[U-Boot] [PATCH] configs: Delete unused CONFIG_SYS_64BIT_{VSPRINTF, STRTOUL}
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- include/configs/M54418TWR.h | 1 - include/configs/p1_twr.h | 3 --- include/configs/vl_ma2sc.h | 1 - include/configs/x600.h | 1 - 4 files changed, 6 deletions(-)
diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 031672e..3d7dc1f 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -77,7 +77,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE #define CONFIG_SYS_NAND_SELECT_DEVICE -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* Network configuration */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 601bac7..c296a07 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -238,9 +238,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_OF_BOARD_SETUP #define CONFIG_OF_STDOUT_VIA_ALIAS
-#define CONFIG_SYS_64BIT_VSPRINTF -#define CONFIG_SYS_64BIT_STRTOUL - /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ diff --git a/include/configs/vl_ma2sc.h b/include/configs/vl_ma2sc.h index 2187f77..14c6e67 100644 --- a/include/configs/vl_ma2sc.h +++ b/include/configs/vl_ma2sc.h @@ -322,7 +322,6 @@ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_ENABLE_PIN GPIO_PIN_PD(15) #define CONFIG_SYS_NAND_READY_PIN GPIO_PIN_PB(0) -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* Ethernet */ diff --git a/include/configs/x600.h b/include/configs/x600.h index a427ca5..8141927 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -171,7 +171,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LOAD_ADDR 0x00800000 #define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_64BIT_VSPRINTF
/* Use last 2 lwords in internal SRAM for bootcounter */ #define CONFIG_BOOTCOUNT_LIMIT
Masahiro Yamada
