[U-Boot] [PATCH v9 01/14] sf: spi_flash_validate_params => spi_flash_scan
Rename spi_flash_validate_params to spi_flash_scan as this code not only deals with params setup but also configure all spi_flash attributes.
And also moved all flash related code into spi_flash_scan for future functionality addition.
Tested-by: Jagan Teki jteki@openedev.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v9: - Fixed nits pointed by Bin
drivers/mtd/spi/sf_probe.c | 147 +++++++++++++++++++++++---------------------- 1 file changed, 76 insertions(+), 71 deletions(-)
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index a619182..d60c40e 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -130,13 +130,42 @@ bank_end: } #endif
-static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, - struct spi_flash *flash) +#if CONFIG_IS_ENABLED(OF_CONTROL) +int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) +{ + fdt_addr_t addr; + fdt_size_t size; + int node; + + /* If there is no node, do nothing */ + node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); + if (node < 0) + return 0; + + addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); + if (addr == FDT_ADDR_T_NONE) { + debug("%s: Cannot decode address\n", __func__); + return 0; + } + + if (flash->size != size) { + debug("%s: Memory map must cover entire device\n", __func__); + return -1; + } + flash->memory_map = map_sysmem(addr, size); + + return 0; +} +#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ + +static int spi_flash_scan(struct spi_slave *spi, u8 *idcode, + struct spi_flash *flash) { const struct spi_flash_params *params; u8 cmd; u16 jedec = idcode[1] << 8 | idcode[2]; u16 ext_jedec = idcode[3] << 8 | idcode[4]; + int ret;
/* Validate params from spi_flash_params table */ params = spi_flash_params_table; @@ -158,6 +187,13 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, return -EPROTONOSUPPORT; }
+ /* Flash powers up read-only, so clear BP# bits */ +#if defined(CONFIG_SPI_FLASH_ATMEL) || \ + defined(CONFIG_SPI_FLASH_MACRONIX) || \ + defined(CONFIG_SPI_FLASH_SST) + spi_flash_cmd_write_status(flash, 0); +#endif + /* Assign spi data */ flash->spi = spi; flash->name = params->name; @@ -253,6 +289,17 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, /* Go for default supported write cmd */ flash->write_cmd = CMD_PAGE_PROGRAM;
+ /* Set the quad enable bit - only for quad commands */ + if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || + (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || + (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { + ret = spi_flash_set_qeb(flash, idcode[0]); + if (ret) { + debug("SF: Fail to set QEB for %02x\n", idcode[0]); + return -EINVAL; + } + } + /* Read dummy_byte: dummy byte is determined based on the * dummy cycles of a particular command. * Fast commands - dummy_byte = dummy_cycles/8 @@ -279,48 +326,41 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode,
/* Configure the BAR - discover bank cmds and read current bank */ #ifdef CONFIG_SPI_FLASH_BAR - int ret = spi_flash_read_bank(flash, idcode[0]); + ret = spi_flash_read_bank(flash, idcode[0]); if (ret < 0) return ret; #endif
- /* Flash powers up read-only, so clear BP# bits */ -#if defined(CONFIG_SPI_FLASH_ATMEL) || \ - defined(CONFIG_SPI_FLASH_MACRONIX) || \ - defined(CONFIG_SPI_FLASH_SST) - spi_flash_cmd_write_status(flash, 0); -#endif - - return 0; -} - #if CONFIG_IS_ENABLED(OF_CONTROL) -int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) -{ - fdt_addr_t addr; - fdt_size_t size; - int node; - - /* If there is no node, do nothing */ - node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); - if (node < 0) - return 0; - - addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); - if (addr == FDT_ADDR_T_NONE) { - debug("%s: Cannot decode address\n", __func__); - return 0; + ret = spi_flash_decode_fdt(gd->fdt_blob, flash); + if (ret) { + debug("SF: FDT decode error\n"); + return -EINVAL; } +#endif
