[PATCH 1/1] efi_loader: add handle for UART
When loading an EFI binary via the UART we assign a UART device path to it. But we lack a handle with that device path.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/efi_loader.h | 1 + lib/efi_loader/efi_console.c | 52 +++++++++++++++++------------------- 2 files changed, 26 insertions(+), 27 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index f4ae84dc89..e390d323a9 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -769,6 +769,7 @@ const struct efi_device_path *efi_dp_last_node( efi_status_t efi_dp_split_file_path(struct efi_device_path *full_path, struct efi_device_path **device_path, struct efi_device_path **file_path); +struct efi_device_path *efi_dp_from_uart(void); efi_status_t efi_dp_from_name(const char *dev, const char *devnr, const char *path, struct efi_device_path **device, diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 3b012e1a66..ba68a15017 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -25,6 +25,8 @@ struct cout_mode { int present; };
+__maybe_unused static struct efi_object uart_obj; + static struct cout_mode efi_cout_modes[] = { /* EFI Mode 0 is 80x25 and always present */ { @@ -1258,37 +1260,33 @@ static void EFIAPI efi_key_notify(struct efi_event *event, void *context) efi_status_t efi_console_register(void) { efi_status_t r; - efi_handle_t console_output_handle; - efi_handle_t console_input_handle; + struct efi_device_path *dp;
/* Set up mode information */ query_console_size();
- /* Create handles */ - r = efi_create_handle(&console_output_handle); - if (r != EFI_SUCCESS) - goto out_of_memory; - - r = efi_add_protocol(console_output_handle, - &efi_guid_text_output_protocol, &efi_con_out); - if (r != EFI_SUCCESS) - goto out_of_memory; - systab.con_out_handle = console_output_handle; - systab.stderr_handle = console_output_handle; - - r = efi_create_handle(&console_input_handle); - if (r != EFI_SUCCESS) - goto out_of_memory; - - r = efi_add_protocol(console_input_handle, - &efi_guid_text_input_protocol, &efi_con_in); - if (r != EFI_SUCCESS) - goto out_of_memory; - systab.con_in_handle = console_input_handle; - r = efi_add_protocol(console_input_handle, - &efi_guid_text_input_ex_protocol, &efi_con_in_ex); - if (r != EFI_SUCCESS) - goto out_of_memory; + /* Install protocols on root node */ + r = EFI_CALL(efi_install_multiple_protocol_interfaces + (&efi_root, + &efi_guid_text_output_protocol, &efi_con_out, + &efi_guid_text_input_protocol, &efi_con_in, + &efi_guid_text_input_ex_protocol, &efi_con_in_ex, + NULL)); + + /* Create console node and install device path protocols */ + if (CONFIG_IS_ENABLED(DM_SERIAL)) { + dp = efi_dp_from_uart(); + if (!dp) + goto out_of_memory; + + /* Hook UART up to the device list */ + efi_add_handle(&uart_obj); + + /* Install device path */ + r = efi_add_protocol(&uart_obj, &efi_guid_device_path, dp); + if (r != EFI_SUCCESS) + goto out_of_memory; + }
/* Create console events */ r = efi_create_event(EVT_NOTIFY_WAIT, TPL_CALLBACK, efi_key_notify,
