[PATCH v4 0/2] net: ti: am65-cpsw-nuss: Fix DT binding handling of pinctrl
This series is based on: https://lore.kernel.org/all/20230713072019.3153871-1-nm@ti.com/ https://lore.kernel.org/u-boot/20230614222853.574427-1-dannenberg@ti.com/ https://lore.kernel.org/u-boot/20230722193151.117345-1-rogerq@kernel.org/
It fixes the issue of Linux booting from the DT embedded by U-boot. The main issue there is that U-Boot doesn't handle the MDIO child node that might have resources attached to it.
Thus, any pinctrl configuration that could be attached to the MDIO child node is effectively ignored. Unfortunately, starting with 6.5-rc1, Linux does just that.
This was solved by duplicating the pinctrl configuration onto the MAC device node. Unfortunately, this doesn't work for Linux since now it has two devices competing for the same pins.
Let me know what you think, Maxime
Signed-off-by: Maxime Ripard mripard@kernel.org --- Changes in v4: - Squashed fixup patches - Link to v3: https://lore.kernel.org/r/20230724-ti-mdio-pinmux-v3-0-fc8359b0014b@kernel.o...
Changes in v3: - Rebase on top of latest Roger series - Link to v2: https://lore.kernel.org/r/20230721-ti-mdio-pinmux-v2-0-4bb443e09ac0@kernel.o...
Changes in v2: - Drop the pinctrl API change in favour of a dummy driver - Link to v1: https://lore.kernel.org/r/20230720-ti-mdio-pinmux-v1-0-0bd3bd1cf759@kernel.o...
--- Maxime Ripard (2): net: ti: am65-cpsw-nuss: Enforce pinctrl state on the MDIO child node fixup! arm: dts: k3-am62: Bump dtsi from linux v6.5-rc1
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 1 - drivers/net/ti/Kconfig | 1 + drivers/net/ti/am65-cpsw-nuss.c | 60 ++++++++++++++++++++++++++++++++++++ 3 files changed, 61 insertions(+), 1 deletion(-) --- base-commit: db7126c87c44c45c448c68925d366510f7a09b11 change-id: 20230720-ti-mdio-pinmux-a12525dba973
The binding represents the MDIO controller as a child device tree node of the MAC device tree node.
The U-Boot driver mostly ignores that child device tree node and just hardcodes the resources it uses to support both the MAC and MDIO in a single driver.
However, some resources like pinctrl muxing states are thus ignored. This has been a problem with some device trees that will put some pinctrl states on the MDIO device tree node, like the SK-AM62 Device Tree does.
Let's rework the driver a bit to create a dummy MDIO driver that we will then get during our initialization to force the core to select the right muxing.
Signed-off-by: Maxime Ripard mripard@kernel.org --- drivers/net/ti/Kconfig | 1 + drivers/net/ti/am65-cpsw-nuss.c | 60 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 61 insertions(+)
diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig index d9f1c019a885..02660e4fbb44 100644 --- a/drivers/net/ti/Kconfig +++ b/drivers/net/ti/Kconfig @@ -41,6 +41,7 @@ endchoice config TI_AM65_CPSW_NUSS bool "TI K3 AM65x MCU CPSW Nuss Ethernet controller driver" depends on ARCH_K3 + imply DM_MDIO imply MISC_INIT_R imply MISC imply SYSCON diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index ce52106e5238..51a8167d14a9 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -15,6 +15,7 @@ #include <dm.h> #include <dm/device_compat.h> #include <dm/lists.h> +#include <dm/pinctrl.h> #include <dma-uclass.h> #include <dm/of_access.h> #include <miiphy.h> @@ -605,14 +606,62 @@ static const struct soc_attr k3_mdio_soc_data[] = { { /* sentinel */ }, };