- if (flash->size != size) { - debug("%s: Memory map must cover entire device\n", __func__); - return -1; +#ifndef CONFIG_SPL_BUILD + printf("SF: Detected %s with page size ", flash->name); + print_size(flash->page_size, ", erase size "); + print_size(flash->erase_size, ", total "); + print_size(flash->size, ""); + if (flash->memory_map) + printf(", mapped at %p", flash->memory_map); + puts("\n"); +#endif + +#ifndef CONFIG_SPI_FLASH_BAR + if (((flash->dual_flash == SF_SINGLE_FLASH) && + (flash->size > SPI_FLASH_16MB_BOUN)) || + ((flash->dual_flash > SF_SINGLE_FLASH) && + (flash->size > SPI_FLASH_16MB_BOUN << 1))) { + puts("SF: Warning - Only lower 16MiB accessible,"); + puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); } - flash->memory_map = map_sysmem(addr, size); +#endif
- return 0; + return ret; } -#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */
/** * spi_flash_probe_slave() - Probe for a SPI flash device on a bus @@ -359,47 +399,12 @@ int spi_flash_probe_slave(struct spi_slave *spi, struct spi_flash *flash) print_buffer(0, idcode, 1, sizeof(idcode), 0); #endif
- if (spi_flash_validate_params(spi, idcode, flash)) { + ret = spi_flash_scan(spi, idcode, flash); + if (ret) { ret = -EINVAL; goto err_read_id; }
- /* Set the quad enable bit - only for quad commands */ - if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || - (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || - (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { - if (spi_flash_set_qeb(flash, idcode[0])) { - debug("SF: Fail to set QEB for %02x\n", idcode[0]); - ret = -EINVAL; - goto err_read_id; - } - } - -#if CONFIG_IS_ENABLED(OF_CONTROL) - if (spi_flash_decode_fdt(gd->fdt_blob, flash)) { - debug("SF: FDT decode error\n"); - ret = -EINVAL; - goto err_read_id; - } -#endif -#ifndef CONFIG_SPL_BUILD - printf("SF: Detected %s with page size ", flash->name); - print_size(flash->page_size, ", erase size "); - print_size(flash->erase_size, ", total "); - print_size(flash->size, ""); - if (flash->memory_map) - printf(", mapped at %p", flash->memory_map); - puts("\n"); -#endif -#ifndef CONFIG_SPI_FLASH_BAR - if (((flash->dual_flash == SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN)) || - ((flash->dual_flash > SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN << 1))) { - puts("SF: Warning - Only lower 16MiB accessible,"); - puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); - } -#endif #ifdef CONFIG_SPI_FLASH_MTD ret = spi_flash_mtd_register(flash); #endif
Intension is that sf_ops should deals all spi_flash related stuff and sf_probe (which should renamed future) should be an interface layer for spi_flash versus spi drivers.
sf_ops => spi_flash interface sf_probe => interface layer vs spi_flash(sf_probe) to spi drivers
Tested-by: Jagan Teki jteki@openedev.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v9: - Rebase on "v9 01/14"
drivers/mtd/spi/sf_internal.h | 14 ++ drivers/mtd/spi/sf_ops.c | 343 ++++++++++++++++++++++++++++++++++++++++++ drivers/mtd/spi/sf_probe.c | 342 ----------------------------------------- 3 files changed, 357 insertions(+), 342 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 85c8a89..f3eb6f3 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -245,4 +245,18 @@ int spi_flash_mtd_register(struct spi_flash *flash); void spi_flash_mtd_unregister(void); #endif
+/** + * spi_flash_scan - scan the SPI FLASH + * @spi: the spi slave structure + * @idcode: idcode of spi flash + * @flash: the spi flash structure + * + * The drivers can use this fuction to scan the SPI FLASH. + * In the scanning, it will try to get all the necessary information to + * fill the spi_flash{}. + * + * Return: 0 for success, others for failure. + */ +int spi_flash_scan(struct spi_slave *spi, u8 *idcode, struct spi_flash *flash); + #endif /* _SF_INTERNAL_H_ */ diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 3a56d7f..306db8f 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -11,6 +11,7 @@ #include <common.h> #include <errno.h> #include <malloc.h> +#include <mapmem.h> #include <spi.h> #include <spi_flash.h> #include <watchdog.h> @@ -19,6 +20,8 @@
