[PATCH] xilinx: Add support for ENV_VARS_UBOOT_RUNTIME_CONFIG
Start to use ENV_VARS_UBOOT_RUNTIME_CONFIG to enable/disable updating variables with run time information.
arch/arm/Kconfig | 3 +++ board/xilinx/versal/board.c | 3 +++ board/xilinx/zynq/board.c | 8 ++++++++ board/xilinx/zynqmp/zynqmp.c | 3 +++ 4 files changed, 17 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 156698f23d48..7e54288ad789 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1075,6 +1075,7 @@ config ARCH_VERSAL select DM_SERIAL select OF_CONTROL imply BOARD_LATE_INIT + imply ENV_VARS_UBOOT_RUNTIME_CONFIG
config ARCH_VF610 bool "Freescale Vybrid" @@ -1110,6 +1111,7 @@ config ARCH_ZYNQ imply CMD_CLK imply CMD_DM imply CMD_SPL + imply ENV_VARS_UBOOT_RUNTIME_CONFIG imply FAT_WRITE
config ARCH_ZYNQMP_R5 @@ -1149,6 +1151,7 @@ config ARCH_ZYNQMP select ZYNQMP_IPI imply BOARD_LATE_INIT imply CMD_DM + imply ENV_VARS_UBOOT_RUNTIME_CONFIG imply FAT_WRITE imply MP imply DM_USB_GADGET diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 3dc7044b213e..a5ca4ca87401 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -116,6 +116,9 @@ int board_late_init(void) return 0; }
+ if (!CONFIG_IS_ENABLED(ENV_VARS_UBOOT_RUNTIME_CONFIG)) + return 0; + bootmode = versal_get_bootmode();
puts("Bootmode: "); diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 2164eac8d518..f98497eb73d6 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -33,6 +33,14 @@ int board_late_init(void) char *new_targets; char *env_targets;
+ if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { + debug("Saved variables - Skipping\n"); + return 0; + } + + if (!CONFIG_IS_ENABLED(ENV_VARS_UBOOT_RUNTIME_CONFIG)) + return 0; + switch ((zynq_slcr_get_boot_mode()) & ZYNQ_BM_MASK) { case ZYNQ_BM_QSPI: mode = "qspi"; diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index e8ea3c5a4975..de25f804fcd7 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -521,6 +521,9 @@ int board_late_init(void) return 0; }
+ if (!CONFIG_IS_ENABLED(ENV_VARS_UBOOT_RUNTIME_CONFIG)) + return 0; + ret = set_fdtfile(); if (ret) return ret;
st 5. 8. 2020 v 14:01 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
bootmode = versal_get_bootmode(); puts("Bootmode: ");
-- 2.27.0
Applied with adding missing log.h to zynq/board.c
Thanks, Michal
Michal Simek
Michal Simek
