thanks.
Eric Bénard
Stefano Babic
Vikram Narayanan