#include "sf_internal.h"
+DECLARE_GLOBAL_DATA_PTR; + static void spi_flash_addr(u32 addr, u8 *cmd) { /* cmd[0] is actual command */ @@ -757,3 +760,343 @@ int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) return 0; } #endif + + +/* Read commands array */ +static u8 spi_read_cmds_array[] = { + CMD_READ_ARRAY_SLOW, + CMD_READ_ARRAY_FAST, + CMD_READ_DUAL_OUTPUT_FAST, + CMD_READ_DUAL_IO_FAST, + CMD_READ_QUAD_OUTPUT_FAST, + CMD_READ_QUAD_IO_FAST, +}; + +#ifdef CONFIG_SPI_FLASH_MACRONIX +static int spi_flash_set_qeb_mxic(struct spi_flash *flash) +{ + u8 qeb_status; + int ret; + + ret = spi_flash_cmd_read_status(flash, &qeb_status); + if (ret < 0) + return ret; + + if (qeb_status & STATUS_QEB_MXIC) { + debug("SF: mxic: QEB is already set\n"); + } else { + ret = spi_flash_cmd_write_status(flash, STATUS_QEB_MXIC); + if (ret < 0) + return ret; + } + + return ret; +} +#endif + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +static int spi_flash_set_qeb_winspan(struct spi_flash *flash) +{ + u8 qeb_status; + int ret; + + ret = spi_flash_cmd_read_config(flash, &qeb_status); + if (ret < 0) + return ret; + + if (qeb_status & STATUS_QEB_WINSPAN) { + debug("SF: winspan: QEB is already set\n"); + } else { + ret = spi_flash_cmd_write_config(flash, STATUS_QEB_WINSPAN); + if (ret < 0) + return ret; + } + + return ret; +} +#endif + +static int spi_flash_set_qeb(struct spi_flash *flash, u8 idcode0) +{ + switch (idcode0) { +#ifdef CONFIG_SPI_FLASH_MACRONIX + case SPI_FLASH_CFI_MFR_MACRONIX: + return spi_flash_set_qeb_mxic(flash); +#endif +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + case SPI_FLASH_CFI_MFR_SPANSION: + case SPI_FLASH_CFI_MFR_WINBOND: + return spi_flash_set_qeb_winspan(flash); +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO + case SPI_FLASH_CFI_MFR_STMICRO: + debug("SF: QEB is volatile for %02x flash\n", idcode0); + return 0; +#endif + default: + printf("SF: Need set QEB func for %02x flash\n", idcode0); + return -1; + } +} + +#ifdef CONFIG_SPI_FLASH_BAR +static int spi_flash_read_bank(struct spi_flash *flash, u8 idcode0) +{ + u8 curr_bank = 0; + int ret; + + if (flash->size <= SPI_FLASH_16MB_BOUN) + goto bank_end; + + switch (idcode0) { + case SPI_FLASH_CFI_MFR_SPANSION: + flash->bank_read_cmd = CMD_BANKADDR_BRRD; + flash->bank_write_cmd = CMD_BANKADDR_BRWR; + default: + flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; + flash->bank_write_cmd = CMD_EXTNADDR_WREAR; + } + + ret = spi_flash_read_common(flash, &flash->bank_read_cmd, 1, + &curr_bank, 1); + if (ret) { + debug("SF: fail to read bank addr register\n"); + return ret; + } + +bank_end: + flash->bank_curr = curr_bank; + return 0; +} +#endif + +#if CONFIG_IS_ENABLED(OF_CONTROL) +int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) +{ + fdt_addr_t addr; + fdt_size_t size; + int node; + + /* If there is no node, do nothing */ + node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); + if (node < 0) + return 0; + + addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); + if (addr == FDT_ADDR_T_NONE) { + debug("%s: Cannot decode address\n", __func__); + return 0; + } + + if (flash->size != size) { + debug("%s: Memory map must cover entire device\n", __func__); + return -1; + } + flash->memory_map = map_sysmem(addr, size); + + return 0; +} +#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ + +int spi_flash_scan(struct spi_slave *spi, u8 *idcode, struct spi_flash *flash) +{ + const struct spi_flash_params *params; + u8 cmd; + u16 jedec = idcode[1] << 8 | idcode[2]; + u16 ext_jedec = idcode[3] << 8 | idcode[4]; + int ret; + + /* Validate params from spi_flash_params table */ + params = spi_flash_params_table; + for (; params->name != NULL; params++) { + if ((params->jedec >> 16) == idcode[0]) { + if ((params->jedec & 