[U-Boot-Users] [PATCH 1/2] net/ppc4xx: Rework 4xx non NET_MULTI MII init code
This patch simplifies the 4xx MII PHY init code by introducing the define CONFIG_PPC4xx_EMAC for EMAC enabled SoC's.
Signed-off-by: Stefan Roese sr@denx.de --- This is post 1.3.4 material.
Ben, could you please queue this up and push it in the next merge window? If nobody objects of course.
net/eth.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/net/eth.c b/net/eth.c index 38979aa..77a8500 100644 --- a/net/eth.c +++ b/net/eth.c @@ -620,8 +620,7 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_AT91RM9200) at91rm9200_miiphy_initialize(bis); #endif -#if defined(CONFIG_4xx) && !defined(CONFIG_IOP480) \ - && !defined(CONFIG_AP1000) && !defined(CONFIG_405) +#if defined(CONFIG_PPC4xx_EMAC) emac4xx_miiphy_initialize(bis); #endif #if defined(CONFIG_MCF52x2)
Will do. I'll try to get to it tonight (early morning now). Thanks, I was about to rant about growing conditional non-compilation, but you saved everybody.
cheers, Ben
Ben Warren
Stefan Roese