+static ofnode am65_cpsw_find_mdio(ofnode parent) +{ + ofnode node; + + ofnode_for_each_subnode(node, parent) + if (ofnode_device_is_compatible(node, "ti,cpsw-mdio")) + return node; + + return ofnode_null(); +} + +static int am65_cpsw_mdio_setup(struct udevice *dev) +{ + struct am65_cpsw_priv *priv = dev_get_priv(dev); + struct am65_cpsw_common *cpsw_common = priv->cpsw_common; + struct udevice *mdio_dev; + ofnode mdio; + int ret; + + mdio = am65_cpsw_find_mdio(dev_ofnode(cpsw_common->dev)); + if (!ofnode_valid(mdio)) + return 0; + + /* + * The MDIO controller is represented in the DT binding by a + * subnode of the MAC controller. + * + * We don't have a DM driver for the MDIO device yet, and thus any + * pinctrl setting on its node will be ignored. + * + * However, we do need to make sure the pins states tied to the + * MDIO node are configured properly. Fortunately, the core DM + * does that for use when we get a device, so we can work around + * that whole issue by just requesting a dummy MDIO driver to + * probe, and our pins will get muxed. + */ + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, mdio, &mdio_dev); + if (ret) + return ret; + + return 0; +} + static int am65_cpsw_mdio_init(struct udevice *dev) { struct am65_cpsw_priv *priv = dev_get_priv(dev); struct am65_cpsw_common *cpsw_common = priv->cpsw_common; + int ret;
if (!priv->has_phy || cpsw_common->bus) return 0;
+ ret = am65_cpsw_mdio_setup(dev); + if (ret) + return ret; + cpsw_common->bus = cpsw_mdio_init(dev->name, cpsw_common->mdio_base, cpsw_common->bus_freq, @@ -868,3 +917,14 @@ U_BOOT_DRIVER(am65_cpsw_nuss_port) = { .plat_auto = sizeof(struct eth_pdata), .flags = DM_FLAG_ALLOC_PRIV_DMA | DM_FLAG_OS_PREPARE, }; + +static const struct udevice_id am65_cpsw_mdio_ids[] = { + { .compatible = "ti,cpsw-mdio" }, + { } +}; + +U_BOOT_DRIVER(am65_cpsw_mdio) = { + .name = "am65_cpsw_mdio", + .id = UCLASS_MDIO, + .of_match = am65_cpsw_mdio_ids, +};
Hello Maxime,
Thank you for the patch.
LGTM.
Reviewed-by: Siddharth Vadapalli s-vadapalli@ti.com
- imply DM_MDIO imply MISC_INIT_R imply MISC imply SYSCON
- ofnode node;
- ofnode_for_each_subnode(node, parent)
return node;
- return ofnode_null();
- struct am65_cpsw_priv *priv = dev_get_priv(dev);
- struct am65_cpsw_common *cpsw_common = priv->cpsw_common;
- struct udevice *mdio_dev;
- ofnode mdio;
- int ret;
- mdio = am65_cpsw_find_mdio(dev_ofnode(cpsw_common->dev));
- if (!ofnode_valid(mdio))
- ret = uclass_get_device_by_ofnode(UCLASS_MDIO, mdio, &mdio_dev);
- if (ret)
return ret;
int ret;
if (ret)
return ret;
- { .compatible = "ti,cpsw-mdio" },
- .name = "am65_cpsw_mdio",
- .id = UCLASS_MDIO,
- .of_match = am65_cpsw_mdio_ids,
Acked-by: Roger Quadros rogerq@kernel.org
Acked-by: Nishanth Menon nm@ti.com
Hi Maxime
Just a minor nitpick in the comments below.
diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig index d9f1c019a885..02660e4fbb44 100644 --- a/drivers/net/ti/Kconfig +++ b/drivers/net/ti/Kconfig @@ -41,6 +41,7 @@ endchoice config TI_AM65_CPSW_NUSS bool "TI K3 AM65x MCU CPSW Nuss Ethernet controller driver" depends on ARCH_K3 + imply DM_MDIO imply MISC_INIT_R imply MISC imply SYSCON diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index ce52106e5238..51a8167d14a9 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -15,6 +15,7 @@ #include <dm.h> #include <dm/device_compat.h> #include <dm/lists.h> +#include <dm/pinctrl.h> #include <dma-uclass.h> #include <dm/of_access.h> #include <miiphy.h> @@ -605,14 +606,62 @@ static const struct soc_attr k3_mdio_soc_data[] = { { /* sentinel */ }, }; +static ofnode am65_cpsw_find_mdio(ofnode parent) +{ + ofnode node;
Does that for us?