0xFFFF) == jedec) { + if (params->ext_jedec == 0) + break; + else if (params->ext_jedec == ext_jedec) + break; + } + } + } + + if (!params->name) { + printf("SF: Unsupported flash IDs: "); + printf("manuf %02x, jedec %04x, ext_jedec %04x\n", + idcode[0], jedec, ext_jedec); + return -EPROTONOSUPPORT; + } + + /* Flash powers up read-only, so clear BP# bits */ +#if defined(CONFIG_SPI_FLASH_ATMEL) || \ + defined(CONFIG_SPI_FLASH_MACRONIX) || \ + defined(CONFIG_SPI_FLASH_SST) + spi_flash_cmd_write_status(flash, 0); +#endif + + /* Assign spi data */ + flash->spi = spi; + flash->name = params->name; + flash->memory_map = spi->memory_map; + flash->dual_flash = flash->spi->option; + + /* Assign spi flash flags */ + if (params->flags & SST_WR) + flash->flags |= SNOR_F_SST_WR; + + /* Assign spi_flash ops */ +#ifndef CONFIG_DM_SPI_FLASH + flash->write = spi_flash_cmd_write_ops; +#if defined(CONFIG_SPI_FLASH_SST) + if (flash->flags & SNOR_F_SST_WR) { + if (flash->spi->op_mode_tx & SPI_OPM_TX_BP) + flash->write = sst_write_bp; + else + flash->write = sst_write_wp; + } +#endif + flash->erase = spi_flash_cmd_erase_ops; + flash->read = spi_flash_cmd_read_ops; +#endif + + /* lock hooks are flash specific - assign them based on idcode0 */ + switch (idcode[0]) { +#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) + case SPI_FLASH_CFI_MFR_STMICRO: + case SPI_FLASH_CFI_MFR_SST: + flash->flash_lock = stm_lock; + flash->flash_unlock = stm_unlock; + flash->flash_is_locked = stm_is_locked; +#endif + break; + default: + debug("SF: Lock ops not supported for %02x flash\n", idcode[0]); + } + + /* Compute the flash size */ + flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; + /* + * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the + * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with + * the 0x4d00 Extended JEDEC code have 512b pages. All of the others + * have 256b pages. + */ + if (ext_jedec == 0x4d00) { + if ((jedec == 0x0215) || (jedec == 0x216)) + flash->page_size = 256; + else + flash->page_size = 512; + } else { + flash->page_size = 256; + } + flash->page_size <<= flash->shift; + flash->sector_size = params->sector_size << flash->shift; + flash->size = flash->sector_size * params->nr_sectors << flash->shift; +#ifdef CONFIG_SF_DUAL_FLASH + if (flash->dual_flash & SF_DUAL_STACKED_FLASH) + flash->size <<= 1; +#endif + + /* Compute erase sector and command */ + if (params->flags & SECT_4K) { + flash->erase_cmd = CMD_ERASE_4K; + flash->erase_size = 4096 << flash->shift; + } else if (params->flags & SECT_32K) { + flash->erase_cmd = CMD_ERASE_32K; + flash->erase_size = 32768 << flash->shift; + } else { + flash->erase_cmd = CMD_ERASE_64K; + flash->erase_size = flash->sector_size; + } + + /* Now erase size becomes valid sector size */ + flash->sector_size = flash->erase_size; + + /* Look for the fastest read cmd */ + cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); + if (cmd) { + cmd = spi_read_cmds_array[cmd - 1]; + flash->read_cmd = cmd; + } else { + /* Go for default supported read cmd */ + flash->read_cmd = CMD_READ_ARRAY_FAST; + } + + /* Not require to look for fastest only two write cmds yet */ + if (params->flags & WR_QPP && flash->spi->op_mode_tx & SPI_OPM_TX_QPP) + flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; + else + /* Go for default supported write cmd */ + flash->write_cmd = CMD_PAGE_PROGRAM; + + /* Set the quad enable bit - only for quad commands */ + if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || + (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || + (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { + ret = spi_flash_set_qeb(flash, idcode[0]); + if (ret) { + debug("SF: Fail to set QEB for %02x\n", idcode[0]); + return -EINVAL; + } + } + + /* Read dummy_byte: dummy byte is determined based on the + * dummy cycles of a particular command. + * Fast commands - dummy_byte = dummy_cycles/8 + * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 + * For I/O