[U-Boot] VAR-SOM-MX6 - Boot Count Limit support?
Hello,
I have a VAR-SOM-MX6 with the following details:
Board: Variscite VAR_SOM_MX6 SOM-Solo SOC_FAMILY = "mx6:mx6q:mx6dl" PREFERRED_PROVIDER_virtual/kernel_var-som-mx6 ?= "linux-variscite" PREFERRED_VERSION_linux-imx_mx6 = "4.1.15"
and the following u-boot details:
U-Boot SPL 2013.10-00027-g58782ac (Mar 09 2015 - 13:33:44) i.MX6SOLO SOC DDR EEPROM configuration Part number: VSM-SOLO-102 Assembly: AS151004858 Date: 2016 Feb 08 Ram size 1024 Boot Device: NAND NAND: 512 MiB
U-Boot 2013.10-00027-g58782ac (Mar 09 2015 - 13:33:44)
CPU: Freescale i.MX6SOLO rev1.2 at 792 MHz CPU: Temperature 51 C, calibration data: 0x5744e269 Reset cause: POR Board: Variscite VAR_SOM_MX6 SOM-Solo I2C: ready DRAM: 1 GiB NAND: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial Board: Variscite VAR_SOM_MX6 SOM-Solo Net: using phy at 7
I am using Yocto to create my images (.swu) to update my board through swupdate https://sbabic.github.io/swupdate/swupdate.html . The update process and loading process via NFS and NAND causes no issues.
I am trying to implement a system whereby if the board fails to boot, it should boot to a recovery configuration where the user is presented with the swupdate landing page to allow for an image (.swu) upload to update or boot to a recovery .img (uImage, .dtb, rootfs stored on MMC or NAND).
I have read about uboot's Boot Count Limit http://www.denx.de/wiki/view/DULG/UBootBootCountLimit which is along the lines of what I would like to implement i.e. after x failed boot attempts use an alternate boot action. However this functionality is not supported by my board.
I am new to this and was wondering if anyone could shed any light on what I need to look at or how I can somehow implement the Boot Count Limit functionality or similar.
Thanks for your help.
-- View this message in context: http://u-boot.10912.n7.nabble.com/VAR-SOM-MX6-Boot-Count-Limit-support-tp276... Sent from the U-Boot mailing list archive at Nabble.com.
You need to choose the backend for use. The i.MX has few persistent registers which can be used for this purpose, depending on the product design.
brendan
Otavio Salvador
