[U-Boot] [PATCH v3] timer: Support clocks via phandle
Earlier timer driver needed a clock-frequency property in compatible device-tree nodes. Another way is to reference a clock via a phandle.
So now timer_pre_probe tries to get clock by reference through device tree. In case it is impossible to get clock device through the reference, clock-frequency property of the timer node is read to provide backward compatibility.
Signed-off-by: Vlad Zakharov vzakhar@synopsys.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes v2..v3: - Use value type instead of pointer for timer_clk in order to fix build time warnings
drivers/timer/timer-uclass.c | 17 ++++++++++++++--- 1 file changed, 14 insertions(+), 3 deletions(-)
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index f8ddf93..5c63e6b 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -8,6 +8,7 @@ #include <dm.h> #include <dm/lists.h> #include <dm/device-internal.h> +#include <clk.h> #include <errno.h> #include <timer.h>
@@ -42,9 +43,19 @@ unsigned long notrace timer_get_rate(struct udevice *dev) static int timer_pre_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); - - uc_priv->clock_rate = fdtdec_get_int(gd->fdt_blob, dev->of_offset, - "clock-frequency", 0); + struct clk timer_clk; + int err; + ulong ret; + + err = clk_get_by_index(dev, 0, &timer_clk); + if (!err) { + ret = clk_get_rate(&timer_clk); + if (IS_ERR_VALUE(ret)) + return ret; + uc_priv->clock_rate = ret; + } else + uc_priv->clock_rate = fdtdec_get_int(gd->fdt_blob, + dev->of_offset, "clock-frequency", 0);
return 0; }
Hi Tom,
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index f8ddf93..5c63e6b 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -8,6 +8,7 @@ #include <dm.h> #include <dm/lists.h> #include <dm/device-internal.h> +#include <clk.h> #include <errno.h> #include <timer.h> @@ -42,9 +43,19 @@ unsigned long notrace timer_get_rate(struct udevice *dev) static int timer_pre_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- struct clk timer_clk;
- int err;
- ulong ret;
- err = clk_get_by_index(dev, 0, &timer_clk);
- if (!err) {
return ret;
- } else
return 0; }
Could you please apply this patch if there's no any objections or comments on it? Thanks.
Vlad Zakharov