commands except cmd[0] everything goes on no.of lines + * based on particular command but incase of fast commands except + * data all go on single line irrespective of command. + */ + switch (flash->read_cmd) { + case CMD_READ_QUAD_IO_FAST: + flash->dummy_byte = 2; + break; + case CMD_READ_ARRAY_SLOW: + flash->dummy_byte = 0; + break; + default: + flash->dummy_byte = 1; + } + +#ifdef CONFIG_SPI_FLASH_STMICRO + if (params->flags & E_FSR) + flash->flags |= SNOR_F_USE_FSR; +#endif + + /* Configure the BAR - discover bank cmds and read current bank */ +#ifdef CONFIG_SPI_FLASH_BAR + ret = spi_flash_read_bank(flash, idcode[0]); + if (ret < 0) + return ret; +#endif + +#if CONFIG_IS_ENABLED(OF_CONTROL) + ret = spi_flash_decode_fdt(gd->fdt_blob, flash); + if (ret) { + debug("SF: FDT decode error\n"); + return -EINVAL; + } +#endif + +#ifndef CONFIG_SPL_BUILD + printf("SF: Detected %s with page size ", flash->name); + print_size(flash->page_size, ", erase size "); + print_size(flash->erase_size, ", total "); + print_size(flash->size, ""); + if (flash->memory_map) + printf(", mapped at %p", flash->memory_map); + puts("\n"); +#endif + +#ifndef CONFIG_SPI_FLASH_BAR + if (((flash->dual_flash == SF_SINGLE_FLASH) && + (flash->size > SPI_FLASH_16MB_BOUN)) || + ((flash->dual_flash > SF_SINGLE_FLASH) && + (flash->size > SPI_FLASH_16MB_BOUN << 1))) { + puts("SF: Warning - Only lower 16MiB accessible,"); + puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); + } +#endif + + return ret; +} diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index d60c40e..994559d 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -20,348 +20,6 @@
-DECLARE_GLOBAL_DATA_PTR; - -/* Read commands array */ -static u8 spi_read_cmds_array[] = { - CMD_READ_ARRAY_SLOW, - CMD_READ_ARRAY_FAST, - CMD_READ_DUAL_OUTPUT_FAST, - CMD_READ_DUAL_IO_FAST, - CMD_READ_QUAD_OUTPUT_FAST, - CMD_READ_QUAD_IO_FAST, -}; - -#ifdef CONFIG_SPI_FLASH_MACRONIX -static int spi_flash_set_qeb_mxic(struct spi_flash *flash) -{ - u8 qeb_status; - int ret; - - ret = spi_flash_cmd_read_status(flash, &qeb_status); - if (ret < 0) - return ret; - - if (qeb_status & STATUS_QEB_MXIC) { - debug("SF: mxic: QEB is already set\n"); - } else { - ret = spi_flash_cmd_write_status(flash, STATUS_QEB_MXIC); - if (ret < 0) - return ret; - } - - return ret; -} -#endif - -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) -static int spi_flash_set_qeb_winspan(struct spi_flash *flash) -{ - u8 qeb_status; - int ret; - - ret = spi_flash_cmd_read_config(flash, &qeb_status); - if (ret < 0) - return ret; - - if (qeb_status & STATUS_QEB_WINSPAN) { - debug("SF: winspan: QEB is already set\n"); - } else { - ret = spi_flash_cmd_write_config(flash, STATUS_QEB_WINSPAN); - if (ret < 0) - return ret; - } - - return ret; -} -#endif - -static int spi_flash_set_qeb(struct spi_flash *flash, u8 idcode0) -{ - switch (idcode0) { -#ifdef CONFIG_SPI_FLASH_MACRONIX - case SPI_FLASH_CFI_MFR_MACRONIX: - return spi_flash_set_qeb_mxic(flash); -#endif -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) - case SPI_FLASH_CFI_MFR_SPANSION: - case SPI_FLASH_CFI_MFR_WINBOND: - return spi_flash_set_qeb_winspan(flash); -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - case SPI_FLASH_CFI_MFR_STMICRO: - debug("SF: QEB is volatile for %02x flash\n", idcode0); - return 0; -#endif - default: - printf("SF: Need set QEB func for %02x flash\n", idcode0); - return -1; - } -} - -#ifdef CONFIG_SPI_FLASH_BAR -static int spi_flash_read_bank(struct spi_flash *flash, u8 idcode0) -{ - u8 curr_bank = 0; - int ret; - - if (flash->size <= SPI_FLASH_16MB_BOUN) - goto bank_end; - - switch (idcode0) { - case SPI_FLASH_CFI_MFR_SPANSION: - flash->bank_read_cmd = CMD_BANKADDR_BRRD; - flash->bank_write_cmd = CMD_BANKADDR_BRWR; - default: - flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; - flash->bank_write_cmd = CMD_EXTNADDR_WREAR; - } - - ret = spi_flash_read_common(flash, &flash->bank_read_cmd, 1, - &curr_bank, 