[U-Boot] [PATCH] SPL: SPI: select SPL_SPI_FLASH_SUPPORT on SPL_SPI_SUNXI
The Allwinner SPI flash SPL boot support is guarded by the SPL_SPI_SUNXI symbol. But despite its generic name, the actual only use case for this is to provide SPI flash support to the SPL, which requires CONFIG_SPL_SPI_FLASH_SUPPORT to be defined. Select this symbol from the SPL_SPI_SUNXI Kconfig definition. This avoids doing this explicitly in the defconfig, and fixes SPI booting on the Pine64 SoPine (and -LTS version) and the OrangePi Win board (both with SPI flash).
Signed-off-by: Andre Przywara andre.przywara@arm.com --- configs/orangepi_pc2_defconfig | 1 - configs/orangepi_zero_defconfig | 1 - drivers/mtd/spi/Kconfig | 1 + 3 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index 61b2d98705..ae732a8ee3 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_MACH_SUN50I_H5=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index 4d8d9262cb..64290ddd8f 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=624 CONFIG_DRAM_ZQ=3881979 diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 5700859ff2..6ba255d676 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -140,6 +140,7 @@ if SPL config SPL_SPI_SUNXI bool "Support for SPI Flash on Allwinner SoCs in SPL" depends on MACH_SUN4I || MACH_SUN5I || MACH_SUN7I || MACH_SUNXI_H3_H5 || MACH_SUN50I + select SPL_SPI_FLASH_SUPPORT ---help--- Enable support for SPI Flash. This option allows SPL to read from sunxi SPI Flash. It uses the same method as the boot ROM, so does
Applied, thanks! Maxime
Andre Przywara
Maxime Ripard
