[U-Boot] Pull request - ColdFire
Wolfgang,
The following changes since commit 0b692dcb190655c7eb96b6b8003bee163e3b58dd: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-net
git://www.denx.de/git/u-boot-coldfire.git master
TsiChung Liew (1): MCF5271-only: Added a weak board_reset function to allow custom reset
Wolfgang Wegner (3): add include/asm-m68k/unaligned.h allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE
cpu/mcf52x2/cpu.c | 6 ++++++ cpu/mcf52x2/cpu.h | 33 +++++++++++++++++++++++++++++++++ cpu/mcf532x/speed.c | 3 +++ cpu/mcf532x/start.S | 6 +++++- drivers/mtd/cfi_flash.c | 2 +- include/asm-m68k/unaligned.h | 15 +++++++++++++++ 6 files changed, 63 insertions(+), 2 deletions(-) create mode 100644 cpu/mcf52x2/cpu.h create mode 100644 include/asm-m68k/unaligned.h
Thanks!
Regards, TsiChung
Dear TC Liew,
In message a90206391002101023k7f32c804k62e675e8a29dce29@mail.gmail.com you wrote:
Wolfgang,
Hm... strange... The patch as posted (see for example here: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70457 was submitted by Richard Retanubun; it carries an explicit
From: Richard Retanubun RichardRetanubun@RuggedCom.com
and has a different commit message, and a different date.
Please make sure to use git-am to apply patches from the mailing list, so dates and attribution is correct.
It seems you many
This patch adds a too long line. Sorry for not noticing this before.
Sorry, not pulled.
The long line is a nuisance only, but the wrong attribution should really be fixed.
Thanks.
Dear Wolfgang, TsiChung,
On Thu, Feb 11, 2010 at 11:55:11PM +0100, Wolfgang Denk wrote: [...]
sorry for that - it was posted before I found out about checkpatch.pl
I can send a corrected patch on tuesday because I do not have that stuff set up here and company is closed until then... :-(
Regards, Wolfgang
CONFIG_MONITOR_IS_IN_RAM is broken for MCF532x (and all other processors having RAM located above the FLASH area). This patch fixes this by conditionally - removing the vector table at the beginning of code (MCF532x) - not overwriting the vector base register (MCF532x) - removing the code to re-set the PLL, which effectively disables SDRAM access (MCF532x) - fixing the preprocessor condition to switch monitor protection off (all architectures)
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- This revised version fixes the too long line in drivers/mtd/cfi_flash.c that would have been introduced by the first version. In case it is preferred to provide a "patch for the patch" to fix the long line alone, please let me know.
cpu/mcf532x/speed.c | 3 +++ cpu/mcf532x/start.S | 4 ++++ drivers/mtd/cfi_flash.c | 3 ++- 3 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/cpu/mcf532x/speed.c b/cpu/mcf532x/speed.c index 0d378e6..67f08c7 100644 --- a/cpu/mcf532x/speed.c +++ b/cpu/mcf532x/speed.c @@ -204,6 +204,8 @@ int clock_pll(int fsys, int flags) fout = ((fref * mfd) / (BUSDIV * 4)); #endif
+/* must not tamper with SDRAMC if running from SDRAM */ +#if !defined(CONFIG_MONITOR_IS_IN_RAM) /* * Check to see if the SDRAM has already been initialized. * If it has then the SDRAM needs to be put into self refresh @@ -254,6 +256,7 @@ int clock_pll(int fsys, int flags)
/* wait for DQS logic to relock */ for (i = 0; i < 0x200; i++) ; +#endif /* !defined(CONFIG_MONITOR_IS_IN_RAM) */
return fout; } diff --git a/cpu/mcf532x/start.S b/cpu/mcf532x/start.S index ff13a9f..5b134aa 100644 --- a/cpu/mcf532x/start.S +++ b/cpu/mcf532x/start.S @@ -45,6 +45,7 @@ addl #60,%sp; /* space for 15 regs */ \ rte;
+#if !defined(CONFIG_MONITOR_IS_IN_RAM) .text /* * Vector table. This is used for initial platform startup. @@ -121,6 +122,7 @@ vector192_255: .long _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT .long _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT .long _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT, _FAULT +#endif /* !defined(CONFIG_MONITOR_IS_IN_RAM) */
.text
@@ -130,9 +132,11 @@ _start: nop move.w #0x2700,%sr /* Mask off Interrupt */
+#if !defined(CONFIG_MONITOR_IS_IN_RAM) /* Set vector base register at the beginning of the Flash */ move.l #CONFIG_SYS_FLASH_BASE, %d0 movec %d0, %VBR +#endif
move.l #(CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_CTRL), %d0 movec %d0, %RAMBAR1 diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 24eb33f..fdba297 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1980,7 +1980,8 @@ unsigned long flash_init (void) }
/* Monitor protection ON by default */ -#if (CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE) +#if (CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE) && \ + (!defined(CONFIG_MONITOR_IS_IN_RAM)) flash_protect (FLAG_PROTECT_SET, CONFIG_SYS_MONITOR_BASE, CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1,
For platforms with flash below ram addresses, the current check to activate monitor protection is wrong/insufficient. This patch fixes CONFIG_MONITOR_IS_IN_RAM for these systems by adding a check for this configuration.
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- This patch is the CFI-relevant part of "[PATCH] allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM" dated 16.02.2010 to allow integration by the CFI maintainer independent of coldfire stuff.
drivers/mtd/cfi_flash.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
CONFIG_MONITOR_IS_IN_RAM is broken for MCF532x. This patch fixes this by conditionally - removing the vector table at the beginning of code - not overwriting the vector base register - removing the code to re-set the PLL, which effectively disables SDRAM access
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- This patch is the coldfire-relevant part of "[PATCH] allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM" dated 16.02.2010 to allow integration by the coldfire maintainer independent of CFI stuff.
cpu/mcf532x/speed.c | 3 +++ cpu/mcf532x/start.S | 4 ++++ 2 files changed, 7 insertions(+), 0 deletions(-)
.text
Applied to u-boot-cfi-flash/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
participants (5)
Stefan Roese
TC Liew
Wolfgang Wegner
wolfgang@leila.ping.de