1); - if (ret) { - debug("SF: fail to read bank addr register\n"); - return ret; - } - -bank_end: - flash->bank_curr = curr_bank; - return 0; -} -#endif - -#if CONFIG_IS_ENABLED(OF_CONTROL) -int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) -{ - fdt_addr_t addr; - fdt_size_t size; - int node; - - /* If there is no node, do nothing */ - node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); - if (node < 0) - return 0; - - addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); - if (addr == FDT_ADDR_T_NONE) { - debug("%s: Cannot decode address\n", __func__); - return 0; - } - - if (flash->size != size) { - debug("%s: Memory map must cover entire device\n", __func__); - return -1; - } - flash->memory_map = map_sysmem(addr, size); - - return 0; -} -#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ - -static int spi_flash_scan(struct spi_slave *spi, u8 *idcode, - struct spi_flash *flash) -{ - const struct spi_flash_params *params; - u8 cmd; - u16 jedec = idcode[1] << 8 | idcode[2]; - u16 ext_jedec = idcode[3] << 8 | idcode[4]; - int ret; - - /* Validate params from spi_flash_params table */ - params = spi_flash_params_table; - for (; params->name != NULL; params++) { - if ((params->jedec >> 16) == idcode[0]) { - if ((params->jedec & 0xFFFF) == jedec) { - if (params->ext_jedec == 0) - break; - else if (params->ext_jedec == ext_jedec) - break; - } - } - } - - if (!params->name) { - printf("SF: Unsupported flash IDs: "); - printf("manuf %02x, jedec %04x, ext_jedec %04x\n", - idcode[0], jedec, ext_jedec); - return -EPROTONOSUPPORT; - } - - /* Flash powers up read-only, so clear BP# bits */ -#if defined(CONFIG_SPI_FLASH_ATMEL) || \ - defined(CONFIG_SPI_FLASH_MACRONIX) || \ - defined(CONFIG_SPI_FLASH_SST) - spi_flash_cmd_write_status(flash, 0); -#endif - - /* Assign spi data */ - flash->spi = spi; - flash->name = params->name; - flash->memory_map = spi->memory_map; - flash->dual_flash = flash->spi->option; - - /* Assign spi flash flags */ - if (params->flags & SST_WR) - flash->flags |= SNOR_F_SST_WR; - - /* Assign spi_flash ops */ -#ifndef CONFIG_DM_SPI_FLASH - flash->write = spi_flash_cmd_write_ops; -#if defined(CONFIG_SPI_FLASH_SST) - if (flash->flags & SNOR_F_SST_WR) { - if (flash->spi->op_mode_tx & SPI_OPM_TX_BP) - flash->write = sst_write_bp; - else - flash->write = sst_write_wp; - } -#endif - flash->erase = spi_flash_cmd_erase_ops; - flash->read = spi_flash_cmd_read_ops; -#endif - - /* lock hooks are flash specific - assign them based on idcode0 */ - switch (idcode[0]) { -#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) - case SPI_FLASH_CFI_MFR_STMICRO: - case SPI_FLASH_CFI_MFR_SST: - flash->flash_lock = stm_lock; - flash->flash_unlock = stm_unlock; - flash->flash_is_locked = stm_is_locked; -#endif - break; - default: - debug("SF: Lock ops not supported for %02x flash\n", idcode[0]); - } - - /* Compute the flash size */ - flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; - /* - * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the - * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with - * the 0x4d00 Extended JEDEC code have 512b pages. All of the others - * have 256b pages. - */ - if (ext_jedec == 0x4d00) { - if ((jedec == 0x0215) || (jedec == 0x216)) - flash->page_size = 256; - else - flash->page_size = 512; - } else { - flash->page_size = 256; - } - flash->page_size <<= flash->shift; - flash->sector_size = params->sector_size << flash->shift; - flash->size = flash->sector_size * params->nr_sectors << flash->shift; -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash & SF_DUAL_STACKED_FLASH) - flash->size <<= 1; -#endif - - /* Compute erase sector and command */ - if (params->flags & SECT_4K) { - flash->erase_cmd = CMD_ERASE_4K; - flash->erase_size = 4096 << flash->shift; - } else if (params->flags & SECT_32K) { - flash->erase_cmd = CMD_ERASE_32K; - flash->erase_size = 32768 << flash->shift; - } else { - flash->erase_cmd = CMD_ERASE_64K; - flash->erase_size = flash->sector_size; - } - - /* Now erase size becomes valid sector size */ - flash->sector_size = flash->erase_size; - - /* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); - if (cmd) { - cmd = spi_read_cmds_array[cmd - 1]; - flash->read_cmd = cmd; - } else { - /* Go for default supported read cmd */ - flash->read_cmd = CMD_READ_ARRAY_FAST; - } - - /* Not require to look for fastest only two write cmds yet */ - if (params->flags & WR_QPP && flash->spi->op_mode_tx & SPI_OPM_TX_QPP) - flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; - else - /* Go for default supported write cmd */ - flash->write_cmd = CMD_PAGE_PROGRAM; - - /* Set the quad enable bit - only for quad commands */ - if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || - (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || - (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { - ret = spi_flash_set_qeb(flash, idcode[0]); - if (ret) { - debug("SF: Fail to set QEB for %02x\n", idcode[0]); - return -EINVAL; - } - } - - /* Read dummy_byte: dummy byte is determined based on the - * dummy cycles of a particular command. - * Fast commands - dummy_byte = dummy_cycles/8 - * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 - * For I/O commands except cmd[0] everything goes on no.of lines - * based on particular command but incase of fast commands except - * data all go on single line irrespective of command. - */ - switch (flash->read_cmd) { - case CMD_READ_QUAD_IO_FAST: - flash->dummy_byte = 2; - break; - case CMD_READ_ARRAY_SLOW: - flash->dummy_byte = 0; - break; - default: - flash->dummy_byte = 1; - } - -#ifdef CONFIG_SPI_FLASH_STMICRO - if (params->flags & E_FSR) - flash->flags |= SNOR_F_USE_FSR; -#endif - - /* Configure the BAR - discover bank cmds and read current bank */ -#ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_read_bank(flash, idcode[0]); - if (ret < 0) - return ret; -#endif - -#if CONFIG_IS_ENABLED(OF_CONTROL) - ret = spi_flash_decode_fdt(gd->fdt_blob, flash); - if (ret) { - debug("SF: FDT decode error\n"); - return -EINVAL; - } -#endif - -#ifndef CONFIG_SPL_BUILD - printf("SF: Detected %s with page size ", flash->name); - print_size(flash->page_size, ", erase size "); - print_size(flash->erase_size, ", total "); - print_size(flash->size, ""); - if (flash->memory_map) - printf(", mapped at %p", flash->memory_map); - puts("\n"); -#endif - -#ifndef CONFIG_SPI_FLASH_BAR - if (((flash->dual_flash == SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN)) || - ((flash->dual_flash > SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN << 1))) { - puts("SF: Warning - Only lower 16MiB accessible,"); - puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); - } -#endif - - return ret; -} - /** * spi_flash_probe_slave() - Probe for a SPI flash device on a bus *
Hi Bin,
fdt_addr_t addr;
fdt_size_t size;
int node;
if (node < 0)
return -1;
Please let me know if your fine? I need to push this series asap before the next released.
int ret; /* Validate params from spi_flash_params table */ params = spi_flash_params_table;
if (ret) {
return -EINVAL;
#endif
-#endif
fdt_addr_t addr;
fdt_size_t size;
int node;
if (node < 0)
if (ret) {
return -EINVAL; }
return -1;
puts("\n");
return ret;
- spi_flash_probe_slave() - Probe for a SPI flash device on a bus
ret = -EINVAL;
goto err_read_id;
ret = -EINVAL;
goto err_read_id;
puts("\n");
#endif
1.9.1
Hi Jagan,
On Fri, Dec 11, 2015 at 10:31 PM, Jagan Teki jteki@openedev.com wrote:
Hi Bin,
fdt_addr_t addr;
fdt_size_t size;
int node;
if (node < 0)
return -1;
Still looks not correct. See http://patchwork.ozlabs.org/patch/555780/. I sent you a patch offline. Please check that.
if (ret) {
return -EINVAL;
#endif
-#endif
fdt_addr_t addr;
fdt_size_t size;
int node;
if (node < 0)
if (ret) {
return -EINVAL; }
return -1;
puts("\n");
return ret;
ret = -EINVAL;
goto err_read_id;
ret = -EINVAL;
goto err_read_id;
puts("\n");
#endif
Regards, Bin
Bin Meng
Jagan Teki