+ return 0; +}
static int am65_cpsw_mdio_init(struct udevice *dev) { struct am65_cpsw_priv *priv = dev_get_priv(dev); struct am65_cpsw_common *cpsw_common = priv->cpsw_common; + int ret; if (!priv->has_phy || cpsw_common->bus) return 0; + ret = am65_cpsw_mdio_setup(dev); + if (ret) + return ret;
However, so far I could not make this work for our use-case [1]. It just keeps crashing. Any ideas?
[snip]
Model: Toradex 0076 Verdin AM62 Quad 2GB WB IT V1.0A Serial#: 15037380 Carrier: Toradex Dahlia V1.1A, Serial# 10763237 am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81 103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000 Setting variant to wifi Net: Warning: ethernet@8000000port@1 MAC addresses don't match: Address in ROM is 1c:63:49:22:5f:f9 Address in environment is 00:14:2d:e5:73:c4 eth0: ethernet@8000000port@1 [PRIME]Could not get PHY for ethernet@8000000port@1 : addr 7 am65_cpsw_nuss_port ethernet@8000000port@2: phy_connect() failed
Hit any key to stop autoboot: 0
Verdin AM62 # dhcp ti-udma dma-controller@485c0000: k3_dmaring Ring probed rings:150, sci-dev-id:30 ti-udma dma-controller@485c0000: dma-ring-reset-quirk: disabled am65_cpsw_nuss_port ethernet@8000000port@1: K3 CPSW: rflow_id_base: 19 ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT ! am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error "Synchronous Abort" handler, esr 0x96000010, far 0x8000f04 elr: 00000000808503ac lr : 000000008084ce1c (reloc) elr: 000000009bf533ac lr : 000000009bf4fe1c x0 : 0000000008000f00 x1 : 0000000000000007 x2 : 00000000ffffffff x3 : 0000000000000002 x4 : 000000009bf53388 x5 : 0000000000011d28 x6 : 0000000000007578 x7 : 0000000099f10570 x8 : 0000000000000002 x9 : 0000000000000007 x10: 0000000000000002 x11: 0000000000007578 x12: 0000000099eeea98 x13: 0000000099eef030 x14: 0000000000000000 x15: 0000000099eee834 x16: 000000009bf5d040 x17: 0000000000000000 x18: 0000000099f00d70 x19: 0000000099eeead4 x20: 0000000099f10590 x21: 0000000000000007 x22: 00000000ffffffff x23: 0000000000000001 x24: 0000000000000080 x25: 0000000000000000 x26: 00000000ffffffff x27: 000000001fffffff x28: 0000000000000000 x29: 0000000099eeea30
Code: 2a0103e9 2a0303e8 910003fd f94000e0 (b9400400) Resetting CPU ...
resetting ...
[1] https://lore.kernel.org/all/20230715074050.941051-1-marcel@ziswiler.com
Cheers
Marcel
On Fri, Jul 28, 2023 at 01:34:38PM +0000, Marcel Ziswiler wrote:
Hi Maxime
Does that for us?
+ return 0; +}
[snip]
resetting ...
It looks like this series is fairly outdated and won't reasonably work with these patches. Do you have a branch where you pulled our patches?
Maxime
Hi Maxime
[snip]
[snip]
[snip]
I figured it out now. I was missing CONFIG_PHY_ETHERNET_ID required for reset-gpios in the PHY node to work in U-Boot. Sorry for the noise. Cleaned-up v4 of our stuff incoming...
Thanks!
Maxime
Cheers
Marcel
Signed-off-by: Maxime Ripard mripard@kernel.org Reviewed-by: Siddharth Vadapalli s-vadapalli@ti.com Acked-by: Roger Quadros rogerq@kernel.org Acked-by: Nishanth Menon nm@ti.com
The MDIO pinctrl nodes can't be duplicated between the child and device, because if we ever boot Linux with our DT it will try to attach that pinctrl configuration to both the MAC and MDIO devices, which will result in failure to probe.
Signed-off-by: Maxime Ripard mripard@kernel.org --- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index a3f207baa304..c1685bc9ca39 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -120,7 +120,6 @@
&cpsw3g { bootph-pre-ram; - pinctrl-0 = <&main_mdio1_pins_default &main_rgmii1_pins_default>; };
&cpsw_port1 {
participants (7)
Marcel Ziswiler
Maxime Ripard
mripard@kernel.org
Nishanth Menon
Roger Quadros
Siddharth Vadapalli
