[U-Boot] [PATCH v2 0/3] STiH410-B2260: update environment/configuration settings
Update the CONFIG_EXTRA_ENV_SETTINGS, BOOT_TARGET_DEVICES and CONFIG_BOOTARGS Fix SDRAM size
v2: rebase on v2017.09
Lee Jones (1): board: STiH410-B2260: set ramdisk_addr_r to 0x48000000
Nicolas Le Bayon (1): board: STiH410-B2260: fix sdram size
Patrice Chotard (1): board: STiH410-B2260: update environment variable
configs/stih410-b2260_defconfig | 2 +- include/configs/stih410-b2260.h | 27 +++++++++++++++++++++++---- 2 files changed, 24 insertions(+), 5 deletions(-)
Update environment variable by updating: _ BOOT_TARGET_DEVICE _ CONFIGS_BOOTARGS _ kernel_addr_r, fdtfile, fdt_addr_r, scriptaddr, fdt_high, intird_high
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
configs/stih410-b2260_defconfig | 2 +- include/configs/stih410-b2260.h | 24 +++++++++++++++++++++--- 2 files changed, 22 insertions(+), 4 deletions(-)
diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 8fd1ff2..fe3dde3 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -6,7 +6,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" +CONFIG_BOOTARGS="console=ttyAS1,115200 CONSOLE=/dev/ttyAS1 consoleblank=0 root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait mem=992M@0x40000000 vmalloc=256m" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SYS_PROMPT="stih410-b2260 => " CONFIG_FASTBOOT=y diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index 372c083..115488c 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -18,10 +18,28 @@
#define CONFIG_SYS_HZ_CLOCK 1000000000 /* 1 GHz */
+#include <config_distro_defaults.h> /* Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "board= B2260" \ - "load_addr= #CONFIG_SYS_LOAD_ADDR \0" + +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#define CONFIG_ENV_VARS_UBOOT_CONFIG + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x40000000\0" \ + "fdtfile=stih410-b2260.dtb\0" \ + "fdt_addr_r=0x47000000\0" \ + "scriptaddr=0x50000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + BOOTENV +
#define CONFIG_ENV_SIZE 0x4000
32MB are reserved for Trusted Zone purpose
Signed-off-by: Nicolas Le Bayon nicolas.le.bayon@st.com ---
include/configs/stih410-b2260.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index 115488c..fc11f3c 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -12,7 +12,7 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 0x40000000 #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define PHYS_SDRAM_1_SIZE 0x3FE00000 +#define PHYS_SDRAM_1_SIZE 0x3E000000 #define CONFIG_SYS_TEXT_BASE 0x7D600000 #define CONFIG_SYS_LOAD_ADDR PHYS_SDRAM_1 /* default load addr */
Isn't this called TrustZone ?
Hi Simon
Correct, i will send a v3 with this typo fix
Thanks
Patrice
Add missing ramdisk_addr_r param and set it to 0x48000000
Signed-off-by: Lee Jones lee.jones@linaro.org ---
include/configs/stih410-b2260.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index fc11f3c..958d5cc 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -38,6 +38,7 @@ "scriptaddr=0x50000000\0" \ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ + "ramdisk_addr_r=0x48000000\0" \ BOOTENV
Patrice CHOTARD
