[U-Boot] [POWERPC] mgsuvd: fix compiler warning when using soft_i2c driver
following patch solves the compiler warning for the mgsuvd board, using the soft_i2c driver:
[hs@pollux u-boot]$ ./MAKEALL mgsuvd Configuring for mgsuvd board... soft_i2c.c: In function 'write_byte': soft_i2c.c:209: warning: implicit declaration of function 'i2c_soft_read_pin' text data bss dec hex filename 174608 9712 28436 212756 33f14 ./u-boot [hs@pollux u-boot]$
Signed-off-by: Heiko Schocher hs@denx.de --- drivers/i2c/soft_i2c.c | 2 ++ include/configs/mgsuvd.h | 1 + include/i2c.h | 4 ++++ 3 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 0a9feb6..346125e 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -41,6 +41,8 @@ #endif #include <i2c.h>
+CONFIG_I2C_SOFT_EXTERN + /* #define DEBUG_I2C */
#ifdef DEBUG_I2C diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 4ecaeac..2171115 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -356,6 +356,7 @@
#define I2C_ACTIVE do {} while (0) #define I2C_TRISTATE do {} while (0) +#define CONFIG_I2C_SOFT_EXTERN extern int i2c_soft_read_pin (void); #define I2C_READ i2c_soft_read_pin () #define I2C_SDA(bit) if(bit) { \ *(unsigned short *)(I2C_BASE_DIR) &= ~SDA_CONF; \ diff --git a/include/i2c.h b/include/i2c.h index 9f771dd..24d535f 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -76,6 +76,10 @@ # define I2C_SOFT_DECLARATIONS # endif #endif + +#ifndef CONFIG_I2C_SOFT_EXTERN +#define CONFIG_I2C_SOFT_EXTERN +#endif /* * Initialization, must be called once on start up, may be called * repeatedly to change the speed and slave addresses.
Dear Heiko Schocher,
- Initialization, must be called once on start up, may be called
- repeatedly to change the speed and slave addresses.
NAK. This is really ugly.
Please make i2c_soft_read_pin () an inline function so it's sufficient to change the I2C_READ definition in include/configs/mgsuvd.h
Umm... while we are at it - there is a lot of code in "board/keymile/mgsuvd/mgsuvd.c" that needs to be cleaned up:
24 #if 0 25 #define DEBUG 26 #endif
Please remove.
167 memory_data[0] = cpu_to_be32(bd->bi_memstart); 168 memory_data[1] = cpu_to_be32(bd->bi_memsize); 169 170 nodeoffset = fdt_path_offset (blob, "/memory"); 171 if (nodeoffset >= 0) { 172 ret = fdt_setprop(blob, nodeoffset, "reg", memory_data, 173 sizeof(memory_data));
Indentation is wrong here.
177 } 178 else {
make this "} else {"
180 printf("ft_blob_update(): cannot find /memory node " 181 "err:%s\n", fdt_strerror(nodeoffset));
Indentation.
187 if (nodeoffset >= 0) { 188 ret = fdt_setprop(blob, nodeoffset, "ranges", flash_data, 189 sizeof(flash_data)); 190 if (ret < 0) 191 printf("ft_blob_update(): cannot set /localbus/ranges " 192 "property err:%s\n", fdt_strerror(ret)); 193 } 194 else {
Bad indentation and "} else {" again.
202 if (nodeoffset >= 0) { 203 ret = fdt_setprop(blob, nodeoffset, "brg-frequency", brg_data, 204 sizeof(brg_data)); 205 if (ret < 0) 206 printf("ft_blob_update(): cannot set /soc/cpm/brg-frequency " 207 "property err:%s\n", fdt_strerror(ret)); 208 } 209 else {
Oops. This is the third time you repeat the same code? And yet another time follows below? Please turn this into a function.
Heiko Schocher
